path: root/common/board_f.c
2019-05-18CONFIG_SPL_SYS_[DI]CACHE_OFF: addTrevor Woerner
While converting CONFIG_SYS_[DI]CACHE_OFF to Kconfig, there are instances where these configuration items are conditional on SPL. This commit adds SPL variants of these configuration items, uses CONFIG_IS_ENABLED(), and updates the configurations as required. Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Make the default depend on the setting for full U-Boot, update more zynq hardware] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-04-23sandbox: Improve debugging in initcall_run_list()Simon Glass
At present if one of the initcalls fails on sandbox the address printing is not help, e.g.: initcall sequence 0000557678967c80 failed at call 00005576709dfe1f (err=-96) This is because U-Boot gets relocated high into memory and the relocation offset (gd->reloc_off) does not work correctly for sandbox. Add support for finding the base address of the text region (at least on Linux) and use that to set the relocation offset. This makes the output better: initcall sequence 0000560775957c80 failed at call 0000000000048134 (err=-96) Then you use can use grep to see which init call failed, e.g.: $ grep 0000000000048134 u-boot.map stdio_add_devices Of course another option is to run it with a debugger such as gdb: $ gdb u-boot ... (gdb) br initcall.h:41 Breakpoint 1 at 0x4db9d: initcall.h:41. (2 locations) Note that two locations are reported, since this function is used in both board_init_f() and board_init_r(). (gdb) r Starting program: /tmp/b/sandbox/u-boot [Thread debugging using libthread_db enabled] Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1". U-Boot 2018.09-00264-ge0c2ba9814-dirty (Sep 22 2018 - 12:21:46 -0600) DRAM: 128 MiB MMC: Breakpoint 1, initcall_run_list (init_sequence=0x5555559619e0 <init_sequence_f>) at /scratch/sglass/cosarm/src/third_party/u-boot/files/include/initcall.h:41 41 printf("initcall sequence %p failed at call %p (err=%d)\n", (gdb) print *init_fnc_ptr $1 = (const init_fnc_t) 0x55555559c114 <stdio_add_devices> (gdb) Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-05Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
- Various MTD fixes from Boris - Zap various unused / legacy paths. - pxa3xx NAND update from Miquel Signed-off-by: Tom Rini <trini@konsulko.com>
2018-11-27spi: Zap CONFIG_HARD_SPIJagan Teki
In legacy CONFIG_HARD_SPI initalizing spi_init code, which was removed during dm conversion cleanup. So remove the dead instances of CONFIG_HARD_SPI, and related code. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-11-27spi: Remove used spi_initJagan Teki
spi_init used in some areas in tree, but the respective drivers will remove in future patches. So remove the same instances. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2018-11-26spl: Add support for passing handoff info to U-Boot properSimon Glass
There is some basic informaton that SPL normally wants to pass through to U-Boot, such as the SDRAM size and bank information. Mkae use of the new bloblist structure for this. Add a new 'handoff' blob which is set up in SPL and passed to U-Boot proper. Also adda test for sandbox_spl that checks that this works correctly and a new 'sb' command to show the information passed from SPL. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-26bloblist: Locate bloblist in U-BootSimon Glass
Add support for locating a bloblist in U-Boot that has been set up by SPL. It is copied into RAM during relocation. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-16arm: at91: wdt: Convert watchdog driver to dm/dtPrasanthi Chellakumar
Convert the Watchdog driver for AT91SAM9x processors to support the driver model and device tree. Changes "CONFIG_AT91SAM9_WATCHDOG" to new "CONFIG_WDT_AT91" Kconfig option. Signed-off-by: Prasanthi Chellakumar <prasanthi.chellakumar@microchip.com>
2018-11-14dm: cpu: Fix print_cpuinfo() outputBin Meng
It was observed that current output of print_cpuinfo() on QEMU x86 targets does not have an ending '\n', neither have a leading 'CPU:' any more. However it used to have these before. It turns out commit c0434407b595 introduced a unified DM version of print_cpuinfo() that exposed such issue on QEMU x86. Fixes: c0434407b595 ("board_f: Use static print_cpuinfo if CONFIG_CPU is active") Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-14board_f: Use static print_cpuinfo if CONFIG_CPU is activeMario Six
When the DM CPU drivers are active, printing information about a CPU should be delegated to a matching driver. Hence, add a static print_cpuinfo that implements this delegation when DM CPU drivers are active. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc> Changed condition to CONFIG_IS_ENABLED(CPU): Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-07Revert "board_f: Use static print_cpuinfo if CONFIG_CPU is active"Bin Meng
