path: root/common/cmd_fdt.c
2015-07-20cmd_fdt: save fdtaddr in hex formatSudeep Holla
Commit 90fbee3e4051 ("cmd_fdt: Actually fix fdt command in sandbox") changed the format(from hex address to unsigned long) in which "fdtaddr" is saved . However do_fdt continues reads the "fdtaddr" assuming it to be in hex format. This may lead to fdt being either loaded or attempted to load at erroneous address generating fault if the address is out of memory. This patch changes back the format to hex while saving the "fdtaddr" as it was done before. Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Cc: Hua Yanghao <huayanghao@gmail.com> Cc: Heiko Schocher <hs@denx.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18common: Make sure arch-specific map_sysmem() is definedJoe Hershberger
In the case where the arch defines a custom map_sysmem(), make sure that including just mapmem.h is sufficient to have these functions as they are when the arch does not override it. Also split the non-arch specific functions out of common.h Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-17cmd_fdt: Print the control fdt in terms of virtual memoryJoe Hershberger
If you want to inspect the control device tree using the fdt command, the "fdt address -c" command previously unhelpfully printed the phys memory address of the device tree. That address could not then be used to set the fdt address for inspection. Changed the resulting print to one that can be copied directly to the 'fdt address <addr>' command. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-17cmd_fdt: Actually fix fdt command in sandboxJoe Hershberger
Commit 90bac29a76bc8d649b41a55f2786c0abef9bb2c1 claims to fix this bug that was introduced in commit a92fd6577ea17751ead9b50243e3c562125cf581 but doesn't actually make the change that the commit message describes. Actually fix the bug this time. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-05cmd_fdt: fix working_fdt is set to wrong valueHua Yanghao
Instead of setting working_fdt to map_sysmem(addr) (e.g. blob), it should be set to addr directly as inside set_working_fdt_addr it uses map_sysmem(addr) again. To test: ./u-boot -d dts/dt.bin , then issue: fdt addr 0x100, fdt print will then cause an segmentation fault. After this fix fdt print is functional.
2014-11-21fdt: Add ft_system_setup() function for system device tree additionsSimon Glass
Add an additional function for adding information to the device tree before booting. This permits additions which are not board-specific. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-21fdt: Report failure of ft_board_setup()Simon Glass
Since this function can fail, print a message when it does. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2014-08-09fdt: Rename fdt_resize() to fdt_shrink_to_minimum()Simon Glass
Since libfdt now has an fdt_resize() function, we need to rename the U-Boot one. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-19Reverse the meaning of the fit_config_verify() return codeSimon Glass
It is more common to have 0 mean OK, and -ve mean error. Change this function to work the same way to avoid confusion. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-19fdt_support: delete force argument of fdt_chosen()Masahiro Yamada
After all, we have realized "force" argument is completely useless. fdt_chosen() was always called with force = 1. We should always want to do the same thing (set appropriate value to the property) even if the property already exists. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-19fdt_support: delete force argument of fdt_initrd()Masahiro Yamada
After all, we have realized "force" argument is completely useless. fdt_initrd() was always called with force = 1. We should always want to do the same thing (set appropriate value to the property) even if the property already exists. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-03-21fdt: add "fdt checksign" commandHeiko Schocher
check if a fdt is correct signed pass an optional addr value. Contains the addr of the key blob Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Simon Glass <sjg@chromium.org>
2013-05-01sandbox: fdt: Support fdt command for sandboxSimon Glass
By using map_sysmem() we can get the fdt command to work correctly with sandbox. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-01fdt: Allow fdt command to check and update control FDTSimon Glass
