path: root/common/cmd_bdinfo.c
2014-05-12bd_info: remove bi_barudrate member from struct bd_infoMasahiro Yamada
gd->bd->bi_baudrate is a copy of gd->baudrate. Since baudrate is a common feature for all architectures, keep gd->baudrate only. It is true that bi_baudrate was passed to the kernel in that structure but it was a long time ago. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
2014-03-07powerpc: mpc8260: consolidate CONFIG_MPC8260 and CONFIG_8260Masahiro Yamada
Before this commit, CONFIG_MPC8260 and CONFIG_8260 were used mixed-up. All boards with mpc8260 cpu defined both of them: - CONFIG_MPC8260 was defined in board config headers and include/common.h - CONFIG_8260 was defined arch/powerpc/cpu/mpc8260/config.mk We do not need to have both of them. This commit keeps only CONFIG_MPC8260. This commit does: - Delete CONFIG_8260 and CONFIG_MPC8260 definition in config headers and include/common.h - Rename CONFIG_8260 to CONFIG_MPC8260 in arch/powerpc/cpu/mpc8260/config.mk. - Rename #ifdef CONFIG_8260 to #ifdef CONFIG_MPC8260 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de>
2014-02-07arc: bdinfo, image and arc-specific init functions declarations supportAlexey Brodkin
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Francois Bedard <fbedard@synopsys.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de>
2013-08-20ppc4xx: Remove support for PPC405CR CPUsMatthias Fuchs
This patch removes support for the APM 405CR CPU. This CPU is EOL and no board uses this chip. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2013-05-24common: Update cmd_bdinfo for PPCYork Sun
Add board detail function to print more individual board information. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-15Power: remove support for Freescale MPC8220Wolfgang Denk
The Freescale MPC8220 Power Architecture processors have long reached EOL; Freescale does not even list these any more on their web site. Remove the code to avoid wasting maitaining efforts on dead stuff. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com>
2013-02-04Merge branch 'master' of git://www.denx.de/git/u-boot-microblazeTom Rini
2013-02-04Only use fb_base if we have a displaySimon Glass
The ideal of having a frame buffer when there isn't a display is not that useful. Change the bdinfo command to expect this only when we have an lcd or video display. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04common: cmd_bdinfo: Fix compilation warning for microblazeMichal Simek
Fix one printf compilation warning in microblaze bdinfo part. Warning log: cmd_bdinfo.c: In function 'do_bdinfo': cmd_bdinfo.c:219:2: warning: format '%u' expects argument of type 'unsigned int', but argument 2 has type 'long unsigned int' [-Wformat] Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-02-04common: cmd_bdinfo: Fix bdinfo to show all MACs for Microblaze and ARMMichal Simek
- Show all ethernet MACs in the system. - Show current ethernet device Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-02-01arm: Move tlb_addr and tlb_size to arch_global_dataSimon Glass
Move these fields into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Address tlb_size in this patch as well] Signed-off-by: Tom Rini <trini@ti.com>
2012-10-19x86: Change global data baudrate to intSimon Glass
This doesn't need to be a long, so change it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-19nds32: Change global data baudrate to intSimon Glass
This doesn't need to be a long, so change it. Also adjust bi_baudrate to be unsigned. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-19mips: Change global data baudrate to intSimon Glass
2012-10-19blackfin: Change global data baudrate to intSimon Glass
2012-10-19arm: Change global data baudrate to intSimon Glass
This does not need to be a long, so change it. Also adjust bi_baudrate to be unsigned. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-19sparc: Change bi_baudrate and global data baudrate to intSimon Glass