This reverts commit c0434407b595f785fc7401237896c48c791b45fd. It turns out commit c0434407b595 broke some boards which have DM CPU driver with CONFIG_DISPLAY_CPUINFO option on. These boards just fail to boot when print_cpuinfo() is called during boot. Fixes are already sent to ML and in u-boot-dm/next, however since we are getting close to the v2018.11 release, it's safer we revert the original commit. This commit should be reverted after v2018.11 release. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-18board_f: Use static print_cpuinfo if CONFIG_CPU is activeMario Six
2018-09-18common: board_f: Sort includesMario Six
Includes should be sorted. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-18board_f: Add reset status printingMario Six
To print the reset status during boot, add a method print_resetinfo to board_f, which is called in init_sequence_f[], that gets the reset information from the sysreset driver (assuming there is only one seems reasonable), and prints it. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-07-19lib: fdtdec: Update ram_base to store ram start adddressSiva Durga Prasad Paladugu
This patch updates the ram_base to store the start address of the first bank DRAM and the use this ram_base to calculate ram_top properly. This patch fixes the erroneous calculation of ram_top incase of non zero ram start address. Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-06-05board_f: Only reserve memory for U-Boot if we're going to relocateAlexey Brodkin
In case of no relocation we'll just waste some space at the very end of usable memory area. If target device has very limited amount of memory (for example 256 kB) this loss will be pretty inconvenient. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Heiko Schocher <hs@denx.de> Cc: York Sun <york.sun@nxp.com> Cc: Stefan Roese <sr@denx.de>
2018-03-21arc: Introduce a possibility to not relocate U-bootAlexey Brodkin
Disabling relocation might be useful on ARC for 2 reasons: a) For advanced debugging with Synopsys proprietary MetaWare debugger which is capable of accessing much more specific hardware resources compared to gdb. For example it may show contents of L1 and L2 caches, internal states of some hardware blocks etc. But on the downside MetaWare debugger still cannot work with PIE. Even though that limitation could be work-arounded with change of ELF's header and stripping down all debug info but with it we won't have debug info for source-level debugging which is quite inconvenient. b) Some platforms which might benefit from usage of U-Boot basically don't have enough RAM to accommodate relocation of U-Boot so we keep code in flash and use as much of RAM as possible for more interesting things. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Heiko Schocher <hs@denx.de> Cc: York Sun <york.sun@nxp.com> Cc: Stefan Roese <sr@denx.de>
2018-03-16common: move init_helpers.h prototypes in init.hPatrick Delaunay
Merge init_helpers.h in the new file init.h with only prototypes for init_cache_f_r used in common/board_f.c Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-03-16common: move board_f.c prototypes in init.hPatrick Delaunay
Move prototypes for function used in common/board_f.c from common.h to init.h Remove weak for arch_reserve_stacks in prototype (checkpatch issue) Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-01-28common: board_f: Fix style violationsMario Six
Fix some style violations in the board_f file. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-01-24Merge branch 'master' of git://git.denx.de/u-boot-coldfireTom Rini
2018-01-23common/board_f.c: align m68k arch to use CONFIG_DISPLAY_CPUINFOAngelo Dureghello
Change all coldfire arch files to use CONFIG_DISPLAY_CPUINFO. Signed-off-by: Angelo Dureghello <angelo@sysam.it> Reviewed-by: Tom Rini <trini@konsulko.com> --- Changes for v2: - update common/Kconfig to add M68K to the default y list
2018-01-23common: board_f: vid: Add VID specific API to adjust core voltageRajesh Bhagat
Adds a VID specific API in init_sequence_f and spl code flow namely init_func_vid which is required to adjust core voltage. VID specific code is required in spl, hence moving flag CONFIG_VID out of spl flags. Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-12riscv: Modify generic codes to support RISC-VRick Chen
Support common commands bdinfo and image format, also modify common generic flow for RISC-V. Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Signed-off-by: Greentime Hu <green.hu@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-12-07log: Plumb logging into the init sequenceSimon Glass
