path: root/common/cmd_ext2.c
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-28Fix ext2load return codeWolfgang Denk
Make the ext2load command return 0 on success (instead of the file length). Also fix output format (get rid of random newlines) and some coding style issues (long lines etc.). Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-04-28cmd_ext2.c: fix compile warningsWolfgang Denk
Get rid of these warnings: cmd_ext2.c:247: warning: format '%ld' expects type 'long int', but argument 2 has type 'int' cmd_ext2.c:248: warning: format '%lX' expects type 'long unsigned int', but argument 3 has type 'int' Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-04-28fs: Fix the wrong type of varGao Guanhua
The filelen should be signed type, not unsigned type. otherwise, The condition as below never take. if (filelen < 0) Signed-off-by: Gao Guanhua <B22826@freescale.com> Signed-off-by: Dave Liu <daveliu@freescale.com>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-10-18CONFIG_EFI_PARTITION: Added support for EFI partition in cmd_ext2fs.crichardretanubun
Added support for CONFIG_EFI_PARTITION to ext2 commands. Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com>
2007-11-20[BUILD] conditionally compile common/cmd_*.c in common/MakefileGrant Likely
Modify common/Makefile to conditionally compile the cmd_*.c files based on the board config. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-07-08common/cmd_[af]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[a-f]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-02-20[PATCH 1_4] Merge common get_dev() routines for block devicesGrant Likely
Each of the filesystem drivers duplicate the get_dev routine. This change merges them into a single function in part.c Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2005-10-17Merge with /home/sr/git/u-bootWolfgang Denk
2005-10-14Fix identification on ext2ls help entryStefan Roese
Patch by Stefan Roese, 14 Oct 2005
2005-03-04* Fix get_partition_info() parameter error in all other callswdenk
(common/cmd_ide.c, common/cmd_reiser.c, common/cmd_scsi.c). * Enable USB and IDE support for INKA4x0 board * Patch by Andrew Dyer, 28 February 2005: fix ext2load passing an incorrect pointer to get_partition_info() resulting in load failure for devices other than 0
2005-02-04* Patch by Cajus Hahn, 04 Feb 2005:wdenk
- don't insist on leading '/' for filename in ext2load - set default partition to useful value (1) in ext2load * Patch by Andrew Dyer, 08 Jan 2005: fix wrong return codes in ext2 code
2004-12-16ext2fs support addedstroese
