path: root/common/cmd_console.c
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-08-31devices: merge to list_headJean-Christophe PLAGNIOL-VILLARD
2007-11-20[BUILD] conditionally compile common/cmd_*.c in common/MakefileGrant Likely
Modify common/Makefile to conditionally compile the cmd_*.c files based on the board config. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/cmd_[af]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[a-f]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2004-06-09Patch by Thomas Viehweger, 14 May 2004:wdenk
- flash.h: more flash types added - immap_8260.h: some bits added (useful for RMII) - cmd_coninfo.c: typo corrected, printf -> puts - reduced size by replacing spaces with tab
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2002-08-27Initial revisionwdenk
