path: root/common/Makefile
2017-07-11scsi: Move drivers into new drivers/scsi directorySimon Glass
At present we have the SCSI drivers in the drivers/block and common/ directories. It is better to split them out into their own place. Use drivers/scsi which is what Linux does. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11sata: Move drivers into new drivers/ata directorySimon Glass
At present we have the SATA and PATA drivers mixed up in the drivers/block directory. It is better to split them out into their own place. Use drivers/ata which is what Linux does. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11Kconfig: Add CONFIG_SATA to enable SATASimon Glass
At present CONFIG_CMD_SATA enables the 'sata' command which also brings in SATA support. Some boards may wish to enable SATA without the command. Add a separate CONFIG to permit this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-10boot_fit: Create helper functions that can be used to select DTB out of FITCooper Jr., Franklin
Some platforms may append a FIT image to the U-boot image. This function aids in parsing the FIT image and selecting the correct DTB at runtime. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-10spl: fit: Break out some functions into a common fileCooper Jr., Franklin
Some of the functions within spl_fit will be used for non spl purposes. Instead of duplicating functions simply break the functions to be reused into its own file. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Only add the new define to image.h, otherwise we see breakage due to massive include leakage into host tools in some cases] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-05bootstage: Support SPLSimon Glass
At present bootstage only supports U-Boot proper. But SPL can also consume boot time so it is useful to have the record start there. Add bootstage support to SPL. Also support stashing the timing information when SPL finishes so that it can be picked up and reported by U-Boot proper. This provides a full boot time record, excluding only the time taken by the boot ROM. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Kconfig: Add a CONFIG_IDE optionSimon Glass
At present IDE support is controlled by CONFIG_CMD_IDE. Add a separate CONFIG_IDE option so that IDE support can be enabled without requiring the 'ide' command. Update existing users and move the ide driver into drivers/block since it should not be in common/. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Kconfig: Add CONFIG_HASH to enable hashing APISimon Glass
At present CONFIG_CMD_HASH enables the 'hash' command which also brings in the hashing API. Some boards may wish to enable the API without the command. Add a separate CONFIG to permit this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-12common: Only build cli_readline.o for CMDLINE on non-SPLTom Rini
With gcc-6 and later we may get a warning such as: .../common/cli_readline.c:20:21: warning: ‘tab_seq’ defined but not used [-Wunused-const-variable=] static const char tab_seq[] = " "; /* used to expand TABs */ ^~~~~~~ .../common/cli_readline.c:19:19: warning: ‘erase_seq’ defined but not used [-Wunused-const-variable=] static const char erase_seq[] = "\b \b"; /* erase sequence */ ^~~~~~~~~ Because in SPL we're normally not doing interactive commands anyhow, so lets just not compile this at all in SPL. This also means that we need to correct the logic (and comment) about what the drivers/ddr/fsl/ and CONFIG_FSL_DDR_INTERACTIVE requires and this will be included in SPL there. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-11spl: fdt: support for fdt fixup for falcon bootB, Ravi
Adding support for fdt fixup to update the memory node in device tree for falcon boot. This is needed for single stage or falcon bootmode, to pass memory configuration to kernel through DT memory node. Signed-off-by: Ravi Babu <ravibabu@ti.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-02-12flash: compile common/flash.c iif CONFIG_MTD_NO_FLASH is enabledMasahiro Yamada
The whole of common/flash.c is guarded by #if defined() ... #endif. Move the conditional to common/Makefile. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-09-27common: dfu: saperate the dfu common functionalityB, Ravi
The cmd_dfu functionality is been used by both SPL and u-boot, saperating the core dfu functionality moving it to common/dfu.c. Signed-off-by: Ravi Babu <ravibabu@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-27spl: dfu: add dfu support in SPLB, Ravi
Traditionally the DFU support is available only as part 2nd stage boot loader(u-boot) and DFU is not supported in SPL. The SPL-DFU feature is useful for boards which does not have MMC/SD, ethernet boot mechanism to boot the board and only has USB inteface. This patch add DFU support in SPL with RAM memory device support to load and execute u-boot. And then leverage full functionality DFU in u-boot to flash boot inital binary images to factory or bare-metal boards to memory devices like SPI, eMMC, MMC/SD card using USB interface. This SPL-DFU support can be enabled through Menuconfig->Boot Images->Enable SPL-DFU support Signed-off-by: Ravi Babu <ravibabu@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-16Use separate options for TPL supportSimon Glass
At present TPL uses the same options as SPL support. In a few cases the board config enables or disables the SPL options depending on whether CONFIG_TPL_BUILD is defined. With the move to Kconfig, options are determined for the whole build and (without a hack like an #undef in a header file) cannot be controlled in this way. Create new TPL options for these and update users. This will allow Kconfig conversion to proceed for these boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-08-20cmd: Split 'bootz' and 'booti' out from 'bootm'Tom Rini