There is an existing fdt command to deal with the working FDT. Enhance this to support the control FDT also (CONFIG_OF_CONTROL). Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-01fdt: Add a parameter to fdt_valid()Simon Glass
At present this only checks working_fdt, but we want to check other FDTs also. So add the FDT to check as a parameter to fdt_valid(). Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-28Update set_working_fdt_addr() to use setenv_addr()Simon Glass
We might as well use this common function instead of repeating the same code. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-07treewide: include libfdt_env.h before fdt.hKim Phillips
and, if including libfdt.h which includes libfdt_env.h in the correct order, don't include fdt.h before libfdt.h. this is needed to get the fdt type definitions set from the project environment before fdt.h uses them. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Jerry Van Baren <gvb.uboot@gmail.com>
2012-11-04common/cmd_*.c: sparse fixesKim Phillips
cmd_boot.c:40:5: warning: symbol 'do_go' was not declared. Should it be static? cmd_bootm.c:164:6: warning: symbol '__arch_preboot_os' was not declared. Should it be static? cmd_bootm.c:477:5: warning: symbol 'do_bootm_subcommand' was not declared. Should it be static? cmd_bootm.c:1022:1: error: directive in argument list cmd_bootm.c:1028:1: error: directive in argument list cmd_bootm.c:1029:1: error: directive in argument list cmd_bootm.c:1036:1: error: directive in argument list cmd_bootm.c:1042:1: error: directive in argument list cmd_bootm.c:1044:1: error: directive in argument list cmd_bootm.c:1045:1: error: directive in argument list cmd_bootm.c:1047:1: error: directive in argument list cmd_bootm.c:1089:5: warning: symbol 'do_iminfo' was not declared. Should it be static? cmd_bootm.c:1176:5: warning: symbol 'do_imls' was not declared. Should it be static? cmd_bootm.c:1654:1: error: directive in argument list cmd_bootm.c:1660:1: error: directive in argument list cmd_console.c:32:5: warning: symbol 'do_coninfo' was not declared. Should it be s cmd_date.c:46:5: warning: symbol 'do_date' was not declared. Should it be static? cmd_echo.c:27:5: warning: symbol 'do_echo' was not declared. Should it be static? cmd_exit.c:27:5: warning: symbol 'do_exit' was not declared. Should it be static? cmd_fat.c:97:5: warning: symbol 'do_fat_ls' was not declared. Should it be static? cmd_fat.c:136:5: warning: symbol 'do_fat_fsinfo' was not declared. Should it be s cmd_fdt.c:66:5: warning: symbol 'do_fdt' was not declared. Should it be static? cmd_fdt.c:542:43: warning: incorrect type in assignment (different base types) cmd_fdt.c:542:43: expected unsigned int [unsigned] [usertype] <noident> cmd_fdt.c:542:43: got restricted __be32 [usertype] <noident> cmd_fdt.c:679:42: warning: cast to restricted __be32 cmd_fdt.c:820:1: error: directive in argument list cmd_fdt.c:822:1: error: directive in argument list cmd_flash.c:292:5: warning: symbol 'do_flinfo' was not declared. Should it be static? cmd_flash.c:324:5: warning: symbol 'do_flerase' was not declared. Should it be static? cmd_flash.c:457:5: warning: symbol 'do_protect' was not declared. Should it be st cmd_help.c:27:5: warning: symbol 'do_help' was not declared. Should it be static? cmd_i2c.c:136:6: warning: symbol '__def_i2c_init_board' was not declared. Should it be static? cmd_i2c.c:144:14: warning: symbol '__def_i2c_get_bus_speed' was not declared. Should it be static? cmd_i2c.c:151:5: warning: symbol '__def_i2c_set_bus_speed' was not declared. Should it be static? cmd_i2c.c:1322:1: error: directive in argument list cmd_i2c.c:1324:1: error: directive in argument list cmd_i2c.c:1326:1: error: directive in argument list cmd_i2c.c:1328:1: error: directive in argument list cmd_i2c.c:1337:1: error: directive in argument list cmd_i2c.c:1339:1: error: directive in argument list cmd_irq.c:27:5: warning: symbol 'do_interrupts' was not declared. Should it be static? cmd_itest.c:133:5: warning: symbol 'binary_test' was not declared. Should it be static? cmd_itest.c:158:5: warning: symbol 'do_itest' was not declared. Should it be stat cmd_load.c:54:5: warning: symbol 'do_load_serial' was not declared. Should it be static? cmd_load.c:431:6: warning: symbol 'his_eol' was not declared. Should it be static? cmd_load.c:432:6: warning: symbol 'his_pad_count' was not declared. Should it be static? cmd_load.c:433:6: warning: symbol 'his_pad_char' was not declared. Should it be static? cmd_load.c:434:6: warning: symbol 'his_quote' was not