path: root/common/board_f.c
2015-01-29generic-board: show model name in board_init_f() tooMasahiro Yamada
The common/board_r.c has show_model_r() to display the model name if the DTB has a "model" property. It sounds useful to have a similar function in common/board_f.c too because most of the boards show their board name before relocation. Instead of implementing the same function in both common/board_f.c and common/board_r.c, let's split it up into common/show_board_info.c. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-24Allow architecture-specific memory reservationSimon Glass
All memory to be reserved for use after relocation by adding a new call to perform this reservation. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: board_f: Adjust x86 boot order for performanceSimon Glass
For bare platforms we turn off ROM-caching before calling board_init_f_r() It is then very slow to copy U-Boot from ROM to RAM. So adjust the order so that the copying happens before we turn off ROM-caching. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-29common/board_f.c: fix compile error when tracing disabledKevin Hilman
When CONFIG_TRACE is disabled, linking fails with: common/built-in.o:(.data.init_sequence_f+0x8): undefined reference to `trace_early_init' To fix, wrap the call to trace_early_init() with #ifdef CONFIG_TRACE. Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2014-11-24Revert "common/board_f: add setup of initial stack frame for MIPS"Tom Rini
Daniel discovered a better solution to the problem this was solving, so don't do what this patch was doing anymore. This reverts commit 666ba8444e81c3785a427ae6922e2feededab9a3. Signed-off-by: Tom Rini <trini@ti.com>
2014-11-24Merge git://git.denx.de/u-boot-x86Tom Rini
Conflicts: arch/x86/cpu/Makefile Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23sandbox: Prepare API change for files greater than 2GBSuriyan Ramasami
Change the internal sandbox functions to use loff_t for file offsets. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-23common/board_f: fix gcc warning on MIPS64Daniel Schwierzeck
This fixes following warning when compiled with MIPS64 common/board_f.c: In function 'display_text_info': common/board_f.c:150:2: warning: format '%X' expects argument i of type 'unsigned int', but argument 2 has type 'long unsigned int' [-Wformat=] debug("U-Boot code: %08X -> %08lX BSS: -> %08lX\n", Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-23common/board_f: add setup of initial stack frame for MIPSDaniel Schwierzeck
The MIPS specific setup of the initial stack frame was not ported to generic board_f. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2014-11-21x86: Remove unnecessary find_fdt(), prepare_fdt() functionsSimon Glass
These are no-longer needed so drop them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-11-21Move early malloc() to before arch_cpu_init()Simon Glass
For some CPUs, having malloc() available very early is useful. There is no reason to delay this since early malloc is allocated before board_init_f() is called. Move early malloc() init nearer to the start of the init sequence. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21x86: Use the standard arch_cpu_init() functionSimon Glass
Instead of an x86-specific cpu_init_f() function, use the normal U-Boot one for this purpose. Also remove a useless/misleading comment. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-11-21x86: Use the standard dram_init() functionSimon Glass
Instead of having an x86-specific DRAM init function, adjust things so we can use the normal one. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-10-24common: board: use __weakJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-09-16generic_board: do not set gd->fdt_blob unless CONFIG_OF_CONTROL=yMasahiro Yamada
gd->fdt_blob is used for FDT control of U-Boot. If CONFIG_OF_CONTROL is not defined, it is useless. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-16common: fix include guards for CONFIG_MPGabriel Huau
This was breaking the build for some boards: MPC8536DS MPC8536DS_36BIT MPC8536DS_SDCARD MPC8536DS_SPIFLASH qemu-ppce500 Include only these features for some PPC boards if the configuration for MultiProcessor is enabled. Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr> Cc: Tom Rini <trini@ti.com> Cc: York Sun <yorksun@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2014-09-10dm: Move pre-reloc init earlier to cope with board_early_init_f()Simon Glass
In order to support GPIO access in board_early_init_f() we must set up driver model before this function is called. In any case, earlier is better since driver model is (or will become) a key function for most init. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-08-29Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-08-24nios2: add generic board supportThomas Chou
This patch implements the generic board init as described in doc/README.generic-board. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com> Reviewed-by: Stefan Roese <sr@denx.de>
2014-08-20mx6: add support of multi-processor commandGabriel Huau
This allows u-boot to load different OS or Bare Metal application on different cores of the i.MX6 SoC. For example: running Android on cpu0 and a RT OS like QNX/FreeRTOS on cpu1. Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr> Acked-by: Stefano Babic <sbabic@denx.de>
2014-08-07support blackfin board initialization in generic board_fSonic Zhang
