The command gets an arbitrary number of arguments (up to 30), which
are interpreted as byte values and are feed into the TPM device after
proper initialization. Then the return value and data of the TPM
driver is examined.
TPM commands are described in the TCG specification.
For instance, the following sequence is the 'TPM Startup' command, it
is processed by the TPM and a response is generated:
boot > tpm 0x0 0xc1 0x0 0x0 0x0 0xc 0x0 0x0 0x0 0x99 0x0 0x1
Found TPM SLB9635 TT 1.2 by Infineon
Got TPM response:
00 c4 00 00 00 0a 00 00 00 00
If the command is corrupted (fed one byte short), an error is reported:
generic_lpc_tpm.c:311 unexpected TPM status 0xff000888
generic_lpc_tpm.c:516 failed sending data to TPM
tpm command failed
boot >
Change-Id: I3f3c5bfec8b852e208c4e99ba37b0f2b875140b0
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
CC: Wolfgang Denk <wd@denx.de>
FAT library now uses malloc() and free(). But SPL doesn't
have heap until now. Setup a heap in SDRAM to fix this issue.
However this increases SPL footprint beyond the available SRAM
budget. So, compile out some fancy features in the SDARM init
bring back footprint under control
CC: Sandeep Paulraj <s-paulraj@ti.com>
Signed-off-by: Aneesh V <aneesh@ti.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
We prefer to U-Boot's malloc but for now it is easier to use the C library's
version.
Add pxe command, which is intended to mimic PXELINUX functionality.
'pxe get' uses tftp to retrieve a file based on UUID, MAC address or IP
address. 'pxe boot' interprets the contents of PXELINUX config like file
to boot using a specific initrd, kernel and kernel command line.
This patch also adds a README.pxe file - see it for more details on the
pxe command.
Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
This will be used first by the pxe code, but is intended to be
generic and reusable for other jobs in U-boot.
The 'time' command runs and reports execution time of commands.
Sample usage:
u-boot# time crc 0x1000 1000
CRC32 for 00001000 ... 00001fff ==> ae94dc4b
time: 0.004 seconds, 4 ticks
Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
Unified DDR driver is maintained for better performance, robustness and bug
fixes. Upgrading to use unified DDR driver for MPC83xx takes advantage of
overall improvement. It requires changes for board files to customize
platform-dependent parameters.
To utilize the unified DDR driver, a board needs to define CONFIG_FSL_DDRx
in the header file. No more boards will be accepted without such definition.
Note: the workaround for erratum DDR6 for the very old MPC834x Rev 1.0/1.1
and MPC8360 Rev 1.1/1.2 parts is not migrated to unified driver.
Signed-off-by: York Sun <yorksun@freescale.com>
Addition of cmd_led into the Makefile wasn't included in the patch
applied to u-boot-ti.
Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
Signed-off-by: Koen Kooi <koen@dominion.thruhere.net>
Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com>
Command calls update_tftp() analogous to automatic update described
in doc/README.update.
Usage:
fitupd [addr]
- run update from FIT image at addr
or from tftp 'updatefile'
Signed-off-by: Andreas Pretzsch <apr@cn-eng.de>
The 'trab' board configuration is broken, and there is nobody who is
interested and willing to fix it. Drop it.
This includes support for VFD displays which have always been used by
this board only.
The new mdio command doesn't have all of the features of the mii
command, but it provides the necessary read/write primitives, and allows
users to interact with 10G PHYs, and other PHYs which use Clause 45 of
802.3. This means that the mdio command requires a "Device Address"
argument, though for clause 22 PHYs, the argument can be "-".
Signed-off-by: Andy Fleming <afleming@freescale.com>
Acked-by: Detlev Zundel <dzu@denx.de>
Extends the mii_dev structure to participate in a full-blown MDIO and
PHY driver scheme. The mii_dev structure and miiphy calls are modified
in such a way to allow the original mii command and miiphy
infrastructure to work as before, but also to support a new set of APIs
which allow (among other things) sharing of PHY driver code and 10G support
The mii command will continue to support normal PHY management functions
(Clause 22 of 802.3), but will not be changed to support 10G
(Clause 45).
The basic design is similar to PHY Lib from Linux, but simplified for
U-Boot's network and driver infrastructure.
We now have MDIO drivers and PHY drivers
An MDIO driver provides:
read
write
reset
A PHY driver provides:
(optionally): probe
config - initial setup, starting of auto-negotiation
startup - waiting for AN, and reading link state
shutdown - any cleanup needed
The ethernet drivers interact with the PHY Lib using these functions:
phy_connect()
phy_config()
phy_startup()
phy_shutdown()
Each PHY driver can be configured separately, or all at once using
config_phylib_all_drivers.h (added in the patch which adds the drivers)
We also provide generic drivers for Clause 22 (10/100/1000), and
Clause 45 (10G) PHYs.
