path: root/common/board_f.c
2015-04-18common: Make sure arch-specific map_sysmem() is definedJoe Hershberger
In the case where the arch defines a custom map_sysmem(), make sure that including just mapmem.h is sufficient to have these functions as they are when the arch does not override it. Also split the non-arch specific functions out of common.h Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-16dm: Add a new CPU init function which can use driver modelSimon Glass
Since driver model is set up after arch_cpu_init(), that function cannot use drivers. Add a new arch_cpu_init_dm() function which is called immediately after driver model is ready, and can reference devices. This can be used to probe essential devices for the CPU. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-04-03arc: clean-up init procedureAlexey Brodkin
Intention behind this work was elimination of as much assembly-written code as it is possible. In case of ARC we already have relocation fix-up implemented in C so why don't we use C for U-Boot copying, .bss zeroing etc. It turned out x86 uses pretty similar approach so we re-used parts of code in "board_f.c" initially implemented for x86. Now assembly usage during init is limited to stack- and frame-pointer setup before and after relocation. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Simon Glass <sjg@chromium.org>
2015-03-28m68k: fix 3 broken boardsangelo@sysam.it
Fix eb_cpu5282 and eb_cpu5282_internal unresolved external error. These boards have video but don't need any ppc related video_setmem(). Fix M53017EVB moving away embedded env to a different offset, as in M52277EVB. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2015-03-28common/board_f: move board_init_f_mem() from #else CONFIG_X86Alexey Brodkin
Purpose of this change is to make it possible to re-use code currently used on X86 solely for other architectures. For example: * init_sequence_f_r * board_init_f_r Even though board_init_f_mem() has nothing to do with any particular architecture it won't work (at least in current implementation) for X86. This is because on X86 "gd" is an alias to function get_fs_gd_ptr(), thus we cannot assign anything to it. So this change separates selection of board_init_f_mem() from X86 while keeping it disabled for X86 still. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com>
2015-03-18Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-03-13common/board_f.c: Enable IMX watchdog in init_func_watchdog_init()Stefan Roese
Without this patch, the IMX watchdog will not be initialized. And therefor not active. This patch fixes this by calling hw_watchdog_init() also when CONFIG_IMX_WATCHDOG is defined. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2015-03-10Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
Conflicts: README Signed-off-by: Tom Rini <trini@konsulko.com>
2015-03-05common/board_f: implement type casting for gd structureAlexey Brodkin
In case of global data structure defined as "register volatile" compiler throws an warning about incorrect type used: --->8--- common/board_f.c: In function "board_init_f_r": common/board_f.c:1073:2: warning: passing argument 1 of "&board_init_r +(sizetype)gd->reloc_off" discards "volatile" qualifier from pointer target type [enabled by default] (board_init_r + gd->reloc_off)(gd, gd->relocaddr); ^ common/board_f.c:1073:2: note: expected "struct gd_t *" but argument is of type "volatile struct gd_t *" --->8--- An obvious fix is manual casting to "gd_t *". Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-05m68k: Add generic board support for MCF547X/8X and MCF5445XAlison Wang
This patch adds generic board support for MCF547X/8X and MCF5445X. It is based on the patch about common generic board support for M68K architecture sent by Angelo. Signed-off-by: Alison Wang <alison.wang@freescale.com>
2015-03-05m68k: add generic-board supportangelo@sysam.it
Add generic-board support for the m68k architecture. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2015-03-04common: board: support systems with where RAM ends beyond 4GBStephen Warren
Some systems have so much RAM that the end of RAM is beyond 4GB. An example would be a Tegra124 system (where RAM starts at 2GB physical) that has more than 2GB of RAM. In this case, we can gd->ram_size to represent the actual RAM size, so that the actual RAM size is passed to the OS. This is useful if the OS implements LPAE, and can actually use the "extra" RAM. However, U-Boot does not implement LPAE and so must deal with 32-bit physical addresses. To this end, we enhance board_get_usable_ram_top() to detect the "over-sized" case, and limit the relocation addres so that it fits into 32-bits of physical address space. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-02-17avr32: add generic board supportAndreas Bießmann
2015-02-17common/board_f: factor out reserve_stacksAndreas Bießmann
Introduce arch_reserve_stacks() to tailor gd->start_addr_sp and gd->irq_sp to the architecture needs. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-12Introduce board_init_f_mem() to handle early memory layoutSimon Glass
