path: root/common/cmd_ambapp.c
2016-01-25Move all command code into its own directorySimon Glass
There are a lot of unrelated files in common, including all of the commands. Moving them into their own directory makes them easier to find and is more logical. Some commands include non-command code, such as cmd_scsi.c. This should be sorted out at some point so that the function can be enabled with or without the associated command. Unfortunately, with m68k I get this error: m68k: + M5329AFEE +arch/m68k/cpu/mcf532x/start.o: In function `_start': +arch/m68k/cpu/mcf532x/start.S:159:(.text+0x452): relocation truncated to fit: R_68K_PC16 against symbol `board_init_f' defined in .text.board_init_f section in common/built-in.o I hope someone can shed some light on what this means. I hope it isn't depending on the position of code in the image. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-11-13sparc: leon3: Moved GRLIB core header files to common include/grlib directoryDaniel Hellstrom
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2015-11-13sparc: leon3: Reimplemented AMBA Plug&Play scanning routines.Daniel Hellstrom
2010-08-09various cmd_* files: fixed layout a little bitFrans Meulenbroeks
Most of the files have U_BOOT_CMD on a separate line, but a few didn't and had the first line on the same line as U_BOOT_CMD. This changes these files by adding a line break and a tab Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-04-13Coding Style cleanup; update CHANGELOGWolfgang Denk
2008-04-08SPARC/LEON3: Added AMBA Bus Plug&Play information print command (ambapp). It ↵Daniel Hellstrom
can print available cores (type: AHB Master, AHB Slave, APB Slave), their address ranges, IRQ number and version. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
