path: root/common/cmd_cramfs.c
2011-05-10cramfs: make cramfs usable without a NOR flashHeiko Schocher
cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-05-10cramfs: fix bug in using CONFIG_CRAMFS_CMDLINEHeiko Schocher
do not define own flash_info variable, instead use the flash_info variable defined in your flash driver. Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2010-08-09various cmd_* files: remove the command name from the help messageFrans Meulenbroeks
removed the command name from the help message as it is already printed. for cmd_mmc also rewrote the message a little bit Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com>
2010-01-18CRAMFS: support cramfs in RAMHeiko Schocher
cramfsls and cramfsload are added to the command list. A cramfs placed at 'cramfs_addr' can the be listed with 'cramfsls' and files can be loaded with 'cramfsload'. 'cramfs_addr' is an environment variable specifying the address the cramfs is located. This works for powerpc and for ARM. Use CONFIG_CMD_CRAMFS. Signed-off-by: Andreas Huber <andreas.huber@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de>
