path: root/common/cmd_bdinfo.c
2012-04-24cmd_bdinfo: display the address map size (32-bit vs. 36-bit)Timur Tabi
Some Freescale SOCs support 32-bit and 36-bit physical addressing, and U-Boot must be built to enable one or the other. Add this information to the bdinfo command. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-02-12davinci: add support for printing clock frequencyHadli, Manjunath
add support for printing various clock frequency info found in SOC such as ARM core frequency, DSP core frequency and DDR frequency as part of bdinfo command. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com>
2012-01-13openrisc: Add board info printout to cmd_bdinfoStefan Kristiansson
Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
2011-12-07Fix unused function in cmd_bdinfo.cSimon Glass
It is fine to use __maybe_unused instead of #ifdef, but we also need one for print_eth() since not all boards have Ethernet. This fixes this warning: cmd_bdinfo.c:39:13: warning: 'print_eth' defined but not used [-Wunused-function] Signed-off-by: Simon Glass <sjg@chromium.org>
2011-12-06cmd_bdinfo: simplify local static funcs a bitMike Frysinger
If we move the local funcs to the top of the file, and use the __maybe_unused define, we can drop a lot of ugly ifdef logic and duplicated prototypes. Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-11-29x86: Provide more configuration granularityGraeme Russ
Planned future ports requires more granularity for some options Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2011-10-22nds32: common bdinfo, bootm, image supportMacpaul Lin
Add support of NDS32 to common commands bdinfo, bootm, and image format. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-10-22cmd_bdinfo: replace print_str() with print_mhz()Timur Tabi
The print_str() helper function for cmd_bdinfo can print any string, but it is only used to print MHz values. Replace it with print_mhz() that takes a number and converts it to a string internally. Signed-off-by: Timur Tabi <timur@freescale.com>
2011-10-17sandbox: Add board info for architectureSimon Glass
This is required for the bdinfo command to work. Signed-off-by: Simon Glass <sjg@chromium.org> Fix syntax error. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-07-04armv7: rename cache related CONFIG flagsAneesh V
Replace the cache related CONFIG flags with more meaningful names. Following are the changes: CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF CONFIG_SYS_NO_ICACHE -> CONFIG_SYS_ICACHE_OFF CONFIG_SYS_NO_DCACHE -> CONFIG_SYS_DCACHE_OFF Signed-off-by: Aneesh V <aneesh@ti.com> V2: * Changed CONFIG_L2_OFF -> CONFIG_SYS_NO_L2CACHE V4: * Changed all three flags to the final names suggested as above and accordingly changed the commit message
2011-05-12cosmetic: cmd_bdinfo.c: clean up by using checkpatch.plMacpaul Lin
cmd_bdinfo.c: clean up with 2.6.38 checkpatch.pl Signed-off-by: Macpaul Lin <macpaul@andestech.com> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-12common/cmd_bdinfo.c: fix do_bdinfo() for AVR32Andreas Bießmann
This patch fixes following warning message: ---8<--- cmd_bdinfo.c:458: warning: initialization from incompatible pointer type --->8--- There was a prototype change in 54841ab50c20d6fa6c9cc3eb826989da3a22d934 for argv[] pointer type to const. This change was not made for AVR32 cause this code came in later by a merge. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2010-10-29Drop support for CONFIG_SYS_ARM_WITHOUT_RELOCWolfgang Denk
When this define was introduced, the idea was to provide a soft migration path for ARM boards to get adapted to the new relocation support. However, other recent changes led to a different implementation (ELF relocation), where this no longer works. By now CONFIG_SYS_ARM_WITHOUT_RELOC does not only not help any more, but it actually hurts because it obfuscates the actual code by sprinkling it with lots of dead and non-working debris. So let's make a clean cut and drop CONFIG_SYS_ARM_WITHOUT_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-07x86: Remove bi_env from do_bdinfoGraeme Russ
Commit 55e97429d1e6cf0976711e4e0f29ea924b7e5917 removed the definition from /arch/i386/include/asm/u-boot.h but not its usage in do_bdinfo()
2010-09-19ARM: add relocation supportHeiko Schocher
!! This breaks support for all arm boards !! To compile in old style, you must define CONFIG_SYS_ARM_WITHOUT_RELOC or you can compile with "CONFIG_SYS_ARM_WITHOUT_RELOC=1 ./MAKEALL board" !! This define will be removed soon, so convert your board to use relocation support Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de> Fix boot from NAND for non-ARM systems Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-19arm: get rid of bi_envHeiko Schocher
bi_env is nowhere used, so delete it! Signed-off-by: Heiko Schocher <hs@denx.de> similar patch posted from Dirk Behme Tue Jul 27 18:36:09 CEST 2010 http://lists.denx.de/pipermail/u-boot/2010-July/074542.html
2010-09-13x86: Add do_bdinfo()Graeme Russ
x86 failed to compile with a message "a case for this architecture does not exist!" - Add do_bdinfo() for this arch
2010-08-30sh: Add support do_bdinfo functionNobuhiro Iwamatsu