At present on some architectures we set up the following before calling board_init_f(): - global_data - stack - early malloc memory Adding the code to support early malloc and global data setup to every arch's assembler start-up is a pain. Also this code is not actually architecture-specific. We can use common code for all architectures and with a bit of care we can write this code in C. Add a new function to deal with this. It should be called after memory is available, with a pointer to the top of the area that should be used before relocation. The function will set things up and return the lowest memory address that it allocated/used. That can then be set as the top of the stack. Note that on some archs this function will use the stack, so the stack pointer should be set to same value as is pased to board_init_f_mem(). A margin of 128 bytes will be left for this stack, so that it is not overwritten. This means that 64 bytes is wasted by this early call. This is not strictly necessary on several more modern archs, so we could remove this at the cost of some arch-dependent code. With this function there is no-longer any need for the assembler code to zero global_data or set up the early malloc pointers. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-10Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2015-02-09microblaze: Move architecture to use generic board initMichal Simek
Compile code with -fPIC to get GOT. Do not build SPL with fPIC because it increasing SPL size for nothing. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-02-07common/board_f: add at91 wdtHeiko Schocher
call hw_watchdog_init() also if CONFIG_AT91SAM9_WATCHDOG is used. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-01-29generic-board: show model name in board_init_f() tooMasahiro Yamada
The common/board_r.c has show_model_r() to display the model name if the DTB has a "model" property. It sounds useful to have a similar function in common/board_f.c too because most of the boards show their board name before relocation. Instead of implementing the same function in both common/board_f.c and common/board_r.c, let's split it up into common/show_board_info.c. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-24Allow architecture-specific memory reservationSimon Glass
All memory to be reserved for use after relocation by adding a new call to perform this reservation. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: board_f: Adjust x86 boot order for performanceSimon Glass
For bare platforms we turn off ROM-caching before calling board_init_f_r() It is then very slow to copy U-Boot from ROM to RAM. So adjust the order so that the copying happens before we turn off ROM-caching. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-29common/board_f.c: fix compile error when tracing disabledKevin Hilman
When CONFIG_TRACE is disabled, linking fails with: common/built-in.o:(.data.init_sequence_f+0x8): undefined reference to `trace_early_init' To fix, wrap the call to trace_early_init() with #ifdef CONFIG_TRACE. Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2014-11-24Revert "common/board_f: add setup of initial stack frame for MIPS"Tom Rini
Daniel discovered a better solution to the problem this was solving, so don't do what this patch was doing anymore. This reverts commit 666ba8444e81c3785a427ae6922e2feededab9a3. Signed-off-by: Tom Rini <trini@ti.com>
2014-11-24Merge git://git.denx.de/u-boot-x86Tom Rini
Conflicts: arch/x86/cpu/Makefile Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23sandbox: Prepare API change for files greater than 2GBSuriyan Ramasami
Change the internal sandbox functions to use loff_t for file offsets. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-23common/board_f: fix gcc warning on MIPS64Daniel Schwierzeck
This fixes following warning when compiled with MIPS64 common/board_f.c: In function 'display_text_info': common/board_f.c:150:2: warning: format '%X' expects argument i of type 'unsigned int', but argument 2 has type 'long unsigned int' [-Wformat=] debug("U-Boot code: %08X -> %08lX BSS: -> %08lX\n", Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-23common/board_f: add setup of initial stack frame for MIPSDaniel Schwierzeck
The MIPS specific setup of the initial stack frame was not ported to generic board_f. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2014-11-21x86: Remove unnecessary find_fdt(), prepare_fdt() functionsSimon Glass
These are no-longer needed so drop them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-11-21Move early malloc() to before arch_cpu_init()Simon Glass
For some CPUs, having malloc() available very early is useful. There is no reason to delay this since early malloc is allocated before board_init_f() is called. Move early malloc() init nearer to the start of the init sequence. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21x86: Use the standard arch_cpu_init() functionSimon Glass
Instead of an x86-specific cpu_init_f() function, use the normal U-Boot one for this purpose. Also remove a useless/misleading comment. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-11-21x86: Use the standard dram_init() functionSimon Glass
Instead of having an x86-specific DRAM init function, adjust things so we can use the normal one. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-10-24common: board: use __weakJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-09-16generic_board: do not set gd->fdt_blob unless CONFIG_OF_CONTROL=yMasahiro Yamada
gd->fdt_blob is used for FDT control of U-Boot. If CONFIG_OF_CONTROL is not defined, it is useless. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-16common: fix include guards for CONFIG_MPGabriel Huau
This was breaking the build for some boards: MPC8536DS MPC8536DS_36BIT MPC8536DS_SDCARD MPC8536DS_SPIFLASH qemu-ppce500 Include only these features for some PPC boards if the configuration for MultiProcessor is enabled. Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr> Cc: Tom Rini <trini@ti.com> Cc: York Sun <yorksun@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2014-09-10dm: Move pre-reloc init earlier to cope with board_early_init_f()Simon Glass
In order to support GPIO access in board_early_init_f() we must set up driver model before this function is called. In any case, earlier is better since driver model is (or will become) a key function for most init. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-08-29Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-08-24nios2: add generic board supportThomas Chou
