path: root/common/cmd_dtt.c
2016-01-25Move all command code into its own directorySimon Glass
There are a lot of unrelated files in common, including all of the commands. Moving them into their own directory makes them easier to find and is more logical. Some commands include non-command code, such as cmd_scsi.c. This should be sorted out at some point so that the function can be enabled with or without the associated command. Unfortunately, with m68k I get this error: m68k: + M5329AFEE +arch/m68k/cpu/mcf532x/start.o: In function `_start': +arch/m68k/cpu/mcf532x/start.S:159:(.text+0x452): relocation truncated to fit: R_68K_PC16 against symbol `board_init_f' defined in .text.board_init_f section in common/built-in.o I hope someone can shed some light on what this means. I hope it isn't depending on the position of code in the image. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c: common changes for multibus/multiadapter supportHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org> Cc: Henrik Nordström <henrik@henriknordstrom.net>
2013-03-12TMU: Add TMU support in dtt commandAkshay Saraswat
Add generic TMU support alongwith i2c sensors in dtt command to enable temperature reading in cases where TMU is present along-with/instead-of i2c sensors. Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-10-22hwmon: Provide dtt_init()Dirk Eibach
Our boards rely on dtt for initialization of fan hardware. dtt_init() was implemented to be called form board specific code. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Acked-by: Heiko Schocher <hs@denx.de> Tested-by: Heiko Schocher <hs@denx.de>
2011-08-04hwmon: do not init sensors on startupHeiko Schocher
The U-Boot Design Principles[1] clearly say: Initialize devices only when they are needed within U-Boot, i.e. don't initialize the Ethernet interface(s) unless U-Boot performs a download over Ethernet; don't initialize any IDE or USB devices unless U-Boot actually tries to load files from these, etc. (and don't forget to shut down these devices after using them - otherwise nasty things may happen when you try to boot your OS). So, do not initialize and read the sensors on startup. Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Holger Brunck <holger.brunck@keymile.com>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2007-11-20[BUILD] conditionally compile common/cmd_*.c in common/MakefileGrant Likely
Modify common/Makefile to conditionally compile the cmd_*.c files based on the board config. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-10-19Fix two typos.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2007-07-08common/cmd_[af]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[a-f]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-02-20[PATCH] I2C: Add support for multiple I2C busses for RTC & DTTStefan Roese
This patch switches to the desired I2C bus when the date/dtt commands are called. This can be configured using the CFG_RTC_BUS_NUM and/or CFG_DTT_BUS_NUM defines. Signed-off-by: Stefan Roese <sr@denx.de>
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2002-08-27Initial revisionwdenk
