path: root/common/cmd_bootm.c
2015-05-28Combine bootm_find_<thing> functions togetherKarl Apsite
bootm_find_ramdisk_fdt() renamed to bootm_find_images() for readability. The function bootm_find_ramdisk_fdt() appears to be a simple wrapper for bootm_find_ramdisk(), bootm_find_fdt(), and now bootm_find_loadables(). I didn't see any other callers entering a bootm_find<thing>, so removing the wrapper, and condensing these together hopefully makes the code a little simpler. Signed-off-by: Karl Apsite <Karl.Apsite@dornerworks.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18common: Make sure arch-specific map_sysmem() is definedJoe Hershberger
In the case where the arch defines a custom map_sysmem(), make sure that including just mapmem.h is sufficient to have these functions as they are when the arch does not override it. Also split the non-arch specific functions out of common.h Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-03-05spl: fix calling "spl export .." more than onceHeiko Schocher
running "spl export ..." more than once fails with: Trying to execute a command out of order Trying to execute a command out of order Trying to execute a command out of order Trying to execute a command out of order Trying to execute a command out of order Trying to execute a command out of order ERROR prep subcommand failed! Subcommand failed reason is commmit: 35fc84fa1f: Refactor the bootm command to reduce code duplication It used "state != BOOTM_STATE_START" but state is a bitfield, so check if the bit BOOTM_STATE_START is not set. With this fix, "spl export ..." can called more than once ... Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-01-29common: bootm: Document fake bootm sub-commandMichal Simek
Fake option is enabled only when CONFIG_TRACE is enabled in common/bootm.c:do_boot_states(). Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-10-22x86: Support loading kernel setup from a FITSimon Glass
Add a new setup@ section to the FIT which can be used to provide a setup binary for booting Linux on x86. This makes it possible to boot x86 from a FIT. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-08-30cmd_bootm.c: Add 'booti' for ARM64 Linux kernel ImagesTom Rini
The default format for arm64 Linux kernels is the "Image" format, described in Documentation/arm64/booting.txt. This, along with an optional gzip compression on top is all that is generated by default. The Image format has a magic number within the header for verification, a text_offset where the Image must be run from, an image_size that includes the BSS and reserved fields. This does not support automatic detection of a gzip compressed image. Signed-off-by: Tom Rini <trini@ti.com>
2014-06-19bootm: Split out code from cmd_bootm.cSimon Glass
This file has code in three different categories: - Command processing - OS-specific boot code - Locating images and setting up to boot Only the first category really belongs in a file called cmd_bootm.c. Leave the command processing code where it is. Split out the OS-specific boot code into bootm_os.c. Split out the other code into bootm.c Header files and extern declarations are tidied but otherwise no code changes are made, to make it easier to review. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-11Check run_command() return code properlyThomas Betker
run_command() returns 0 for success, 1 for failure. Fix places which assume that failure is indicated by a negative return code. Signed-off-by: Thomas Betker <thomas.betker@rohde-schwarz.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Tested-by: Stefan Roese <sr@denx.de>
2014-06-05bootm: make use of legacy image format configurableHeiko Schocher
make the use of legacy image format configurable through the config define CONFIG_IMAGE_FORMAT_LEGACY. When relying on signed FIT images with required signature check the legacy image format should be disabled. Therefore introduce this new define and enable legacy image format if CONFIG_FIT_SIGNATURE is not set. If CONFIG_FIT_SIGNATURE is set disable per default the legacy image format. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Lars Steubesand <lars.steubesand@philips.com> Cc: Mike Pearce <mike@kaew.be> Cc: Wolfgang Denk <wd@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Michal Simek <monstr@monstr.eu> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-29Remove unnecessary use of hush header fileSimon Glass
Some files include hush.h but don't actually use it. Remove this where possible. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-22Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2014-05-12cmd_bootm.c: Only say XIP image when load is image_startTom Rini
We say we have an XIP (in this case, image loaded at desired execution address) when the image header has been offset in the load. It's possible that in some cases executing the header is non-fatal but that's not true in many other cases. Signed-off-by: Tom Rini <trini@ti.com>
