path: root/common/autoboot.c
2016-07-01autoboot: move bootdelay >= 0 check to abortboot()Masahiro Yamada
Move the bootdelay >= 0 check to the caller, which simplifies the callees. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher <hs@denx.de>
2016-07-01autoboot: move CONFIG_SILENT_CONSOLE handlingMasahiro Yamada
Factor out the same code from the callees to the caller. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher <hs@denx.de>
2016-07-01autoboot: rename abortboot_{keyed, normal} to __abortbootMasahiro Yamada
Because abortboot_keyed() and abortboot_normal() are not compiled at the same time, we can rename both of them to __abortboot(). This allows to drop #ifdef from the caller. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher <hs@denx.de>
2016-07-01autoboot: remove CONFIG_ZERO_BOOTDELAY_CHECKMasahiro Yamada
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2 means the autoboot with no delay, with no abort check even if CONFIG_ZERO_BOOTDELAY_CHECK is defined. To sum up, the autoboot behaves as follows: [1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n autoboot with no delay, with no check for abort [3] CONFIG_BOOTDELAY=-1 disable autoboot [4] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort As you notice, [2] and [4] come to the same result, which means we do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the cases only by CONFIG_BOOTDELAY, like this: [1] CONFIG_BOOTDELAY=0 autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=-1 disable autoboot [3] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort This commit converts the logic as follow: CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n --> CONFIG_BOOTDELAY=-2 Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Christian Riesch <christian.riesch@omicronenergy.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2016-02-05autoboot.c: Fill env vars in process_fdt_options() only if TEXT_BASE is setStefan Roese
The x86 build target "efi-x86" has no TEXT_BASE configured. And with the introduction of CONFIG_BOOTDELAY for x86, this function is now called for this board as well. Resulting in compile errors for this target. Without TEXT_BASE it makes no sense to fill these values. So lets only configure the env variable if TEXT_BASE is defined. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-19Move console definitions into a new console.h fileSimon Glass
The console includes a global variable and several functions that are only used by a small subset of U-Boot files. Before adding more functions, move the definitions into their own header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-08autoboot.c: Add feature to stop autobooting via SHA256 encrypted passwordStefan Roese
This patch adds the feature to only stop the autobooting, and therefor boot into the U-Boot prompt, when the input string / password matches a values that is encypted via a SHA256 hash and saved in the environment. This feature is enabled by defined these config options: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_STOP_STR_SHA256 Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-06-08autoboot.c: Move config options to KconfigStefan Roese
This patch moves the following config options to Kconfig: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Drop ip04 and pm9263 configs/ additions, those boards previously set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over all boards that did change. Make digsy_mtc_* string include seconds to match others and not warn. ] Signed-off-by: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-06-08autoboot.c: Remove CONFIG_AUTOBOOT_STOP_STR2 and CONFIG_AUTOBOOT_DELAY_STR2Stefan Roese
These defines for a 2nd autoboot stop and delay string are nearly unused. Only sc3 defines CONFIG_AUTOBOOT_DELAY_STR2. And a patch to remove this most likely unmaintained board is also posted to the list. By removing these defines the code will become cleaner and moving the remaining compile options to Kconfig will get easier. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de>
2014-07-18autoboot: add its own headerJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-06-19cosmetic: autoboot: update old style GNU struct initJeroen Hofstee
2014-05-29main: Make the execution path a little clearer in main.cSimon Glass
bootdelay_process() never returns in some circumstances, whichs makes the control flow confusing. Change it so that the decision about how to execute the boot command is made in the main_loop() code, so it is easier to follow. Move CLI stuff to cli.c. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Rename bootretry functions and remove #ifdefsSimon Glass
Add a bootretry_ prefix to these two functions, and remove the need for the #ifdef around everything (it moves to the Makefile). Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Move bootretry code into bootretry.c and clean upSimon Glass
This code is only used by one board, so it seems a shame to clutter up the readline code with it. Move it into its own file. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Move autoboot code to autoboot.cSimon Glass
The autoboot code is complex and long. It deserves its own file with a simple interface from main.c. Signed-off-by: Simon Glass <sjg@chromium.org>
