path: root/common/cmd_date.c
2015-07-14cmd: date: Change to use CONFIG_DM_RTC instead of CONFIG_DM_I2CBin Meng
Currently CONFIG_DM_I2C is used in cmd_date.c for driver model, but it should be actually CONFIG_DM_RTC. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-05dm: rtc: Convert 'date' command to support driver modelSimon Glass
Adjust this command so that it supports using driver model for I2C, i.e. CONFIG_DM_I2C. This will permit it to be used in sandbox also. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-05dm: rtc: Rename gregorian day functionSimon Glass
Change this function name to something more descriptive. Also return a failure code if it cannot calculate a correct value. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-04-23rtc: Set valid date after resetMarek Vasut
Some RTC chips tend to set garbage date after reset. This patch sets the date to 2000-01-01 00:00 immediatelly after the RTC chip reset is issued using the "date reset" command. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@konsulko.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c: common changes for multibus/multiadapter supportHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org> Cc: Henrik Nordström <henrik@henriknordstrom.net>
2012-11-04common/cmd_*.c: sparse fixesKim Phillips
cmd_boot.c:40:5: warning: symbol 'do_go' was not declared. Should it be static? cmd_bootm.c:164:6: warning: symbol '__arch_preboot_os' was not declared. Should it be static? cmd_bootm.c:477:5: warning: symbol 'do_bootm_subcommand' was not declared. Should it be static? cmd_bootm.c:1022:1: error: directive in argument list cmd_bootm.c:1028:1: error: directive in argument list cmd_bootm.c:1029:1: error: directive in argument list cmd_bootm.c:1036:1: error: directive in argument list cmd_bootm.c:1042:1: error: directive in argument list cmd_bootm.c:1044:1: error: directive in argument list cmd_bootm.c:1045:1: error: directive in argument list cmd_bootm.c:1047:1: error: directive in argument list cmd_bootm.c:1089:5: warning: symbol 'do_iminfo' was not declared. Should it be static? cmd_bootm.c:1176:5: warning: symbol 'do_imls' was not declared. Should it be static? cmd_bootm.c:1654:1: error: directive in argument list cmd_bootm.c:1660:1: error: directive in argument list cmd_console.c:32:5: warning: symbol 'do_coninfo' was not declared. Should it be s cmd_date.c:46:5: warning: symbol 'do_date' was not declared. Should it be static? cmd_echo.c:27:5: warning: symbol 'do_echo' was not declared. Should it be static? cmd_exit.c:27:5: warning: symbol 'do_exit' was not declared. Should it be static? cmd_fat.c:97:5: warning: symbol 'do_fat_ls' was not declared. Should it be static? cmd_fat.c:136:5: warning: symbol 'do_fat_fsinfo' was not declared. Should it be s cmd_fdt.c:66:5: warning: symbol 'do_fdt' was not declared. Should it be static? cmd_fdt.c:542:43: warning: incorrect type in assignment (different base types) cmd_fdt.c:542:43: expected unsigned int [unsigned] [usertype] <noident> cmd_fdt.c:542:43: got restricted __be32 [usertype] <noident> cmd_fdt.c:679:42: warning: cast to restricted __be32 cmd_fdt.c:820:1: error: directive in argument list cmd_fdt.c:822:1: error: directive in argument list cmd_flash.c:292:5: warning: symbol 'do_flinfo' was not declared. Should it be static? cmd_flash.c:324:5: warning: symbol 'do_flerase' was not declared. Should it be static? cmd_flash.c:457:5: warning: symbol 'do_protect' was not declared. Should it be st cmd_help.c:27:5: warning: symbol 'do_help' was not declared. Should it be static? cmd_i2c.c:136:6: warning: symbol '__def_i2c_init_board' was not declared. Should it be static? cmd_i2c.c:144:14: warning: symbol '__def_i2c_get_bus_speed' was not declared. Should it be static? cmd_i2c.c:151:5: warning: symbol '__def_i2c_set_bus_speed' was not declared. Should it be static? cmd_i2c.c:1322:1: error: directive in argument list cmd_i2c.c:1324:1: error: directive in argument list cmd_i2c.c:1326:1: error: directive in argument list cmd_i2c.c:1328:1: error: directive in argument list cmd_i2c.c:1337:1: error: directive in argument list cmd_i2c.c:1339:1: error: directive in argument list cmd_irq.c:27:5: warning: symbol 