path: root/common/cmd_bedbug.c
2014-06-11Use run_command_repeatable()Thomas Betker
Replace run_command() by run_command_repeatable() in places which depend on the return code to indicate repeatability. Signed-off-by: Thomas Betker <thomas.betker@rohde-schwarz.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-05-29Add cli_ prefix to readline functionsSimon Glass
This makes it clear where the code resides. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29move CLI prototypes to cli.h and add commentsSimon Glass
Move the CLI prototypes from common.h to cli.h as part of an effort to reduce the size of common.h. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-04-01Consolidate bool typeYork Sun
'bool' is defined in random places. This patch consolidates them into a single header file include/linux/types.h, using stdbool.h introduced in C99. All other #define, typedef and enum are removed. They are all consistent with true = 1, false = 0. Replace FALSE, False with false. Replace TRUE, True with true. Skip *.py, *.php, lib/* files. Signed-off-by: York Sun <yorksun@freescale.com>
2012-03-06Convert cmd_usage() calls in common to use a return valueSimon Glass
Change all files in common/ to use CMD_RET_USAGE instead of calling cmd_usage() directly. I'm not completely sure about this patch since the code since impact is small (100 byte or so on ARM) and it might need splitting into smaller patches. But for now here it is. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-06Stop using builtin_run_command()Simon Glass
Boards can select either the 'built-in' parser or the hush parser. We should not call builtin_run_command() if we are using the hush parser. We use run_command() instead, since it knows how to call the correct parser. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-06Rename run_command() to builtin_run_command()Simon Glass
The current run_command() is only one of the parsing options - the other is hush. We should not call run_command() when the hush parser is being used. So we rename this function to better explain its purpose. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-11-22common: move extern char console_buffer[] to common.hIgor Grinberg
Extract all extern declarations for console_buffer[] out of c files into the common.h header. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Frank Gottschling <fgottschling@eltec.de> Cc: Murray Jensen <Murray.Jensen@csiro.au>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-11-02Consolidate MAX/MIN definitionsAndy Fleming
There were several, now there is one (two if you count the lower-case versions). Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-11-20[BUILD] conditionally compile common/cmd_*.c in common/MakefileGrant Likely
Modify common/Makefile to conditionally compile the cmd_*.c files based on the board config. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/cmd_[af]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[a-f]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-04-10Add support for TQM862L moduleswdenk
