path: root/common/cmd_dtt.c
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2007-11-20[BUILD] conditionally compile common/cmd_*.c in common/MakefileGrant Likely
Modify common/Makefile to conditionally compile the cmd_*.c files based on the board config. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-10-19Fix two typos.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2007-07-08common/cmd_[af]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[a-f]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-02-20[PATCH] I2C: Add support for multiple I2C busses for RTC & DTTStefan Roese
This patch switches to the desired I2C bus when the date/dtt commands are called. This can be configured using the CFG_RTC_BUS_NUM and/or CFG_DTT_BUS_NUM defines. Signed-off-by: Stefan Roese <sr@denx.de>
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2002-08-27Initial revisionwdenk
