Nothing appears to use or compile cmd_df.c anymore.
Change all files in common/ to use CMD_RET_USAGE instead of calling
cmd_usage() directly. I'm not completely sure about this patch since
the code since impact is small (100 byte or so on ARM) and it might
need splitting into smaller patches. But for now here it is.
Lots of code use this construct:
cmd_usage(cmdtp);
return 1;
Change cmd_usage() let it return 1 - then we can replace all these
ocurrances by
return cmd_usage(cmdtp);
This fixes a few places with incorrect return code handling, too.
The hush shell dynamically allocates (and re-allocates) memory for the
argument strings in the "char *argv[]" argument vector passed to
commands. Any code that modifies these pointers will cause serious
corruption of the malloc data structures and crash U-Boot, so make
sure the compiler can check that no such modifications are being done
by changing the code into "char * const argv[]".
This modification is the result of debugging a strange crash caused
after adding a new command, which used the following argument
processing code which has been working perfectly fine in all Unix
systems since version 6 - but not so in U-Boot:
int main (int argc, char **argv)
while (--argc > 0 && **++argv == '-') {
/* ====> */ while (*++*argv) {
switch (**argv) {
case 'd':
debug++;
break;
default:
usage ();
The line marked "====>" will corrupt the malloc data structures and
usually cause U-Boot to crash when the next command gets executed by
the shell. With the modification, the compiler will prevent this with
an
error: increment of read-only location '*argv'
N.B.: The code above can be trivially rewritten like this:
char *arg = *argv;
while (*++arg) {
switch (*arg) {
Many of the help messages were not really helpful; for example, many
commands that take no arguments would not print a correct synopsis
line, but "No additional help available." which is not exactly wrong,
but not helpful either.
Commit ``Make "usage" messages more helpful.'' changed this
partially. But it also became clear that lots of "Usage" and "Help"
messages (fields "usage" and "help" in struct cmd_tbl_s respective)
were actually redundant.
This patch cleans this up - for example:
Before:
=> help dtt
dtt - Digital Thermometer and Thermostat
Usage:
dtt - Read temperature from digital thermometer and thermostat.
After:
=> help dtt
dtt - Read temperature from Digital Thermometer and Thermostat
Usage:
dtt
Remove command name from all command "usage" fields and update
common/command.c to display "name - usage" instead of
just "usage". Also remove newlines from command usage fields.
This patch gets rid of the spi_chipsel table and adds a handful of new
functions that makes the SPI layer cleaner and more flexible.
Instead of the spi_chipsel table, each board that wants to use SPI
gets to implement three hooks:
* spi_cs_activate(): Activates the chipselect for a given slave
* spi_cs_deactivate(): Deactivates the chipselect for a given slave
* spi_cs_is_valid(): Determines if the given bus/chipselect
combination can be activated.
Not all drivers may need those extra functions however. If that's the
case, the board code may just leave them out (assuming they know what
the driver needs) or rely on the linker to strip them out (assuming
--gc-sections is being used.)
To set up communication parameters for a given slave, the driver needs
to call spi_setup_slave(). This returns a pointer to an opaque
spi_slave struct which must be passed as a parameter to subsequent SPI
calls. This struct can be freed by calling spi_free_slave(), but most
driver probably don't want to do this.
Before starting one or more SPI transfers, the driver must call
spi_claim_bus() to gain exclusive access to the SPI bus and initialize
the hardware. When all transfers are done, the driver must call
spi_release_bus() to make the bus available to others, and possibly
shut down the SPI controller hardware.
spi_xfer() behaves mostly the same as before, but it now takes a
spi_slave parameter instead of a spi_chipsel function pointer. It also
got a new parameter, flags, which is used to specify chip select
behaviour. This may be extended with other flags in the future.
This patch has been build-tested on all powerpc and arm boards
involved. I have not tested NIOS since I don't have a toolchain for it
installed, so I expect some breakage there even though I've tried
fixing up everything I could find by visual inspection.
I have run-time tested this on AVR32 ATNGW100 using the atmel_spi and
DataFlash drivers posted as a follow-up. I'd like some help testing
other boards that use the existing SPI API.
But most of all, I'd like some comments on the new API. Is this stuff
usable for everyone? If not, why?
Changed in v4:
- Build fixes for various boards, drivers and commands
- Provide common struct spi_slave definition that can be extended by
drivers
- Pass a struct spi_slave * to spi_cs_activate and spi_cs_deactivate
- Make default bus and mode build-time configurable
- Override default SPI bus ID and mode on mx32ads and imx31_litekit.
Changed in v3:
- Add opaque struct spi_slave for controller-specific data associated
with a slave.
- Add spi_claim_bus() and spi_release_bus()
- Add spi_free_slave()
- spi_setup() is now called spi_setup_slave() and returns a
struct spi_slave
- soft_spi now supports four SPI modes (CPOL|CPHA)
- Add bus parameter to spi_setup_slave()
- Convert the new i.MX32 SPI driver
- Convert the new MC13783 RTC driver
Changed in v2:
- Convert the mpc8xxx_spi driver and the mpc8349emds board to the
new API.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Tested-by: Guennadi Liakhovetski <lg@denx.de>
