path: root/common/cmd_flash.c
2011-07-28cleanup: Fix typos and misspellings in various files.Mike Williams
Recieve/Receive recieve/receive Interupt/Interrupt interupt/interrupt Addres/Address addres/address Signed-off-by: Mike Williams <mike@mikebwilliams.com>
2011-02-19Fix build warnings in cmd_flash.cRemy Bohmer
These variables are only used in case CONFIG_SYS_NO_FLASH is NOT set: struct mtd_device *dev; struct part_info *part; u8 dev_type, dev_num, pnum; Signed-off-by: Remy Bohmer <linux@bohmer.net>
2010-10-12CONFIG_CMD_JFFS2 is not necessary to use mtdparts on erase & protect on/offAlexander Stein
The include <jffs2/jffs2.h> is still necessary though. Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com> Acked-by: Stefan Roese <sr@denx.de>
2010-09-20cfi_flash: Remove uneccessary #ifdef CONFIG_SYS_MAX_FLASH_BANKS_DETECTStefan Roese
Now that the defines are moved to header files we don't need this conditional compilation any more. Remove it. Signed-off-by: Stefan Roese <sr@denx.de>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-05-21Fix "par[t]ition" typo.Wolfgang Denk
2009-07-19cmd_flash.c: fix fix compile error for boards with DataFlashWolfgang Denk
Commit 5669ed45 ("cmd_flash.c: fix warning: unused variable 'addr_first'/'addr_last'") changed the #ifdef logic areound the declaration of these variables and missed a combination of settings of HAS_DATAFLASH with SYS_NO_FLASH; this patch fixes this. Also spotted by Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-18cmd_flash.c: fix warning: unused variable 'addr_first'/'addr_last'Wolfgang Denk
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-20Separate mtdparts command from jffs2Stefan Roese
Currently the mtdparts commands are included in the jffs2 command support. This doesn't make sense anymore since other commands (e.g. UBI) use this infrastructure as well now. This patch separates the mtdparts commands from the jffs2 commands making it possible to only select mtdparts when no JFFS2 support is needed. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-10-18flash: factor out adjusting of Flash address to the end of sectorBartlomiej Sieka
The upcoming automatic update feature needs the ability to adjust an address within Flash to the end of its respective sector. Factor out this functionality to a new function flash_sect_roundb(). Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-08-06Fix merge problemsStefan Roese
2008-07-14Code cleanup: fix old style assignment ambiguities like "=-" etc.Wolfgang Denk
2008-07-13Fix some more printf() format problems.Wolfgang Denk
2008-07-13Fix some more printf() format issues.Jean-Christophe PLAGNIOL-VILLARD
2008-07-10silence misc printf formatting compiler warningsKim Phillips
2008-03-30Fix CFG_NO_FLASH compilation.Stelian Pop
Many Atmel boards have no "real" (NOR) flash on board, and rely only on DataFlash and NAND memories. This patch enables CFG_NO_FLASH to be present in a board configuration file, while still enabling flash commands like 'flinfo', 'protect', etc. Signed-off-by: Stelian Pop <stelian@popies.net>
2007-11-20[BUILD] conditionally compile common/cmd_*.c in common/MakefileGrant Likely
Modify common/Makefile to conditionally compile the cmd_*.c files based on the board config. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-07-11Fix some compile problems introduced by the latest CFG_CMD_xxx cleanupStefan Roese
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/cmd_[af]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[a-f]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-06-12Change 'repeatable' attribute of some commands to sensible values.Detlev Zundel
Most prominently this changes 'erase' to be non-repeatable. Signed-off-by: Detlev Zundel <dzu@denx.de>
2006-04-11Fixes common/cmd_flash.c:Heiko Schocher
- fix some compiler/parser error, if using m68k tool chain - optical fix for protect on/off all messages, if using more then one bank Patch by Jens Scharsig, 28 July 2005
2006-04-01* Changes/fixes for drivers/cfi_flash.c:Stefan Roese
- Add Intel legacy lock/unlock support to common CFI driver On some Intel flash's (e.g. Intel J3) legacy unlocking is supported, meaning that unlocking of one sector will unlock all sectors of this bank. Using this feature, unlocking of all sectors upon startup (via env var "unlock=yes") will get much faster. - Fixed problem with multiple reads of envronment variable "unlock" as pointed out by Reinhard Arlt & Anders Larsen. - Removed unwanted linefeeds from "protect" command when CFG_FLASH_PROTECTION is enabled. - Changed p3p400 board to use CFG_FLASH_PROTECTION Patch by Stefan Roese, 01 Apr 2006 * Changes/fixes for drivers/cfi_flash.c: - Correctly handle the cases where CFG_HZ != 1000 (several XScale-based boards) - Fix the timeout calculation of buffered writes (off by a factor of 1000) Patch by Anders Larsen, 31 Mar 2006
2005-10-11Added support for TQM834x boards.Marian Balakowicz
2005-08-10Add configuration for IFM AEV FIFO board.Wolfgang Denk
Minor coding style cleanup.
