path: root/common/board_r.c
2015-05-10ppc4xx: Remove sc3 boardStefan Roese
As this board seems to be unmaintained for quite some time, and its not moved to the generic board ingrastructure, lets remove it. This will also enable us to remove the CONFIG_AUTOBOOT_DELAY_STR2 and CONFIG_AUTOBOOT_STOP_STR2 macros, as this sc3 board is the only one using one of this macros. A removal patch will follow soon. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Juergen Beisert <jbeisert@eurodsn.de> Acked-by: Heiko Schocher <hs@denx.de>
2015-04-30x86: Allow CPUs to be set up after relocationSimon Glass
This permits init of additional CPU cores after relocation and when driver model is ready. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-04-23armv8/fsl-lsch3: Update early MMU tableYork Sun
During booting, IFC is mapped to low region. After booting up, IFC is remapped to high region for larger space. The environmental variables are also stored at high region. In order to read the variables during booting, a virtual mapping is required. Cache was enabled for entire IFC space before. Actually the first two entries are big enough (4MB) to cover the boot code and environmental variables. Remove extra entries. Move OCRAM entry out of ifdef. Signed-off-by: York Sun <yorksun@freescale.com>
2015-04-18dm: x86: spi: Convert ICH SPI driver to driver modelSimon Glass
Convert this driver over to use driver model. Since all x86 platforms use it, move x86 to use driver model for SPI and SPI flash. Adjust all dependent code and remove the old x86 spi_init() function. Note that this does not make full use of the new PCI uclass as yet. We still scan the bus looking for the device. It should move to finding its details in the device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Remove the bd* parameter from net stack functionsJoe Hershberger
This value is not used by the network stack and is available in the global data, so stop passing it around. For the one legacy function that still expects it (init op on old Ethernet drivers) pass in the global pointer version directly to avoid changing that interface. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (Trival fix to remove an unneeded variable declaration in 4xx_enet.c)
2015-04-18common: Make sure arch-specific map_sysmem() is definedJoe Hershberger
In the case where the arch defines a custom map_sysmem(), make sure that including just mapmem.h is sufficient to have these functions as they are when the arch does not override it. Also split the non-arch specific functions out of common.h Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-16dm: pci: Add a uclass for PCISimon Glass
Add a uclass for PCI controllers and a generic one for PCI devices. Adjust the 'pci' command and the existing PCI support to work with this new uclass. Keep most of the compatibility code in a separate file so that it can be removed one day. TODO: Add more header file comments to the new parts of pci.h Signed-off-by: Simon Glass <sjg@chromium.org>
2015-03-09common/board_r: Restore non-cached memory setupJan Kiszka
This fixes a regression of e310b93ec1, affecting Ethernet on the Jetson TK1, e.g. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
2015-03-05m68k: Add generic board support for MCF547X/8X and MCF5445XAlison Wang
This patch adds generic board support for MCF547X/8X and MCF5445X. It is based on the patch about common generic board support for M68K architecture sent by Angelo. Signed-off-by: Alison Wang <alison.wang@freescale.com>
2015-03-05m68k: add generic-board supportangelo@sysam.it
Add generic-board support for the m68k architecture. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2015-02-17avr32: add generic board supportAndreas Bießmann
2015-02-17common/board_r: allocate bootparamsAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-09microblaze: Move architecture to use generic board initMichal Simek
Compile code with -fPIC to get GOT. Do not build SPL with fPIC because it increasing SPL size for nothing. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-02-09common/board_r: manual relocation for cmd tableAndreas Bießmann
This is required for architectures still need manual relocation like avr32, mk68 and others. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Michal Simek <michal.simek@xilinx.com>
2015-01-29generic-board: show model name in board_init_f() tooMasahiro Yamada
The common/board_r.c has show_model_r() to display the model name if the DTB has a "model" property. It sounds useful to have a similar function in common/board_f.c too because most of the boards show their board name before relocation. Instead of implementing the same function in both common/board_f.c and common/board_r.c, let's split it up into common/show_board_info.c. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-18ARM: Implement non-cached memory supportThierry Reding