Set up logging both before and after relocation. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-12-07Drop the log bufferSimon Glass
This does not appear to be used by any boards. Before introducing a new log system, remove this old one. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-16board_f: Drop the timer after relocationSimon Glass
Once U-Boot relocates itself the existing driver-model timer (if any) is no-longer valid until the device is reinitialised. Any use of the device may cause a crash. To handle this, set the timer to NULL after relocation. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-20common/board_f.c: remove CONFIG_SYS_GENERIC_GLOBAL_DATAThomas Petazzoni
CONFIG_SYS_GENERIC_GLOBAL_DATA is no longer used by any board or platform, so support for it can be dropped. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv_hex(), getenv_yesno(), getenv_ulong()Simon Glass
We are now using an env_ prefix for environment functions. Rename these for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-02common: board_f: Make reserve_mmu a weak functionSiva Durga Prasad Paladugu
Make reserve_mmu a weak so that it provides an option to customize this routine as per platform need Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-27spl: make SPL and normal u-boot stage use independent SYS_MALLOC_F_LENAndy Yan
Some platforms have very limited SRAM to run SPL code, so there may not be the same amount space for a malloc pool before relocation in the SPL stage as the normal U-Boot stage. Make SPL and (the full) U-Boot stage use independent SYS_MALLOC_F_LEN, so the size of pre-relocation malloc pool can be configured memory space independently. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [fixed up commit-message:] Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-25MIPS: Stop building position independent codePaul Burton
U-Boot has up until now built with -fpic for the MIPS architecture, producing position independent code which uses indirection through a global offset table, making relocation fairly straightforward as it simply involves patching up GOT entries. Using -fpic does however have some downsides. The biggest of these is that generated code is bloated in various ways. For example, function calls are indirected through the GOT & the t9 register: 8f998064 lw t9,-32668(gp) 0320f809 jalr t9 Without -fpic the call is simply: 0f803f01 jal be00fc04 <puts> This is more compact & faster (due to the lack of the load & the dependency the jump has on its result). It is also easier to read & debug because the disassembly shows what function is being called, rather than just an offset from gp which would then have to be looked up in the ELF to discover the target function. Another disadvantage of -fpic is that each function begins with a sequence to calculate the value of the gp register, for example: 3c1c0004 lui gp,0x4 279c3384 addiu gp,gp,13188 0399e021 addu gp,gp,t9 Without using -fpic this sequence no longer appears at the start of each function, reducing code size considerably. This patch switches U-Boot from building with -fpic to building with -fno-pic, in order to gain the benefits described above. The cost of this is an extra step during the build process to extract relocation data from the ELF & write it into a new .rel section in a compact format, plus the added complexity of dealing with multiple types of relocation rather than the single type that applied to the GOT. The benefit is smaller, cleaner, more debuggable code. The relocate_code() function is reimplemented in C to handle the new relocation scheme, which also makes it easier to read & debug. Taking maltael_defconfig as an example the size of u-boot.bin built using the Codescape MIPS 2016.05-06 toolchain (gcc 4.9.2, binutils 2.24.90) shrinks from 254KiB to 224KiB. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: u-boot@lists.denx.de Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Tested-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2017-07-10board_f: Add new function to allow runtime DTB selectionCooper Jr., Franklin
Runtime U-boot dtb selection is generally a two step process. First step is to simply use an initial generic dtb. The second step is to select the dtb and perhaps execute additional code ones U-boot knows what board it is running on. Embedded_dtb_select handles the second step by allowing board specific code to run and perform what ever necessary configuration that is needed. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-03powerpc: remove 4xx supportHeiko Schocher
There was for long time no activity in the 4xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 4xx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-16powerpc, 5xxx, 512x: remove support for mpc5xxx and mpc512xHeiko Schocher
