path: root/common/cli.c
2019-04-26main: add new bootstage ID for entering cli loopHeiko Schocher
adding a new bootstage ID: BOOTSTAGE_ID_ENTER_CLI_LOOP Signed-off-by: Heiko Schocher <hs@denx.de>
2019-01-26dfu: Remove dependency on HUSH parser in SPLAndrew F. Davis
CLI support with the HUSH parser is not currently SPL safe due to it's use of realloc. That function is not defined for SPLs that use SYS_MALLOC_SIMPLE. CLI support can be built in to SPL and some functions do work, but use of some like run_command() will cause build to fail. When no SPL code calls this function build works as the compiler removes this unreachable code so the unresolved symbols are ignored. If DFU support is enabled in SPL then MMU DFU support may get brought in also, this code does make a call to run_command() causing build to fail if the HUSH parser is not built-in. To break this odd and unneeded dependency chain we use CONFIG_IS_ENABLED where appropriate to prevent calls into HUSH code from SPL. This also removes our need to pull in the rather unrelated source file when SPL_DFU is defined. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-24hush: complete renaming CONFIG_SYS_HUSH_PARSER to CONFIG_HUSH_PARSERMasahiro Yamada
There is no more define of CONFIG_SYS_HUSH_PARSER. Rename some remaining references and drop the backward compatible Kconfig entry. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-04common: cli: Fix typo CONFIG_CMDINE -> CONFIG_CMDLINEStefan Roese
Patch f8bb6964 (Drop command-processing code when CONFIG_CMDLINE is disabled) introduced a small typo. This patch fixes it and unbreaks all boards again that don't have the Hush parser enabled. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com>
2016-04-01Drop command-processing code when CONFIG_CMDLINE is disabledSimon Glass
Command parsing and processing code is not needed when the command line is disabled. Remove this code in that case. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-04common: cli: avoid memory leakPeng Fan
Whether CONFIG_SYS_HUSH_PARSER is defined or not, should always check to free 'buff' to avoid memory leak. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org>
2015-11-19Move console definitions into a new console.h fileSimon Glass
The console includes a global variable and several functions that are only used by a small subset of U-Boot files. Before adding more functions, move the definitions into their own header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-18of: clean up OF_CONTROL ifdef conditionalsMasahiro Yamada
We have flipped CONFIG_SPL_DISABLE_OF_CONTROL. We have cleansing devices, $(SPL_) and CONFIG_IS_ENABLED(), so we are ready to clear away the ugly logic in include/fdtdec.h: #ifdef CONFIG_OF_CONTROL # if defined(CONFIG_SPL_BUILD) && !defined(SPL_OF_CONTROL) # define OF_CONTROL 0 # else # define OF_CONTROL 1 # endif #else # define OF_CONTROL 0 #endif Now CONFIG_IS_ENABLED(OF_CONTROL) is the substitute. It refers to CONFIG_OF_CONTROL for U-boot proper and CONFIG_SPL_OF_CONTROL for SPL. Also, we no longer have to cancel CONFIG_OF_CONTROL in include/config_uncmd_spl.h and scripts/Makefile.spl. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-27cli: hush: Adjust 'run' command to run each line of the env varSimon Glass
The run command treats each argument an an environment variable. It gets the value of each variable and executes it as a command. If an environment variable contains a newline and the hush cli is used, it is supposed to execute each line one after the other. Normally a newline signals to hush to exit - this is used in normal command line entry - after a command is entered we want to return to allow the user to enter the next one. But environment variables obviously need to execute to completion. Add a special case for the execution of environment variables which continues when a newline is seen, and add a few tests to check this behaviour. Note: it's not impossible that this may cause regressions in other areas. I can't think of a case but with any change of behaviour with limited test coverage there is always a risk. From what I can tell this behaviour has been around since at least U-Boot 2011.03, although this pre-dates sandbox and I have not tested it on real hardware. Reported-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-11Add run_command_repeatable()Thomas Betker
run_command() returns 0 on success and 1 on error. However, there are some invocations which expect 0 or 1 for success (not repeatable or repeatable) and -1 for error; add run_command_repeatable() for this purpose. Signed-off-by: Thomas Betker <thomas.betker@rohde-schwarz.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-05-29main: Make the execution path a little clearer in main.cSimon Glass
bootdelay_process() never returns in some circumstances, whichs makes the control flow confusing. Change it so that the decision about how to execute the boot command is made in the main_loop() code, so it is easier to follow. Move CLI stuff to cli.c. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29main: Hide the hush/simple details inside cli.cSimon Glass
Move these details from main (which doesn't care which parser is used) to cli.c where they belong. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Move command line API into cli.cSimon Glass
We now have a single entry point to the CLI, whether simple or hush. Put this in its own file. Signed-off-by: Simon Glass <sjg@chromium.org>
