path: root/common/cli_readline.c
2016-08-20common: cli_readline: Improve command line editingJames Byrne
This improves the cread_line() function so that it will correctly process the 'Home', 'End', 'Delete' and arrow key escape sequences produced by various terminal emulators. This makes command line editing a more pleasant experience. The previous code only supported the cursor keys and the 'Home' key, and only for certain terminal emulator configurations. This adds support for the 'End and 'Delete' keys, and recognises a wider range of escape sequences. For example, the left arrow key can be 'ESC O D' instead of 'ESC [ D', and the 'Home' key can be 'ESC [ H', 'ESC O H', 'ESC 1 ~' or 'ESC 7 ~', depending on what terminal emulator you use and how it is configured. Signed-off-by: James Byrne <james.byrne@origamienergy.com> Changes for v2 - Explicitly initialize variable to avoid spurious compiler warning. Changes for v3 - Remove unnecessary setting of 'act' to ESC_REJECT (now its default value).
2015-08-12spl, common, serial: build SPL without serial supportHeiko Schocher
This patch enables building SPL without CONFIG_SPL_SERIAL_SUPPORT support. Signed-off-by: Heiko Schocher <hs@denx.de> [trini: Ensure we build arch/arm/imx-common on mx28] Signed-off-by: Tom Rini <trini@konsulko.com>
2014-05-29Move bootretry code into bootretry.c and clean upSimon Glass
This code is only used by one board, so it seems a shame to clutter up the readline code with it. Move it into its own file. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Add cli_ prefix to readline functionsSimon Glass
This makes it clear where the code resides. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Split out simple parser and readline into separate filesSimon Glass
It doesn't make sense to have the simple parser and the readline code all in main. Split them out into separate files. Signed-off-by: Simon Glass <sjg@chromium.org>
