path: root/common/cli_hush.c
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-08hush: Add rudimentary support for PS1 and PS2Marek Vasut
Add trivial support for changing the U-Boot command prompt string by setting PS1 and PS2 environment variables. Only static variables are supported. Signed-off-by: Marek Vasut <marex@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-08hush: Pull out U-Boot prompt display and read functionalityMarek Vasut
Pull the code which displays U-Boot prompt and reads the command line into a separate function. No functional change. Signed-off-by: Marek Vasut <marex@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-12-12common: cli_hush: Fix up simple typoNishanth Menon
Correct the spelling for character.. Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-12-05common: cli_hush: avoid memory leakPeng Fan
Need to free memory avoid memory leak, when error. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com>
2015-12-05common: cli_hush: avoid dead codePeng Fan
Condition "(value == NULL && ++value == NULL)" actully will always return false. Instead, use condition "(value == NULL || *(value + 1) == 0)" to detect such expression "c=". To "c=", *(value + 1) is 0, so directly return -1, but not continue. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Rabin Vincent <rabin@rab.in> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-11-19Move console definitions into a new console.h fileSimon Glass
The console includes a global variable and several functions that are only used by a small subset of U-Boot files. Before adding more functions, move the definitions into their own header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-24Revert "hush: fix segfault on syntax error"Rabin Vincent
128059b92 ("hush: fix segfault on syntax error") attempted to fix a segfault on syntax errors, but it broke Ctrl-C handling, and the assumption that it made, that rcode could not be -1, is incorrect. Revert this change. Reported-by: Stephen Warren <swarren@wwwdotorg.org> Reported-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Rabin Vincent <rabin@rab.in>
2014-11-07hush: make run_command() return an error on parsing failureRabin Vincent
run_command() returns success even if the command had a syntax error; correct this behaviour. Signed-off-by: Rabin Vincent <rabin@rab.in> Acked-by: Simon Glass <sjg@chromium.org)
2014-11-07hush: fix segfault on syntax errorRabin Vincent
Hush segfaults if it sees a syntax error while attempting to parse a command: $ ./u-boot -c "'" ... syntax error Segmentation fault (core dumped) This is due to a NULL pointer dereference of in_str->p in static_peek(). The problem is that the exit condition for the loop in parse_stream_outer() checks for rcode not being -1, but rcode is only ever 0 or 1. Signed-off-by: Rabin Vincent <rabin@rab.in> Acked-by: Simon Glass <sjg@chromium.org) Tested-by: Simon Glass <sjg@chromium.org)
2014-11-07hush: return consistent codes from run_command()Rabin Vincent
Attempting to run: - an empty string - a string with just spaces returns different error codes, 1 for the empty string and 0 for the string with just spaces. Make both of them return 0 for consistency. Signed-off-by: Rabin Vincent <rabin@rab.in> Acked-by: Simon Glass <sjg@chromium.org)
2014-10-27cli: hush: Adjust 'run' command to run each line of the env varSimon Glass
The run command treats each argument an an environment variable. It gets the value of each variable and executes it as a command. If an environment variable contains a newline and the hush cli is used, it is supposed to execute each line one after the other. Normally a newline signals to hush to exit - this is used in normal command line entry - after a command is entered we want to return to allow the user to enter the next one. But environment variables obviously need to execute to completion. Add a special case for the execution of environment variables which continues when a newline is seen, and add a few tests to check this behaviour. Note: it's not impossible that this may cause regressions in other areas. I can't think of a case but with any change of behaviour with limited test coverage there is always a risk. From what I can tell this behaviour has been around since at least U-Boot 2011.03, although this pre-dates sandbox and I have not tested it on real hardware. Reported-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-11common/cli_hush.c: remove unnecessary double bracesJeroen Hofstee
Clang interpretes an if condition like "if ((a = b) == NULL) as it tries to assign a value in a statement. Hence if you do "if ((something)) it warns you that you might be confused. Hence drop the double braces for plane if statements. Simon Glass <sjg@chromium.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-06-05Fix hush to give the correct return code for a simple commandSimon Glass
When a simple command like 'false' is provided, hush should return the result of that command. However, hush only does this if the FLAG_EXIT_FROM_LOOP flag is provided. Without this flag, hush will happily execute the empty string command immediate after 'false' and then return a success code. This behaviour does not seem very useful, and requiring the flag also seems wrong, since it means that hush will execute only the first command in a sequence. Add a check for empty string and fall out of the loop in that case. That at least fixes the simple command case. This is a change in behaviour but it is unlikely that the old behaviour would be considered correct in any case. Reported-by: Stefan Herbrechtsmeier <stefan@herbrechtsmeier.net> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Rename bootretry functions and remove #ifdefsSimon Glass
Add a bootretry_ prefix to these two functions, and remove the need for the #ifdef around everything (it moves to the Makefile). Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Move bootretry code into bootretry.c and clean upSimon Glass
This code is only used by one board, so it seems a shame to clutter up the readline code with it. Move it into its own file. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Add cli_ prefix to readline functionsSimon Glass
This makes it clear where the code resides. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29move CLI prototypes to cli.h and add commentsSimon Glass
Move the CLI prototypes from common.h to cli.h as part of an effort to reduce the size of common.h. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Rename hush to cli_hushSimon Glass
Hush is a command-line interpreter, so rename it to make that clearer. Signed-off-by: Simon Glass <sjg@chromium.org>