declared. Should it be static? cmd_load.c:436:5: warning: symbol 'do_load_serial_bin' was not declared. Should it be static? cmd_load.c:549:6: warning: symbol 'send_pad' was not declared. Should it be static? cmd_load.c:558:6: warning: symbol 'ktrans' was not declared. Should it be static? cmd_load.c:568:5: warning: symbol 'chk1' was not declared. Should it be static? cmd_load.c:578:6: warning: symbol 's1_sendpacket' was not declared. Should it be static? cmd_load.c:587:6: warning: symbol 'send_ack' was not declared. Should it be static? cmd_load.c:600:6: warning: symbol 'send_nack' was not declared. Should it be static? cmd_load.c:614:6: warning: symbol 'os_data_init' was not declared. Should it be static? cmd_load.c:615:6: warning: symbol 'os_data_char' was not declared. Should it be static? cmd_load.c:657:6: warning: symbol 'k_data_init' was not declared. Should it be static? cmd_load.c:663:6: warning: symbol 'k_data_save' was not declared. Should it be static? cmd_load.c:669:6: warning: symbol 'k_data_restore' was not declared. Should it be static? cmd_load.c:675:6: warning: symbol 'k_data_char' was not declared. Should it be static? cmd_load.c:693:6: warning: symbol 'send_parms' was not declared. Should it be static? cmd_load.c:694:6: warning: symbol 'send_ptr' was not declared. Should it be static? cmd_load.c:698:6: warning: symbol 'handle_send_packet' was not declared. Should i cmd_mdio.c:60:5: warning: symbol 'mdio_write_ranges' was not declared. Should it be static? cmd_mdio.c:82:5: warning: symbol 'mdio_read_ranges' was not declared. Should it be static? cmd_mdio.c:115:5: warning: symbol 'extract_reg_range' was not declared. Should it be static? cmd_mdio.c:144:5: warning: symbol 'extract_phy_range' was not declared. Should it cmd_mem.c:54:5: warning: symbol 'do_mem_md' was not declared. Should it be static? cmd_mem.c:150:5: warning: symbol 'do_mem_mm' was not declared. Should it be static? cmd_mem.c:154:5: warning: symbol 'do_mem_nm' was not declared. Should it be static? cmd_mem.c:159:5: warning: symbol 'do_mem_mw' was not declared. Should it be static? cmd_mem.c:256:5: warning: symbol 'do_mem_cmp' was not declared. Should it be static? cmd_mem.c:326:5: warning: symbol 'do_mem_cp' was not declared. Should it be static? cmd_mem.c:436:5: warning: symbol 'do_mem_base' was not declared. Should it be static? cmd_mem.c:449:5: warning: symbol 'do_mem_loop' was not declared. Should it be static? cmd_mem.c:595:5: warning: symbol 'do_mem_mtest' was not declared. Should it be static? cmd_mem.c:618:26: warning: Using plain integer as NULL pointer cmd_mem.c:1057:5: warning: symbol 'do_mem_crc' was not declared. Should it be static? cmd_misc.c:30:5: warning: symbol 'do_sleep' was not declared. Should it be static cmd_mmc.c:118:5: warning: symbol 'do_mmcinfo' was not declared. Should it be static? cmd_mmc.c:272:32: warning: Using plain integer as NULL pointer cmd_mmc.c:150:5: warning: symbol 'do_mmcops' was not declared. Should it be stati cmd_mp.c:27:1: warning: symbol 'cpu_cmd' was not declared. Should it be static? cmd_mp.c:85:1: error: directive in argument list cmd_mp.c:88:1: error: directive in argument list cmd_mtdparts.c:150:18: warning: symbol 'mtdids' was not declared. Should it be static? cmd_mtdparts.c:153:18: warning: symbol 'devices' was not declared. Should it be static? cmd_mtdparts.c:713:5: warning: symbol 'mtd_device_validate' was not declared. Should it be static? cmd_mtdparts.c:1887:5: warning: symbol 'do_chpart' was not declared. Should it be static? cmd_mtdparts.c:1925:5: warning: symbol 'do_mtdparts' was not declared. Should it be static? cmd_mtdparts.c:2060:1: error: directive in argument list cmd_mtdparts.c:2063:1: error: directive in argument list cmd_mtdparts.c:2066:1: error: directive in argument list cmd_mtdparts.c:2071:1: error: directive in argument list cmd_mtdparts.c:2073:1: error: directive in argument list cmd_nand.c:377:18: error: bad constant expression cmd_nand.c:431:5: warning: symbol 'do_nand' was not declared. Should it be static? cmd_nand.c:796:1: error: directive in argument list cmd_nand.c:801:1: error: directive in argument list cmd_nand.c:802:1: error: directive in argument list cmd_nand.c:806:1: error: directive in argument list cmd_nand.c:819:1: error: directive in argument list cmd_nand.c:824:1: error: directive in argument list cmd_nand.c:825:1: error: directive in argument list cmd_nand.c:831:1: error: directive in argument list cmd_nand.c:918:5: warning: