path: root/common/cmd_demo.c
2015-02-12dm: Prevent "demo hello" and "demo status" segfaultsPeter Tyser
Segfaults can occur when a mandatory argument is not provided to "demo hello" and "demo status". Eg: => demo hello Segmentation fault (core dumped) Add a check to ensure all required arguments are provided. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: demo: Add a simple GPIO demonstrationSimon Glass
Add a new 'demo light' command which uses GPIOs to control imaginary lights. Each light is assigned a bit number in the overall value. This provides an example driver for using the new GPIO API. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-27dm: rename device struct to udeviceHeiko Schocher
using UBI and DM together leads in compiler error, as both define a "struct device", so rename "struct device" in include/dm/device.h to "struct udevice", as we use linux code (MTD/UBI/UBIFS some USB code,...) and cannot change the linux "struct device" Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Marek Vasut <marex@denx.de>
2014-03-04dm: Add a demonstration/example driverSimon Glass
As an example of how to write a uclass and a driver, provide a demo version of each, accessible through the 'demo' command. To use these with driver model, define CONFIG_CMD_DEMO and CONFIG_DM_DEMO. The two demo drivers are enabled with CONFIG_DM_DEMO_SIMPLE and CONFIG_DM_DEMO_SHAPE. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com> Signed-off-by: Viktor Křivák <viktor.krivak@gmail.com> Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com>
