path: root/common/cmd_fdc.c
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2002-11-18* Patch by Daniel Engström, 13 Nov 2002:LABEL_2002_11_18_0115wdenk
Add support for i386 architecture and AMD SC520 board * Patch by Pierre Aubert, 12 Nov 2002: Add support for DOS filesystem and booting from DOS floppy disk
2002-11-10* Vince Husovsky, 7 Nov 2002:LABEL_2002_11_10_2310wdenk
Add "-n" to linker options to get rid of "Not enough room for program headers" problem * Patch by David Müller, 05 Nov 2002 Rename CONFIG_PLL_INPUT_FREQ to CONFIG_SYS_CLK_FREQ so we can use an already existing name * Patch by Pierre Aubert, 05 Nov 2002 Hardware related improvements in FDC boot code * Patch by Holger Schurig, 5 Nov 2002: Make the PXA really change it's frequency * Patch by Pierre Aubert, 05 Nov 2002 Add support for slave serial Spartan 2 FPGAs * Fix uninitialized memory (MAC address) in 8xx SCC/FEC ethernet drivers
2002-08-27Initial revisionwdenk
