path: root/common/cmd_echo.c
2012-11-04common/cmd_*.c: sparse fixesKim Phillips
cmd_boot.c:40:5: warning: symbol 'do_go' was not declared. Should it be static? cmd_bootm.c:164:6: warning: symbol '__arch_preboot_os' was not declared. Should it be static? cmd_bootm.c:477:5: warning: symbol 'do_bootm_subcommand' was not declared. Should it be static? cmd_bootm.c:1022:1: error: directive in argument list cmd_bootm.c:1028:1: error: directive in argument list cmd_bootm.c:1029:1: error: directive in argument list cmd_bootm.c:1036:1: error: directive in argument list cmd_bootm.c:1042:1: error: directive in argument list cmd_bootm.c:1044:1: error: directive in argument list cmd_bootm.c:1045:1: error: directive in argument list cmd_bootm.c:1047:1: error: directive in argument list cmd_bootm.c:1089:5: warning: symbol 'do_iminfo' was not declared. Should it be static? cmd_bootm.c:1176:5: warning: symbol 'do_imls' was not declared. Should it be static? cmd_bootm.c:1654:1: error: directive in argument list cmd_bootm.c:1660:1: error: directive in argument list cmd_console.c:32:5: warning: symbol 'do_coninfo' was not declared. Should it be s cmd_date.c:46:5: warning: symbol 'do_date' was not declared. Should it be static? cmd_echo.c:27:5: warning: symbol 'do_echo' was not declared. Should it be static? cmd_exit.c:27:5: warning: symbol 'do_exit' was not declared. Should it be static? cmd_fat.c:97:5: warning: symbol 'do_fat_ls' was not declared. Should it be static? cmd_fat.c:136:5: warning: symbol 'do_fat_fsinfo' was not declared. Should it be s cmd_fdt.c:66:5: warning: symbol 'do_fdt' was not declared. Should it be static? cmd_fdt.c:542:43: warning: incorrect type in assignment (different base types) cmd_fdt.c:542:43: expected unsigned int [unsigned] [usertype] <noident> cmd_fdt.c:542:43: got restricted __be32 [usertype] <noident> cmd_fdt.c:679:42: warning: cast to restricted __be32 cmd_fdt.c:820:1: error: directive in argument list cmd_fdt.c:822:1: error: directive in argument list cmd_flash.c:292:5: warning: symbol 'do_flinfo' was not declared. Should it be static? cmd_flash.c:324:5: warning: symbol 'do_flerase' was not declared. Should it be static? cmd_flash.c:457:5: warning: symbol 'do_protect' was not declared. Should it be st cmd_help.c:27:5: warning: symbol 'do_help' was not declared. Should it be static? cmd_i2c.c:136:6: warning: symbol '__def_i2c_init_board' was not declared. Should it be static? cmd_i2c.c:144:14: warning: symbol '__def_i2c_get_bus_speed' was not declared. Should it be static? cmd_i2c.c:151:5: warning: symbol '__def_i2c_set_bus_speed' was not declared. Should it be static? cmd_i2c.c:1322:1: error: directive in argument list cmd_i2c.c:1324:1: error: directive in argument list cmd_i2c.c:1326:1: error: directive in argument list cmd_i2c.c:1328:1: error: directive in argument list cmd_i2c.c:1337:1: error: directive in argument list cmd_i2c.c:1339:1: error: directive in argument list cmd_irq.c:27:5: warning: symbol 'do_interrupts' was not declared. Should it be static? cmd_itest.c:133:5: warning: symbol 'binary_test' was not declared. Should it be static? cmd_itest.c:158:5: warning: symbol 'do_itest' was not declared. Should it be stat cmd_load.c:54:5: warning: symbol 'do_load_serial' was not declared. Should it be static? cmd_load.c:431:6: warning: symbol 'his_eol' was not declared. Should it be static? cmd_load.c:432:6: warning: symbol 'his_pad_count' was not declared. Should it be static? cmd_load.c:433:6: warning: symbol 'his_pad_char' was not declared. Should it be static? cmd_load.c:434:6: warning: symbol 'his_quote' was not declared. Should it be static? cmd_load.c:436:5: warning: symbol 'do_load_serial_bin' was not declared. Should it be static? cmd_load.c:549:6: warning: symbol 'send_pad' was not declared. Should it be static? cmd_load.c:558:6: warning: symbol 'ktrans' was not declared. Should it be static? cmd_load.c:568:5: warning: symbol 'chk1' was not declared. Should it be static? cmd_load.c:578:6: warning: symbol 's1_sendpacket' was not declared. Should it be static? cmd_load.c:587:6: warning: symbol 'send_ack' was not declared. Should it be static? cmd_load.c:600:6: warning: symbol 'send_nack' was not declared. Should it be static? cmd_load.c:614:6: warning: symbol 'os_data_init' was not declared. Should it be static? cmd_load.c:615:6: warning: symbol 'os_data_char' was not declared. Should it be static? cmd_load.c:657:6: warning: symbol 'k_data_init' was not declared. Should it be static? cmd_load.c:663:6: warning: symbol 'k_data_save' was not declared. Should it be static? cmd_load.c:669:6: warning: symbol 'k_data_restore' was not declared. Should it be static? cmd_load.c:675:6: warning: symbol 'k_data_char' was not declared. Should it be static? cmd_load.c:693:6: warning: symbol 'send_parms' was not declared. Should it be static? cmd_load.c:694:6: warning: symbol 'send_ptr' was not declared. Should it be static? cmd_load.c:698:6: warning: symbol 'handle_send_packet' was not declared. Should i cmd_mdio.c:60:5: warning: symbol 'mdio_write_ranges' was not declared. Should it be static? cmd_mdio.c:82:5: warning: symbol 'mdio_read_ranges' was not declared. Should it be static? cmd_mdio.c:115:5: warning: symbol 'extract_reg_range' was not declared. Should it be static? cmd_mdio.c:144:5: warning: symbol 'extract_phy_range' was not declared. Should it cmd_mem.c:54:5: warning: symbol 'do_mem_md' was not declared. Should it be static? cmd_mem.c:150:5: warning: symbol 'do_mem_mm' was not declared. Should it be static? cmd_mem.c:154:5: warning: symbol 'do_mem_nm' was not declared. Should it be static? cmd_mem.c:159:5: warning: symbol 'do_mem_mw' was not declared. Should it be static? cmd_mem.c:256:5: warning: symbol 'do_mem_cmp' was not declared. Should it be static? cmd_mem.c:326:5: warning: symbol 'do_mem_cp' was not declared. Should it be static? cmd_mem.c:436:5: warning: symbol 'do_mem_base' was not declared. Should it be static? cmd_mem.c:449:5: warning: symbol 'do_mem_loop' was not declared. Should it be static? cmd_mem.c:595:5: warning: symbol 'do_mem_mtest' was not declared. Should it be static? cmd_mem.c:618:26: warning: Using plain integer as NULL pointer cmd_mem.c:1057:5: warning: symbol 'do_mem_crc' was not declared. Should it be static? cmd_misc.c:30:5: warning: symbol 'do_sleep' was not declared. Should it be static cmd_mmc.c:118:5: warning: symbol 'do_mmcinfo' was not declared. Should it be static? cmd_mmc.c:272:32: warning: Using plain integer as NULL pointer cmd_mmc.c:150:5: warning: symbol 'do_mmcops' was not declared. Should it be stati cmd_mp.c:27:1: warning: symbol 'cpu_cmd' was not declared. Should it be static? cmd_mp.c:85:1: error: directive in argument list cmd_mp.c:88:1: error: directive in argument list cmd_mtdparts.c:150:18: warning: symbol 'mtdids' was not declared. Should it be static? cmd_mtdparts.c:153:18: warning: symbol 'devices' was not declared. Should it be static? cmd_mtdparts.c:713:5: warning: symbol 'mtd_device_validate' was not declared. Should it be static? cmd_mtdparts.c:1887:5: warning: symbol 'do_chpart' was not declared. Should it be static? cmd_mtdparts.c:1925:5: warning: symbol 'do_mtdparts' was not declared. Should it be static? cmd_mtdparts.c:2060:1: error: directive in argument list cmd_mtdparts.c:2063:1: error: directive in argument list cmd_mtdparts.c:2066:1: error: directive in argument list cmd_mtdparts.c:2071:1: error: directive in argument list cmd_mtdparts.c:2073:1: error: directive in argument list cmd_nand.c:377:18: error: bad constant expression cmd_nand.c:431:5: warning: symbol 'do_nand' was not declared. Should it be static? cmd_nand.c:796:1: error: directive in argument list cmd_nand.c:801:1: error: directive in argument list cmd_nand.c:802:1: error: directive in argument list cmd_nand.c:806:1: error: directive in argument list cmd_nand.c:819:1: error: directive in argument list cmd_nand.c:824:1: error: directive in argument list cmd_nand.c:825:1: error: directive in argument list cmd_nand.c:831:1: error: directive in argument list cmd_nand.c:918:5: warning: symbol 'do_nandboot' was not declared. Should it be static? cmd_net.c:33:5: warning: symbol 'do_bootp' was not declared. Should it be static? cmd_net.c:107:5: warning: symbol 'do_dhcp' was not declared. Should it be static? cmd_net.c:120:5: warning: symbol 'do_nfs' was not declared. Should it be static? cmd_nvedit.c:138:5: warning: symbol 'do_env_print' was not declared. Should it be static? cmd_nvedit.c:323:5: warning: symbol '_do_env_set' was not declared. Should it be static? cmd_nvedit.c:435:5: warning: symbol 'do_env_set' was not declared. Should it be static? cmd_nvedit.c:514:5: warning: symbol 'do_env_edit' was not declared. Should it be static? cmd_nvedit.c:620:5: warning: symbol 'do_env_save' was not declared. Should it be static? cmd_nvedit.c:1016:1: error: directive in argument list cmd_nvedit.c:1018:1: error: directive in argument list cmd_nvedit.c:1021:1: error: directive in argument list cmd_nvedit.c:1023:1: error: directive in argument list cmd_nvedit.c:1024:1: error: directive in argument list cmd_nvedit.c:1026:1: error: directive in argument list cmd_nvedit.c:1027:1: error: directive in argument list cmd_nvedit.c:1029:1: error: directive in argument list cmd_nvedit.c:1030:1: error: directive in argument list cmd_nvedit.c:1032:1: error: directive in argument list cmd_nvedit.c:1034:1: error: directive in argument list cmd_nvedit.c:1036:1: error: directive in argument list cmd_nvedit.c:1037:1: error: directive in argument list cmd_nvedit.c:1039:1: error: directive in argument list cmd_pci.c:38:17: warning: symbol 'ShortPCIListing' was not declared. Should it be static? cmd_pci.c:38:22: warning: 'ShortPCIListing' defined but not used [-Wunused-variable] cmd_pci.c:411:5: warning: symbol 'do_pci' was not declared. Should it be static? cmd_pci.c:494:1: error: directive in argument list cmd_pci.c:497:1: error: directive in argument list cmd_reginfo.c:40:5: warning: symbol 'do_reginfo' was not declared. Should it be static? cmd_sata.c:31:5: warning: symbol 'sata_curr_device' was not declared. Should it be static? note -> ata_piix.c doesn't seem to use 'sata_curr_device'; deleted. cmd_sata.c:32:18: warning: symbol 'sata_dev_desc' was not declared. Should it be static? cmd_sata.c:70:5: warning: symbol 'do_sata' was not declared. Should it be static? cmd_setexpr.c:53:5: warning: symbol 'do_setexpr' was not declared. Should it be static? cmd_source.c:186:1: error: directive in argument list cmd_source.c:190:1: error: directive in argument list cmd_test.c:27:5: warning: symbol 'do_test' was not declared. Should it be static? cmd_test.c:153:5: warning: symbol 'do_false' was not declared. Should it be static? cmd_test.c:164:5: warning: symbol 'do_true' was not declared. Should it be static cmd_usb.c:43:6: warning: symbol 'usb_get_class_desc' was not declared. Should it be static? cmd_usb.c:69:6: warning: symbol 'usb_display_class_sub' was not declared. Should it be static? cmd_usb.c:151:6: warning: symbol 'usb_display_string' was not declared. Should it be static? cmd_usb.c:161:6: warning: symbol 'usb_display_desc' was not declared. Should it be static? cmd_usb.c:195:6: warning: symbol 'usb_display_conf_desc' was not declared. Should it be static? cmd_usb.c:210:6: warning: symbol 'usb_display_if_desc' was not declared. Should it be static? cmd_usb.c:227:6: warning: symbol 'usb_display_ep_desc' was not declared. Should it be static? cmd_usb.c:252:6: warning: symbol 'usb_display_config' was not declared. Should it be static? cmd_usb.c:283:6: warning: symbol 'usb_show_tree_graph' was not declared. Should it be static? cmd_usb.c:343:6: warning: symbol 'usb_show_tree' was not declared. Should it be static? cmd_usb.c:356:5: warning: symbol 'do_usbboot' was not declared. Should it be static? cmd_usb.c:366:5: warning: symbol 'do_usb' was not declared. Should it be static? cmd_version.c:31:5: warning: symbol 'do_version' was not declared. Should it be s cmd_ximg.c:46:1: warning: symbol 'do_imgextract' was not declared. Should it be static? cmd_ximg.c:272:1: error: directive in argument list cmd_ximg.c:276:1: error: directive in argument list Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-10-03Output strings from echo with puts where easyJoe Hershberger
Change echo to puts characters together where it knows about them together. This improves netconsole performance by greatly reducing the number of packets that are sent. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2009-11-23command.c: Break commands out to appropriate cmd_*.c filesPeter Tyser
command.c should contain common code related to commands, not miscellaneous command implementations. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
