Better use depends on instead of select.
1. Since libavb library alone is highly portable, introduce dedicated
Kconfig symbol for AVB bootloader-dependent operations, so it's possible
to build libavb separately. AVB bootloader-dependent operations include:
* Helpers to process strings in order to build OS bootargs.
* Helpers to access MMC, similar to drivers/fastboot/fb_mmc.c.
* Helpers to alloc/init/free avb ops.
2. Add CONFIG_FASTBOOT dependency, as fastboot buffer is
re-used in partition verification operations.
Reported-by: Eugeniu Rosca <rosca.eugeniu@gmail.com>
Signed-off-by: Igor Opaniuk <igor.opaniuk@linaro.org>
Reviewed-by: Eugeniu Rosca <rosca.eugeniu@gmail.com>
Tested-by: Eugeniu Rosca <rosca.eugeniu@gmail.com>
Some boards indicate support from booting NAND or
ONENAND booting, but don't enable the CONFIG_NAND. This
makes those boards imply NAND which will make
enabling other flags that are dependent on CONFIG_NAND
possible and easier to migrate.
Extend BOOTDELAY help text to cover its additional usage within the
bootmenu command.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Compling with CONFIG_LOG and without CONFIG_DM results in
common/log.c:47: undefined reference to `uclass_get_name'
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
[trini: Re-run migration]
Migrate the CONFIG_LAST_STAGE_INIT option to Kconfig.
Migrate the CONFIG_BOARD_EARLY_INIT_R option to Kconfig.
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
Convert the CONFIG_UPDATE_TFTP and related symbols to Kconfig.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
When functions return an error it propagates up the stack to the point
where it is reported. Often the error code provides enough information
about the root cause of the error that this is obvious what went wrong.
However in some cases the error may be hard to trace. For example if a
driver uses several devices to perform an operation, it may not be
obvious which one failed.
Add a log_ret() macro to help with this. This can be used to wrap any
error-return value. The logging system will then output a log record when
the original error is generated, making it easy to trace the call stack
of the error.
This macro can significantly impact code size, so its use is controlled
by a Kconfig option, which is enabled for sandbox.
Change all coldfire arch files to use CONFIG_DISPLAY_CPUINFO.
Signed-off-by: Angelo Dureghello <angelo@sysam.it>
Changes for v2:
- update common/Kconfig to add M68K to the default y list
Add a command which exercises the logging system.
It is useful to display log messages on the console. Add a simple driver
to handle this.
Note that this driver outputs to the console, which may be serial or
video. It does not specifically select serial output.
Add the logging header file and implementation with some configuration
options to control it.
We first introduce CONFIG_USE_BOOTCOMMAND, similar to
CONFIG_USE_BOOTARGS. We then migrate CONFIG_BOOTCOMMAND for most
CONFIG_DISTRO_DEFAULT users. In some cases platforms have a complex
scheme around this usage, and these have been defered for the moment so
that platform maintainers can work on a migration plan.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
CONFIG_FIT_EMBED might be confused with CONFIG_OF_EMBED, rename it
MULTI_DTB_FIT as it is able to get a DTB from a FIT image containing
multiple DTBs. Also move the option to the Kconfig dedicated to the DTS
options and create a README for this feature.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
While this came in with a default value of 6 I am lowering this to 4.
The MTD/UBI code has a large number of error messages that we include
now. In addition, "normally" warning messages are not included so this
feels like a more natural level to have.
When we import code from Linux, with regular re-sync planned, we want
to use printk() and pr_*(). U-Boot does not support them in a clean
way. So, people end up with local macros, or compat headers here and
there, then we occasionally see build errors of definition conflicts.
We have include/linux/compat.h, but putting all sorts of unrelated
things into a single header is just a temporal workaround. Hence this
patch, to find the best home for all printk variants. If you want to
use printk() and friends, please include <linux/printk.h>. This header
is self-contained, and pulls in only a few headers.
When I was testing this clean-up, I noticed the image size exceeded
its platform limit on some boards. This is because all pr_*() that
were previously defined as no-op in include/linux/mtd/mtd.h (unless
CONFIG_MTD_DEBUG is set), are now enabled.
To make such boards happy, this commit also implements CONFIG_LOGLEVEL.
The concept is similar to the kernel parameter "loglevel". (Actually,
the Kconfig help message was taken from kernel-paremeter.txt of Linux)
Messages with a loglevel smaller than console loglevel will be printed.
The difference is the loglevel is build-time determined. To save the
image size, lower priority pr_*() are compiled out. I set the default
of CONFIG_LOGLEVEL to 6, i.e. pr_notice and higher priority messages
are compiled in.
I adjusted CONFIG_LOGLEVEL to avoid build error for some boards.