There was for long time no activity in the mpx5xxx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in mpc5xxx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12board_f: fix calculation of reloc_offLothar Waßmann
relocate_code() calculates the relocation offset wrt. the symbol __image_copy_start which happens to have the same value as CONFIG_TEXT_BASE on most systems. When creating an i.MX boot image with an integrated IVT it is convenient to have CONFIG_TEXT_BASE point to the start of the IVT that is prepended to the actual code. Thus CONFIG_TEXT_BASE will differ from __image_copy_start, while the calculation 'gd->relocaddr - __image_copy_start' still gives the right relocation offset. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
2017-06-12board_f: Use IS_ENABLED instead of #ifdef in initf_bootstage()Simon Glass
The current implementation makes it look like the 'if (from_spl)' part is dead code because these features are not enabled for sandbox. We could enable it for sandbox_spl, but this is not done yet (it requires sharing memory between SPL and U-Boot proper which is in fact supported). It is probably nicer to avoid #ifdef anyway. Change it. Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Coverity (CID: 163244) Fixes: 824bb1b (bootstage: Support SPL)
2017-06-12powerpc, 5xx: remove support for 5xxHeiko Schocher
There was for long time no activity in the 5xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 5xx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8260: remove support for mpc8260Heiko Schocher
There was for long time no activity in the 8260 area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8260, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8xx: remove support for 8xxHeiko Schocher
There was for long time no activity in the 8xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8xx, so remove it (with a heavy heart, knowing that I remove here the root of U-Boot). Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-05bootstage: Support SPLSimon Glass
At present bootstage only supports U-Boot proper. But SPL can also consume boot time so it is useful to have the record start there. Add bootstage support to SPL. Also support stashing the timing information when SPL finishes so that it can be picked up and reported by U-Boot proper. This provides a full boot time record, excluding only the time taken by the boot ROM. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-05bootstage: Record the time taken to set up driver modelSimon Glass
Driver model is set up ones before relocation and once after. Record the time taken in each case. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-05bootstage: Init as early as possibleSimon Glass
At present we don't allow use of bootstage before driver model is running. This means we cannot time the init of driver model itself. Now that bootstage requires its own board-specific timer, we can move its init to earlier in the sequence, both before and after relocation. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-05bootstage: Support relocating boostage dataSimon Glass
Some boards cannot access pre-relocation data after relocation. Reserve space for this and copy it during preparation for relocation. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-05bootstage: Convert to use malloc()Simon Glass
At present bootstage uses the data section of the image to store its information. There are a few problems with this: - It does not work on all boards (e.g. those which run from flash before relocation) - Allocated strings still point back to the pre-relocation data after relocation Now that U-Boot has a pre-relocation malloc() we can use this instead, with a pointer to the data in global_data. Update bootstage to do this and set up an init routine to allocate the memory. Now that we have a real init function, we can drop the fake 'reset' record and add a normal one instead. Note that part of the problem with allocated strings remains. They are reallocated but this will only work where pre-relocation memory is accessible after relocation. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-05arm: Remove include files from common.hSimon Glass
With a small tweak we can avoid including these files for all boards. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-15Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
2017-05-15board_f: skip timer_init() on Coldfire archsAngelo Dureghello
Coldfire arch is not happy with timer_init since interrupt handlers are still not set at that stage, and the boot hangs silently. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2017-05-15i2c: Finish dropping use of CONFIG_I2C_HARDSimon Glass
Drop use of this long-deprecated option. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