The bootz and booti commands rely on common functionality that is found in common/bootm.c and common/bootm_os.c. They do not however rely on the rest of cmd/bootm.c to be implemented so split them into their own files. Have various Makefiles include the required infrastructure for CONFIG_CMD_BOOT[IZ] as well as CONFIG_CMD_BOOTM. Move the declaration of 'images' over to common/bootm.c. Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-06-24hush: complete renaming CONFIG_SYS_HUSH_PARSER to CONFIG_HUSH_PARSERMasahiro Yamada
There is no more define of CONFIG_SYS_HUSH_PARSER. Rename some remaining references and drop the backward compatible Kconfig entry. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-20autoboot: add CONFIG_AUTOBOOT to allow to not compile autoboot.cMasahiro Yamada
Since commit bb597c0eeb7e ("common: bootdelay: move CONFIG_BOOTDELAY into a Kconfig option"), CONFIG_BOOTDELAY is defined for all boards. Prior to that commit, it was allowed to unset CONFIG_BOOTDELAY to not compile common/autoboot.c, as described in common/Makefile: # This option is not just y/n - it can have a numeric value ifdef CONFIG_BOOTDELAY obj-y += autoboot.o endif It was a bit odd to enable/disable code with an integer type option, but it was how this option worked before that commit, and several boards actually unset it to opt out of the autoboot feature. This commit adds a new bool option, CONFIG_AUTOBOOT, and makes CONFIG_BOOTDELAY depend on it. I chose "default y" for this option because most boards use the autoboot. I added "# CONFIG_AUTOBOOT is not set" for the boards that had not set CONFIG_BOOTDELAY prior to the bad commit. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-12verified-boot: Minimal support for booting U-Boot proper from SPLTeddy Reed
This allows a board to configure verified boot within the SPL using a FIT or FIT with external data. It also allows the SPL to perform signature verification without needing relocation. The board configuration will need to add the following feature defines: CONFIG_SPL_CRYPTO_SUPPORT CONFIG_SPL_HASH_SUPPORT CONFIG_SPL_SHA256 In this example, SHA256 is the only selected hashing algorithm. And the following booleans: CONFIG_SPL=y CONFIG_SPL_DM=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT=y CONFIG_SPL_OF_CONTROL=y CONFIG_SPL_OF_LIBFDT=y CONFIG_SPL_FIT_SIGNATURE=y Signed-off-by: Teddy Reed <teddy.reed@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Andreas Dannenberg <dannenberg@ti.com> Acked-by: Sumit Garg <sumit.garg@nxp.com>
2016-05-27Drop use of CONFIG_SYS_GENERIC_BOARD in U-BootSimon Glass
This option is always enabled and is about to be removed. Drop references to it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
2016-05-20cmd: eeprom: add support for layout aware commandsNikita Kiryanov
Introduce the (optional) eeprom print and eeprom update commands. These commands are eeprom layout aware: * The eeprom print command prints the contents of the eeprom in a human readable way (eeprom layout fields, and data formatted to be fit for human consumption). * The eeprom update command allows user to update eeprom fields by specifying the field name, and providing the new data in a human readable format (same format as displayed by the eeprom print command). * Both commands can either auto detect the layout, or be told which layout to use. New CONFIG options: CONFIG_CMD_EEPROM_LAYOUT - enables commands. CONFIG_EEPROM_LAYOUT_HELP_STRING - tells user what layout names are supported Feature API: __weak int parse_layout_version(char *str) - override to provide your own layout name parsing __weak void __eeprom_layout_assign(struct eeprom_layout *layout, int layout_version); - override to setup the layout metadata based on the version __weak int eeprom_layout_detect(unsigned char *data) - override to provide your own algorithm for detecting layout version eeprom_field.c - contains various printing and updating functions for common types of eeprom fields. Can be used for defining custom layouts. Cc: Heiko Schocher <hs@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2016-05-17dm: sata: Separate the non-command code into its own fileSimon Glass
At present the SATA command code includes both the command-processing code and the core SATA functions and data structures. Separate the latter into its own file, adding functions as needed to avoid the command code accessing data structures directly. With this commit: - All CONFIG option are referenced from the non-command code - The concept of a 'current SATA device' is confined to the command code This will make it easier to convert this code to driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: ide: Separate the non-command code into its own fileSimon Glass
At present the IDE command code includes both the command-processing code and the core IDE functions and data structures. Separate the latter into its own file, adding functions as needed to avoid the command code accessing data structures directly. With this commit: - Most CONFIG option are referenced from the non-command code - The concept of a 'current IDE device' is confined to the command code This will make it easier to convert this code to driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: scsi: Separate the non-command code into its own fileSimon Glass
At present the SCSI command code includes both the command-processing code and the core SCSI functions and data structures. Separate the latter into its own file, adding functions as needed to avoid the command code accessing data structures directly. This functions use the new legacy block functions. With this commit: - There is no CONFIG option referenced from the command code - The concept of a 'current SCSI device' is confined to the command code This will make it easier to convert this code to driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-04-18common: env: support sata devicePeng Fan
