2013-05-13 | bootstage: Allow marking a particular line of code | Simon Glass | |
Add a function which allows a (file, function, line number) to be marked in bootstage. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> | |||
2013-05-13 | bootstage: Copy bootstage strings post-relocation | Doug Anderson | |
Any pointers to name strings that were passed to bootstage_mark_name() pre-relocation should be copied post-relocation so that they don't get trashed as the original location of U-Boot is re-used for other purposes. This change introduces a new API call that should be called from board_init_r() after malloc has been initted on any board that uses bootstage. Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> | |||
2012-10-03 | bootstage: Add feature to stash/unstash bootstage info | Simon Glass | |
It is useful to be able to write the bootstage information to memory for use by a later utility, or the Linux kernel. Provide a function to do this as well as a function to read bootstage information back and incorporate it into the current table. This also makes it possible for U-Boot to chain to another U-Boot and pass on its bootstage information. Signed-off-by: Simon Glass <sjg@chromium.org> | |||
2012-10-02 | bootstage: Store boot timings in device tree | Simon Glass | |
Add an option, CONFIG_BOOTSTAGE_FDT to pass boot timings to the kernel in the device tree, if available. To use this, you must have CONFIG_OF_LIBFDT defined. Signed-off-by: Simon Glass <sjg@chromium.org> | |||
2012-10-02 | bootstage: Add time accumulation feature | Simon Glass | |
Sometimes we want to add up the amount of time spent in a particular activity when it is happening in a number of discrete chunks. Add bootstage_start() to mark the start of an acitivity and bootstage_accum() to accumulate the time since the last start. Calling these function in pairs results in the accumulated time being collected. Signed-off-by: Simon Glass <sjg@chromium.org> | |||
2012-10-02 | bootstage: Export bootstage_add_record() function | Simon Glass | |
This function is not static, but not exported either. Add a prototype in the header file and move the required enum to the header also. Signed-off-by: Simon Glass <sjg@chromium.org> | |||
2012-04-10 | Move bootstage timer out of lib/time.c | Simon Glass | |
The standalone example does not have get_timer() defined, so we cannot rely on it being available. Move the timer function into boootstage.c to avoid this problem. This corrects a build breakage for the standalone example on some boards. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu> | |||
2012-03-18 | bootstage: Implement core microsecond boot time measurement | Simon Glass | |
This defines the basics of a new boot time measurement feature. This allows logging of very accurate time measurements as the boot proceeds, by using an available microsecond counter. To enable the feature, define CONFIG_BOOTSTAGE in your board config file. Also available is CONFIG_BOOTSTAGE_REPORT which will cause a report to be printed just before handing off to the OS. Most IDs are not named at this stage. For that I would first like to renumber them all. Timer summary in microseconds: Mark Elapsed Stage 0 0 reset 205,000 205,000 board_init_f 6,053,000 5,848,000 bootm_start 6,053,000 0 id=1 6,058,000 5,000 id=101 6,058,000 0 id=100 6,061,000 3,000 id=103 6,064,000 3,000 id=104 6,093,000 29,000 id=107 6,093,000 0 id=106 6,093,000 0 id=105 6,093,000 0 id=108 7,089,000 996,000 id=7 7,089,000 0 id=15 7,089,000 0 id=8 7,097,000 8,000 start_kernel Signed-off-by: Simon Glass <sjg@chromium.org> |