SH did not support do_bdinfo fuction. This code based avr32 stuff. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2010-06-29Fix #if chain and added AVR32 case in cmd_bdinfo.cReinhard Meyer
AVR32 case was missing in cmd_bdinfo, resulting in compiler warning (bd->bi_baudrate declared unsigned int at AVR32, but printf used %d) At the same time slightly reordered #if #elif #endif to make ARM one of the cases and not an extra case surrounding all others Signed-off-by: Reinhard Meyer <info@emk-elektronik.de> Tested-by: Andreas Bießmann <biessmann@corscience.de>
2010-05-28nios: remove nios-32 archThomas Chou
The nios-32 arch is obsolete and broken. So it is removed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2010-03-24fix cmd_bdinfo.c:354: warning: 'print_eth' defined but not usedPhilippe De Muyter
This fixes the following warnings when running MAKEALL for coldfire : cmd_bdinfo.c:354: warning: 'print_eth' defined but not used Signed-off-by: Philippe De Muyter <phdm at macqel.be>
2010-03-11PPC: Record U-Boot's relocated address in RAM and show in bdinfo.Richard Retanubun
This patch uses gd->relocaddr variable to store uboot's relocated address in RAM and shows it in bdinfo command. This patch moves CONFIG_AMIGAONEG3SE style copying of the address in board_init_f to just before relocation is actually done. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com> Tested-by: Detlev Zundel <dzu@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-29ARM: fix warning: 'print_eth' defined but not usedWolfgang Denk
This warning got issued for all ARM systems that don't have CONFIG_CMD_NET enabled. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-20bdinfo: get mac address from environmentMike Frysinger
Add a new print_eth() function to automate the eth*addr env var acquisition and display. Affects all arches. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Scott McNutt <smcnutt@psyent.com> CC: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> CC: Michal Simek <monstr@seznam.cz> CC: Daniel Hellstrom <daniel@gaisler.com> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20convert print_IPaddr() to %pI4Mike Frysinger
Now that our printf functions support the %pI4 modifier like the kernel, let's drop the inflexible print_IPaddr() function and covert over to the %pI4 modifier. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-02-06Coldfire: cmd_bdinfo cleanupRichard Retanubun
CONFIG_M68K bdinfo cleanup: Fixed compiler warning about baudrate printing. format '%d' expects type 'int', but argument 2 has type 'long unsigned int'. Added printing of "cpufreq" Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-23Blackfin: use common strmhz() in system outputMike Frysinger
2008-10-18Adds two more ethernet interface to 83xxrichardretanubun
Added as a convenience for other platforms that uses MPC8360 (has 8 UCC). Six eth interface is chosen because the platform I am using combines UCC1&2 and UCC3&4 as 1000 Eth and the other four UCCs as 10/100 Eth. Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-06Fix merge problemsStefan Roese
2008-07-06ppc4xx: Rename CONFIG_XILINX_ML300 to CONFIG_XILINX_405Michal Simek
This change helps with better handling with others Xilinx based platform. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Stefan Roese <sr@denx.de>
2008-06-12Change bd/gd memsize/ram_size to be phys_size_t.Becky Bruce
Currently, both are defined as an unsigned long, but should be phys_size_t. This should result in no real change, since phys_size_t is currently an unsigned long for all the default configs. Also add print_lnum to cmd_bdinfo to deal with the potentially wider memsize. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-04-08SPARC: added SPARC board information to the command bdinfo.Daniel Hellstrom
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-02-15Merge branch 'master' of git://www.denx.de/git/u-boot-blackfinWolfgang Denk
Conflicts: Makefile doc/README.standalone Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-02-04add Blackfin-specific bdinfo commandMike Frysinger
2008-02-04ARM: Display Ethernet info in do_bdinfo only if CONFIG_CMD_NET is definedHebbar
Add ifdef to bdinfo command to display ethernet information only if CONFIG_CMD_NET is defined for arm modules. Signed-off-by: K R Gururaja Hebbar <gururajakr@sanyo.co.in>
2008-01-10Nios2: remove common/cmd_bdinfo.c unused variable.Jean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2007-11-20[BUILD] conditionally compile common/cmd_*.c in common/MakefileGrant Likely
Modify common/Makefile to conditionally compile the cmd_*.c files based on the board config. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-08-18ColdFire: Fix some remaining problems with CFG_CMD_Stefan Roese
2007-08-16ColdFire: Add M54455EVB for MCF5445xTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-08-16ColdFire: MCF5329 Update and cleanupTsiChungLiew
2007-08-15Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-07-10common/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-08common/cmd_[af]*: Remove obsolete references to CONFIG_COMMANDS.Jon Loeliger
2007-07-04common/cmd_[a-f]* : Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