symbol 'do_nandboot' was not declared. Should it be static? cmd_net.c:33:5: warning: symbol 'do_bootp' was not declared. Should it be static? cmd_net.c:107:5: warning: symbol 'do_dhcp' was not declared. Should it be static? cmd_net.c:120:5: warning: symbol 'do_nfs' was not declared. Should it be static? cmd_nvedit.c:138:5: warning: symbol 'do_env_print' was not declared. Should it be static? cmd_nvedit.c:323:5: warning: symbol '_do_env_set' was not declared. Should it be static? cmd_nvedit.c:435:5: warning: symbol 'do_env_set' was not declared. Should it be static? cmd_nvedit.c:514:5: warning: symbol 'do_env_edit' was not declared. Should it be static? cmd_nvedit.c:620:5: warning: symbol 'do_env_save' was not declared. Should it be static? cmd_nvedit.c:1016:1: error: directive in argument list cmd_nvedit.c:1018:1: error: directive in argument list cmd_nvedit.c:1021:1: error: directive in argument list cmd_nvedit.c:1023:1: error: directive in argument list cmd_nvedit.c:1024:1: error: directive in argument list cmd_nvedit.c:1026:1: error: directive in argument list cmd_nvedit.c:1027:1: error: directive in argument list cmd_nvedit.c:1029:1: error: directive in argument list cmd_nvedit.c:1030:1: error: directive in argument list cmd_nvedit.c:1032:1: error: directive in argument list cmd_nvedit.c:1034:1: error: directive in argument list cmd_nvedit.c:1036:1: error: directive in argument list cmd_nvedit.c:1037:1: error: directive in argument list cmd_nvedit.c:1039:1: error: directive in argument list cmd_pci.c:38:17: warning: symbol 'ShortPCIListing' was not declared. Should it be static? cmd_pci.c:38:22: warning: 'ShortPCIListing' defined but not used [-Wunused-variable] cmd_pci.c:411:5: warning: symbol 'do_pci' was not declared. Should it be static? cmd_pci.c:494:1: error: directive in argument list cmd_pci.c:497:1: error: directive in argument list cmd_reginfo.c:40:5: warning: symbol 'do_reginfo' was not declared. Should it be static? cmd_sata.c:31:5: warning: symbol 'sata_curr_device' was not declared. Should it be static? note -> ata_piix.c doesn't seem to use 'sata_curr_device'; deleted. cmd_sata.c:32:18: warning: symbol 'sata_dev_desc' was not declared. Should it be static? cmd_sata.c:70:5: warning: symbol 'do_sata' was not declared. Should it be static? cmd_setexpr.c:53:5: warning: symbol 'do_setexpr' was not declared. Should it be static? cmd_source.c:186:1: error: directive in argument list cmd_source.c:190:1: error: directive in argument list cmd_test.c:27:5: warning: symbol 'do_test' was not declared. Should it be static? cmd_test.c:153:5: warning: symbol 'do_false' was not declared. Should it be static? cmd_test.c:164:5: warning: symbol 'do_true' was not declared. Should it be static cmd_usb.c:43:6: warning: symbol 'usb_get_class_desc' was not declared. Should it be static? cmd_usb.c:69:6: warning: symbol 'usb_display_class_sub' was not declared. Should it be static? cmd_usb.c:151:6: warning: symbol 'usb_display_string' was not declared. Should it be static? cmd_usb.c:161:6: warning: symbol 'usb_display_desc' was not declared. Should it be static? cmd_usb.c:195:6: warning: symbol 'usb_display_conf_desc' was not declared. Should it be static? cmd_usb.c:210:6: warning: symbol 'usb_display_if_desc' was not declared. Should it be static? cmd_usb.c:227:6: warning: symbol 'usb_display_ep_desc' was not declared. Should it be static? cmd_usb.c:252:6: warning: symbol 'usb_display_config' was not declared. Should it be static? cmd_usb.c:283:6: warning: symbol 'usb_show_tree_graph' was not declared. Should it be static? cmd_usb.c:343:6: warning: symbol 'usb_show_tree' was not declared. Should it be static? cmd_usb.c:356:5: warning: symbol 'do_usbboot' was not declared. Should it be static? cmd_usb.c:366:5: warning: symbol 'do_usb' was not declared. Should it be static? cmd_version.c:31:5: warning: symbol 'do_version' was not declared. Should it be s cmd_ximg.c:46:1: warning: symbol 'do_imgextract' was not declared. Should it be static? cmd_ximg.c:272:1: error: directive in argument list cmd_ximg.c:276:1: error: directive in argument list Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-11-02cmd_fdt.c: Use %p when printing pointersTom Rini
When putting pointers into a format string use %p to ensure that they are printed correctly regardless of bitsize. This fixes warnings on sandbox on 64bit systems. Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Gerald Van Baren <vanbaren@cideas.com> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2012-10-15fdt: Identify scripts in ITBs as printable stringsJoe Hershberger