This patch implements the generic board init as described in doc/README.generic-board. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com> Reviewed-by: Stefan Roese <sr@denx.de>
2014-08-20mx6: add support of multi-processor commandGabriel Huau
This allows u-boot to load different OS or Bare Metal application on different cores of the i.MX6 SoC. For example: running Android on cpu0 and a RT OS like QNX/FreeRTOS on cpu1. Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr> Acked-by: Stefano Babic <sbabic@denx.de>
2014-08-07support blackfin board initialization in generic board_fSonic Zhang
- init hardware watchdog if applicable - use CONFIG_SYS_MONITOR_LEN as the gd monitor len for Blackfin - reserve u-boot memory at the top field of the RAM for Blackfin - avoid refer to CONFIG_SYS_MONITOR_LEN, which is not defined by Blackfin Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2014-07-23dm: Support driver model prior to relocationSimon Glass
Initialise devices marked 'pre-reloc' and make them available prior to relocation. Note that this requires pre-reloc malloc() to be available. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-23Add a simple malloc() implementation for pre-relocationSimon Glass
If we are to have driver model before relocation we need to support some way of calling memory allocation routines. The standard malloc() is pretty complicated: 1. It uses some BSS memory for its state, and BSS is not available before relocation 2. It supports algorithms for reducing memory fragmentation and improving performace of free(). Before relocation we could happily just not support free(). 3. It includes about 4KB of code (Thumb 2) and 1KB of data. However since this has been loaded anyway this is not really a problem. The simplest way to support pre-relocation malloc() is to reserve an area of memory and allocate it in increasing blocks as needed. This implementation does this. To enable it, you need to define the size of the malloc() pool as described in the README. It will be located above the pre-relocation stack on supported architectures. Note that this implementation is only useful on machines which have some memory available before dram_init() is called - this includes those that do no DRAM init (like tegra) and those that do it in SPL (quite a few boards). Enabling driver model preior to relocation for the rest of the boards is left for a later exercise. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-18common: board_f: cosmetic use __weak for ledsJeroen Hofstee
First of all this looks a lot better, but it also prevents a gcc warning (W=1), that the weak function has no previous prototype. cc: Simon Glass <sjg@chromium.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-12common/board_f: Fix size variableYork Sun
DRAM size should use 64-bit variable when the size could be more than 4GB. Caught and verified on P4080DS with 4GB DDR. Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-12common/board_f: Initialized global data for generic boardYork Sun
Some platforms (tested on mpc85xx, mpc86xx) use global data before calling function baord_inti_f(). The data should not be cleared later. Any arch which uses global data in generic board board_init_f() should define CONFIG_SYS_GENERIC_GLOBAL_DATA. Signed-off-by: York Sun <yorksun@freescale.com> CC: Scott Wood <scottwood@freescale.com> CC: Simon Glass <sjg@chromium.org> CC: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-12bd_info: remove bi_barudrate member from struct bd_infoMasahiro Yamada
gd->bd->bi_baudrate is a copy of gd->baudrate. Since baudrate is a common feature for all architectures, keep gd->baudrate only. It is true that bi_baudrate was passed to the kernel in that structure but it was a long time ago. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
2014-04-20board_f: call timer_init on MIPSPaul Burton
MIPS needs a call to timer_init to preserve its current behaviour ensuring that the cop0 compare register is initialised appropriately. Reported-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2014-04-20board_f: call init_func_ram on MIPSPaul Burton
Assigning gd->ram_size the return value of initdram matches the existing MIPS board behaviour. Suggested-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2014-03-17sandbox: Use os functions to read host device treeSimon Glass
At present we use U-Boot's filesystem layer to read the sandbox device tree, but this is problematic since it relies on a temporary feauture added there. Since we plan to implement proper block layer support for sandbox, change this code to use the os layer functions instead. Also use the new fdt_create_empty_tree() instead of our own code. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-07powerpc: mpc8260: consolidate CONFIG_MPC8260 and CONFIG_8260Masahiro Yamada
Before this commit, CONFIG_MPC8260 and CONFIG_8260 were used mixed-up. All boards with mpc8260 cpu defined both of them: - CONFIG_MPC8260 was defined in board config headers and include/common.h - CONFIG_8260 was defined arch/powerpc/cpu/mpc8260/config.mk We do not need to have both of them. This commit keeps only CONFIG_MPC8260. This commit does: - Delete CONFIG_8260 and CONFIG_MPC8260 definition in config headers and include/common.h - Rename CONFIG_8260 to CONFIG_MPC8260 in arch/powerpc/cpu/mpc8260/config.mk. - Rename #ifdef CONFIG_8260 to #ifdef CONFIG_MPC8260 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de>
2014-02-26Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: arch/arm/cpu/armv7/config.mk board/ti/am43xx/mux.c include/configs/am43xx_evm.h Signed-off-by: Tom Rini <trini@ti.com>
