path: root/common/board_info.c
2015-08-13generic-board: allow showing custom board infoMarcel Ziswiler
Allow showing custom board info from a checkboard() function being implemented if CONFIG_CUSTOM_BOARDINFO is specified. Previously the device tree model was always displayed not taking any CONFIG_CUSTOM_BOARDINFO into account. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-05common: Print nothing in the __weak checkboard()Bin Meng
Do not print confusing "Board: Unknown" during boot. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-27generic_board: Call "checkboard" even though the root node has a "model" ↵Haikun.Wang@freescale.com
property In case of enable CONFIG_OF_CONTROL and has a "model" property in the root node, the board special "checkboard" will not be called. Usually we show some useful version information in the function. This patch enable call "checkboard" in any case. It is not conflicting with showing "model" at the same time. For example on LS2085AQDS: Showing "model" only: Model: Freescale Layerscape 2085a QDS Board Showing "checkboard" only: Board: LS2085E-QDS, Board Arch: V1, Board version: B, boot from vBank: 4 Showing both: Model: Freescale Layerscape 2085a QDS Board Board: LS2085E-QDS, Board Arch: V1, Board version: B, boot from vBank: 4 Signed-off-by: Haikun Wang <haikun.wang@freescale.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-01-29generic-board: show model name in board_init_f() tooMasahiro Yamada
The common/board_r.c has show_model_r() to display the model name if the DTB has a "model" property. It sounds useful to have a similar function in common/board_f.c too because most of the boards show their board name before relocation. Instead of implementing the same function in both common/board_f.c and common/board_r.c, let's split it up into common/show_board_info.c. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
