path: root/common/Makefile
2014-05-29Move bootretry code into bootretry.c and clean upSimon Glass
This code is only used by one board, so it seems a shame to clutter up the readline code with it. Move it into its own file. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Move command line API into cli.cSimon Glass
We now have a single entry point to the CLI, whether simple or hush. Put this in its own file. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Move autoboot code to autoboot.cSimon Glass
The autoboot code is complex and long. It deserves its own file with a simple interface from main.c. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Split out simple parser and readline into separate filesSimon Glass
It doesn't make sense to have the simple parser and the readline code all in main. Split them out into separate files. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Rename hush to cli_hushSimon Glass
Hush is a command-line interpreter, so rename it to make that clearer. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-08usb/gadget: add the fastboot gadgetSebastian Siewior
This patch contains an implementation of the fastboot protocol on the device side and documentation. This is based on USB download gadget infrastructure. The fastboot function implements the getvar, reboot, download and reboot commands. What is missing is the flash handling i.e. writting the image to media. v3 (Rob Herring): This is based on http://patchwork.ozlabs.org/patch/126798/ with the following changes: - Rebase to current mainline and updates for current gadget API - Use SPDX identifiers for licenses - Traced the history and added missing copyright to cmd_fastboot.c - Use load_addr/load_size for transfer buffer - Allow vendor strings to be optional - Set vendor/product ID from config defines - Allow Ctrl-C to exit fastboot mode v4: - Major re-write to use the USB download gadget. Consolidated function code to a single file. - Moved globals into single struct. - Use puts and putc as appropriate. - Added CONFIG_USB_FASTBOOT_BUF_ADDR and CONFIG_USB_FASTBOOT_BUF_SIZE to set the fastboot transfer buffer. v5: - Add CONFIG option documentation to README - Rebase using new downloader registration Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Rob Herring <robh@kernel.org>
2014-05-08image: add support for Android's boot image formatSebastian Siewior
This patch adds support for the Android boot-image format. The header file is from the Android project and got slightly alterted so the struct + its defines are not generic but have something like a namespace. The header file is from bootloader/legacy/include/boot/bootimg.h. The header parsing has been written from scratch and I looked at bootloader/legacy/usbloader/usbloader.c for some details. The image contains the physical address (load address) of the kernel and ramdisk. This address is considered only for the kernel image. The "second image" defined in the image header is currently not supported. I haven't found anything that is creating this. v3 (Rob Herring): This is based on http://patchwork.ozlabs.org/patch/126797/ with the following changes: - Rebased to current mainline - Moved android image handling to separate functions in common/image-android.c - s/u8/char/ in header to fix string function warnings - Use SPDX identifiers for licenses - Cleaned-up file source information: android_image.h is from file include/boot/bootimg.h in repository: https://android.googlesource.com/platform/bootable/bootloader/legacy The git commit hash is 4205b865141ff2e255fe1d3bd16de18e217ef06a usbloader.c would be from the same commit, but it does not appear to have been used for any actual code. v4: - s/andriod/android/ - Use a separate flag ep_found to track if the entry point has been set rather than using a magic value. Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Rob Herring <robh@kernel.org> Reviewed-by: Tom Rini <trini@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2014-04-17Merge branch 'next'Tom Rini
2014-03-22Add lzmadec commandPatrice Bouchand
I needed to be able to uncompress lzma files. I did this command based on unzip command and propose it if it could help. Signed-off-by: Patrice Bouchand <pbfwdlist@gmail.com> Changed to work with sandbox Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-21aes: Add 'aes' command to access AES-128-CBCMarek Vasut
Add simple 'aes' command, which allows using the AES-128-CBC encryption and decryption functions from U-Boot command line. Signed-off-by: Marek Vasut <marex@denx.de>
2014-03-17cros_ec: Move EC interface into common libraryVadim Bendebury
Add a common library for obtaining access to the Chrome OS EC. This is used by boards which need to talk to the EC. Reviewed-by: Vadim Bendebury <vbendeb@google.com> Tested-by: Vadim Bendebury <vbendeb@google.com> Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-04dm: Add a demonstration/example driverSimon Glass
As an example of how to write a uclass and a driver, provide a demo version of each, accessible through the 'demo' command. To use these with driver model, define CONFIG_CMD_DEMO and CONFIG_DM_DEMO. The two demo drivers are enabled with CONFIG_DM_DEMO_SIMPLE and CONFIG_DM_DEMO_SHAPE. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com> Signed-off-by: Viktor Křivák <viktor.krivak@gmail.com> Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com>