'do_interrupts' was not declared. Should it be static? cmd_itest.c:133:5: warning: symbol 'binary_test' was not declared. Should it be static? cmd_itest.c:158:5: warning: symbol 'do_itest' was not declared. Should it be stat cmd_load.c:54:5: warning: symbol 'do_load_serial' was not declared. Should it be static? cmd_load.c:431:6: warning: symbol 'his_eol' was not declared. Should it be static? cmd_load.c:432:6: warning: symbol 'his_pad_count' was not declared. Should it be static? cmd_load.c:433:6: warning: symbol 'his_pad_char' was not declared. Should it be static? cmd_load.c:434:6: warning: symbol 'his_quote' was not declared. Should it be static? cmd_load.c:436:5: warning: symbol 'do_load_serial_bin' was not declared. Should it be static? cmd_load.c:549:6: warning: symbol 'send_pad' was not declared. Should it be static? cmd_load.c:558:6: warning: symbol 'ktrans' was not declared. Should it be static? cmd_load.c:568:5: warning: symbol 'chk1' was not declared. Should it be static? cmd_load.c:578:6: warning: symbol 's1_sendpacket' was not declared. Should it be static? cmd_load.c:587:6: warning: symbol 'send_ack' was not declared. Should it be static? cmd_load.c:600:6: warning: symbol 'send_nack' was not declared. Should it be static? cmd_load.c:614:6: warning: symbol 'os_data_init' was not declared. Should it be static? cmd_load.c:615:6: warning: symbol 'os_data_char' was not declared. Should it be static? cmd_load.c:657:6: warning: symbol 'k_data_init' was not declared. Should it be static? cmd_load.c:663:6: warning: symbol 'k_data_save' was not declared. Should it be static? cmd_load.c:669:6: warning: symbol 'k_data_restore' was not declared. Should it be static? cmd_load.c:675:6: warning: symbol 'k_data_char' was not declared. Should it be static? cmd_load.c:693:6: warning: symbol 'send_parms' was not declared. Should it be static? cmd_load.c:694:6: warning: symbol 'send_ptr' was not declared. Should it be static? cmd_load.c:698:6: warning: symbol 'handle_send_packet' was not declared. Should i cmd_mdio.c:60:5: warning: symbol 'mdio_write_ranges' was not declared. Should it be static? cmd_mdio.c:82:5: warning: symbol 'mdio_read_ranges' was not declared. Should it be static? cmd_mdio.c:115:5: warning: symbol 'extract_reg_range' was not declared. Should it be static? cmd_mdio.c:144:5: warning: symbol 'extract_phy_range' was not declared. Should it cmd_mem.c:54:5: warning: symbol 'do_mem_md' was not declared. Should it be static? cmd_mem.c:150:5: warning: symbol 'do_mem_mm' was not declared. Should it be static? cmd_mem.c:154:5: warning: symbol 'do_mem_nm' was not declared. Should it be static? cmd_mem.c:159:5: warning: symbol 'do_mem_mw' was not declared. Should it be static? cmd_mem.c:256:5: warning: symbol 'do_mem_cmp' was not declared. Should it be static? cmd_mem.c:326:5: warning: symbol 'do_mem_cp' was not declared. Should it be static? cmd_mem.c:436:5: warning: symbol 'do_mem_base' was not declared. Should it be static? cmd_mem.c:449:5: warning: symbol 'do_mem_loop' was not declared. Should it be static? cmd_mem.c:595:5: warning: symbol 'do_mem_mtest' was not declared. Should it be static? cmd_mem.c:618:26: warning: Using plain integer as NULL pointer cmd_mem.c:1057:5: warning: symbol 'do_mem_crc' was not declared. Should it be static? cmd_misc.c:30:5: warning: symbol 'do_sleep' was not declared. Should it be static cmd_mmc.c:118:5: warning: symbol 'do_mmcinfo' was not declared. Should it be static? cmd_mmc.c:272:32: warning: Using plain integer as NULL pointer cmd_mmc.c:150:5: warning: symbol 'do_mmcops' was not declared. Should it be stati cmd_mp.c:27:1: warning: symbol 'cpu_cmd' was not declared. Should it be static? cmd_mp.c:85:1: error: directive in argument list cmd_mp.c:88:1: error: directive in argument list cmd_mtdparts.c:150:18: warning: symbol 'mtdids' was not declared. Should it be static? cmd_mtdparts.c:153:18: warning: symbol 'devices' was not declared. Should it be static? cmd_mtdparts.c:713:5: warning: symbol 'mtd_device_validate' was not declared. Should it be static? cmd_mtdparts.c:1887:5: warning: symbol 'do_chpart' was not declared. Should it be static? cmd_mtdparts.c:1925:5: warning: symbol 