2014-05-08image: add support for Android's boot image formatSebastian Siewior
This patch adds support for the Android boot-image format. The header file is from the Android project and got slightly alterted so the struct + its defines are not generic but have something like a namespace. The header file is from bootloader/legacy/include/boot/bootimg.h. The header parsing has been written from scratch and I looked at bootloader/legacy/usbloader/usbloader.c for some details. The image contains the physical address (load address) of the kernel and ramdisk. This address is considered only for the kernel image. The "second image" defined in the image header is currently not supported. I haven't found anything that is creating this. v3 (Rob Herring): This is based on http://patchwork.ozlabs.org/patch/126797/ with the following changes: - Rebased to current mainline - Moved android image handling to separate functions in common/image-android.c - s/u8/char/ in header to fix string function warnings - Use SPDX identifiers for licenses - Cleaned-up file source information: android_image.h is from file include/boot/bootimg.h in repository: https://android.googlesource.com/platform/bootable/bootloader/legacy The git commit hash is 4205b865141ff2e255fe1d3bd16de18e217ef06a usbloader.c would be from the same commit, but it does not appear to have been used for any actual code. v4: - s/andriod/android/ - Use a separate flag ep_found to track if the entry point has been set rather than using a magic value. Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Rob Herring <robh@kernel.org> Reviewed-by: Tom Rini <trini@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2014-04-18bootm: set max decompression size for LZOKees Cook
The LZO decompressor wasn't initializing the maximum output size, which meant it would fail to decompress most of the time. Reported-by: Matthias Weißer <weisserm@arcor.de> Signed-off-by: Kees Cook <keescook@chromium.org> Tested-by: Matthias Weißer <weisserm@arcor.de> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-21common: Remove invalid endianess conversionChristian Eggers
do_bootm_standanlone() calls ntohl(images->ep) which is wrong because endianess conversion has already been done: do_bootm() \-do_bootm_states() +-bootm_find_os() | \-images.ep = image_get_ep(); | \-uimage_to_cpu(hdr->ih_ep); \-boot_selected_os() \-do_bootm_standanlone() Without this conversion the code works correctly at least on AT91SAM9G45. On big endian systems there should be no difference after applying this patch because uimage_to_cpu(x) and ntohl(x) both expand to 'x'. Signed-off-by: Christian Eggers <ceggers@gmx.de>
2014-01-14bootm: Reinstate special case for standalone imagesSimon Glass
For standalone images, bootm had a special case where the OS boot function was NULL but did actually exist. It was just called manually. This was removed by commit 35fc84fa which checks for the non-existence of this function before the special case is examined. There is no obvious reason why standalone is handled with a special case. Adjust the code so that standalone has a normal OS boot function. We still need a special case for when the function returns, but at least we can avoid the main problem. This is intended to fix the reported: ERROR: booting os 'U-Boot' (17) is not supported but needs testing. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-16common/cmd_bootm: extend do_bootm_vxworks to support the new VxWorks boot ↵Miao Yan
interface. The next version VxWorks adopts device tree (for PowerPC and ARM) as its hardware description mechanism. For PowerPC, the boot interface conforms to the ePAPR standard, which is: void (*kernel_entry)(ulong fdt_addr, ulong r4 /* 0 */, ulong r5 /* 0 */, ulong r6 /* EPAPR_MAGIC */, ulong r7 /* IMA size */, ulong r8 /* 0 */, ulong r9 /* 0 */) For ARM, the boot interface is: void (*kernel_entry)(void *fdt_addr) Signed-off-by: Miao Yan <miao.yan@windriver.com> [trini: Fix build error when !CONFIG_OF_FDT is set, typo on PowerPC, missing extern ft_fixup_num_cores] Signed-off-by: Tom Rini <trini@ti.com>
2013-12-13common/cmd_bootm.c: seperate do_bootm_vxworks related code from CONFIG_CMD_ELF.Miao Yan
do_bootm_vxworks now is available under the configuration option CONFIG_BOOTM_VXWORKS, thus aligned with other operating systems that supported by bootm command. The bootvx command still depneds on CONFIG_CMD_ELF. Signed-off-by: Miao Yan <miao.yan@windriver.com>
2013-12-13netbsd:fix documentation typo.Kees Jongenburger
The documentation suggested the arguments where passed over r3-r6 while the code below simply does that over r0-r3. Cc: Kumar Gala <galak@kernel.crashing.org>
2013-11-08common/cmd_bootm.c: fix subcommand processing in OS specific do_bootm_xxx() ↵Miao Yan