- init hardware watchdog if applicable - use CONFIG_SYS_MONITOR_LEN as the gd monitor len for Blackfin - reserve u-boot memory at the top field of the RAM for Blackfin - avoid refer to CONFIG_SYS_MONITOR_LEN, which is not defined by Blackfin Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2014-07-23dm: Support driver model prior to relocationSimon Glass
Initialise devices marked 'pre-reloc' and make them available prior to relocation. Note that this requires pre-reloc malloc() to be available. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-23Add a simple malloc() implementation for pre-relocationSimon Glass
If we are to have driver model before relocation we need to support some way of calling memory allocation routines. The standard malloc() is pretty complicated: 1. It uses some BSS memory for its state, and BSS is not available before relocation 2. It supports algorithms for reducing memory fragmentation and improving performace of free(). Before relocation we could happily just not support free(). 3. It includes about 4KB of code (Thumb 2) and 1KB of data. However since this has been loaded anyway this is not really a problem. The simplest way to support pre-relocation malloc() is to reserve an area of memory and allocate it in increasing blocks as needed. This implementation does this. To enable it, you need to define the size of the malloc() pool as described in the README. It will be located above the pre-relocation stack on supported architectures. Note that this implementation is only useful on machines which have some memory available before dram_init() is called - this includes those that do no DRAM init (like tegra) and those that do it in SPL (quite a few boards). Enabling driver model preior to relocation for the rest of the boards is left for a later exercise. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-18common: board_f: cosmetic use __weak for ledsJeroen Hofstee
First of all this looks a lot better, but it also prevents a gcc warning (W=1), that the weak function has no previous prototype. cc: Simon Glass <sjg@chromium.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-12common/board_f: Fix size variableYork Sun
DRAM size should use 64-bit variable when the size could be more than 4GB. Caught and verified on P4080DS with 4GB DDR. Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-12common/board_f: Initialized global data for generic boardYork Sun
Some platforms (tested on mpc85xx, mpc86xx) use global data before calling function baord_inti_f(). The data should not be cleared later. Any arch which uses global data in generic board board_init_f() should define CONFIG_SYS_GENERIC_GLOBAL_DATA. Signed-off-by: York Sun <yorksun@freescale.com> CC: Scott Wood <scottwood@freescale.com> CC: Simon Glass <sjg@chromium.org> CC: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-12bd_info: remove bi_barudrate member from struct bd_infoMasahiro Yamada
gd->bd->bi_baudrate is a copy of gd->baudrate. Since baudrate is a common feature for all architectures, keep gd->baudrate only. It is true that bi_baudrate was passed to the kernel in that structure but it was a long time ago. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
2014-04-20board_f: call timer_init on MIPSPaul Burton
MIPS needs a call to timer_init to preserve its current behaviour ensuring that the cop0 compare register is initialised appropriately. Reported-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2014-04-20board_f: call init_func_ram on MIPSPaul Burton
Assigning gd->ram_size the return value of initdram matches the existing MIPS board behaviour. Suggested-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2014-03-17sandbox: Use os functions to read host device treeSimon Glass
At present we use U-Boot's filesystem layer to read the sandbox device tree, but this is problematic since it relies on a temporary feauture added there. Since we plan to implement proper block layer support for sandbox, change this code to use the os layer functions instead. Also use the new fdt_create_empty_tree() instead of our own code. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-07powerpc: mpc8260: consolidate CONFIG_MPC8260 and CONFIG_8260Masahiro Yamada
Before this commit, CONFIG_MPC8260 and CONFIG_8260 were used mixed-up. All boards with mpc8260 cpu defined both of them: - CONFIG_MPC8260 was defined in board config headers and include/common.h - CONFIG_8260 was defined arch/powerpc/cpu/mpc8260/config.mk We do not need to have both of them. This commit keeps only CONFIG_MPC8260. This commit does: - Delete CONFIG_8260 and CONFIG_MPC8260 definition in config headers and include/common.h - Rename CONFIG_8260 to CONFIG_MPC8260 in arch/powerpc/cpu/mpc8260/config.mk. - Rename #ifdef CONFIG_8260 to #ifdef CONFIG_MPC8260 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de>
2014-02-26Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: arch/arm/cpu/armv7/config.mk board/ti/am43xx/mux.c include/configs/am43xx_evm.h Signed-off-by: Tom Rini <trini@ti.com>
2014-02-26arm: remove unneeded symbol offsets and _TEXT_BASEAlbert ARIBAUD
Remove the last uses of symbol offsets in ARM U-Boot. Remove some needless uses of _TEXT_BASE. Remove all _TEXT_BASE definitions. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-02-21common: Add get_effective_memsize() to memsize.cYork Sun