'do_mtdparts' was not declared. Should it be static? cmd_mtdparts.c:2060:1: error: directive in argument list cmd_mtdparts.c:2063:1: error: directive in argument list cmd_mtdparts.c:2066:1: error: directive in argument list cmd_mtdparts.c:2071:1: error: directive in argument list cmd_mtdparts.c:2073:1: error: directive in argument list cmd_nand.c:377:18: error: bad constant expression cmd_nand.c:431:5: warning: symbol 'do_nand' was not declared. Should it be static? cmd_nand.c:796:1: error: directive in argument list cmd_nand.c:801:1: error: directive in argument list cmd_nand.c:802:1: error: directive in argument list cmd_nand.c:806:1: error: directive in argument list cmd_nand.c:819:1: error: directive in argument list cmd_nand.c:824:1: error: directive in argument list cmd_nand.c:825:1: error: directive in argument list cmd_nand.c:831:1: error: directive in argument list cmd_nand.c:918:5: warning: symbol 'do_nandboot' was not declared. Should it be static? cmd_net.c:33:5: warning: symbol 'do_bootp' was not declared. Should it be static? cmd_net.c:107:5: warning: symbol 'do_dhcp' was not declared. Should it be static? cmd_net.c:120:5: warning: symbol 'do_nfs' was not declared. Should it be static? cmd_nvedit.c:138:5: warning: symbol 'do_env_print' was not declared. Should it be static? cmd_nvedit.c:323:5: warning: symbol '_do_env_set' was not declared. Should it be static? cmd_nvedit.c:435:5: warning: symbol 'do_env_set' was not declared. Should it be static? cmd_nvedit.c:514:5: warning: symbol 'do_env_edit' was not declared. Should it be static? cmd_nvedit.c:620:5: warning: symbol 'do_env_save' was not declared. Should it be static? cmd_nvedit.c:1016:1: error: directive in argument list cmd_nvedit.c:1018:1: error: directive in argument list cmd_nvedit.c:1021:1: error: directive in argument list cmd_nvedit.c:1023:1: error: directive in argument list cmd_nvedit.c:1024:1: error: directive in argument list cmd_nvedit.c:1026:1: error: directive in argument list cmd_nvedit.c:1027:1: error: directive in argument list cmd_nvedit.c:1029:1: error: directive in argument list cmd_nvedit.c:1030:1: error: directive in argument list cmd_nvedit.c:1032:1: error: directive in argument list cmd_nvedit.c:1034:1: error: directive in argument list cmd_nvedit.c:1036:1: error: directive in argument list cmd_nvedit.c:1037:1: error: directive in argument list cmd_nvedit.c:1039:1: error: directive in argument list cmd_pci.c:38:17: warning: symbol 'ShortPCIListing' was not declared. Should it be static? cmd_pci.c:38:22: warning: 'ShortPCIListing' defined but not used [-Wunused-variable] cmd_pci.c:411:5: warning: symbol 'do_pci' was not declared. Should it be static? cmd_pci.c:494:1: error: directive in argument list cmd_pci.c:497:1: error: directive in argument list cmd_reginfo.c:40:5: warning: symbol 'do_reginfo' was not declared. Should it be static? cmd_sata.c:31:5: warning: symbol 'sata_curr_device' was not declared. Should it be static? note -> ata_piix.c doesn't seem to use 'sata_curr_device'; deleted. cmd_sata.c:32:18: warning: symbol 'sata_dev_desc' was not declared. Should it be static? cmd_sata.c:70:5: warning: symbol 'do_sata' was not declared. Should it be static? cmd_setexpr.c:53:5: warning: symbol 'do_setexpr' was not declared. Should it be static? cmd_source.c:186:1: error: directive in argument list cmd_source.c:190:1: error: directive in argument list cmd_test.c:27:5: warning: symbol 'do_test' was not declared. Should it be static? cmd_test.c:153:5: warning: symbol 'do_false' was not declared. Should it be static? cmd_test.c:164:5: warning: symbol 'do_true' was not declared. Should it be static cmd_usb.c:43:6: warning: symbol 'usb_get_class_desc' was not declared. Should it be static? cmd_usb.c:69:6: warning: symbol 'usb_display_class_sub' was not declared. Should it be static? cmd_usb.c:151:6: warning: symbol 'usb_display_string' was not declared. Should it be static? cmd_usb.c:161:6: warning: symbol 'usb_display_desc' was not declared. Should it be static? cmd_usb.c:195:6: warning: symbol 'usb_display_conf_desc' was not declared. Should it be static? cmd_usb.c:210:6: warning: symbol 'usb_display_if_desc' was not declared. Should it