CONFIG_ID_EEPROM
At present when function names are logged, the output is a little hard to
read since every function is a different length. Add a way to pad the
names so that the log messages line up vertically. This doesn't work if
the function name is very long, but it makes a big difference in most
cases.
Use 20 characters as a default since this covers the vast majority of
functions.
Move this down to provide more space for the bloblist.
Add support for stack protector for UBOOT, SPL, and TPL
as well as new pytest for stackprotector
Signed-off-by: Joel Peshkin <joel.peshkin@broadcom.com>
Adjust UEFI build flags.
CONFIG_MISC_INIT_F
This Trusted Application allows enabling SCP03 as well as provisioning
the keys on TEE controlled secure element (ie, NXP SE050).
All the information flowing on buses (ie I2C) between the processor
and the secure element must be encrypted. Secure elements are
pre-provisioned with a set of keys known to the user so that the
secure channel protocol (encryption) can be enforced on the first
boot. This situation is however unsafe since the keys are publically
available.
For example, in the case of the NXP SE050, these keys would be
available in the OP-TEE source tree [2] and of course in the
documentation corresponding to the part.
To address that, users are required to rotate/provision those keys
(ie, generate new keys and write them in the secure element's
persistent memory).
For information on SCP03, check the Global Platform HomePage and
google for that term [1]
[1] globalplatform.org
[2] https://github.com/OP-TEE/optee_os/
check:
core/drivers/crypto/se050/adaptors/utils/scp_config.c
Signed-off-by: Jorge Ramirez-Ortiz <jorge@foundries.io>
AVB Verified Boot uses functions related to MMC.
Reviewed-by: Igor Opaniuk <igor.opaniuk@foundries.io>
Typically in TPL/SPL the bloblist is quite small. But U-Boot proper may
want to add a lot more to it, such as ACPI tables.
Add a way to expand the bloblist by relocating it in U-Boot proper, along
with the other relocation activities.
Currently, the following #ifdef construct is used to check whether to run
console_record_init() during pre-relocation init:
defined(CONFIG_CONSOLE_RECORD) && CONFIG_VAL(SYS_MALLOC_F_LEN)
Introduce CONFIG_CONSOLE_RECORD_INIT_F Kconfig option to get rid of the
complex ifdef check. Also, use IS_ENABLED() instead of #ifdef.
Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com>
The main purpose of this patch is to separate a generic interface for
updating firmware using DFU drivers from "auto-update" via tftp.
This function will also be used in implementing UEFI capsule update
in a later commit.
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
This actually relates to something displayed on start-up, so move it into
that menu.
This option does not belong at the top level. Move it under generic
driver options.
This relates to the environment so should not be at the top level. Move
it.
These are start-up hooks so put them under that menu.
These hooks relate to U-Boot init so move them under that menu.
There are quite a few options at the top level relating to U-Boot init.
Move them into their own menu.
This relates to booting since it is the default devicetree provided to
Linux. Move it under the 'boot options' menu.
This relates to booting, so move it under the 'boot images' menu.
There are a number of miscellaneous boot images at the top level of the
kconfig menu. Move these into the 'boot options' menu.
This option relates to autoboot, so move it there.
This relates to booting, so move it under the boot menu.
Most of the boot options are in common/Kconfig but that file is already
extremely large. Create a new Kconfig.boot to hold the boot options.
The 44758771ee commit removes CONFIG_PREBOOT but actually sets the USE_PREBOOT
Kconfig option which isn't CONFIG_PREBOOT and is also a bool option which means
we regress because 'usb start' isn't run when expected, it should also be run
for devices that have USB storage because keyboards aren't the only thing we
might need the USB bus for.
Fixes: 44758771ee ("arm: move CONFIG_PREBOOT="usb start" to KConfig")
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Cc: Jonas Smedegaard <dr@jones.dk>
Cc: Neil Armstrong <narmstrong@baylibre.com>
Kconfig provides several config options for setting up default variables
but these are unused when variables are passed to U-Boot via file.
That's why cover this dependency in Kconfig.
AVB only uses CONFIG_FASTBOOT_BUF_ADDR from fastboot for memory.
This memory is used for assigning temporary buffers.
This can be assigned a new variable and used as CONFIG_AVB_BUF_ADDR.
This is to support future boards that support AVB but dont support
USB and therefore dont support FASTBOOT.
Signed-off-by: Usama Arif <usama.arif@arm.com>
Cc: Igor Opaniuk <igor.opaniuk@gmail.com>
Acked-by: Igor Opaniuk <igor.opaniuk@gmail.com>
[trini: Change defaults]
Now that this is in Kconfig we can move the logic at the top of the file
to Kconfig, and use if() instead of #if. Update the file with these
changes.
CONFIG_SYS_DEVICE_NULLDEV
This commit moves CONFIG_PREBOOT="usb start" to common/KConfig
for all boards also declaring USB_KEYBOARD.
Besides simplifying defconfig files, this also enables support for
board-specific CONFIG_PREBOOT for sunxi boards:
commit 37304aaf60bf ("Convert CONFIG_USE_PREBOOT and CONFIG_PREBOOT to
Kconfig") intended to support CONFIG_PREBOOT, but
include/configs/sunxi-common.h hardcodes preboot as part of internally
defined CONSOLE_STDIN_SETTINGS, silently ignoring any board-specific
CONFIG_PREBOOT.
Signed-off-by: Jonas Smedegaard <dr@jones.dk>
Reviewed-by: Neil Armstrong <narmstrong@baylibre.com>
Series-Cc: Jagan Teki <jagan@amarulasolutions.com>
Series-Cc: Lukasz Majewski <lukma@denx.de>
Series-Cc: Andre Przywara <andre.przywara@arm.com>
The name of the function emitting a log message may be of interest for a
developer but is distracting for normal users. See the example below:
try_load_entry() Booting: Debian
Make the default format for log messages customizable. By default show
only the message text.
