path: root/common/Kconfig
2016-01-25Move all command code into its own directorySimon Glass
There are a lot of unrelated files in common, including all of the commands. Moving them into their own directory makes them easier to find and is more logical. Some commands include non-command code, such as cmd_scsi.c. This should be sorted out at some point so that the function can be enabled with or without the associated command. Unfortunately, with m68k I get this error: m68k: + M5329AFEE +arch/m68k/cpu/mcf532x/start.o: In function `_start': +arch/m68k/cpu/mcf532x/start.S:159:(.text+0x452): relocation truncated to fit: R_68K_PC16 against symbol `board_init_f' defined in .text.board_init_f section in common/built-in.o I hope someone can shed some light on what this means. I hope it isn't depending on the position of code in the image. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2016-01-13cmd_boot: Add a poweroff commandMichael van Slingerland
Add a 'poweroff' command to boot commands, this only gets enabled if the board Kconfig does a "select CMD_POWEROFF". Signed-off-by: Michael van Slingerland <michael@deviousops.nl> [hdegoede@redhat.com: Make the cmd conditional on a CMD_POWEROFF Kconfig] Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-11-19console: Add a console bufferSimon Glass
It is useful to be able to record console output and provide console input via a buffer. This provides sandbox with the ability to run a command and check its output. If the console is set to silent then no visible output is generated. This also provides a means to fix the problem where tests produce unwanted output, such as errors or warnings. This can be confusing. We can instead set the console to silent and record this output. It can be checked later in the test if required. It is possible that this may prove useful for non-test situations. For example the console output may be suppressed for normal operations, but recorded and stored for access by the OS. That feature is not implemented at present. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-13sparc: Kconfig: Move the CMD_AMBAPP command to KconfigFrancois Retief
Add an initr function in the board_r.c file for the AMBA Plug&Play command. Add a Kconfig entry for the ambapp command and remove all CONFIG_CMD_AMBAPP defines from the board configuration headers. Add a Kconfig entry to display the AMBA Plug&Play information on startup. This option is off by default. Remove relevent define from board configuration headers. Signed-off-by: Francois Retief <fgretief@spaceteq.co.za>
2015-10-22drivers: Introduce a simplified remoteproc frameworkNishanth Menon
Many System on Chip(SoC) solutions are complex with multiple processors on the same die dedicated to either general purpose of specialized functions. Many examples do exist in today's SoCs from various vendors. Typical examples are micro controllers such as an ARM M3/M0 doing a offload of specific function such as event integration or power management or controlling camera etc. Traditionally, the responsibility of loading up such a processor with a firmware and communication has been with a High Level Operating System(HLOS) such as Linux. However, there exists classes of products where Linux would need to expect services from such a processor or the delay of Linux and operating system being able to load up such a firmware is unacceptable. To address these needs, we need some minimal capability to load such a system and ensure it is started prior to an Operating System(Linux or any other) is started up. NOTE: This is NOT meant to be a solve-all solution, instead, it tries to address certain class of SoCs and products that need such a solution. A very simple model is introduced here as part of the initial support that supports microcontrollers with internal memory (no MMU, no execution from external memory, or specific image format needs). This basic framework can then (hopefully) be extensible to other complex SoC processor support as need be. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-31dm: tpm: Add a 'tpmtest' commandSimon Glass
These tests come from Chrome OS code. They are not particularly tidy but can be useful for checking that the TPM is behaving correctly. Some knowledge of TPM operation is required to use these. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard<christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-31tpm: Add Kconfig options for TPMsSimon Glass
Add new Kconfig options for TPMs in preparation for moving boards to use Kconfig for TPM configuration. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard<christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-07-01common: Add CMD_SF Kconfig entryJagan Teki
Added Kconfig entry for CMD_SF. Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-06-25common: Add the CMD_ENV_EXISTS config to KconfigJoe Hershberger
This command needs to exist in the Kconfig so that it can be moved from the config_cmd_default.h. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-06-25common: Fix comment for saveenv in KconfigJoe Hershberger
The help for this was simply copied from another command. Update it to reflect the command. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-06-08autoboot.c: Add feature to stop autobooting via SHA256 encrypted passwordStefan Roese
This patch adds the feature to only stop the autobooting, and therefor boot into the U-Boot prompt, when the input string / password matches a values that is encypted via a SHA256 hash and saved in the environment. This feature is enabled by defined these config options: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_STOP_STR_SHA256 Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-06-08autoboot.c: Move config options to KconfigStefan Roese
This patch moves the following config options to Kconfig: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Drop ip04 and pm9263 configs/ additions, those boards previously set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over all boards that did change. Make digsy_mtc_* string include seconds to match others and not warn. ] Signed-off-by: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-14dm: regulator: add regulator commandPrzemyslaw Marczak
