path: root/common/cmd_eeprom.c
2015-02-17cmd_eeprom: make it possible to define the used i2c busChristian Gmeiner
A SoC like the i.MX6 supports more then one i2c bus. In oder to be able to use the eeprom command add a new define to specify the i2c bus to use. If CONFIG_SYS_I2C_EEPROM_BUS is not defined there is no functional change, else a call to i2c_set_bus_num(..) is done before calling i2c_read(..) and i2c_write(..). Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-10-27Revert "common, env: Fix support for environment in i2c eeprom"Valentin Longchamp
Since i2c_init_all always sets the bus back to CONFIG_SYS_SPD_BUS_NUM for compatibility reasons, it means that any eeprom not located on this CONFIG_SYS_SPD_BUS_NUM is not accessible with the eeprom commands, even if you change the bus number with an i2c dev command before. Furthermore i2c_init_all should disappear and is currently only called from the early board initialisation sequences, it is not suited for other usage. This reverts commit 01a0c64762e902971b34587a8a61b59e9ea51374. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2014-07-18common: commands: make commands staticJeroen Hofstee
Since most commands are not public, make them static. This prevents warnings that no common prototype is available. Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-03-28common, env: Fix support for environment in i2c eepromMatthias Fuchs
When using CONFIG_SYS_I2C i2c needs to be initialized by i2c_init_all(). This is done in some places but not in eeprom_init(). Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2013-12-05cmd_eeprom: bug fix for i2c read/writeKuo-Jung Su
The local pointer of address (i.e., addr) only gets referenced under SPI mode, and it won't be appropriate to pass only 1-byte addr[1] to i2c_read/i2c_write while CONFIG_SYS_I2C_EEPROM_ADDR_LEN > 1. 1. In U-boot's I2C model, the address would be re-assembled to a byte string in MSB order inside I2C controller drivers. 2. The 'CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW' option which could be found at soft_i2c.c is always turned on in cmd_eeprom.c, the addr[0] always contains the device address with overflowed MSB address bits. Signed-off-by: Kuo-Jung Su <dantesu@faraday-tech.com> Cc: Alexey Brodkin <abrodkin@synopsys.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> cc: Peter Tyser <ptyser@xes-inc.com> Cc: Heiko Schocher <hs@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Mischa Jonker <mjonker@synopsys.com>
2013-11-13cmd_eeprom: fix i2c_{read|write} usage if env is in I2C EEPROMAlexey Brodkin
Data "offset" is not used directly in case of I2C EEPROM. Istead it is split into "block number" and "offset within mentioned block". Which are "addr[0]" and "addr[1]" respectively. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> cc: Peter Tyser <ptyser@xes-inc.com> Cc: Heiko Schocher <hs@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Mischa Jonker <mjonker@synopsys.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2012-03-06Convert cmd_usage() calls in common to use a return valueSimon Glass
Change all files in common/ to use CMD_RET_USAGE instead of calling cmd_usage() directly. I'm not completely sure about this patch since the code since impact is small (100 byte or so on ARM) and it might need splitting into smaller patches. But for now here it is. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-02-14cmd_eeprom: typoPeter Meerwald
Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-28cosmetic: spell fixes etc.Michael Jones
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-01-18cmd_eeprom: I2C updatesHeiko Schocher
- CONFIG_ENV_EEPROM_IS_ON_I2C define this, if you have I2C and SPI activated, and your EEPROM, which holds the environment, is on the I2C bus. - CONFIG_I2C_ENV_EEPROM_BUS if you have an Environment on an EEPROM reached over I2C muxes, you can now define, how to reach this EEPROM. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12i2c.h: Provide a default CONFIG_SYS_I2C_SLAVE valuePeter Tyser
Many boards/controllers/drivers don't support an I2C slave interface, however CONFIG_SYS_I2C_SLAVE is used in common code so provide a default Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-09-10cmd_eeprom: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/cmd_[af]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[a-f]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2005-09-22Add SM501 support to HH405 board.Stefan Roese
Add support for gzip compressed bmp's (CONFIG_VIDEO_BMP_GZIP). Add support for eeprom write-enable (CFG_EEPROM_WREN). Patch by Stefan Roese, 22 Sep 2005
2005-08-19Add new board specific commands for TQM5200/STK52XXWolfgang Denk
- Sound commands (beep, wav, sound) - Test commands (led, can, backlight, rs232) Patch by Martin Krause, 02 May 2005
2005-08-12FRAM memory access optimization.
2004-03-23* Patches by Thomas Viehweger, 16 Mar 2004:wdenk
- show PCI clock frequency on MPC8260 systems - add FCC_PSMR_RMII flag for HiP7 processors - in do_jffs2_fsload(), take load address from load_addr if not set explicit, update load_addr otherwise - replaced printf by putc/puts when no formatting is needed (smaller code size, faster execution)
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-06-19Patches by Murray Jensen, 17 Jun 2003:wdenk
- Hymod board database mods: add "who" field and new xilinx chip types - provide new "init_cmd_timeout()" function so code external to "common/main.c" can use the "reset_cmd_timeout()" function before entering the main loop - add DTT support for adm1021 (new file dtt/adm1021.c; config slightly different. see include/configs/hymod.h for an example (requires CONFIG_DTT_ADM1021, CONFIG_DTT_SENSORS, and CFG_DTT_ADM1021 defined) - add new "eeprom_probe()" function which has similar args and behaves in a similar way to "eeprom_read()" etc. - add 8260 FCC ethernet loopback code (new "eth_loopback_test()" function which is enabled by defining CONFIG_ETHER_LOOPBACK_TEST) - gdbtools copyright update - ensure that set_msr() executes the "sync" and "isync" instructions after the "mtmsr" instruction in cpu/mpc8260/interrupts.c - 8260 I/O ports fix: Open Drain should be set last when configuring - add SIU IRQ defines for 8260 - allow LDSCRIPT override and OBJCFLAGS initialization: change to config.mk to allow board configurations to override the GNU linker script, selected via the LDSCRIPT, make variable, and to give an initial value to the OBJCFLAGS make variable - 8260 i2c enhancement: o correctly extends the timeout depending on the size of all queued messages for both transmit and receive o will not continue with receive if transmit times out o ensures that the error callback is done for all queued tx and rx messages o correctly detects both tx and rx timeouts, only delivers one to the callback, and does not overwrite an earlier error o logic in i2c_probe now correct - add "vprintf()" function so that "panic()" function can be technically correct - many Hymod board changes
2003-01-17* Add dual ethernet support on PM826wdenk
* Add support for LXT971 PHY on PM826 * Patch by Tord Andersson, 16 Jan 2003: Fix flash sector count for TQM8xxL * Fix I2C EEPROM problem on ICU862 board (would only write the first 16 bytes out of each 32 byte block)
2002-08-27Initial revisionwdenk