Introduce env support for sata device. 1. Implement write_env/read_env/env_relocate_spec/saveenv/sata_get_env_dev 2. If want to enable this feature, define CONFIG_ENV_IS_IN_SATA, and define CONFIG_SYS_SATA_ENV_DEV or implement your own sata_get_ev_dev. Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Simon Glass <sjg@chromium.org> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Stuart Longland <stuartl@vrt.com.au> Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-22Allow command-line files to be droppedSimon Glass
These files do not need to be compiled when CONFIG_CMDLINE is disabled. Update the Makefile to reflect this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14fdt: Allow libfdt to be used in SPLSimon Glass
Add an option to enable libfdt in SPL. This can be useful when decoding FIT files in SPL. We need to make sure this option is not enabled in SPL by this change. Also this option needs to be enabled in host builds. Si add a new IMAGE_USE_LIBFDT #define which can be used in files that are built on the host but must also build for U-Boot and SPL. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14common: Add support for environment file in EXT4.Stuart Longland
This is an enhancement that permits storing the environment file on an EXT4 partition such as the root filesystem. It is based on the existing FAT environment file code.
2016-02-08Remove unused CONFIG_MODEM_SUPPORT option and associated dead code.David Müller (ELSOFT AG)
Signed-off-by: David Müller <d.mueller@elsoft.ch>
2016-01-25Move all command code into its own directorySimon Glass
There are a lot of unrelated files in common, including all of the commands. Moving them into their own directory makes them easier to find and is more logical. Some commands include non-command code, such as cmd_scsi.c. This should be sorted out at some point so that the function can be enabled with or without the associated command. Unfortunately, with m68k I get this error: m68k: + M5329AFEE +arch/m68k/cpu/mcf532x/start.o: In function `_start': +arch/m68k/cpu/mcf532x/start.S:159:(.text+0x452): relocation truncated to fit: R_68K_PC16 against symbol `board_init_f' defined in .text.board_init_f section in common/built-in.o I hope someone can shed some light on what this means. I hope it isn't depending on the position of code in the image. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2016-01-20dm: lcd: Avoid using the lcd.h header file with driver modelSimon Glass
The LCD functions and definitions are not used with the driver model video uclass. When all boards are converted over we can remove the file. For now, use #ifdef to omit the contents. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-12-05common/Makefile: Compile fdt_support is enabled in SPLStefan Roese
When CONFIG_SPL_OF_TRANSLATE is enabled fdt_support.c needs to get compiled. Otherwise fdt_translate_address() is missing which is needed in dev_get_addr(). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-12sparse: Rename the file and headerMaxime Ripard
The Android sparse image format is currently supported through a file called aboot, which isn't really such a great name, since the sparse image format is only used for transferring data with fastboot. Rename the file and header to a file called "sparse", which also makes it consistent with the header defining the image structures. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-12fastboot: Implement NAND backendMaxime Ripard
So far the fastboot code was only supporting MMC-backed devices for its flashing operations (flash and erase). Add a storage backend for NAND-backed devices. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-10-24Move board_init_f_mem() into a common locationSimon Glass
This function will be used by both SPL and U-Boot proper. So move it into a common place. Also change the #ifdef so that the early malloc() area is not set up in SPL if CONFIG_SYS_SPL_MALLOC_START is defined. In that case it would never actually be used, and just chews up stack space. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-22drivers: Introduce a simplified remoteproc frameworkNishanth Menon
Many System on Chip(SoC) solutions are complex with multiple processors on the same die dedicated to either general purpose of specialized functions. Many examples do exist in today's SoCs from various vendors. Typical examples are micro controllers such as an ARM M3/M0 doing a offload of specific function such as event integration or power management or controlling camera etc. Traditionally, the responsibility of loading up such a processor with a firmware and communication has been with a High Level Operating System(HLOS) such as Linux. However, there exists classes of products where Linux would need to expect services from such a processor or the delay of Linux and operating system being able to load up such a firmware is unacceptable. To address these needs, we need some minimal capability to load such a system and ensure it is started prior to an Operating System(Linux or any other) is started up. NOTE: This is NOT meant to be a solve-all solution, instead, it tries to address certain class of SoCs and products that need such a solution. A very simple model is introduced here as part of the initial support that supports microcontrollers with internal memory (no MMU, no execution from external memory, or specific image format needs). This basic framework can then (hopefully) be extensible to other complex SoC processor support as need be. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-21common/cmd_ethsw: Add generic commands for Ethernet SwitchesCodrin Ciubotariu
