path: root/common/cmd_fat.c
2015-04-18common: Make sure arch-specific map_sysmem() is definedJoe Hershberger
In the case where the arch defines a custom map_sysmem(), make sure that including just mapmem.h is sufficient to have these functions as they are when the arch does not override it. Also split the non-arch specific functions out of common.h Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-11-23fat: Prepare API change for files greater than 2GBSuriyan Ramasami
Change the internal FAT functions to use loff_t for offsets. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Fix fs/fat/fat.c for min3 updates] Signed-off-by: Tom Rini <trini@ti.com>
2014-08-09fs: implement size/fatsize/ext4sizeStephen Warren
These commands may be used to determine the size of a file without actually reading the whole file content into memory. This may be used to determine if the file will fit into the memory buffer that will contain it. In particular, the DFU code will use it for this purpose in the next commit. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-07-22Fix help text of ext2load and fatload.Pavel Machek
Fix help text of ext2load and fatload to match code in fs/fs.c Signed-off-by: Pavel Machek <pavel@denx.de> Reviewed-by: Marek Vasut <marex@denx.de>
2014-06-05fs: fatwrite: use map_sysmem before use file_fat_writeWu, Josh
When the map_sysmem, then the fatwrite command can support sandbox. Following command will show how to use it: => sb bind 0 sd.img => fatls host 0 => fatwrite host 0 $memaddr filename $filesize Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-10-07Fix number base handling of "load" commandWolfgang Denk
As documented, almost all U-Boot commands expect numbers to be entered in hexadecimal input format. (Exception: for historical reasons, the "sleep" command takes its argument in decimal input format.) This rule was broken for the "load" command; for details please see especially commits 045fa1e "fs: add filesystem switch libary, implement ls and fsload commands" and 3f83c87 "fs: fix number base behaviour change in fatload/ext*load". In the result, the load command would always require an explicit "0x" prefix for regular (i. e. base 16 formatted) input. Change this to use the standard notation of base 16 input format. While strictly speaking this is a change of the user interface, we hope that it will not cause trouble. Stephen Warren comments (see [1]): I suppose you can change the behaviour if you want; anyone writing "0x..." for their values presumably won't be affected, and if people really do assume all values in U-Boot are in hex, presumably nobody currently relies upon using non-prefixed values with the generic load command, since it doesn't work like that right now. [1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/171172 Acked-by: Tom Rini <trini@ti.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-03-12cmd_fat.c: Note in fatread help about alignment requirementsTom Rini
When using the partial read feature of fatwrite the buffer we read into can become unaligned not just due to initial location but the size of our partial reads as well. Make this clear in the help text. Signed-off-by: Tom Rini <trini@ti.com>
2012-11-04common/cmd_*.c: sparse fixesKim Phillips
cmd_boot.c:40:5: warning: symbol 'do_go' was not declared. Should it be static? cmd_bootm.c:164:6: warning: symbol '__arch_preboot_os' was not declared. Should it be static? cmd_bootm.c:477:5: warning: symbol 'do_bootm_subcommand' was not declared. Should it be static? cmd_bootm.c:1022:1: error: directive in argument list cmd_bootm.c:1028:1: error: directive in argument list cmd_bootm.c:1029:1: error: directive in argument list cmd_bootm.c:1036:1: error: directive in argument list cmd_bootm.c:1042:1: error: directive in argument list cmd_bootm.c:1044:1: error: directive in argument list cmd_bootm.c:1045:1: error: directive in argument list cmd_bootm.c:1047:1: error: directive in argument list cmd_bootm.c:1089:5: warning: symbol 'do_iminfo' was not declared. Should it be static? cmd_bootm.c:1176:5: warning: symbol 'do_imls' was not declared. Should it be static? cmd_bootm.c:1654:1: error: directive in argument list cmd_bootm.c:1660:1: error: directive in argument list cmd_console.c:32:5: warning: symbol 'do_coninfo' was not declared. Should it be s cmd_date.c:46:5: warning: symbol 'do_date' was not declared. Should it be static? cmd_echo.c:27:5: warning: symbol 'do_echo' was not declared. Should it be static? cmd_exit.c:27:5: warning: symbol 'do_exit' was not declared. Should it be static? cmd_fat.c:97:5: warning: symbol 'do_fat_ls' was not declared. Should it be static? cmd_fat.c:136:5: warning: symbol 'do_fat_fsinfo' was not declared. Should it be s cmd_fdt.c:66:5: warning: symbol 'do_fdt' was not declared. Should it be static? cmd_fdt.c:542:43: warning: incorrect type in assignment (different base types) cmd_fdt.c:542:43: expected unsigned int [unsigned] [usertype] <noident> cmd_fdt.c:542:43: got restricted __be32 [usertype] <noident> cmd_fdt.c:679:42: warning: cast to restricted __be32 cmd_fdt.c:820:1: error: directive in argument list cmd_fdt.c:822:1: error: directive in argument list cmd_flash.c:292:5: warning: symbol 'do_flinfo' was not declared. Should it be static? cmd_flash.c:324:5: warning: symbol 'do_flerase' was not declared. Should it be static? cmd_flash.c:457:5: warning: symbol 'do_protect' was not declared. Should it be st cmd_help.c:27:5: warning: symbol 'do_help' was not declared. Should it be static? cmd_i2c.c:136:6: warning: symbol '__def_i2c_init_board' was not declared. Should it be static? cmd_i2c.c:144:14: warning: symbol '__def_i2c_get_bus_speed' was not declared. Should it be static? cmd_i2c.c:151:5: warning: symbol '__def_i2c_set_bus_speed' was not declared. Should it be static? cmd_i2c.c:1322:1: error: directive in argument list cmd_i2c.c:1324:1: error: directive in argument list cmd_i2c.c:1326:1: error: directive in argument list cmd_i2c.c:1328:1: error: directive in argument list cmd_i2c.c:1337:1: error: directive in argument list cmd_i2c.c:1339:1: error: directive in argument list cmd_irq.c:27:5: warning: symbol 'do_interrupts' was not declared. Should it be static? cmd_itest.c:133:5: warning: symbol 'binary_test' was not declared. Should it be static? cmd_itest.c:158:5: warning: symbol 'do_itest' was not declared. Should it be stat cmd_load.c:54:5: warning: symbol 'do_load_serial' was not declared. Should it be static? cmd_load.c:431:6: warning: symbol 'his_eol' was not declared. Should it be static? cmd_load.c:432:6: warning: symbol 'his_pad_count' was not declared. Should it be static? cmd_load.c:433:6: warning: symbol 'his_pad_char' was not declared. Should it be static? cmd_load.c:434:6: warning: symbol 'his_quote' was not declared. Should it be static? cmd_load.c:436:5: warning: symbol 'do_load_serial_bin' was not declared. Should it be static? cmd_load.c:549:6: warning: symbol 'send_pad' was not declared. Should it be static? cmd_load.c:558:6: warning: symbol 'ktrans' was not declared. Should it be static? cmd_load.c:568:5: warning: symbol 'chk1' was not declared. Should it be static? cmd_load.c:578:6: warning: symbol 's1_sendpacket' was not declared. Should it be static? cmd_load.c:587:6: warning: symbol 'send_ack' was not declared. Should it be static? cmd_load.c:600:6: warning: symbol 'send_nack' was not declared. Should it be static? cmd_load.c:614:6: warning: symbol 'os_data_init' was not declared. Should it be static? cmd_load.c:615:6: warning: symbol 'os_data_char' was not declared. Should it be static? cmd_load.c:657:6: warning: symbol 'k_data_init' was not declared. Should it be static? cmd_load.c:663:6: warning: symbol 'k_data_save' was not declared. Should it be static? cmd_load.c:669:6: warning: symbol 'k_data_restore' was not declared. Should it be static? cmd_load.c:675:6: warning: symbol 'k_data_char' was not declared. Should it be static? cmd_load.c:693:6: warning: symbol 'send_parms' was not declared. Should it be static? cmd_load.c:694:6: warning: symbol 'send_ptr' was not declared. Should it be static? cmd_load.c:698:6: warning: symbol 'handle_send_packet' was not declared. Should i cmd_mdio.c:60:5: warning: symbol 'mdio_write_ranges' was not declared. Should it be static? cmd_mdio.c:82:5: warning: symbol 'mdio_read_ranges' was not declared. Should it be static? cmd_mdio.c:115:5: warning: symbol 'extract_reg_range' was not declared. Should it be static? cmd_mdio.c:144:5: warning: symbol 'extract_phy_range' was not declared. Should it cmd_mem.c:54:5: warning: symbol 'do_mem_md' was not declared. Should it be static? cmd_mem.c:150:5: warning: symbol 'do_mem_mm' was not declared. Should it be static? cmd_mem.c:154:5: warning: symbol 'do_mem_nm' was not declared. Should it be static? cmd_mem.c:159:5: warning: symbol 'do_mem_mw' was not declared. Should it be static? cmd_mem.c:256:5: warning: symbol 'do_mem_cmp' was not declared. Should it be static? cmd_mem.c:326:5: warning: symbol 'do_mem_cp' was not declared. Should it be static? cmd_mem.c:436:5: warning: symbol 'do_mem_base' was not declared. Should it be static? cmd_mem.c:449:5: warning: symbol 'do_mem_loop' was not declared. Should it be static? cmd_mem.c:595:5: warning: symbol 'do_mem_mtest' was not declared. Should it be static? cmd_mem.c:618:26: warning: Using plain integer as NULL pointer cmd_mem.c:1057:5: warning: symbol 'do_mem_crc' was not declared. Should it be static? cmd_misc.c:30:5: warning: symbol 'do_sleep' was not declared. Should it be static cmd_mmc.c:118:5: warning: symbol 'do_mmcinfo' was not declared. Should it be static? cmd_mmc.c:272:32: warning: Using plain integer as NULL pointer cmd_mmc.c:150:5: warning: symbol 'do_mmcops' was not declared. Should it be stati cmd_mp.c:27:1: warning: symbol 'cpu_cmd' was not declared. Should it be static? cmd_mp.c:85:1: error: directive in argument list cmd_mp.c:88:1: error: directive in argument list cmd_mtdparts.c:150:18: warning: symbol 'mtdids' was not declared. Should it be static? cmd_mtdparts.c:153:18: warning: symbol 'devices' was not declared. Should it be static? cmd_mtdparts.c:713:5: warning: symbol 'mtd_device_validate' was not declared. Should it be static? cmd_mtdparts.c:1887:5: warning: symbol 'do_chpart' was not declared. Should it be static? cmd_mtdparts.c:1925:5: warning: symbol 'do_mtdparts' was not declared. Should it be static? cmd_mtdparts.c:2060:1: error: directive in argument list cmd_mtdparts.c:2063:1: error: directive in argument list cmd_mtdparts.c:2066:1: error: directive in argument list cmd_mtdparts.c:2071:1: error: directive in argument list cmd_mtdparts.c:2073:1: error: directive in argument list cmd_nand.c:377:18: error: bad constant expression cmd_nand.c:431:5: warning: symbol 'do_nand' was not declared. Should it be static? cmd_nand.c:796:1: error: directive in argument list cmd_nand.c:801:1: error: directive in argument list cmd_nand.c:802:1: error: directive in argument list cmd_nand.c:806:1: error: directive in argument list cmd_nand.c:819:1: error: directive in argument list cmd_nand.c:824:1: error: directive in argument list cmd_nand.c:825:1: error: directive in argument list cmd_nand.c:831:1: error: directive in argument list cmd_nand.c:918:5: warning: symbol 'do_nandboot' was not declared. Should it be static? cmd_net.c:33:5: warning: symbol 'do_bootp' was not declared. Should it be static? cmd_net.c:107:5: warning: symbol 'do_dhcp' was not declared. Should it be static? cmd_net.c:120:5: warning: symbol 'do_nfs' was not declared. Should it be static? cmd_nvedit.c:138:5: warning: symbol 'do_env_print' was not declared. Should it be static? cmd_nvedit.c:323:5: warning: symbol '_do_env_set' was not declared. Should it be static? cmd_nvedit.c:435:5: warning: symbol 'do_env_set' was not declared. Should it be static? cmd_nvedit.c:514:5: warning: symbol 'do_env_edit' was not declared. Should it be static? cmd_nvedit.c:620:5: warning: symbol 'do_env_save' was not declared. Should it be static? cmd_nvedit.c:1016:1: error: directive in argument list cmd_nvedit.c:1018:1: error: directive in argument list cmd_nvedit.c:1021:1: error: directive in argument list cmd_nvedit.c:1023:1: error: directive in argument list cmd_nvedit.c:1024:1: error: directive in argument list cmd_nvedit.c:1026:1: error: directive in argument list cmd_nvedit.c:1027:1: error: directive in argument list cmd_nvedit.c:1029:1: error: