Introduce a new version of the Keystone-II "ddr" command
for testing the inline ECC support in the DDRSS bridge
available on K3 devices. The ECC hardware support in
K3's DDRSS and the test method differ substantially from
what we support in the K2 variant of the command. The
name of the new command is "ddrss".
The ECC test procedure follows these steps:
1) Flush and disable the data cache.
2) Shrink the protected ECC R0 range.
3) Flip a bit outside the shrunk range.
4) Restore the range to original.
5) Read the modified value (corrected).
6) Re-enable the data cache.
This which will cause the 1-bit ECC error count to increase
while the read will return the corrected value.
The K3 version of the command preserves the syntax for the
"ecc_err" argument.
Signed-off-by: Georgi Vlaev <g-vlaev@ti.com>
Signed-off-by: Santhosh Kumar K <s-k6@ti.com>
To enable splash screen at SPL, need to compile cmd/bmp.c which also
includes bmp commands, since SPL doesn't use commands split bmp.c into
common/bmp.c which includes all bmp functions and cmd/bmp.c which only
contains bmp commands.
Add function delclaration for bmp_info in video.h.
Signed-off-by: Nikhil M Jain <n-jain1@ti.com>
commit 636da2039aea4ea3a638b14da0a9ec258897a10c upstream.
Enable the support for boot image header version 3 and 4
using abootimg command.
In order to use version 3 or 4:
1- Vendor boot image address should be given to abootimg cmd.
abootimg addr $1 $vendor_boot_load_addr
2- "ramdisk_addr_r" env variable (ramdisk address) should be set to host
the ramdisk : generic ramdisk + vendor ramdisk
Replace "struct andr_boot_img_hdr_v0*" by "void *" in
some functions since v3 and v4 are now supported as well.
Signed-off-by: Safae Ouajih <souajih@baylibre.com>
Reviewed-by: Mattijs Korpershoek <mkorpershoek@baylibre.com>
Tested-by: Mattijs Korpershoek <mkorpershoek@baylibre.com>
Signed-off-by: Praneeth Bajjuri <praneeth@ti.com>
commit e058176be32b09ca4f787442fd99d29e44079519 upstream.
Introduce vendor boot image for version 3 and 4 of boot image header.
The vendor boot image will hold extra information about kernel, dtb
and ramdisk.
This is done to prepare for boot image version 3 and 4 support.
commit 607b07554e23ff58d245f16765d831253a4210de upstream.
Move from andr_boot_img_hdr_v0 to andr_image_data
structure to prepare for boot image header
version 3 and 4.
commit 734cb47d6de16d2e3b52a03bce5daab40e5bb29d upstream.
With the new vendor boot image introduced in versions 3 and 4
of boot image header, the header check must be done for both boot
image and vendor boot image. Thus, replace android_image_check_header()
by is_android_boot_image_header() to only refer to boot image header check.
commit 86b62947eb237daddc7014a6b3b5545d1848b02c upstream.
Vendor boot image is introduced in boot image header
version 3 and 4. Please check [1] for more details.
To prepare for boot image v3/v4 support, allow the abootimg command
to store the vendor_boot image address.
Full support for this new format will be done in a future patch.
Link:[1] https://source.android.com/docs/core/architecture/bootloader/partitions/vendor-boot-partitions
commit d71a732af45e2d3acef92649f4f7986a83175cf4 upstream.
Android introduced boot header version 3 or 4.
The header structure change with version 3 and 4 to support
the new updates such as:
- Introducing Vendor boot image: with a vendor ramdisk
- Bootconfig feature (v4)
Change andr_img_hdr struct name to maintain support for version v0,
v1 and v2 while introducing version 3 and 4.
Currently any integer array value is set as long up-to-40 character
hexadecimal string into environment variable when extracted from an
FDT using 'fdt get value path prop index', because the support for
handling integer arrays is not implemented, and fdt_value_env_set()
code falls back into the hash handling behavior instead.
Implement this support simply by checking whether user supplied any
index. If index is set and the property length is multiple of four,
then this is an integer array, and the code would extract value at
specified index.
There is a subtle change where default index is set to -1 instead of 0.
This is OK, since the only place which checks for index to be less or
equal zero is the string array handling code in fdt_value_env_set() and
that code would work perfectly well with index -1 too.
Signed-off-by: Marek Vasut <marek.vasut+renesas@mailbox.org>
The address returned from 'fdt get addr' command must be mapped
into sysmem, as this is a working FDT. Access to this address
without mapping it would lead to crash e.g. in sandbox.