Implement an API that can be used by drivers to allocate memory from a pool that is mapped uncached. This is useful if drivers would otherwise need to do extensive cache maintenance (or explicitly maintaining the cache isn't safe). The API is protected using the new CONFIG_SYS_NONCACHED_MEMORY setting. Boards can set this to the size to be used for the non-cached area. The area will typically be right below the malloc() area, but architectures should take care of aligning the beginning and end of the area to honor any mapping restrictions. Architectures must also ensure that mappings established for this area do not overlap with the malloc() area (which should remain cached for improved performance). While the API is currently only implemented for ARM v7, it should be generic enough to allow other architectures to implement it as well. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-08Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2014-12-08powerpc: mpc8xx: remove hermes board supportMasahiro Yamada
This board sprinkles #ifdef(CONFIG_HERMES) over various global files such as include/common.h, common/board_r.c, common/cmd_bdinfo.c. Let's zap such an ill-behaved board. It has not been converted to generic board yet and mpc8xx is old enough. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2014-12-08flash: do not fail even if flash_size is zeroMasahiro Yamada
CONFIG_SYS_MAX_FLASH_BANKS_DETECT allows to determine the number of flash banks at run-time, that is, there is a possibility that no flash bank is found. Even in such cases, it makes sense to continue the boot process without any flash device. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de>
2014-11-25x86: Remove unnecessary call to initr_enable_interrupts()Bin Meng
Actually initr_enable_interrupts() was never called in an x86 build due to it was wrapped by CONFIG_x86 (typo of X86). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-11-25x86: Remove cpu_init_r() for x86Bin Meng
Since cpu_init_interrupts() was moved out of cpu_init_r(), it is useless to keep cpu_init_r() for x86, thus remove it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-11-25x86: Remove board_early_init_r()Simon Glass
This function is not needed. Remove it to improve the generic init sequence slightly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-11-21dm: Split the simple malloc() implementation into its own fileSimon Glass
The simple malloc() implementation is used when memory is tight. It provides a simple buffer with an incrementing pointer. At present the implementation is inside dlmalloc. Move it into its own file so that it is easier to find. Rather than using relocation as a signal that the full malloc() is available, add a special GD_FLG_FULL_MALLOC_INIT flag. This signals that the simple malloc() should no longer be used. In some cases, such as SPL, even the code space used by the full malloc() is wasteful. Add a CONFIG_SYS_MALLOC_SIMPLE option to provide only the simple malloc. In this case the full malloc is not available at all. It saves about 1KB of code space and about 0.5KB of data on Thumb 2. Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-25common: board_r: make local functions staticJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-10-24common: board: use __weakJeroen Hofstee
2014-10-22dm: Remove spi_init() from board_r.c when using driver modelSimon Glass
Driver model does its own init, so we don't need this. There is still a call in board_f.c but it is only enabled by CONFIG_HARD_SPI. It is easy enough to disable that option when converting boards which use it to driver model. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-10-10common/board_r: remove warning in initr_mem for 64-bit phys_size_tValentin Longchamp
Since on powerpc phys_size_t can be unsigned long long, this printout line can result in a not nice compile warning. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-10-10common/board_r: Fix booting issue on T4240QDSYork Sun
Commit 294b91a5817147d4b7f47be2ac69bac2a1f26491 moved initr_malloc earlier than initr_unlock_ram_in_cache. This causes issue on T4240. It may be related to locked L1 d-cache and unlocked L2 cache. D- cache could and should be unlock earlier for normal operation. This patch moves initr_unlock_ram_in_cache before initr_malloc. It has been verified on the following boards, in which only T4240QDS suffered and has been since fixed: T4240QDS, T2080QDS, P5040DS, P4080DS, MPC8572DS, MPC8536DS, MPC8641HPCN, B4860QDS. Signed-off-by: York Sun <yorksun@freescale.com> CC: Scott Wood <scottwood@freescale.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-13Merge branch 'master' of git://git.denx.de/u-boot-dmTom Rini