be static? cmd_usb.c:227:6: warning: symbol 'usb_display_ep_desc' was not declared. Should it be static? cmd_usb.c:252:6: warning: symbol 'usb_display_config' was not declared. Should it be static? cmd_usb.c:283:6: warning: symbol 'usb_show_tree_graph' was not declared. Should it be static? cmd_usb.c:343:6: warning: symbol 'usb_show_tree' was not declared. Should it be static? cmd_usb.c:356:5: warning: symbol 'do_usbboot' was not declared. Should it be static? cmd_usb.c:366:5: warning: symbol 'do_usb' was not declared. Should it be static? cmd_version.c:31:5: warning: symbol 'do_version' was not declared. Should it be s cmd_ximg.c:46:1: warning: symbol 'do_imgextract' was not declared. Should it be static? cmd_ximg.c:272:1: error: directive in argument list cmd_ximg.c:276:1: error: directive in argument list Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-03-06Convert cmd_usage() calls in common to use a return valueSimon Glass
Change all files in common/ to use CMD_RET_USAGE instead of calling cmd_usage() directly. I'm not completely sure about this patch since the code since impact is small (100 byte or so on ARM) and it might need splitting into smaller patches. But for now here it is. Signed-off-by: Simon Glass <sjg@chromium.org>
2010-11-28cmd_date: constifyMike Frysinger
Many strings in this file need not be writable. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2009-12-02cmd_date: Fix spelling in error message.Magnus Lilja
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2009-10-03Conditionally perform common relocation fixupsPeter Tyser
Add #ifdefs where necessary to not perform relocation fixups. This allows boards/architectures which support relocation to trim a decent chunk of code. Note that this patch doesn't add #ifdefs to architecture-specific code which does not support relocation. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-09-07rtc: allow rtc_set to return an error and use it in cmd_dateJean-Christophe PLAGNIOL-VILLARD
2007-11-20[BUILD] conditionally compile common/cmd_*.c in common/MakefileGrant Likely
Modify common/Makefile to conditionally compile the cmd_*.c files based on the board config. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/cmd_[af]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[a-f]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-02-20[PATCH] I2C: Add support for multiple I2C busses for RTC & DTTStefan Roese
This patch switches to the desired I2C bus when the date/dtt commands are called. This can be configured using the CFG_RTC_BUS_NUM and/or CFG_DTT_BUS_NUM defines. Signed-off-by: Stefan Roese <sr@denx.de>
2004-03-23* Patches by Thomas Viehweger, 16 Mar 2004:wdenk
- show PCI clock frequency on MPC8260 systems - add FCC_PSMR_RMII flag for HiP7 processors - in do_jffs2_fsload(), take load address from load_addr if not set explicit, update load_addr otherwise - replaced printf by putc/puts when no formatting is needed (smaller code size, faster execution)
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-04-05* Patch by Arun Dharankar, 4 Apr 2003:LABEL_2003_04_05_0300wdenk
Add IDMA example code (tested on 8260 only) * Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs * Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS * Patch by Denis Peter, 04 Apr 2003: - update MIP405-4 board * Patches by Denis Peter, 03 April 2003: - fix PCI IRQs on MPL boards - fix two more un-relocated pointer problems * Fix behaviour of "run" command: - print error message iv variable does not exist - terminate processing of arguments in case of error * Patches by Peter Figuli, 10 Mar 2003 - Add support for BTUART on PXA platform - Add support for WEP EP250 (PXA) board * Fix flash problems on INCA-IP; add tool to allow bruning images to flash using a BDI2000 * Implement fix for I2C Edge Conditions problem for all boards that use the bit-banging driver (common/soft_i2c.c) * Add patches by Robert Schwebel, 31 Mar 2003: - csb226 board: bring in sync with innokom/memsetup.S - csb226 board: fix MDREFR handling - misc doc fixes / extensions - innokom board: cleanup, MDREFR fix in memsetup.S, config update - add BOOT_PROGRESS to armlinux.c
2002-08-27Initial revisionwdenk