2014-02-26Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: arch/arm/cpu/armv7/config.mk board/ti/am43xx/mux.c include/configs/am43xx_evm.h Signed-off-by: Tom Rini <trini@ti.com>
2014-02-26arm: Switch to -mno-unaligned-access when supported by the compilerTom Rini
When we tell the compiler to optimize for ARMv7 (and ARMv6 for that matter) it assumes a default of SCTRL.A being cleared and unaligned accesses being allowed and fast at the hardware level. We set this bit and must pass along -mno-unaligned-access so that the compiler will still breakdown accesses and not trigger a data abort. To better help understand the requirements of the project with respect to unaligned memory access, the Documentation/unaligned-memory-access.txt file has been added as doc/README.unaligned-memory-access.txt and is taken from the v3.14-rc1 tag of the kernel. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Mans Rullgard <mans@mansr.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-02-21fs/fdos: RemoveTom Rini
We have an unused FAT implementation in fs/fdos, remove. Signed-off-by: Tom Rini <trini@ti.com>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19common: spl: Add spl sata boot supportDan Murphy
Add spl_sata to read a fat partition from a bootable SATA drive. Signed-off-by: Dan Murphy <dmurphy@ti.com> Reviewed-by: Roger Quadros <rogerq@ti.com>
2014-02-04common: Add new clk commandMichal Simek
Command provides just dump subcommand for showing clock frequencies in a soc. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-01-24spl: common: Support for USB MSD FAT image loadingDan Murphy
Add SPL support to be able to detect a USB Mass Storage device connected to a USB host. Once a USB Mass storage device is detected the SPL will load the u-boot.img from a FAT partition to target address. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-12-13Makefile: delete unnecessary CPPFLAGS settingsMasahiro Yamada
2013-11-25common: Delete unnecessary rules.Masahiro Yamada
The directory tools/ is always built before common/. So when envcrc tool is necessary in common/Makefile, it already exists. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-10-31common: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-20cmd:thor: Support for TIZEN's download command (thordown)Lukasz Majewski
New command - thordown - has been added to support downloading data via lthor TIZEN program. It is similar to dfu command syntax and reuses its code for flashing data. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2013-07-25powerpc/ppc4xx: Add fpgad command for dumping gdsys fpga registersDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2013-07-01video: lcd: Add CONFIG_SPLASH_SCREEN_PREPARE support to CONFIG_VIDEORobert Winkler
Create splash.c/h to put the function and any future common splash screen code in. Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-06-26image: Add signing infrastructureSimon Glass
Add a structure to describe an algorithm which can sign and (later) verify images. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26Add a trace commandSimon Glass
Add a trace command with sub-commands to start/stop tracing, print out statistics and dump trace information to memory for later upload to a host. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-20Makefile: move the common makefile line to public areaYing Zhang
Move the common makefile line shared by the SPL and non-SPL to the public area, so that we can avoid excessive SPL symbols. Some of them will be used by the SPL later. This patch is on top of the patch "common/Makefile: Add new symbol CONFIG_SPL_ENV_SUPPORT for environment in SPL". Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20common/Makefile: Add new symbol CONFIG_SPL_ENV_SUPPORT for environment in SPLYing Zhang
There will need the environment in SPL for reasons other than network support (in particular, hwconfig contains info for how to set up DDR). Add a new symbol CONFIG_SPL_ENV_SUPPORT to replace CONFIG_SPL_NET_SUPPORT for environment in common/Makefile. Signed-off-by: Ying Zhang <b40530@freescale.com> Reviewed-by: Tom Rini <trini@ti.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-30Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: common/cmd_fpga.c drivers/usb/host/ohci-at91.c
2013-05-14image: Split libfdt code into image-fdt.cSimon Glass
The image file is still very large, and some of the code is only used when libfdt is in use. Move this code into a new file. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-14image: Split FIT code into new image-fit.cSimon Glass
The FIT code is about half the size of the >3000-line image.c. Split this code into its own file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-05-13blackfin: bf609: add softswitch config commandBob Liu
Add softswitch_output command for bf609-ezkit to enable softswitches. Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2013-04-28Add fuse API and commandsBenoît Thébaudeau
This can be useful for fuse-like hardware, OTP SoC options, etc. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-11env: Add support for UBI environmentJoe Hershberger
