path: root/common/bootm_os.c
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-08-28bootvx_fdt: fix missing 'fdt_fixup_ethernet(...)' on vxWorks bootHannes Schmelzer
Before commit 26d6119 (fdt: Move fdt_fixup_ethernet to a common place) the fdt_fixup_ethernet(...) was called during do_bootvx_fdt(...). Afterwards the only (common) place for this fixup is during image_setup_libfdt(...) and this is only called, at least on ARM platform, from image_setup_linux(...). All this ends up in the fact, that the fdt_fixup_ethernet(...) is only called on booting a linux image and not on booting a vxWorks image. We fix this with adding the fdt_fixup_ethernet(...) call again to do_bootvx_fdt(...) Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename common functions related to setenv()Simon Glass
We are now using an env_ prefix for environment functions. Rename these commonly used functions, for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-12powerpc, 8xx: remove support for 8xxHeiko Schocher
There was for long time no activity in the 8xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8xx, so remove it (with a heavy heart, knowing that I remove here the root of U-Boot). Signed-off-by: Heiko Schocher <hs@denx.de>
2017-05-01fdt: Move fdt_fixup_ethernet to a common placeTom Rini
With 3f66149d9fb4 we no longer have a common call fdt_fixup_ethernet. This was fine to do on PowerPC as they largely had calls already in ft_cpu_fixup. On ARM however we largely relied on this call. Rather than introduce a large number of changes to ft_cpu_fixup / ft_board_fixup we recognize that this is a common enough call that we should be doing it in a central location. Do it early enough that we can do any further updates in ft_cpu_fixup / ft_board_fixup. Cc: Gerd Hoffmann <kraxel@redhat.com> Cc: Chen-Yu Tsai <wens@csie.org> Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: Thomas Chou <thomas@wytron.com.tw> (maintainer:NIOS) Cc: York Sun <york.sun@nxp.com> (maintainer:POWERPC MPC85XX) Cc: Stefan Roese <sr@denx.de> (maintainer:POWERPC PPC4XX) Cc: Simon Glass <sjg@chromium.org> Cc: Joakim Tjernlund <Joakim.Tjernlund@infinera.com> Fixes: 3f66149d9fb4 ("Remove extra fdt_fixup_ethernet() call") Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-20bootm: qnx: Disable data cache before booting QNX imageEmmanuel Vadot
Instead of disabling the data cache in the bootelf command, disabling it in the do_bootm_qnxelf function. Some ELF binary might want the cache enabled. Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com>
2016-07-14sandbox: Don't exit when bootm completesSimon Glass
At present sandbox exits when the 'bootm' command completes, since it is not actually able to run the OS that is loaded. Normally 'bootm' failure is considered a fatal error in U-Boot. However this is annoying for tests, which may want to examine the state after a test is complete. In any case there is a 'reset' command which can be used to exit, if required. Change the behaviour to return normally from the 'bootm' command on sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Teddy Reed <teddy.reed@gmail.com>
2016-05-27cosmetic: debug: Replace #ifdef DEBUG with debug() macroLukasz Majewski
Replace #ifdef DEBUG with dedicated debug() macro. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl>
2015-12-12VxWorks: fixup MAC address for VxWorksMiao Yan
VxWorks 7 kernels retrieve 'local-mac-addr' from dtb and use that for NIC MAC address. As a result, when booting the same kernel image on multiple boards, there will be address conflicts. So fixup MAC address when booting VxWorks 7 kernels Signed-off-by: Miao Yan <yanmiaobest@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-01-14image: bootm: Add OpenRTOS image typeMarek Vasut
Add separate image type for the Wittenstein OpenRTOS . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-18common: bootm_os: make arch_preboot_os __weakJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-06-19bootm: Split out code from cmd_bootm.cSimon Glass
This file has code in three different categories: - Command processing - OS-specific boot code - Locating images and setting up to boot Only the first category really belongs in a file called cmd_bootm.c. Leave the command processing code where it is. Split out the OS-specific boot code into bootm_os.c. Split out the other code into bootm.c Header files and extern declarations are tidied but otherwise no code changes are made, to make it easier to review. Signed-off-by: Simon Glass <sjg@chromium.org>