LOG_DEFAULT_LEVEL has been chosen as 6. Adjust the default of LOG_MAX_LEVEL
to this value.
Use ranges to clamp log levels to reasonable values.
Group output options by main U-Boot, SPL, TPL, followed by other logging
options.
With CONFIG_DM_PCI enabled, PCI buses are not enumerated at boot, as they
are without that config option enabled. However, there are cases such as DM
PCI-based Ethernet devices that need the PCI bus enumerated so that they
can be discovered by their drivers.
Currently, to solve this, some boards enumerate the pci bus using
"pci enum" preboot command, while others do it manually in board files
(in board_init/board_late_init/etc. functions).
In order to possibly make the pci enumeration process uniform across all
boards, introduce CONFIG_PCI_INIT_R Kconfig option.
This change also preserves the current behavior in the !DM_PCI case
(pci_init is run unconditionally at boot).
Do not build image_sign_info helper functions in SPL if not needed.
Fixes: b983cc2da0ba ("lib: rsa: decouple rsa from FIT image verification")
Provide a log driver that broadcasts RFC 3164 messages to syslog servers.
rsyslog is one implementation of such a server.
The messages are sent to the local broadcast address 255.255.255.255 on
port 514.
The environment variable log_hostname can be used to provide the HOSTNAME
field for the messages. The optional TIMESTAMP field of RFC 3164 is not
provided.
An error
undefined reference to `do_log_test'
occurs for CONFIG_CMD_LOG=y, CONFIG_LOG_TEST=y, CONGIG_UNIT_TEST=n
Make CONFIG_UNIT_TEST a prerequisite.
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze into next
Xilinx changes for v2020.07
common:
- Align ENV_FAT_INTERFACE
- Fix MAC address source print log
- Improve based autodetection code
xilinx:
- Enable netconsole
Microblaze:
- Setup default ENV_OFFSET/ENV_SECT_SIZE
Zynq:
- Multiple DT updates/fixes
- Use DEVICE_TREE environment variable for DTB selection
- Switch to single zynq configuration
- Enable NOR flash via DM
- Minor SPL print removal
- Enable i2c mux driver
ZynqMP:
- Print multiboot register
- Enable cache commands in mini mtest
- Fix firmware probing when driver is not enabled
- Specify 3rd backup RAM boot mode in SPL
- Add SPL support for zcu102 v1.1 and zcu111 revA
- Redesign debug uart enabling and psu_init delay
- Enable full u-boot run from EL3
- Enable u-boot.itb generation without ATF with U-Boot in EL3
Versal:
- Enable distro default
- Enable others SPI flashes
- Enable systems without DDR
Drivers:
- Gem:
- Flush memory after freeing
- Handle mdio bus separately
- Watchdog:
- Get rid of unused global data pointer
- Enable window watchdog timer
- Serial:
- Change reinitialization logic in zynq serial driver
Enable pre console buffer for rk3399 platform.
This would help to capture the console messages prior to
the console being initialised. Enabling this would help
to capture all the console messages on video output source
like HDMI. So we can find the full console messages of
U-Boot proper on HDMI display when enabled it for RK3399
platform boards.
Buffer address used for pre console is 0x0f200000 which is
ram base plus 240MiB. right now the Allwinner SoC is using
similar computation.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Tested-by: Peter Robinson <pbrobinson@gmail.com>
Introduce new configuration, CONFIG_RSA_VERIFY which will decouple building
RSA functions from FIT verification and allow for adding a RSA-based
signature verification for other file formats, in particular PE file
for UEFI secure boot.
Enable pre console buffer for rk3288 platform.
U-Boot proper on HDMI display when enabled it for RK3288
platform boards.
Buffer address used for pre console is 0x0f000000 which is
As LOGLEVEL ranges form 0 to 9 set the limit to 10.
Signed-off-by: Marek Bykowski <marek.bykowski@gmail.com>
Add more clarity by changing the Kconfig entry name.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
[trini: Re-run migration, update a few more cases]
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
Signed-off-by: Simon South <simon@simonsouth.net>
CONFIG_SHOW_BOOT_PROGRESS
This patch determines the A/B-specific bootloader message structure
that is the basis for implementation of recovery and A/B update
functions. A/B metadata is stored in this structure and used to decide
which slot should we use to boot the device. Also some basic functions
for A/B metadata manipulation are implemented (like slot selection).
The patch was extracted from commits [1], [2] with some coding style
fixes.
[1] https://android-review.googlesource.com/c/platform/external/u-boot/+/729878/2
[2] https://android-review.googlesource.com/c/platform/external/u-boot/+/729880/2
Signed-off-by: Ruslan Trofymenko <ruslan.trofymenko@linaro.org>
Signed-off-by: Igor Opaniuk <igor.opaniuk@gmail.com>
Reviewed-by: Sam Protsenko <semen.protsenko@linaro.org>
If bootstage is enabled in TPL it lacks a record count and so does not
build. Fix this by adding a new Kconfig option.
Use Kconfig to activate CONFIG_PREBOOT (empty by default).
This is the same migration path as commit b6251db8c3f0 ("Kconfig:
Introduce USE_BOOTCOMMAND and migrate BOOTCOMMAND").
I also moved the description in README to the Kconfig help.
I ripped off the sentence about 'LWMON' since it is gone already.
I only let my boards migrate, leaving the rest to platform maintainers.
At present the default log level is set to LOGL_INFO on start-up. Allow
this to be controlled from Kconfig.
The log level numbers in the Kconfig are not actually correct. Fix them
and also add a missing space in the header-file comment.