UBI is a better place for the environment on NAND devices because it handles wear-leveling and bad blocks. Gluebi is needed in Linux to access the env as an MTD partition. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-03-29New command bootmenu: ANSI terminal boot menu supportPali Rohár
The "bootmenu" command uses U-Boot menu interfaces and provides a simple mechanism for creating menus with several boot items. When running this command the menu will be assembled as defined by a set of environment variables which contain a title and command key-value pairs. The "Up" and "Down" keys are used for navigation through the items. Current active menu item is highlighted and can be selected using the "Enter" key. The command interprets and generates various ANSI escape sequencies, so for proper menu rendering and item selection the used terminal should support them. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> [agust: various fixes and documentation updates] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-03-18usb:gadget: USB Mass Storage Gadget supportLukasz Majewski
This patch adds the USB Mass Storage Gadget to u-boot New command called "ums" is implemented to provide access to on-device embedded persistent memory. USB Mass Storage is supposed to work on top of the USB Gadget framework Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Marek Vasut <marek.vasut@gmail.com>
2013-03-15Introduce generic post-relocation board_r.cSimon Glass
This file handles common post-relocation init for boards which use the generic framework. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-15Introduce generic pre-relocation board_f.cSimon Glass
This file handles common pre-relocation init for boards which use the generic framework. It starts up the console, DRAM, performs relocation and then jumps to post-relocation init. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2013-03-04sandbox: Add 'sb' command to access filesystem featuresSimon Glass
The new 'sb' command is intended to deal with sandbox-specific features that have no parallel in other archs. This commit adds two sub-commands to list a directory and read a file from the host filesystem. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2012-12-19Merge remote-tracking branch 'u-boot/master' into u-boot-arm-mergedAllen Martin
Conflicts: README arch/arm/cpu/armv7/exynos/clock.c board/samsung/universal_c210/universal.c drivers/misc/Makefile drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/seaboard.h
2012-12-13env: Add environment variable flagsJoe Hershberger
Currently just validates variable types as decimal, hexidecimal, boolean, ip address, and mac address. If the entry is not found in the env ".flags", then look in the static one. This allows the env to override the static definitions, but prevents the need to have every definition in the environment distracting you. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Add support for callbacks to environment varsJoe Hershberger
Add support for per-variable callbacks to the "hashtable" functions. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> !!!fix comment in callback
2012-12-13gpt: Support for new "gpt" commandPiotr Wilczek
New command - "gpt" is supported. It restores the GPT partition table. It looks into the given environment variable for partitions definition. It can be enabled at target configuration file with CONFIG_CMD_GPT. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2012-12-11Add console command to access io space registersVadim Bendebury
Provide u-boot console functions to access IO space registers. A no thrills implementation, accessing one register at a time. For example: boot > iod 80 0080: 00000094 boot > iod.w 80 0080: 0094 boot > iod.b 80 0080: 94 boot > iow.b 0x80 12 boot > iod 0x80 0080: 00000012 Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-11edid: Library of EDID decode and printTom Wai-Hong Tam
This implements a library for accessing EDID data from an LCD panel. This is used to obtain information about the panel such as its resolution and type. This is a tidied-up version of the original code pulled from https://github.com/ynezz/u-boot-edid. The changes we made are: - removed bit fields in the struct; - removed endianness cases in the struct; - fixed some wrong definitions; - fixed to fit 80 columns; - fixed some code styles. Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-11Add hash command to perform hashing using various algorithmsSimon Glass
This new command supports hashing SHA1 and SHA256. It could be extended to others such as MD5 and the CRC algorithms. The syntax is modeled on those: hash <algorithm> <address> <length> [*<dest_addr> | <dest_envvar>] to calculate a hash, and: hash -v <algorithm> <address> <length> [*<verify_addr> | <verify_envvar>] to verify a hash. Use CONFIG_CMD_HASH to enable the command, CONFIG_SHA1 to enable SHA1 and CONFIG_SHA256 to enable SHA256. The existing sha1sum command remains. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-11Add generic hash APISimon Glass
We have a SHA1 command and want to add a SHA256 command also. Instead of duplicating the code, create a generic hash API which can process commands for different algorithms. Signed-off-by: Simon Glass <sjg@chromium.org>