Scripts in the ITB format will have spaces in them and will end in a newline charachter. Make sure that these are considered printable. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-10-15fdt: Add get commands to fdtJoe Hershberger
Add commands to access data in the fdt. This allows data from a dtb or itb to be accessed from the shell scripts. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-10-15fdt: Limit printed hex in fdt print and list commandsJoe Hershberger
Prevent printing the entire image in a itb. It is most likely unhelpful to have the hex of the entire image scroll for minutes on your slow serial console. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-09-15fdt: Check if the FDT address is configuredMarek Vasut
In case the "fdt addr" command wasn't ran yet and any other "fdt" subcommand was issued, the system crashed due to NULL pointer being used. This is caused by "fdt addr" command setting up a pointer to the FDT memory location. Prior issuing "fdt addr", the pointer is NULL so calling any other subcommands crashed the u-boot. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org>
2012-03-06Convert cmd_usage() calls in common to use a return valueSimon Glass
Change all files in common/ to use CMD_RET_USAGE instead of calling cmd_usage() directly. I'm not completely sure about this patch since the code since impact is small (100 byte or so on ARM) and it might need splitting into smaller patches. But for now here it is. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-06-01common/cmd_fdt.c: fix wrong data displayed in fdt printHaojian Zhuang
All data in dtb is big endian. Some ARM devices are little-endian. In print_data(), it displays data with big-endian format. For ARM device, data should be converted to little-endian first. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Cc: Gerald Van Baren <vanbaren@cideas.com>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-09-24cmd_fdt.c: fix parse of byte streams and stringsKen MacLeod
Commit 4abd844d8e extended the fdt command parser to handle property strings which are split across multiple arguments but it was broken for byte streams and strings. Byte stream parsing: * Fixes where it would terminate early or go into an endless loop. * Fixes a 0x00 being inserted into the data if there is a space after '[' or a separate argument. * Fixes dereferencing the argument pointer after the last argument. * Checks for bad characters. String parsing: * Treat multiple arguments as a string list. This fixes an issue where only the last argument was stored. Signed-off-by: Ken MacLeod <ken@bitsko.slc.ut.us>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-09-13powerpc: Fix bootm to boot up again with a RamdiskHeiko Schocher
Commit 2a1a2cb6 didnt remove the dummy mem reservation in fdt_chosen, and this stopped Linux from booting with a Ramdisk. This patch fixes this, by deleting the useless dummy mem reservation. When booting with a Ramdisk, a fix offset FDT_RAMDISK_OVERHEAD is now added to of_size, so we dont need anymore a dummy mem reservation. I measured the value of FDT_RAMDISK_OVERHEAD on a MPC8270 based system (=0x44 bytes) and rounded it up to 0x80). Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-26fdt: Added resize commandKumar Gala
Resize the fdt to size + padding to 4k boundary Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-26bootm: Set working fdt address as part of the bootm flowKumar Gala
Set the fdt working address so "fdt FOO" commands can be used as part of the bootm flow. Also set an the environment variable "fdtaddr" with the value. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-24Add note on dereferencing /aliases pointersGerald Van Baren
Replace the "must quote special characters" note with a hint on how to dereference /aliases pointers by omitting the leading "/". This feature was introduced by Kumar Gala as a libfdt enhancement in commit ed035708235332c3c117ee3bb1a426063f03cfcb. Example: => fdt print /aliases aliases { ethernet0 = "/qe@e0100000/ucc@2000"; ethernet1 = "/qe@e0100000/ucc@3000"; serial0 = "/soc8360@e0000000/serial@4500"; serial1 = "/soc8360@e0000000/serial@4600"; pci0 = "/pci@e0008500"; }; => fdt print ethernet0 ucc@2000 { device_type = "network"; compatible = "ucc_geth"; cell-index = <0x1>; reg = <0x2000 0x200>; interrupts = <0x20>; interrupt-parent = <0x2>; local-mac-address = [00 00 00 00 00 00]; rx-clock-name = "none"; tx-clock-name = "clk9"; phy-handle = <0x3>; phy-connection-type = "rgmii-id"; pio-handle = <0x4>; }; Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2008-08-21fdt: fdt addr w/o any args reports back the current working addressKumar Gala