We also implement phy_reset(), and call it in phy_connect(). Because
phy_reset() is essentially the same as miiphy_reset, but:
a) must support 10G PHYs, and
b) should use the phylib primitives,
we implement miiphy_reset, using phy_reset(), but only when
CONFIG_PHYLIB is set. Otherwise, we just use the old version. In this
way, we save on compile size, even if we don't manage to save code size.
Pulled ethtool.h and mdio.h from:
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6
782d640afd15af7a1faf01cfe566ca4ac511319d
With many, many deletions so as to enable compilation under u-boot
The Blackfin gpio command isn't terribly Blackfin-specific. So generalize
the few pieces into two new optional helpers:
name_to_gpio() - turn a string name into a GPIO #
gpio_status() - display current pin bindings (think /proc/gpio)
Once these pieces are pulled out, we can relocate the cmd_gpio.c into the
common directory.
There's no real need to keep these functions in the cmd_mem file since
they do not use any of the common global mem variables. So split them
out into their own dedicated cmd files.
This patch supports mmc/sd card with spi interface. It is based on
the generic mmc framework. It works with SDHC and supports multi
blocks read/write.
The crc checksum on data packet is enabled with the def,
There is a subcomamnd "mmc_spi" to setup spi bus and cs at run time.
Simple command to decode/check an LDR image before we try to boot it.
We have config_defaults.h which are random configuration settings that
everyone gets by default. We also have config_cmd_default.h which is a
recommended list of defaults but boards have to opt into. Now we have
config_cmd_defaults.h which is a list of defaults that everyone gets
and has to actively opt out of.
For now, we populate it with the bootm command which previously was
unable to be disabled.
Some boards use an embedded environment, where env_embedded.o has to
be linked at a special position in the U-Boot image; to make this
possible, we do not include it into libcommon.o for such boards.
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
This patch is to save environment data to mmc card.
It uses interfaces defined in generic mmc.
Signed-off-by: Terry Lv <r65388@freescale.com>
cramfsls and cramfsload are added to the command list.
A cramfs placed at 'cramfs_addr' can the be listed with 'cramfsls' and files
can be loaded with 'cramfsload'. 'cramfs_addr' is an environment variable
specifying the address the cramfs is located.
This works for powerpc and for ARM.
Use CONFIG_CMD_CRAMFS.
Signed-off-by: Andreas Huber <andreas.huber@keymile.com>
The default kgdb functions can be implemented with common U-Boot functions,
so rather than force everyone to copy & paste these things, create a set of
weak stubs.
Signed-off-by: Robin Getz <robin.getz@analog.com>
board/esd/plu405/plu405.c
drivers/rtc/ftrtc010.c
circbuf could be used as a generic library and is only currently
needed when CONFIG_USB_TTY is defined.
command.c should contain common code related to commands, not
miscellaneous command implementations.
Breaks building on many boards, and no really clean fix available yet.
This reverts commit 6dab6add2d8ee80905234b326abc3de11be1d178.
The env code is protected by the ENV_IS_EMBEDDED define, so attempting to
compile the code when this isn't defined is pointless. Now that the env
headers have unified around CONFIG_ENV_IS_EMBEDDED, convert the build
system to only build the env objects when this is enabled. And now that
the env code is conditionally compiled, we can drop the source code checks.
For people who want to extract the environment manually, add a new option
CONFIG_BUILD_ENVCRC that only enables the envcrc utility.
From: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
This patch adds support for the Tundra TSI148 VME-bridge. It's used on
the upcoming esd VME8349 board.
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
So far the console API uses the following naming convention:
======Extract======
typedef struct device_t;
int device_register (device_t * dev);
int devices_init (void);
int device_deregister(char *devname);
struct list_head* device_get_list(void);
device_t* device_get_by_name(char* name);
device_t* device_clone(device_t *dev);
which is too generic and confusing.
Instead of using device_XX and device_t we change this
into stdio_XX and stdio_dev
This will also allow to add later a generic device mechanism in order
to have support for multiple devices and driver instances.
Edited commit message.
Legacy NAND had been scheduled for removal. Any boards that use this
were already not building in the previous release due to an #error.
The disk on chip code in common/cmd_doc.c relies on legacy NAND,
and it has also been removed. There is newer disk on chip code
in drivers/mtd/nand; someone with access to hardware and sufficient
time and motivation can try to get that working, but for now disk
on chip is not supported.
This patch implements simple hwconfig infrastructure: an
interface for software knobs to control a hardware.
This is very simple implementation, i.e. it is implemented
via `hwconfig' environment variable. Later we could write
some "hwconfig <enable|disable|list>" commands, ncurses
interface for Award BIOS-like interface, and frame-buffer
interface for AMI GUI[1] BIOS-like interface with mouse
support[2].
Current implementation details/limitations:
1. Doesn't support options dependencies and mutual exclusion.
We can implement this by integrating apt-get[3] into the
u-boot. But I didn't bother yet.
