path: root/common/cmd_gpt.c
2014-04-02cmd:gpt: randomly generate each partition uuid if undefinedPrzemyslaw Marczak
Changes: - randomly generate partition uuid if any is undefined and CONFIG_RAND_UUID is defined - print debug info about set/unset/generated uuid - update doc/README.gpt Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Piotr Wilczek <p.wilczek@samsung.com> Cc: Tom Rini <trini@ti.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Lukasz Majewski <l.majewski@samsung.com>
2013-11-08cmd/gpt: Support gpt command for all devicesEgbert Eich
The gpt command was only implemented for mmc devices. There is no reason why this command should not be generalized and be applied all other storage device classes. This change both simplifies the implementation and eliminates a build failure for systems that don't support mmcs. Signed-off-by: Egbert Eich <eich@suse.com> Tested-by: Piotr Wilczek <p.wilczek@samsung.com> [trini: Change coding style slightly] Signed-off-by: Tom Rini <trini@ti.com>
2013-09-20Fix some obvious typos across multiple subsystems.Robert P. J. Day
Typoes fixed: "partion" -> "partition" "retrive", "retreive" -> "retrieve" "th" -> "to" Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2013-02-20gpt: fix partion size limitPiotr Wilczek
Currently, in gpt command, partion size is converted from string to unsigned long type using 'ustrtol' function. That type limits the partition size to 4GB. This patch changes the conversion function to 'ustrtoll' to return unsigned long long type. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-12-13gpt: Support for new "gpt" commandPiotr Wilczek
New command - "gpt" is supported. It restores the GPT partition table. It looks into the given environment variable for partitions definition. It can be enabled at target configuration file with CONFIG_CMD_GPT. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
