path: root/common/autoboot.c
2014-07-18autoboot: add its own headerJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-06-19cosmetic: autoboot: update old style GNU struct initJeroen Hofstee
2014-05-29main: Make the execution path a little clearer in main.cSimon Glass
bootdelay_process() never returns in some circumstances, whichs makes the control flow confusing. Change it so that the decision about how to execute the boot command is made in the main_loop() code, so it is easier to follow. Move CLI stuff to cli.c. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Rename bootretry functions and remove #ifdefsSimon Glass
Add a bootretry_ prefix to these two functions, and remove the need for the #ifdef around everything (it moves to the Makefile). Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Move bootretry code into bootretry.c and clean upSimon Glass
This code is only used by one board, so it seems a shame to clutter up the readline code with it. Move it into its own file. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Move autoboot code to autoboot.cSimon Glass
The autoboot code is complex and long. It deserves its own file with a simple interface from main.c. Signed-off-by: Simon Glass <sjg@chromium.org>
