* Cleanup compiler warnings
* Fix problem with side effects in macros in include/usb.h
* Patch by David Benson, 13 Nov 2003:
bug 841358 - fix TFTP download size limit
* Fixing bug 850768:
improper flush_cache() in load_serial()
* Fixing bug 834943:
MPC8540 - missing volatile declarations
* Patch by Stephen Williams, 09 Feb 2004:
Add support for Xilinx SystemACE chip:
- New files common/cmd_ace.c and include/systemace.h
- Hook systemace support into cmd_fat and the partition manager
* Patch by Travis Sawyer, 09 Feb 2004:
Add bi_opbfreq & bi_iic_fast to 440GX bd_info as needed for Linux
- Added Motorola CPU 8540/8560 support (cpu/85xx)
- Added Motorola MPC8540ADS board support (board/mpc8540ads)
- Added Motorola MPC8560ADS board support (board/mpc8560ads)
* Minor code cleanup
* Make fatload set filesize environment variable
fix potential buffer overlow problem
* enable basic / medium / high-end configurations for PPChameleonEVB
board; fix NAND code
* enable TFTP client code to specify to the server the desired
timeout value (see RFC-2349)
add FAT support for IDE, SCSI and USB
* Patches by Gleb Natapov, 2 Sep 2003:
- cleanup of POST code for unsupported architectures
- MPC824x locks way0 of data cache for use as initial RAM;
this patch unlocks it after relocation to RAM and invalidates
the locked entries.
* Patch by Gleb Natapov, 30 Aug 2003:
new I2C driver for mpc107 bridge. Now works from flash.
* Patch by Dave Ellis, 11 Aug 2003:
- JFFS2: fix typo in common/cmd_jffs2.c
- JFFS2: fix CFG_JFFS2_SORT_FRAGMENTS option
- JFFS2: remove node version 0 warning
- JFFS2: accept JFFS2 PADDING nodes
- SXNI855T: add AM29LV800 support
- SXNI855T: move environment from EEPROM to flash
- SXNI855T: boot from JFFS2 in NOR or NAND flash
* Patch by Bill Hargen, 11 Aug 2003:
fixes for I2C on MPC8240
- fix i2c_write routine
- fix iprobe command
- eliminates use of global variables, plus dead code, cleanup.
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
* Patches by Kyle Harris, 13 Mar 2003:
- Add FAT partition support
- Add command support for FAT
- Add command support for MMC
- Add Intel PXA support for video
- Add Intel PXA support for MMC
- Enable MMC and FAT for lubbock board
- Other misc changes for lubbock board