directive in argument list cmd_nvedit.c:1030:1: error: directive in argument list cmd_nvedit.c:1032:1: error: directive in argument list cmd_nvedit.c:1034:1: error: directive in argument list cmd_nvedit.c:1036:1: error: directive in argument list cmd_nvedit.c:1037:1: error: directive in argument list cmd_nvedit.c:1039:1: error: directive in argument list cmd_pci.c:38:17: warning: symbol 'ShortPCIListing' was not declared. Should it be static? cmd_pci.c:38:22: warning: 'ShortPCIListing' defined but not used [-Wunused-variable] cmd_pci.c:411:5: warning: symbol 'do_pci' was not declared. Should it be static? cmd_pci.c:494:1: error: directive in argument list cmd_pci.c:497:1: error: directive in argument list cmd_reginfo.c:40:5: warning: symbol 'do_reginfo' was not declared. Should it be static? cmd_sata.c:31:5: warning: symbol 'sata_curr_device' was not declared. Should it be static? note -> ata_piix.c doesn't seem to use 'sata_curr_device'; deleted. cmd_sata.c:32:18: warning: symbol 'sata_dev_desc' was not declared. Should it be static? cmd_sata.c:70:5: warning: symbol 'do_sata' was not declared. Should it be static? cmd_setexpr.c:53:5: warning: symbol 'do_setexpr' was not declared. Should it be static? cmd_source.c:186:1: error: directive in argument list cmd_source.c:190:1: error: directive in argument list cmd_test.c:27:5: warning: symbol 'do_test' was not declared. Should it be static? cmd_test.c:153:5: warning: symbol 'do_false' was not declared. Should it be static? cmd_test.c:164:5: warning: symbol 'do_true' was not declared. Should it be static cmd_usb.c:43:6: warning: symbol 'usb_get_class_desc' was not declared. Should it be static? cmd_usb.c:69:6: warning: symbol 'usb_display_class_sub' was not declared. Should it be static? cmd_usb.c:151:6: warning: symbol 'usb_display_string' was not declared. Should it be static? cmd_usb.c:161:6: warning: symbol 'usb_display_desc' was not declared. Should it be static? cmd_usb.c:195:6: warning: symbol 'usb_display_conf_desc' was not declared. Should it be static? cmd_usb.c:210:6: warning: symbol 'usb_display_if_desc' was not declared. Should it be static? cmd_usb.c:227:6: warning: symbol 'usb_display_ep_desc' was not declared. Should it be static? cmd_usb.c:252:6: warning: symbol 'usb_display_config' was not declared. Should it be static? cmd_usb.c:283:6: warning: symbol 'usb_show_tree_graph' was not declared. Should it be static? cmd_usb.c:343:6: warning: symbol 'usb_show_tree' was not declared. Should it be static? cmd_usb.c:356:5: warning: symbol 'do_usbboot' was not declared. Should it be static? cmd_usb.c:366:5: warning: symbol 'do_usb' was not declared. Should it be static? cmd_version.c:31:5: warning: symbol 'do_version' was not declared. Should it be s cmd_ximg.c:46:1: warning: symbol 'do_imgextract' was not declared. Should it be static? cmd_ximg.c:272:1: error: directive in argument list cmd_ximg.c:276:1: error: directive in argument list Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-11-04fs: rename fsload command to loadStephen Warren
When the generic filesystem load command "fsload" was written, I felt that "load" was too generic of a name for it, since many other similar commands already existed. However, it turns out that there is already an "fsload" command, so that name cannot be used. Rename the new "fsload" to plain "load" to avoid the conflict. At least anyone who's used a Basic interpreter should feel familiar with the name! Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-11-04fs: fix number base behaviour change in fatload/ext*loadStephen Warren
Commit 045fa1e "fs: add filesystem switch libary, implement ls and fsload commands" unified the implementation of fatload and ext*load with the new command fsload. However, this altered the interpretation of command-line numbers from always being base-16, to requiring a "0x" prefix for base-16 numbers. Enhance do_fsload() to allow commands to specify which base to use. Use base 0, thus requiring a "0x" prefix for the new fsload command. This feels much cleaner than assuming base 16. Use base 16 for the pre-existing fatload and ext*load to prevent a change in behaviour. Use base 16 exclusively for the loadaddr environment variable, since that variable is interpreted in multiple places, so we don't want the behaviour to change. Update command help text to make it clear where numbers are assumed to be hex, and where an explicit "0x" prefix is required. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2012-10-29fs: add filesystem switch libary, implement ls and fsload commandsStephen Warren