This patch creates a flexible parser for Ethernet Switch configurations that should support complex commands. The parser searches for predefined keywords in the command and calls the proper function when a match is found. Also, the parser allows for optional keywords, such as "port", to apply the command on a port or on all ports. For now, the defined commands are: ethsw [port <port_no>] { enable | disable | show } Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-09-07update: tftp: dfu: Extend update_tftp() function to support DFULukasz Majewski
This code allows using DFU defined mediums for storing data received via TFTP protocol. It reuses and preserves functionality of legacy code at common/update.c. The update_tftp() function now accepts parameters - namely medium device name and its number (e.g. mmc 1). Without this information passed old behavior is preserved. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-08-31dm: tpm: Add a 'tpmtest' commandSimon Glass
These tests come from Chrome OS code. They are not particularly tidy but can be useful for checking that the TPM is behaving correctly. Some knowledge of TPM operation is required to use these. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard<christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-12spl, common, serial: build SPL without serial supportHeiko Schocher
This patch enables building SPL without CONFIG_SPL_SERIAL_SUPPORT support. Signed-off-by: Heiko Schocher <hs@denx.de> [trini: Ensure we build arch/arm/imx-common on mx28] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-05efi: Add a command to display the memory mapSimon Glass
The EFI memory map is passed from the stub to U-Boot in a table. Add a command to display it in a vaguely readable fashion. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested on QEMU Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-05-14dm: regulator: add regulator commandPrzemyslaw Marczak
This command is based on driver model regulator's API. The user interface provides: - list UCLASS regulator devices - show or [set] operating regulator device - print constraints info - print operating status - print/[set] voltage value [uV] (force) - print/[set] current value [uA] - print/[set] operating mode id - enable the regulator output - disable the regulator output The 'force' option can be used for setting the value which exceeds the constraints min/max limits. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-14dm: pmic: add pmic commandPrzemyslaw Marczak
This is new command for the PMIC devices based on driver model PMIC API. Command features are unchanged: - list UCLASS pmic devices - show or [set] operating pmic device (NEW) - dump registers - read byte of register at address - write byte to register at address The only one change for this command is 'dev' subcommand. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-29Add a 'cpu' command to print CPU informationSimon Glass
Add a simple command which provides access to a list of available CPUs along with descriptions and basic information. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-04-20Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2015-04-19sandbox: Renamed sb command to hostSjoerd Simons
As suggested by Simon Glass, rename the sb command to host but keep the old sb command as an alias Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18common/lcd_console: introduce display/framebuffer rotationHannes Petermaier
Sometimes, for example if the display is mounted in portrait mode or even if it is mounted landscape but rotated by 180 degrees, we need to rotate our content of the display respectively the framebuffer, so that user can read the messages which are printed out. For this we introduce the feature called "CONFIG_LCD_ROTATION", this may be defined in the board-configuration if needed. After this the lcd_console will be initialized with a given rotation from "vl_rot" out of "vidinfo_t" which is provided by the board specific code. If CONFIG_LCD_ROTATION is not defined, the console will be initialized with 0 degrees rotation. Signed-off-by: Hannes Petermaier <hannes.petermaier@br-automation.com> Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at> Acked-by: Nikita Kiryanov <nikita@compulab.co.il> [agust: fixed 'struct vidinfo' has no member named 'vl_rot' errors] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2015-04-10common/armflash: Support for ARM flash imagesLinus Walleij
The ARM reference designs all use a special flash image format that stores a footer (two versions exist) at the end of the last erase block of the image in flash memory. Version one of the footer is indicated by the magic number 0xA0FFFF9F at 12 bytes before the end of the flash block and version two is indicated by the magic number 0x464F4F54 0x464C5348 (ASCII for "FLSHFOOT") in the very last 8 bytes of the erase block. This command driver implements support for both versions of the AFS images (the name comes from the Linux driver in drivers/mtd/afs.c) and makes it possible to list images and load an image by name into the memory with these commands: afs - lists flash contents afs load <image> - loads image to address indicated in the image afs load <image> <addres> - loads image to a specified address This image scheme is used on the ARM Integrator family, ARM Versatile family, ARM RealView family (not yet supported in U-Boot) and ARM Versatile Express family up to and including the new Juno board for 64 bit development. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-02-10Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
Conflicts: include/splash.h Signed-off-by: Tom Rini <trini@ti.com>
2015-02-10Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