functions In commit "5c427e4: use BOOTM_STATE_OS_CMDLINE flag for plain bootm" and "3d187b3: Only pass BOOTM_STATE_OS_CMDLINE on PowerPC/MIPS", BOOTM_STATE_OS_CMDLINE was added to do_bootm for PowerPC and MIPS. This breaks other OSes (vxworks, netbsd, plan9,...) that don't support subcommand processing, e.g. they all contain the following code in their do_bootm_xxx(): if (flag & BOOTM_STATE_OS_PREP) return 0; if ((flag != 0) && (flag != BOOTM_STATE_OS_GO)) return 1; which will result a "subcommand not supported" error. This patch changes the above logic to: /* if not go command, pretend everything to be OK */ if (flag != BOOTM_STATE_OS_GO) return 0; Signed-off-by: Miao Yan <miao.yan@windriver.com>
2013-09-23cmd_bootm.c: Only pass BOOTM_STATE_OS_CMDLINE on PowerPC/MIPSTom Rini
In 5c427e4 we pass BOOTM_STATE_OS_CMDLINE as part of the bootm states to run, on all arches. However, this is only valid / useful on PowerPC and MIPS, and causes a problem on ARM where we specifically do not use it. Rather than make this state fake pass like we do for GO on some arches (which need updating to use the GO state), we should just not pass CMDLINE except when it may be used, like before. Tested-by: Dan Murphy <dmurphy@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-09-20Fix loading freeze when netconsole is activeFrederic Leroy
Netconsole calls eth_halt() before giving control to another operating system. But the state machine of netconsole don't take it into account. Thus, netconsole calls network functions of an halted network device, making the whole system freeze. Rather than modifying the state machine of netconsole, we just unregister the current network device before booting. It does work because nc_send_packet() verifies that the current network device is not null. Signed-off-by: Frédéric Leroy <fredo@starox.org>
2013-09-20bootm: use BOOTM_STATE_OS_CMDLINE flag for plain bootmPaul Burton
A plain bootm used to call the architecture specific boot function with no flags, but was modified by commit 35fc84fa "Refactor the bootm command to reduce code duplication" to call the architecture specific boot function multiple times with various flags in sequence. The BOOTM_STATE_OS_CMDLINE flag was not used, indeed it seems that at least ARM prepares the command line on BOOTM_STATE_OS_PREP. However on MIPS since commit 59e8cbdb "MIPS: bootm: refactor initialisation of kernel cmdline" the command line is not prepared in response to a BOOTM_STATE_OS_PREP flag, only on BOOTM_STATE_OS_CMDLINE or a call with no flags. The end result is that a combination of those 2 commits leads to MIPS boards booting kernels with no command line arguments. An extra invocation of the architecture specific boot function with BOOTM_STATE_OS_CMDLINE fixes this. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-09-03bootm: allow correct bounds-check of destinationKees Cook
While nothing presently examines the destination size, it should at least be correct so that future users of sys_mapmem() will not be surprised. Without this, it might be possible to overflow memory. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-09-03sandbox: Correct compiler warnings in cmd_bootm/cmd_ximgSimon Glass
Correct the following warnings found with sandbox when compression is enabled. cmd_bootm.c: In function 'bootm_load_os': cmd_bootm.c:443:11: warning: passing argument 4 of 'lzop_decompress' from incompatible pointer type [enabled by default] /usr/local/google/c/cosarm/src/third_party/u-boot/files/include/linux/lzo.h:31:5: note: expected 'size_t *' but argument is of type 'uint *' cmd_ximg.c: In function 'do_imgextract': cmd_ximg.c:225:6: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] cmd_ximg.c:225:14: warning: 'hdr' may be used uninitialized in this function [-Wuninitialized] Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Kees Cook <keescook@chromium.org>
2013-08-16bootm: fix conditional controlling call to fixup_silent_linuxPaul B. Henson
This function is only defined if CONFIG_SILENT_CONSOLE is set and CONFIG_SILENT_U_BOOT_ONLY is not set, the call to it should be based on the same conditions. Signed-off-by: Paul B. Henson <henson@acm.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-08-16RFC: bootm: Add silent_linux environment variableSimon Glass
At present the console for linux is silent if the U-Boot console is silent, unless CONFIG_SILENT_U_BOOT_ONLY is set. I wonder if a better way would be to have an environment variable to control this? Then we can control the verbosity from scripts, and set the variable to 'no' for those boards that want Linux to boot with console output. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-17bootm: Move fixup_silent_linux() earlier in the bootm stagesSimon Glass