Implement "ls" and "fsload" commands that act like {fat,ext2}{ls,load}, and transparently handle either file-system. This scheme could easily be extended to other filesystem types; I only didn't do it for zfs because I don't have any filesystems of that type to test with. Replace the implementation of {fat,ext[24]}{ls,load} with this new code too. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-10-25FAT: implement fat_set_blk_dev(), convert cmd_fat.cStephen Warren
This makes the FAT filesystem API more consistent with other block-based filesystems. If in the future standard multi-filesystem commands such as "ls" or "load" are implemented, having FAT work the same way as other filesystems will be necessary. Convert cmd_fat.c to the new API, so the code looks more like other files implementing the same commands for other filesystems. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2012-09-29cmd_fat.c: fix build warningAnatolij Gustschin
Commit cfda5aeab89d73779e26f0d34cf10f64caa67431 (cmd_fat: use common get_device_and_partition function) introduced a warning: cmd_fat.c: In function 'do_fat_fswrite': cmd_fat.c:178:8: warning: unused variable 'ep' [-Wunused-variable] Fix it. Signed-off-by: Anatolij Gustschin <agust@denx.de> Reported-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-09-26FAT: Make it possible to read from any file positionBenoît Thébaudeau
When storage devices contain files larger than the embedded RAM, it is useful to be able to read these files by chunks, e.g. for a software update to the embedded NAND Flash from an external storage device (USB stick, SD card, etc.). Hence, this patch makes it possible by adding a new FAT API to read files from a given position. This patch also adds this feature to the fatload command. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-25disk: get_device_and_partition() "auto" partition and cleanupStephen Warren
Rework get_device_and_partition() to: a) Implement a new partition ID of "auto", which requests that U-Boot search for the first "bootable" partition, and fall back to the first valid partition if none is found. This way, users don't need to specify an explicit partition in their commands. b) Make use of get_device(). c) Add parameter to indicate whether returning a whole device is acceptable, or whether a partition is mandatory. d) Make error-checking of the user's device-/partition-specification more complete. In particular, if strtoul() doesn't convert all characters, it's an error rather than just ignored. The resultant device/partition returned by the function will be as follows, based on whether the disk has a partition table (ptable) or not, and whether the calling command allows the whole device to be returned or not. (D and P are integers, P >= 1) D D: No ptable: !allow_whole_dev: error allow_whole_dev: device D ptable: device D partition 1 D:0 !allow_whole_dev: error allow_whole_dev: device D D:P No ptable: error ptable: device D partition P D:auto No ptable: !allow_whole_dev: error allow_whole_dev: device D ptable: first partition in device D with bootable flag set. If none, first valid paratition in device D. Note: In order to review this patch, it's probably easiest to simply look at the file contents post-application, rather than reading the patch itself. Signed-off-by: Rob Herring <rob.herring@calxeda.com> [swarren: Rob implemented scanning for bootable partitions. I fixed a couple of issues there, switched the syntax to ":auto", added the error-checking rework, and ":0" syntax for the whole device] Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-25cmd_fat: use common get_device_and_partition functionRob Herring