2014-09-10dm: Make driver model available before board_init()Simon Glass
For some boards board_init() will change GPIOs, so we need to have driver model available before then. Adjust the board init to arrange this, but enable it for driver model only, just to be safe. This does create additional #ifdef logic, but it is safer than trying to make a pervasive change which may cause some boards to break. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-10Set up stdio earlier when using driver modelSimon Glass
Since driver model registers itself with the stdio subsystem, and we want to avoid delayed registration and other complexity associated with the current serial console, move the stdio subsystem init earlier when driver model is used for serial. This simplifies the implementation. Should there be any problems with this approach they can be dealt with as boards are converted over to use driver model for serial. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-09board_r: ARM[64] do not set gd againJeroen Hofstee
For ARM / ARM64 the relocation routines already updated gd to the new value. Don't set it again. This allows compilation with clang as it cannot update gd directly. cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-08-24nios2: add generic board supportThomas Chou
This patch implements the generic board init as described in doc/README.generic-board. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com> Reviewed-by: Stefan Roese <sr@denx.de>
2014-08-09board_r: Add missing return to initr_docIan Campbell
I happened to spot this while working in the area. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Simon Glass <sjg@chromium.org> Cc: Simon Glass <sjg@chromium.org>
2014-07-23dm: Support driver model prior to relocationSimon Glass
Initialise devices marked 'pre-reloc' and make them available prior to relocation. Note that this requires pre-reloc malloc() to be available. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-23dm: Allow drivers to be marked 'before relocation'Simon Glass
Driver model currently only operates after relocation is complete. In this state U-Boot typically has a small amount of memory available. In adding support for driver model prior to relocation we must try to use as little memory as possible. In addition, on some machines the memory has not be inited and/or the CPU is not running at full speed or the data cache is off. These can reduce execution performance, so the less initialisation that is done before relocation the better. An immediately-obvious improvement is to only initialise drivers which are actually going to be used before relocation. On many boards the only such driver is a serial UART, so this provides a very large potential benefit. Allow drivers to mark themselves as 'pre-reloc' which means that they will be initialised prior to relocation. This can be done either with a driver flag or with a 'dm,pre-reloc' device tree property. To support this, the various dm scanning function now take a 'pre_reloc_only' parameter which indicates that only drivers marked pre-reloc should be bound. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-23Add a simple malloc() implementation for pre-relocationSimon Glass
If we are to have driver model before relocation we need to support some way of calling memory allocation routines. The standard malloc() is pretty complicated: 1. It uses some BSS memory for its state, and BSS is not available before relocation 2. It supports algorithms for reducing memory fragmentation and improving performace of free(). Before relocation we could happily just not support free(). 3. It includes about 4KB of code (Thumb 2) and 1KB of data. However since this has been loaded anyway this is not really a problem. The simplest way to support pre-relocation malloc() is to reserve an area of memory and allocate it in increasing blocks as needed. This implementation does this. To enable it, you need to define the size of the malloc() pool as described in the README. It will be located above the pre-relocation stack on supported architectures. Note that this implementation is only useful on machines which have some memory available before dram_init() is called - this includes those that do no DRAM init (like tegra) and those that do it in SPL (quite a few boards). Enabling driver model preior to relocation for the rest of the boards is left for a later exercise. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-22board_r: run scsi init() on ARM tooIan Campbell