This command is based on driver model regulator's API. The user interface provides: - list UCLASS regulator devices - show or [set] operating regulator device - print constraints info - print operating status - print/[set] voltage value [uV] (force) - print/[set] current value [uA] - print/[set] operating mode id - enable the regulator output - disable the regulator output The 'force' option can be used for setting the value which exceeds the constraints min/max limits. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-14dm: pmic: add pmic commandPrzemyslaw Marczak
This is new command for the PMIC devices based on driver model PMIC API. Command features are unchanged: - list UCLASS pmic devices - show or [set] operating pmic device (NEW) - dump registers - read byte of register at address - write byte to register at address The only one change for this command is 'dev' subcommand. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-29Add a 'cpu' command to print CPU informationSimon Glass
Add a simple command which provides access to a list of available CPUs along with descriptions and basic information. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-04-21kconfig: remove duplicated CMD_DNS optionAndrey Skvortsov
two CMD_DNS options were added by commit 60296a835cb17 ("commands: add more command entries in Kconfig") Signed-off-by: Andrey Skvortsov <andrej.skvortzov@gmail.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-04-18sandbox: exynos: Move CONFIG_CMD_SOUND to KconfigSimon Glass
Move this over to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18Kconfig: Move CONFIG_BOOTSTAGE to KconfigSimon Glass
Move CONFIG_BOOT_STAGE and its associated options to Kconfig. Adjust existing users and code. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-10common/armflash: Support for ARM flash imagesLinus Walleij
The ARM reference designs all use a special flash image format that stores a footer (two versions exist) at the end of the last erase block of the image in flash memory. Version one of the footer is indicated by the magic number 0xA0FFFF9F at 12 bytes before the end of the flash block and version two is indicated by the magic number 0x464F4F54 0x464C5348 (ASCII for "FLSHFOOT") in the very last 8 bytes of the erase block. This command driver implements support for both versions of the AFS images (the name comes from the Linux driver in drivers/mtd/afs.c) and makes it possible to list images and load an image by name into the memory with these commands: afs - lists flash contents afs load <image> - loads image to address indicated in the image afs load <image> <addres> - loads image to a specified address This image scheme is used on the ARM Integrator family, ARM Versatile family, ARM RealView family (not yet supported in U-Boot) and ARM Versatile Express family up to and including the new Juno board for 64 bit development. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-03-05kconfig: common: Fix memtest bool nameNikolaos Pasaloukos
Fix the name appearing in menuconfig for memtest command Signed-off-by: Nikolaos Pasaloukos <Nikolaos.Pasaloukos@imgtec.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com
2015-02-24kconfig: remove unneeded dependency on !SPL_BUILDMasahiro Yamada
Now CONFIG_SPL_BUILD is not defined in Kconfig, so "!depends on SPL_BUILD" and "if !SPL_BUILD" are redundant. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-12dm: Add CMD_DM and CMD_DEMO to KconfigSimon Glass
Add Kconfig settings for these two options. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-23commands: add more command entries in KconfigMasahiro Yamada
This commit adds some of command entries (CONFIG_CMD_*) to cover include/config_cmd_default.h and a little extra. Because U-Boot supports lots of commands, they should be categorized according to their usage. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-23hush: add CONFIG_HUSH_PARSER to KconfigMasahiro Yamada
The README file states that the macros beginning with "CONFIG_SYS_" depend on the hardware etc. and should not be meddled with if you do not what you're doing. We have already screwed up with this policy; we have given the prefix "CONFIG_SYS_" to many user-selectable configurations. Here, "CONFIG_SYS_HUSH_PARSER" is one of them. Users can enable it if they want to use a more powerful command line parser, or disable it if they only need a simple one. This commit attempts to rename CONFIG_SYS_HUSH_PARSER to CONFIG_HUSH_PARSER and move it to Kconfig. Every board maintainer is expected to enable CONFIG_HUSH_PARSER (= add "CONFIG_HUSH_PARSER=y" to his defconfig file) and remove "#define CONFIG_SYS_HUSH_PARSER" from his header file. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24kconfig: move CONFIG_CMD_IMPORTENV to KconfigMasahiro Yamada
Since CONFIG_CMD_IMPORTENV is defined in config_cmd_defaults.h, it should be enabled for all the boards except bf506f-ezkit that undefs it explicitely. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-09-24kconfig: move CONFIG_CMD_GO to KconfigMasahiro Yamada
Since CONFIG_CMD_GO is defined in config_cmd_defaults.h (and no board undefs it its own header), it can be moved to Kconfig with the default value "y". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-09-24kconfig: move CONFIG_CMD_EXPORTENV to KconfigMasahiro Yamada
Since CONFIG_CMD_EXPORTENV is defined in config_cmd_defaults.h, it should be enabled for all the boards except bf506f-ezkit that undefs it explicitely. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-09-24kconfig: move CONFIG_CMD_CRC32 to KconfigMasahiro Yamada
Since CONFIG_CMD_CRC32 is defined in config_cmd_defaults.h, it is enabled for all the boards except the ones undefining it explicitly: kwb tseries_mmc tseries_nand tseries_spi vct_platinum_onenand_small vct_platinum_small vct_platinumavc_onenand_small vct_platinumavc_small vct_premium_onenand_small vct_premium_small The default value of this config option should be "y" and "# CONFIG_CMD_CRC32 is not set" should be added for those exceptions. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-24kconfig: move CONFIG_CMD_BOOTM to KconfigMasahiro Yamada
CONFIG_CMD_BOOTM is defined in config_cmd_defaults.h which is forcebly included from each board. So, the default value of "config CMD_BOOTM" should be "y". For some boards undefining it (bf506f-ezkit, controlcenterd_TRAILBLA, controlcenterd_TRAILBLAZER_DEVELOP, controlcenterd_TRAILBLAZER), "# CONFIG_CMD_BOOTM is not set" should be added to their defconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-24kconfig: add blank Kconfig filesMasahiro Yamada
This would be useful to start moving various config options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