Before the bootm refactor, fixup_silent_linux() was done only in the monolithic bootm case, not in the subcommand case. With the refactor, it is done always, which is good. Unfortunately it is done too late, since it is the PREP or CMDLINE stages that set up the command line for Linux. Move fixup_silent_linux() into the LOADOS stage, which is where we find out the OS being used, and can thus decide whether to perform this step. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-12bootm: Handle errors consistentlySimon Glass
A recent bootm fix left the error path incomplete. If CONFIG_TRACE is set it may still not be a supported command, so cover that with the unsupported subcommand print. Once we handle BOOTM_STATE_OS_GO, we can just move into the error handler itself, no need for a goto there. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Update slightly based on Simon's changes to also cover CONFIG_TRACE/BOOTM_STATE_FAKE_OS_GO] Signed-off-by: Tom Rini <trini@ti.com>
2013-07-12bootm: Use selected configuration for ramdisk and fdtSimon Glass
If a specific configuraion is selected by the bootm command, e.g. with 'bootm 84000000#recoveryconf' we must honour this for not just the kernel, but also the ramdisk and FDT. In the conversion to using a common fit_image_load() function for loading images from FITs (commits a51ec63 and 53f375f) this feature was lost. Reinstate it by passing the selected configuration back from fit_image_load() to boot_get_kernel(), then use this configuration (which is stored in images->fit_uname_cfg) in both boot_get_ramdisk() and boot_get_fdt(). Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-12blackfin: x86: bootm: Handle PREP stage of bootmSimon Glass
The OS function is now always called with the PREP stage. Adjust the remaining bootm OS functions to deal with this correctly. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-12bootm: Remove extra OK messageSimon Glass
This is not needed as we already print 'OK' later in all cases. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-12cmd_bootm.c: Re-order bootm_load_os return check for ELDK4.2Tom Rini
With ELDK4.2 we were getting a warning that load_end may be used uninitialized in calling lmb_reserve. This could not be the case, however. If we re-order the checks (and make them slightly clearer as well) the warning goes away. bootm_load_os may only return 0 on success, BOOTM_ERR_OVERLAP in a non-fatal overlap (already covered in comments) or a fatal BOOTM_ERR that is covered in the error handler. Signed-off-by: Tom Rini <trini@ti.com>
2013-07-10cmd_bootm.c: Make bootz handle BOOTM_STATE_FINDOTHER itselfTom Rini
As a zImage does not have a U-Boot header, we cannot really do what BOOTM_STATE_FINDOTHER does, exactly. Break the ramdisk/fdt portions of bootm_find_other into bootm_find_ramdisk/fdt which can be called in both cases. Signed-off-by: Tom Rini <trini@ti.com>
2013-07-10cmd_bootm.c: Make bootz consume 'bootz' from argv, decrement argcTom Rini
Like 'bootm', 'bootz' needs to consume 'bootz' so that the rest of the state functions will work. Signed-off-by: Tom Rini <trini@ti.com>
2013-07-10bootm: Add the missing PREP stage to bootz and correct image handlingSimon Glass
In the recent bootm refactor, the PREP stage was missing in the bootz command. This causes unpredictable behaviour. The use of a local variable means that the reset of cmd_bootm.c does not in fact use the same image structure, so remove this. Also manually set the OS type to Linux, since this is the only possibility at present, and we need to select the right boot function. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-10bootm: Clean up bootz_setup() functionSimon Glass
This function has no prototype in the headers and passes void * around, thus requiring several casts. Tidy this up. - Add new patch to clean up bootz_setup() function Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-10bootm: Require boot function only if it is about to be usedSimon Glass
The original bootm code (before commit 35fc84f) did not check for a valid boot function in the subcommand case, which was incorrect. This check was introduced in all cases, but in fact we should only check for the function when we need it. Otherwise in some cases the check fires before the OS type is known. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-10bootm: Disable interrupts only when loadingSimon Glass
With the move of the interrupt code to earlier in the sequence, we exposed a problem where the interrupts are disabled at each bootm stage. This is not correct - it should be done only once. Let's disable interrupts in the LOAD stage. Put the code in a function for clarity. Also, bootz lost its interrupt code altogether, so reinstate it. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-04cmd_bootm.c: Correct check/return for unsupported sub-commandTom Rini