Convert fatload, fatls, and fatinfo to use common device and partition parsing function. With the common function "dev:part" can come from the environment and a '-' can be used in that case. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-03-26cmd_fat: add FAT write commandDonggeun Kim
Once CONFIG_FAT_WRITE is defined, users can invoke 'fatwrite' command that saves data in RAM as a FAT file. This patch was originally part of http://article.gmane.org/gmane.comp.boot-loaders.u-boot/121847 Signed-off-by: Donggeun Kim <dg77.kim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Maximilian Schwerin <mvs@tigris.de> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-07-24fs/fat: Big code cleanup.Wolfgang Denk
- reformat - throw out macros like FAT_DPRINT and FAT_DPRINT - remove dead code Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2007-11-20[BUILD] conditionally compile common/cmd_*.c in common/MakefileGrant Likely
Modify common/Makefile to conditionally compile the cmd_*.c files based on the board config. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/cmd_[af]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[a-f]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-02-20[PATCH 1_4] Merge common get_dev() routines for block devicesGrant Likely
Each of the filesystem drivers duplicate the get_dev routine. This change merges them into a single function in part.c Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2004-08-28* Add automatic update support for LWMON boardLABEL_2004_08_28_2355wdenk
* Enable MSDOS/VFAT filesystem support for LWMON board * Clear Block Lock-Bits when erasing flash on LWMON board. * Fix return code of "fatload" command * Disable debugging for TQM5200 board
2004-02-23* CVS add missing fileswdenk
* Cleanup compiler warnings * Fix problem with side effects in macros in include/usb.h * Patch by David Benson, 13 Nov 2003: bug 841358 - fix TFTP download size limit * Fixing bug 850768: improper flush_cache() in load_serial() * Fixing bug 834943: MPC8540 - missing volatile declarations * Patch by Stephen Williams, 09 Feb 2004: Add support for Xilinx SystemACE chip: - New files common/cmd_ace.c and include/systemace.h - Hook systemace support into cmd_fat and the partition manager * Patch by Travis Sawyer, 09 Feb 2004: Add bi_opbfreq & bi_iic_fast to 440GX bd_info as needed for Linux
2003-10-06* Update TRAB auto update codeLABEL_2003_10_06_2355wdenk
* Make fatload set filesize environment variable fix potential buffer overlow problem * enable basic / medium / high-end configurations for PPChameleonEVB board; fix NAND code * enable TFTP client code to specify to the server the desired timeout value (see RFC-2349)
2003-09-10* Patches by Denis Peter, 9 Sep 2003:U-Boot-0_4_8wdenk
add FAT support for IDE, SCSI and USB * Patches by Gleb Natapov, 2 Sep 2003: - cleanup of POST code for unsupported architectures - MPC824x locks way0 of data cache for use as initial RAM; this patch unlocks it after relocation to RAM and invalidates the locked entries. * Patch by Gleb Natapov, 30 Aug 2003: new I2C driver for mpc107 bridge. Now works from flash. * Patch by Dave Ellis, 11 Aug 2003: - JFFS2: fix typo in common/cmd_jffs2.c - JFFS2: fix CFG_JFFS2_SORT_FRAGMENTS option - JFFS2: remove node version 0 warning - JFFS2: accept JFFS2 PADDING nodes - SXNI855T: add AM29LV800 support - SXNI855T: move environment from EEPROM to flash - SXNI855T: boot from JFFS2 in NOR or NAND flash * Patch by Bill Hargen, 11 Aug 2003: fixes for I2C on MPC8240 - fix i2c_write routine - fix iprobe command - eliminates use of global variables, plus dead code, cleanup.
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-06-29Fix some missing commands, cleanup header filesU-Boot-0_4_1wdenk
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
2003-06-15* Fix CONFIG_NET_MULTI support in include/net.hLABEL_2003_06_16_0055wdenk
* Patches by Kyle Harris, 13 Mar 2003: - Add FAT partition support - Add command support for FAT - Add command support for MMC ---- - Add Intel PXA support for video - Add Intel PXA support for MMC ---- - Enable MMC and FAT for lubbock board - Other misc changes for lubbock board
