There are a lot of unrelated files in common, including all of the commands.
Moving them into their own directory makes them easier to find and is more
logical.
Some commands include non-command code, such as cmd_scsi.c. This should be
sorted out at some point so that the function can be enabled with or without
the associated command.
Unfortunately, with m68k I get this error:
m68k: + M5329AFEE
+arch/m68k/cpu/mcf532x/start.o: In function `_start':
+arch/m68k/cpu/mcf532x/start.S:159:(.text+0x452): relocation truncated to fit: R_68K_PC16 against symbol `board_init_f' defined in .text.board_init_f section in common/built-in.o
I hope someone can shed some light on what this means. I hope it isn't
depending on the position of code in the image.
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
Since most commands are not public, make them static. This
prevents warnings that no common prototype is available.
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
[trini: Fixup common/cmd_io.c]
Only print when queried, not every time the setting is changed.
Old code that is not compliant.
flush_dcache()/flush_icache() aren't defined in common.h,
flush_dcache_all()/invalidate_icache_all() however are.
Let the icache and dcache commands use those instead.
Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Change all files in common/ to use CMD_RET_USAGE instead of calling
cmd_usage() directly. I'm not completely sure about this patch since
the code since impact is small (100 byte or so on ARM) and it might
need splitting into smaller patches. But for now here it is.
It might be desirable to have the ability to flush icache/dcache
within u-boot, this patch gives each arch the ability to provide
a flush_dcache/flush_icache function to let u-boot flush caches
from the prompt
Signed-off-by: Matthew McClintock <msm@freescale.com>
Lots of code use this construct:
cmd_usage(cmdtp);
return 1;
Change cmd_usage() let it return 1 - then we can replace all these
ocurrances by
return cmd_usage(cmdtp);
This fixes a few places with incorrect return code handling, too.
The hush shell dynamically allocates (and re-allocates) memory for the
argument strings in the "char *argv[]" argument vector passed to
commands. Any code that modifies these pointers will cause serious
corruption of the malloc data structures and crash U-Boot, so make
sure the compiler can check that no such modifications are being done
by changing the code into "char * const argv[]".
This modification is the result of debugging a strange crash caused
after adding a new command, which used the following argument
processing code which has been working perfectly fine in all Unix
systems since version 6 - but not so in U-Boot:
int main (int argc, char **argv)
while (--argc > 0 && **++argv == '-') {
/* ====> */ while (*++*argv) {
switch (**argv) {
case 'd':
debug++;
break;
default:
usage ();
The line marked "====>" will corrupt the malloc data structures and
usually cause U-Boot to crash when the next command gets executed by
the shell. With the modification, the compiler will prevent this with
an
error: increment of read-only location '*argv'
N.B.: The code above can be trivially rewritten like this:
char *arg = *argv;
while (*++arg) {
switch (*arg) {
A small number of common/cmd_*.c files contain preprocessor tests that
are apparently superfluous since those same tests are used in the
Makefile to control the compilation of those files. Those tests are
clearly redundant as long as they surround the entirety of the source
in those files.
Many of the help messages were not really helpful; for example, many
commands that take no arguments would not print a correct synopsis
line, but "No additional help available." which is not exactly wrong,
but not helpful either.
Commit ``Make "usage" messages more helpful.'' changed this
partially. But it also became clear that lots of "Usage" and "Help"
messages (fields "usage" and "help" in struct cmd_tbl_s respective)
were actually redundant.
This patch cleans this up - for example:
Before:
=> help dtt
dtt - Digital Thermometer and Thermostat
Usage:
dtt - Read temperature from digital thermometer and thermostat.
After:
=> help dtt
dtt - Read temperature from Digital Thermometer and Thermostat
Usage:
dtt
Remove command name from all command "usage" fields and update
common/command.c to display "name - usage" instead of
just "usage". Also remove newlines from command usage fields.
Fixed some broken instances of "#ifdef CMD_CFG_IDE" too.
Those always evaluated TRUE, and thus were always compiled
even when IDE really wasn't defined/wanted.
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