2. Since we don't implement hwconfig command, i.e. we're working
with the environement directly, there is no way to tell that
toggling a particular option will need a reboot to take
an effect. So, for now it's advised to always reboot the
target after modifying hwconfig variable.
3. We support hwconfig options with arguments. For example,
set hwconfig dr_usb:mode=peripheral,phy_type=ulpi
That means:
- dr_usb - enable Dual-Role USB controller;
- dr_usb:mode=peripheral - USB in Function mode;
- dr_usb:phy_type=ulpi - USB should work with ULPI PHYs;
The purpose of this simple implementation is to define some
internal API and then we can continue improving user experience
by adding more mature interface, like hwconfig command with
bells and whistles. Or not adding, if we feel that current
interface fits its needs.
[1] http://en.wikipedia.org/wiki/American_Megatrends
[2] Regarding ncurses and GUI with mouse support -- I'm just
kidding.
[3] The comment regarding apt-get is also a joke, meaning that
dependency tracking could be non-trivial. For example, for
enabling HW feature X we may need to disable Y, and turn Z
into reduced mode (like RMII-only interface for ethernet,
no MII).
It's quite trivial to implement simple cases though.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Newer Blackfin parts can an on-chip ROM that can boot LDRs over SPI flashes,
so add a new 'spibootldr' command to take advantage of it.
The kernel stores address<->symbol names in it so things can be decoded at
runtime. Do it in U-Boot, and we get nice symbol decoding when crashing.
and fix comment
Adjusted Copyright message.
In addition to the changes for CONFIG_ENV_IS_IN_FLASH as done in
commit afcbce07, we also need to do the same for
CONFIG_ENV_IS_IN_EEPROM and CONFIG_ENV_IS_IN_NVRAM.
Since commit a706bfc7 common/env_embedded.o and tools/envcrc were
only built when CONFIG_ENV_IS_EMBEDDED was set, but this breaks
building for many boards.
We always have to build these files when CONFIG_ENV_IS_IN_FLASH is
set.
Mflash is fusion memory device mainly targeted consumer eletronic and
mobile phone.
Internally, it have nand flash and other hardware logics and supports
some different operation (ATA, IO, XIP) modes.
IO mode is custom mode for the host that doesn't have IDE interface.
(Many mobile targeted SoC doesn't have IDE bus)
This driver support mflash IO mode.
Followings are brief descriptions about IO mode.
1. IO mode based on ATA protocol and uses some custom command. (read
confirm, write confirm)
2. IO mode uses SRAM bus interface.
Signed-off-by: unsik Kim <donari75@gmail.com>
According to the doc/feature-removal-schedule.txt, the "autoscr"
command will be replaced by the "source" command in approximately 6
months from now.
This patch prepares this change and starts a 6 month transition
period as follows:
- The new "source" command has been added, which implements exactly
the same functionlaity as the old "autoscr" command before
- The old "autoscr" command name is kept as an alias for compatibility
- Command sequences, script files atc. have been adapted to use the
- Related environment variables ("autoscript", "autoscript_uname")
have *not* been adapted yet; these will be renamed resp. removed in
a separate patch when the support for the "autoscr" command get's
finally dropped.
This patchset adds these UBIFS related commands:
- ubifsmount
Mount an UBIFS volume
- ubifsls
List a directory of the mounted UBIFS volume
- ubifsload
Load a file from the mounted UBIFS volume to memory
Currently the mtdparts commands are included in the jffs2 command support.
This doesn't make sense anymore since other commands (e.g. UBI) use this
infrastructure as well now. This patch separates the mtdparts commands from
the jffs2 commands making it possible to only select mtdparts when no JFFS2
support is needed.
Move global '#ifdef CONFIG_xxx .... #endif' out of the .c files and into
the COBJS-$(CONFIG_xxx) in the Makefile. Also delete unused var in kgdb
code in the process.
Modifications to support console multiplexing. This is controlled using
CONFIG_SYS_CONSOLE_MUX in the board configuration file.
This allows a user to specify multiple console devices in the environment
with a command like this: setenv stdin serial,nc. As a result, the user can
enter text on both the serial and netconsole interfaces.
All devices - stdin, stdout and stderr - can be set in this manner.
1) common/iomux.c and include/iomux.h contain the environment setting
implementation.
2) doc/README.iomux contains a somewhat more detailed description.
3) The implementation in (1) is called from common/cmd_nvedit.c to
handle setenv and from common/console.c to handle initialization of
input/output devices at boot time.
4) common/console.c also contains the code needed to poll multiple console
devices for input and send output to all devices registered for output.
5) include/common.h includes iomux.h and common/Makefile generates iomux.o
when CONFIG_SYS_CONSOLE_MUX is set.
Signed-off-by: Gary Jennejohn <garyj@denx.de>