These don't need to be longs, so change them. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-19powerpc: Change bi_baudrate and global data baudrate to intSimon Glass
2012-10-19openrisc: Change bi_baudrate and global data baudrate to intSimon Glass
2012-10-19nios2: Change bi_baudrate and global data baudrate to intSimon Glass
2012-10-19microblaze: Change bi_baudrate and global data baudrate to intSimon Glass
2012-10-19m68k: Change bi_baudrate and global data baudrate to intSimon Glass
2012-10-19avr32: Change bi_baudrate and global data baudrate to intSimon Glass
These don't need to be longs, so change them. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-19sh: Change bi_baudrate and global data baudrate to intSimon Glass
2012-10-15common: cmd_bdinfo: fix type of value in print_lnumDaniel Schwierzeck
This fixes a warning when compiling with ELDK-5.2.1 for MIPS64: cmd_bdinfo.c: In function 'print_lnum': cmd_bdinfo.c:56:2: warning: format '%llX' expects argument of type 'long long unsigned int', but argument 3 has type 'u64' [-Wformat] Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2012-09-18dm: sparc: common: Fixup cmd_bdinfo warningsMarek Vasut
cmd_bdinfo.c: In function ‘do_bdinfo’: cmd_bdinfo.c:220:9: warning: format ‘%lx’ expects argument of type ‘long unsigned int’, but argument 2 has type ‘int’ [-Wformat] cmd_bdinfo.c:222:9: warning: format ‘%lx’ expects argument of type ‘long unsigned int’, but argument 2 has type ‘int’ [-Wformat] cmd_bdinfo.c:224:9: warning: format ‘%lx’ expects argument of type ‘long unsigned int’, but argument 2 has type ‘int’ [-Wformat] cmd_bdinfo.c:226:9: warning: format ‘%lx’ expects argument of type ‘long unsigned int’, but argument 2 has type ‘int’ [-Wformat] cmd_bdinfo.c:228:9: warning: format ‘%lx’ expects argument of type ‘long unsigned int’, but argument 2 has type ‘int’ [-Wformat] Signed-off-by: Marek Vasut <marex@denx.de> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: u-boot-dm@lists.denx.de
2012-05-15net: punt bd->bi_ip_addrMike Frysinger
This field gets read in one place (by "bdinfo"), and we can replace that with getenv("ipaddr"). After all, the bi_ip_addr field is kept up-to-date implicitly with the value of the ipaddr env var. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-04-24cmd_bdinfo: display the address map size (32-bit vs. 36-bit)Timur Tabi
Some Freescale SOCs support 32-bit and 36-bit physical addressing, and U-Boot must be built to enable one or the other. Add this information to the bdinfo command. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-02-12davinci: add support for printing clock frequencyHadli, Manjunath
add support for printing various clock frequency info found in SOC such as ARM core frequency, DSP core frequency and DDR frequency as part of bdinfo command. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com>
2012-01-13openrisc: Add board info printout to cmd_bdinfoStefan Kristiansson
Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
2011-12-07Fix unused function in cmd_bdinfo.cSimon Glass
It is fine to use __maybe_unused instead of #ifdef, but we also need one for print_eth() since not all boards have Ethernet. This fixes this warning: cmd_bdinfo.c:39:13: warning: 'print_eth' defined but not used [-Wunused-function] Signed-off-by: Simon Glass <sjg@chromium.org>
2011-12-06cmd_bdinfo: simplify local static funcs a bitMike Frysinger
If we move the local funcs to the top of the file, and use the __maybe_unused define, we can drop a lot of ugly ifdef logic and duplicated prototypes. Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-11-29x86: Provide more configuration granularityGraeme Russ
Planned future ports requires more granularity for some options Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2011-10-22nds32: common bdinfo, bootm, image supportMacpaul Lin
Add support of NDS32 to common commands bdinfo, bootm, and image format. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-10-22cmd_bdinfo: replace print_str() with print_mhz()Timur Tabi