This function has been around for powerpc. It is used for systems with memory more than CONFIG_MAX_MEM_MAPPED. In case of non-contiguous memory, this feature can limit U-boot to one block without going over the limit. Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-02-19Move #ifdef(CONFIG_DISPLAY_CPUINFO) from caller to calleeMasahiro Yamada
- When CONFIG_DISPLAY_CPUINFO is not enabled, print_cpuinfo() should be defined as an empty function in a header, include/common.h - Remove #ifdef CONFIG_DISPLAY_CPUINFO .. #endif from caller, common/board_f.c and arch/arm/lib/board.c - Remove redundant prototypes in arch/arm/lib/board.c, arch/arm/include/asm/arch-am33x/sys_proto.h and board/nokia/rx51/rx51.h, keeping the one in include/common.h - Add #ifdef CONFIG_DISPLAY_CPUINFO to the func definition where it is missing Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19dts: re-write dts/Makefile more simply with KbuildMasahiro Yamada
Useful rules in scripts/Makefile.lib allows us to easily generate a device tree blob and wrap it in assembly code. We do not need to parse a linker script to get output format and arch. This commit deletes ./u-boot.dtb since it is a copy of dts/dt.dtb. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Bringing in the MMC tree means that CONFIG_BOUNCE_BUFFER needed to be added to include/configs/exynos5-dt.h now. Conflicts: include/configs/exynos5250-dt.h Signed-off-by: Tom Rini <trini@ti.com>
2014-01-09arm64: generic board supportDavid Feng
Signed-off-by: David Feng <fenghua@phytium.com.cn>
2014-01-08sandbox: Allow reading/writing of RAM bufferSimon Glass
It is useful to be able to save and restore the RAM contents of sandbox U-Boot either for setting up tests, for later analysys, or for chaining together multiple tests which need to keep the same memory contents. Add a function to provide a memory file for U-Boot. This is read on start-up and written when shutting down. If the file does not exist on start-up, it will be created when shutting down. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-01-08sandbox: Allow return from board_init_f()Simon Glass
The execution flow becomes easier if we can return from board_init_f() as ARM does. We can control things from start.c instead of having to call back into that file from other places. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-13board_f: explicitly disable console on early bootAlexey Brodkin
If U-Boot build with DEBUG enabled/defined the first call of "debug" function (that dumps data to any available console) will happen before zeroing of initial "gd" in init call "zero_global_data" in "init_sequence_f". And if stack was not filled with zeros chances are high that "gd->have_console" won't be 0. In its turn it will cause attempt to output things to non-initialized yet serial console. So for safety and predictability we set "gd->have_console = 0". Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Mischa Jonker <mjonker@synopsys.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-10-17i2c: fix init on generic boardtrem
On generic board, the i2c init initialize only one bus. But the new i2c subsystem allow to manage severals i2c bus. So in the case, instead of initializing a bus, we just set the current i2c bus. The initialization will be done in the i2c command. Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c: common changes for multibus/multiadapter supportHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org> Cc: Henrik Nordström <henrik@henriknordstrom.net>
2013-06-26Add trace support to generic boardSimon Glass
Add hooks for tracing to generic board, including: - allow early tracing to start early as possible in U-Boot - reserve memory for trace buffer - copy early trace buffer to main trace buffer after relocation - setup full tracing support after relocation Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-07generic_board: reduce the redundancy of gd_t struct membersMasahiro Yamada
This commit refactors common/board_f.c and common/board_r.c in order to delete the dest_addr and dest_addr_sp from gd_t struct. As mentioned as follows in include/asm-generic/global_data.h, /* TODO: is this the same as relocaddr, or something else? */ unsigned long dest_addr; /* Post-relocation address of U-Boot */ dest_addr is the same as relocaddr. Likewise, dest_addr_sp is the same as start_addr_sp. It seemed dest_addr/dest_addr_sp was used only as a scratch variable to calculate relocaddr/start_addr_sp, respectively. With a little refactoring, we can delete dest_addr and dest_addr_sp. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org>
2013-06-04common: board_f: Do not call board_postclk_init twiceMasahiro Yamada
The generic-board board_init_f function called board_postclk_init twice. The first one came from arch/arm/lib/board.c, while the second one from arch/powerpc/lib/board.c. This commit deletes the first occurrence. In addition, the second get_clocks call is moved after board_postclk_init in order to keep the function call order both for ARM and PowerPC. ARM board calles get_clocks function after board_postclk_init. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-05-15Power: remove support for Freescale MPC8220Wolfgang Denk
The Freescale MPC8220 Power Architecture processors have long reached EOL; Freescale does not even list these any more on their web site. Remove the code to avoid wasting maitaining efforts on dead stuff. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com>