With the do_bootm_states re-organization, we have the call to any potential sub-commands in a single spot. If one fails, we can then stop right there and return to the caller. Prior to these calls we have already ensured that ret is zero so we will not be returning this error for some other case. Signed-off-by: Tom Rini <trini@ti.com> Tested-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-06-28bootm: Disable interrupts before loading OSSimon Glass
This restores the ordering of interrupt disable to what it what before commit 35fc84fa. It seems that on some archiectures (e.g. PowerPC) the OS is loaded into an interrupt region, which can cause problems if interrupts are still running. Tested-by: Stefan Roese <sr@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-28cmd_bootm.c: Correct BOOTM_ERR_OVERLAP handlingTom Rini
With 35fc84fa1 [Refactor the bootm command to reduce code duplication] we stopped checking the return value of bootm_load_os (unintentionally!) and simply returned if we had a non-zero return value from the function. This broke the valid case of a legacy image file of a single kernel loaded into an overlapping memory area (the default way of booting nearly all TI platforms). The best way to fix this problem in the new code is to make bootm_load_os be the one to see if we have a problem with this, and if it's fatal return BOOTM_ERR_RESET and if it's not BOOTM_ERR_OVERLAP, so that we can avoid calling lmb_reserve() but continue with booting. We however still need to handle the other BOOTM_ERR values so re-work do_bootm_states so that we have an error handler at the bottom we can goto for problems from bootm_load_os, or problems from the other callers (as the code was before). Add a comment to do_bootm_states noting the existing restriction on negative return values. Signed-off-by: Tom Rini <trini@ti.com> --- Changes in v2: - Rework so that only bootm_load_os and boot_selected_os head down into the err case code, and other errors simply return back to the caller. Fixes 'spl export'.
2013-06-26cmd_bootm: Add command line arguments to Plan 9Steven Stallion
This patch introduces support for command line arguments to Plan 9. Plan 9 generally dedicates a small region of kernel memory (known as CONFADDR) for runtime configuration. A new environment variable named confaddr was introduced to indicate this location when copying arguments. Signed-off-by: Steven Stallion <sstallion@gmail.com> [trini: Adapt for Simon's changes about correcting argc, no need to bump by 2 now] Signed-off-by: Tom Rini <trini@ti.com>
2013-06-26Add a 'fake' go command to the bootm commandSimon Glass
For tracing it is useful to run as much of U-Boot as possible so as to get a complete picture. Quite a bit of work happens in bootm, and we don't want to have to stop tracing before bootm starts. Add a way of doing a 'fake' boot of the OS - which does everything up to the point where U-Boot is about to jump to the OS image. This allows tracing to record right until the end. This requires arch support to work. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26Refactor the bootm command to reduce code duplicationSimon Glass
At present the bootm code is mostly duplicated for the plain 'bootm' command and its sub-command variant. This makes the code harder to maintain and means that changes must be made to several places. Introduce do_bootm_states() which performs selected portions of the bootm work, so that both plain 'bootm' and 'bootm <sub_command>' can use the same code. Additional duplication exists in bootz, so tidy that up as well. This is not intended to change behaviour, apart from minor fixes where the previously-duplicated code missed some chunks of code. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26Clarify bootm OS argumentsSimon Glass
At present the arguments to bootm are processed in a somewhat confusing way. Sub-functions must know how many arguments their calling functions have processed, and the OS boot function must also have this information. Also it isn't obvious that 'bootm' and 'bootm start' provide arguments in the same way. Adjust the code so that arguments are removed from the list before calling a sub-function. This means that all functions can know that argv[0] is the first argument of which they need to take notice. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-24bootz: un-staticize do_bootzRob Herring
Make do_bootz available for other functions like do_bootm is. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-06-04image: Use fit_image_load() to load kernelSimon Glass
Use the new common code to load a kernel. The functionality should not change. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-04sandbox: Adjust bootm command to work with sandboxSimon Glass
Use map_sysmem() when converting from addresses to pointers, so that bootm can be used with sandbox. Signed-off-by: Simon Glass <sjg@chromium.org>
