path: root/common/bootm_os.c
2015-01-14image: bootm: Add OpenRTOS image typeMarek Vasut
Add separate image type for the Wittenstein OpenRTOS . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-18common: bootm_os: make arch_preboot_os __weakJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-06-19bootm: Split out code from cmd_bootm.cSimon Glass
This file has code in three different categories: - Command processing - OS-specific boot code - Locating images and setting up to boot Only the first category really belongs in a file called cmd_bootm.c. Leave the command processing code where it is. Split out the OS-specific boot code into bootm_os.c. Split out the other code into bootm.c Header files and extern declarations are tidied but otherwise no code changes are made, to make it easier to review. Signed-off-by: Simon Glass <sjg@chromium.org>