2008-08-21fdt: added the ability to set initrd start/end via chosen commandKumar Gala
2008-07-09Fix printf errors.Andrew Klossner
The compiler will help find mismatches between printf formats and arguments if you let it. This patch adds the necessary attributes to declarations in include/common.h, then begins to correct the resulting compiler warnings. Some of these were bugs, e.g., "$d" instead of "%d" and incorrect arguments. Others were just annoying, like int-long mismatches on a system where both are 32 bits. It's worth fixing the annoying errors to catch the real ones. Signed-off-by: Andrew Klossner <andrew@cesa.opbu.xerox.com>
2008-06-10libfdt: Move the working_fdt pointer to cmd_fdt.cGerald Van Baren
The working_fdt pointer was declared in common/fdt_support.c but was not used there. Move it to common/cmd_fdt.c where it is used (it is also used in lib_ppc/bootm.c). Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2008-06-10fdt: unshadow global working fdt variableKim Phillips
differentiate with local variables of the same name by renaming the global 'fdt' variable 'working_fdt'. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-06-09Use strncmp() for the fdt commandGerald Van Baren
Cleaner than doing multiple conditionals on characters. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2008-06-09The fdt boardsetup command criteria was not uniqueGerald Van Baren
It was checking just for "b", which is not unique with respect to the "boot" command. Change to check for "boa"[rdsetup]. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2008-04-02Fix fdt set command to conform to dts specAndy Fleming
The fdt set command was treating properties specified as <00> and <0011> as byte streams, rather than as an array of cells. As we already have syntax for expressing the desire for a stream of bytes ([ xx xx ...]), we should use the <> syntax to describe arrays of cells, which are always 32-bits per element. If we imagine this likely (IMHO) scenario: > fdt set /ethernet-phy@1 reg <1> With the old code, this would create a bad fdt, since the reg cell would be made to be one byte in length. But the cell must be 4 bytes, so this would break mysteriously. Also, the dts spec calls for constants inside the angle brackets (<>) to conform to C constant standards as they pertain to base. Take this scenario: > fdt set /ethernet@f00 reg <0xe250000\ 0x1000> The old fdt command would complain that it couldn't parse that. Or, if you wanted to specify that a certain clock ran at 33 MHz, you'd be required to do this: > fdt set /mydev clock <1f78a40> Whereas the new code will accept decimal numbers. While I was in there, I extended the fdt command parser to handle property strings which are split across multiple arguments: > fdt set /ethernet@f00 interrupts < 33 2 34 2 36 2 > > fdt p /ethernet@f00 ethernet@f00 { interrupts = <0x21 0x2 0x22 0x2 0x24 0x2>; }; Lastly, the fdt print code was rearranged slightly to print arrays of cells if the length of the property is a multiple of 4 bytes, and to not print leading zeros. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-03-26Remove deprecated CONFIG_OF_HAS_UBOOT_ENV and CONFIG_OF_HAS_BD_TJerry Van Baren
These defines embedded the u-boot env variables and/or the bd_t structure in the fdt blob. The conclusion of discussion on the u-boot email list was that embedding these in the fdt blob is not useful: there are better ways of passing the data (in fact, the fdt blob itself replaces the bd_t struct). The only board that enables these is the stxxtc and they don't appear to be used by linux. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-18Fix fdt boardsetup command parsingKumar Gala
The introduciton of the 'fdt bootcpu' broke parsing for 'fdt boardsetup'. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-18Add sub-commands to fdtKumar Gala
fdt header - Display header info fdt bootcpu <id> - Set boot cpuid fdt memory <addr> <size> - Add/Update memory node fdt rsvmem print - Show current mem reserves fdt rsvmem add <addr> <size> - Add a mem reserve fdt rsvmem delete <index> - Delete a mem reserves Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