The print_str() helper function for cmd_bdinfo can print any string, but it is only used to print MHz values. Replace it with print_mhz() that takes a number and converts it to a string internally. Signed-off-by: Timur Tabi <timur@freescale.com>
2011-10-17sandbox: Add board info for architectureSimon Glass
This is required for the bdinfo command to work. Signed-off-by: Simon Glass <sjg@chromium.org> Fix syntax error. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-07-04armv7: rename cache related CONFIG flagsAneesh V
Replace the cache related CONFIG flags with more meaningful names. Following are the changes: CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF CONFIG_SYS_NO_ICACHE -> CONFIG_SYS_ICACHE_OFF CONFIG_SYS_NO_DCACHE -> CONFIG_SYS_DCACHE_OFF Signed-off-by: Aneesh V <aneesh@ti.com> V2: * Changed CONFIG_L2_OFF -> CONFIG_SYS_NO_L2CACHE V4: * Changed all three flags to the final names suggested as above and accordingly changed the commit message
2011-05-12cosmetic: cmd_bdinfo.c: clean up by using checkpatch.plMacpaul Lin
cmd_bdinfo.c: clean up with 2.6.38 checkpatch.pl Signed-off-by: Macpaul Lin <macpaul@andestech.com> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-12common/cmd_bdinfo.c: fix do_bdinfo() for AVR32Andreas Bießmann
This patch fixes following warning message: ---8<--- cmd_bdinfo.c:458: warning: initialization from incompatible pointer type --->8--- There was a prototype change in 54841ab50c20d6fa6c9cc3eb826989da3a22d934 for argv[] pointer type to const. This change was not made for AVR32 cause this code came in later by a merge. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2010-10-29Drop support for CONFIG_SYS_ARM_WITHOUT_RELOCWolfgang Denk
When this define was introduced, the idea was to provide a soft migration path for ARM boards to get adapted to the new relocation support. However, other recent changes led to a different implementation (ELF relocation), where this no longer works. By now CONFIG_SYS_ARM_WITHOUT_RELOC does not only not help any more, but it actually hurts because it obfuscates the actual code by sprinkling it with lots of dead and non-working debris. So let's make a clean cut and drop CONFIG_SYS_ARM_WITHOUT_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-07x86: Remove bi_env from do_bdinfoGraeme Russ
Commit 55e97429d1e6cf0976711e4e0f29ea924b7e5917 removed the definition from /arch/i386/include/asm/u-boot.h but not its usage in do_bdinfo()
2010-09-19ARM: add relocation supportHeiko Schocher
!! This breaks support for all arm boards !! To compile in old style, you must define CONFIG_SYS_ARM_WITHOUT_RELOC or you can compile with "CONFIG_SYS_ARM_WITHOUT_RELOC=1 ./MAKEALL board" !! This define will be removed soon, so convert your board to use relocation support Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de> Fix boot from NAND for non-ARM systems Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-19arm: get rid of bi_envHeiko Schocher
bi_env is nowhere used, so delete it! Signed-off-by: Heiko Schocher <hs@denx.de> similar patch posted from Dirk Behme Tue Jul 27 18:36:09 CEST 2010 http://lists.denx.de/pipermail/u-boot/2010-July/074542.html
2010-09-13x86: Add do_bdinfo()Graeme Russ
x86 failed to compile with a message "a case for this architecture does not exist!" - Add do_bdinfo() for this arch
2010-08-30sh: Add support do_bdinfo functionNobuhiro Iwamatsu
SH did not support do_bdinfo fuction. This code based avr32 stuff. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2010-06-29Fix #if chain and added AVR32 case in cmd_bdinfo.cReinhard Meyer
AVR32 case was missing in cmd_bdinfo, resulting in compiler warning (bd->bi_baudrate declared unsigned int at AVR32, but printf used %d) At the same time slightly reordered #if #elif #endif to make ARM one of the cases and not an extra case surrounding all others Signed-off-by: Reinhard Meyer <info@emk-elektronik.de> Tested-by: Andreas Bießmann <biessmann@corscience.de>
2010-05-28nios: remove nios-32 archThomas Chou
The nios-32 arch is obsolete and broken. So it is removed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