2005-08-09Fix compiler warnings with older GCC versionsWolfgang Denk
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2005-08-05Fix compile problem in cmd_flash.cWolfgang Denk
Patch by Teun Grinwis, 05 Aug 2005
2005-08-02Coding style cleanupWolfgang Denk
2005-07-21Add new argument format for flash commands to allow for usage likeWolfgang Denk
"erase $(addr) +$(filesize)", i. e. a size argument can be used and U-Boot will automaticially find the end of the corresponding sector.
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2004-03-23* Patches by Thomas Viehweger, 16 Mar 2004:wdenk
- show PCI clock frequency on MPC8260 systems - add FCC_PSMR_RMII flag for HiP7 processors - in do_jffs2_fsload(), take load address from load_addr if not set explicit, update load_addr otherwise - replaced printf by putc/puts when no formatting is needed (smaller code size, faster execution)
2004-01-02* Cleanup lowboot code for MPC5200wdenk
* Minor code cleanup (coding style) * Patch by Reinhard Meyer, 30 Dec 2003: - cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE, - added CONFIG_PHY_ADDR to include/configs/IceCube.h, - turned debug print of PHY registers into a function (called in two places) - added support for EMK MPC5200 based modules * Fix MPC8xx PLPRCR_MFD_SHIFT typo * Add support for TQM866M modules * Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash) * Fix a few compiler warnings
2003-12-09Fix output for "Unprotecting".stroese
2003-12-06* Patch by Nicolas Lacressonnière, 12 Nov 2003:wdenk
update for for Atmel AT91RM9200DK development kit: - support for environment variables in DataFlash - Atmel DataFlash AT45DB1282 support * Patch by Jeff Carr, 11 Nov 2003: add support for new version of 8270 processors * Patches by George G. Davis, 05 Nov 2003: - only pass the ARM linux initrd tag to the kernel when an initrd is actually present - update omap1510inn configuration file
2003-10-14* Make sure HUSH is initialized for running auto-update scriptsLABEL_2003_10_14_2140wdenk
* Make 5200 reset command _really_ reset the board, without running any other code after it * Fix flash mapping and display on P3G4 board * Patch by Kyle Harris, 15 Jul 2003: - add support for Intel IXP425 CPU - add support for IXDP425 eval board
2003-08-07Disable debug print for normal use.wdenk
Fix MPC5200 FEC driver
2003-08-05* Map ISP1362 USB OTG controller for NSCU boardwdenk
* Patch by Brad Parker, 02 Aug 2003: fix sc520_cdp problems * Implement Boot Cycle Detection (Req. 2.3 of OSDL CGL Reqirements) * Allow erase command to cross flash bank boundaries
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-06-16* Patch by Nicolas Lacressonniere, 11 Jun 2003:wdenk
Modifications for Atmel AT91RM9200DK ARM920T based development kit - Add Atmel DataFlash support for reading and writing. - Add possibility to boot a Linux from DataFlash with BOOTM command. - Add Flash detection on Atmel AT91RM9200DK (between Atmel AT49BV1614 and AT49BV1614A flashes) - Replace old Ethernet PHY layer functions - Change link address * Patch by Frank Smith, 9 Jun 2003: use CRIT_EXCEPTION for machine check on 4xx * Patch by Detlev Zundel, 13 Jun 2003: added implementation of the "carinfo" command in cmd_immap.c
2002-09-18Initial revisionwdenk