This has been disabled for ARM in initr_scsi since that function was introduced. However it works fine for me on Cubieboard and Cubietruck (with the upcoming AHCI glue patch). I also tested on two random ARM platforms which seem to define CONFIG_CMD_SCSI: - highbank worked fine (on midway hardware) - omap5_uevm built OK and I confirmed using objdump that things were as expected (i.e. the default weak scsi_init nop was used). While there remove the mismatched comment from the #endif (omitting the comment seems to be the prevailing style in this file). Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-29m68k: powerpc: Clean up do_mdm_initSimon Glass
This code seems unnecessarily complex. We really just need to check the global_data. Now that is it all in one place, and not arch-specific, this is pretty easy. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-04-18board_r: return 0 from show_model_rPaul Burton
The show_model_r function should return an int but didn't. Return 0 to indicate inevitable success and avoid the following if it is used: common/board_r.c: In function 'show_model_r': common/board_r.c:531:1: warning: no return statement in function returning non-void [-Wreturn-type] } ^ Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-03-04dm: Set up driver model after relocationSimon Glass
Make driver model available after relocation, by setting up data structures and scanning for devices using compiled-in platform_data and (when available) the device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-02-26arm: remove unneeded symbol offsets and _TEXT_BASEAlbert ARIBAUD
Remove the last uses of symbol offsets in ARM U-Boot. Remove some needless uses of _TEXT_BASE. Remove all _TEXT_BASE definitions. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-01-27board_r - fixup functions table after relocationAlexey Brodkin
This is only required for "PIC" relocation and doesn't apply to modern "PIE" relocation which does data relocation as well as code. "init_sequence_r" is just an array that consists of compile-time adresses of init functions. Since this is basically an array of integers (pointers to "void" to be more precise) it won't be modified during relocation - it will be just copied to new location as it is. As a consequence on execution after relocation "initcall_run_list" will be jumping to pre-relocation addresses. As long as we don't overwrite pre-relocation memory area init calls are executed correctly. But still it is dangerous because after relocation we don't expect initially used memory to stay untouched. Cc: Tom Rini <trini@ti.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Doug Anderson <dianders@chromium.org> Cc: Thomas Langer <thomas.langer@lantiq.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2013-06-26Add trace support to generic boardSimon Glass
Add hooks for tracing to generic board, including: - allow early tracing to start early as possible in U-Boot - reserve memory for trace buffer - copy early trace buffer to main trace buffer after relocation - setup full tracing support after relocation Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-07generic_board: reduce the redundancy of gd_t struct membersMasahiro Yamada
This commit refactors common/board_f.c and common/board_r.c in order to delete the dest_addr and dest_addr_sp from gd_t struct. As mentioned as follows in include/asm-generic/global_data.h, /* TODO: is this the same as relocaddr, or something else? */ unsigned long dest_addr; /* Post-relocation address of U-Boot */ dest_addr is the same as relocaddr. Likewise, dest_addr_sp is the same as start_addr_sp. It seemed dest_addr/dest_addr_sp was used only as a scratch variable to calculate relocaddr/start_addr_sp, respectively. With a little refactoring, we can delete dest_addr and dest_addr_sp. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org>
2013-05-13Call bootstage_relocate() after malloc is inittedDoug Anderson
In a previous CL we added the bootstage_relocate(), which should be called after malloc is initted. Now we call it on generic board. Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-05-01sandbox: Switch over to generic boardSimon Glass
Add generic board support for sandbox. and remove the old board init code. Select CONFIG_SYS_GENERIC_BOARD for sandbox now that this is supported. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-15x86: Allow setup code to manage its own global dataSimon Glass
Currently x86 has its own means of managing the global data and board data (bd_t), and this code resides in start.S. With generic board, we need to ensure that we leave this alone - i.e. don't clear it as we do on other archs. This fixes a problem where the memory init data is cleared which causes the video driver to operate very slowly. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-15x86: Enable generic board supportSimon Glass
This enables generic board support so that x86 boards can define CONFIG_SYS_GENERIC_BOARD. Signed-off-by: Simon Glass <sjg@chromium.org>