[trini: Add in SPL_LOGLEVEL that is the same as LOGLEVEL]
With SPL we often have limited memory and do not need very many bootstage
records. Add a separate Kconfig option for SPL.
The CONFIG_BOOTSTAGE_USER_COUNT option is no-longer needed since we can now
support any number of user IDs. Also BOOTSTAGE_ID_COUNT is not needed now.
Drop these unused options.
About a quarter of the files in common/ relate to the environment. It
seems better to put these into their own subdirectory and remove the
prefix.
Also introduce CONFIG_USE_BOOTARGS option so we can control if
CONFIG_BOOTARGS defined at all.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Resync r8a779[56]_ulcb, various ls10xx targets]
This is architecture-dependent early initialization hence should
be put in the platform Kconfig.
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
CONFIG_BOARD_EARLY_INIT_F literally indicates board-specific codes
and should be not 'default y' for all x86 boards.
We rename the various FAT_ENV_xxx options to CONFIG_ENV_FAT_xxx so that
they can be modified via Kconfig. Migrate all existing users to the new
values.
CONFIG_ENV_IS_IN_ONENAND
CONFIG_ENV_IS_IN_FAT
CONFIG_ENV_IS_IN_REMOTE
CONFIG_ENV_IS_IN_SPI_FLASH
CONFIG_ENV_IS_IN_DATAFLASH
CONFIG_ENV_IS_IN_EEPROM
CONFIG_ENV_IS_IN_NVRAM
CONFIG_ENV_IS_IN_FLASH
The CONFIG_ENV_IS_IN_... options which have already been converted to
Kconfig only have a small amount of help. Move the rest of it over from
the README.
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
Enable the pre-console buffer, displaying the model and post-relocation
console announce on sandbox. Also add a model name to the device tree.
This allows testing of these features.
Runtime U-boot dtb selection is generally a two step process. First step
is to simply use an initial generic dtb. The second step is to select
the dtb and perhaps execute additional code ones U-boot knows what board
it is running on. Embedded_dtb_select handles the second step by allowing
board specific code to run and perform what ever necessary configuration
that is needed.
Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
Some platforms may append a FIT image to the U-boot image. This function
aids in parsing the FIT image and selecting the correct DTB at runtime.
There was for long time no activity in the mpx5xxx area.
We need to go further and convert to Kconfig, but it
turned out, nobody is interested anymore in mpc5xxx,
so remove it.
At present bootstage only supports U-Boot proper. But SPL can also consume
boot time so it is useful to have the record start there.
Add bootstage support to SPL. Also support stashing the timing information
when SPL finishes so that it can be picked up and reported by U-Boot
proper. This provides a full boot time record, excluding only the time
taken by the boot ROM.
At present bootstage has a large array with all possible bootstage IDs
recorded. It adds times to the array element indexed by the ID. This is
inefficient because many IDs are not used during boot. We can save space
by only recording those IDs which actually have timestamps.
Update the array to use a record count, which increments with each
addition of a new timestamp. This takes longer to record a time, since it
may involve an array search. Such a search may be particularly expensive
before relocation when the CPU is running slowly or the cache is off. But
at that stage there should be very few records.
There is no good read to make this hex, and integer is more natural for
this type of setting. Update it.
At present CONFIG_CMD_HASH enables the 'hash' command which also brings
in the hashing API. Some boards may wish to enable the API without the
command. Add a separate CONFIG to permit this.
The default value of BOOTSTAGE_STASH_SIZE should be set to hexadecimal,
but an integer value is set. This fixes the BOOTSTAGE_STASH_SIZE number
from hexadecimal to integer.
The environment location is something that might change per board
(depending on what storage options are availaible there) or depending on
the user choice (when we have several options).
Instead of hardcoding it in our configuration header, create a Kconfig
choice with the options we use for now, and the symbols that depend on it.
Once done, also remove the irrelevant sunxi defines.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
The SPARC architecture is currently unmaintained, remove.
Cc: Francois Retief <fgretief@spaceteq.co.za>
The architecture is currently unmaintained, remove.
Cc: Benjamin Matthews <mben12@gmail.com>
Cc: Chong Huang <chuang@ucrobotics.com>
Cc: Dimitar Penev <dpn@switchfin.org>
Cc: Haitao Zhang <hzhang@ucrobotics.com>
Cc: I-SYST Micromodule <support@i-syst.com>
Cc: M.Hasewinkel (MHA) <info@ssv-embedded.de>
Cc: Martin Strubel <strubel@section5.ch>
Cc: Peter Meerwald <devel@bct-electronic.com>
Cc: Sonic Zhang <sonic.adi@gmail.com>
Cc: Valentin Yakovenkov <yakovenkov@niistt.ru>
Cc: Wojtek Skulski <info@skutek.com>
Cc: Wojtek Skulski <skulski@pas.rochester.edu>
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
