There are a lot of unrelated files in common, including all of the commands.
Moving them into their own directory makes them easier to find and is more
logical.
Some commands include non-command code, such as cmd_scsi.c. This should be
sorted out at some point so that the function can be enabled with or without
the associated command.
Unfortunately, with m68k I get this error:
m68k: + M5329AFEE
+arch/m68k/cpu/mcf532x/start.o: In function `_start':
+arch/m68k/cpu/mcf532x/start.S:159:(.text+0x452): relocation truncated to fit: R_68K_PC16 against symbol `board_init_f' defined in .text.board_init_f section in common/built-in.o
I hope someone can shed some light on what this means. I hope it isn't
depending on the position of code in the image.
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
This will allow the implementation to make use of data in the block_dev
structure beyond the base device number. This will be useful so that eMMC
block devices can encompass the HW partition ID rather than treating this
out-of-band. Equally, the existence of the priv field is crying out for
this patch to exist.
make the use of legacy image format configurable through
the config define CONFIG_IMAGE_FORMAT_LEGACY.
When relying on signed FIT images with required signature check
the legacy image format should be disabled. Therefore introduce
this new define and enable legacy image format if CONFIG_FIT_SIGNATURE
is not set. If CONFIG_FIT_SIGNATURE is set disable per default
the legacy image format.
Cc: Lars Steubesand <lars.steubesand@philips.com>
Cc: Mike Pearce <mike@kaew.be>
Cc: Tom Rini <trini@ti.com>
[trini: Fixup common/cmd_io.c]
With CONFIG_SYS_64BIT_LBA, lbaint_t gets defined as a 64-bit type,
which is required to represent block numbers for storage devices that
exceed 2TiB (the block size usually is 512B), e.g. recent hard drives
We now use lbaint_t for partition offset to reflect the lbaint_t change,
and access partitions beyond or crossing the 2.1TiB limit.
This required changes to signature of ext4fs_devread(), and type of all
variables relatives to block sector.
ext2/ext4 fs uses logical block represented by a 32 bit value. Logical
block is a multiple of device block sector. To avoid overflow problem
when calling ext4fs_devread(), we need to cast the sector parameter.
Signed-off-by: Frédéric Leroy <fredo@starox.org>
Rework get_device_and_partition() to:
a) Implement a new partition ID of "auto", which requests that U-Boot
search for the first "bootable" partition, and fall back to the first
valid partition if none is found. This way, users don't need to
specify an explicit partition in their commands.
b) Make use of get_device().
c) Add parameter to indicate whether returning a whole device is
acceptable, or whether a partition is mandatory.
d) Make error-checking of the user's device-/partition-specification
more complete. In particular, if strtoul() doesn't convert all
characters, it's an error rather than just ignored.
The resultant device/partition returned by the function will be as
follows, based on whether the disk has a partition table (ptable) or not,
and whether the calling command allows the whole device to be returned
or not.
(D and P are integers, P >= 1)
D
D:
No ptable:
!allow_whole_dev: error
allow_whole_dev: device D
ptable:
device D partition 1
D:0
D:P
No ptable: error
ptable: device D partition P
D:auto
No ptable:
ptable:
first partition in device D with bootable flag set.
If none, first valid paratition in device D.
Note: In order to review this patch, it's probably easiest to simply
look at the file contents post-application, rather than reading the
patch itself.
[swarren: Rob implemented scanning for bootable partitions. I fixed a
couple of issues there, switched the syntax to ":auto", added the
error-checking rework, and ":0" syntax for the whole device]
All the raw block load commands duplicate the same code. Starting with
the ide version as it has progress updates convert ide, usb, and scsi boot
commands to all use a common version.