The following command triggers the crash:
./u-boot -Dc 'fdt addr $fdtcontroladdr ; fdt get addr var / compatible ; md $var'
The command assumed 32bit pointers so far, with 64bit pointer the
command would overwrite a piece of stack. Fix it by extending the
array size to cater for 64bit pointer, and use snprintf() to avoid
writing past the end of the array ever again.
The help text references 'addr' as an optional key start address,
but the explanation references the same as 'start', make sure they
both read as 'addr'. Also update the abbreviated 'addr' in the
explanation to 'address'.
On case 'fdt memory' is invoked without parameters, argv[2]/argv[3]
is not valid and this command would SEGFAULT in sandbox environment.
Add missing argc test to avoid the crash and rather print usage help
message.
On case 'fdt bootcpu' is invoked without parameters, argv[2] is not
valid and this command would SEGFAULT in sandbox environment. Add
message.
In case 'fdt rsvmem delete index' is passed a non-existent index, one
which does not exist in 'fdt rsvmem print', then the following command
triggers a print of help message for 'fdt' command instead of erroring
out:
=> fdt rsvmem delete 1234
This is because the subcommand errornously returns 'err' instead of
CMD_RET_FAILURE, fix it. Furthermore, align the number of spaces past
fdt_del_mem_rsv() and fdt_add_mem_rsv() in error message with the rest
of the code.
In case an FDT contains a node '/test-node@1234' , with no property
called 'noprop' in that node, the following command triggers a print
of help message for 'fdt' command instead of erroring out:
=> fdt rm /test-node@1234 noprop
fdt_delprop() in error message with the rest of the code.
It is perfectly valid to request an address or size of FDT property
without value, the only special case if requesting of the value of
FDT property without value. Invert the test such, that properties
without value still set the variable from 'fdt get addr/size' to
address of the property or size of the property, where the later
is 0.
Import is_printable_string() implementation from DTC 1.7.0 as of
DTC commit 039a994 ("Bump version to v1.7.0") . This fixes a print
of u32 property which so far used to be printed as string by U-Boot
fdt print command.
We might see the case where the parsed property value, in this case
it is a 32-bit integer, identified as a printable string or a null byte
(concatenated strings) because of its last character happens to be:
0x00 (null character), 0xB (vertical tab character) or
0x10 (line feed character)
In this situation, if the string is identified as printable string,
it will be displayed as character instead of hex value
When the isprint() condition is true, there are two possibilities:
1) The character is ASCII character (except the first 32)
2) The character is extended ASCII character
For example,
NG property in device tree:
clock-frequency = <16640000>;
by default, would be displayed as
clock-frequency = "", "ýè";
and with this patch applied, would be displayed as
clock-frequency = <0x00fde800>;
Full investigation was done by Nam and Hai, patch reworked by Marek
to use common code from DTC.
Signed-off-by: Hai Pham <hai.pham.ud@renesas.com>
Signed-off-by: Nam Nguyen <nam.nguyen.yh@renesas.com>
Measures the DTB passed to the EFI application upon new boolean config
switch CONFIG_EFI_TCG2_PROTOCOL_MEASURE_DTB. For platforms where the
content of the DTB passed to the OS can change across reboots, there is
not point measuring it hence the config switch to allow platform to not
embed this feature.
Co-developed-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
Signed-off-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
Signed-off-by: Etienne Carriere <etienne.carriere@linaro.org>
Tested-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
Reviewed-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
- mvebu: Support for 2 new Armada 385 boards (Tony)
- mvebu: Minor misc board enhancements (Tony)
- kirkwood: Serial driver fixes (Kconfig & dtsi) (Tony)
- cmd: return code when tlv_eeprom incorrectly called (Heinrich)
A command called with incorrect parameters should set $? to 1 (false).
Instead of calling cmd_usage(cmdtp) and then returning 0 just return
CMD_RET_FAILURE.
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Acked-by: Baruch Siach <baruch@tkos.co.il>
At the moment every subcommand of "fdt", except "addr" itself, requires
the DT address to be set first. We explicitly check for that before even
comparing against the subcommands' string.
This early bailout also affects the "move" subcommand, even though that
does not require or rely on a previous call to "fdt addr". In fact it
even sets the FDT address to the target of the move command, so is a
perfect beginning for a sequence of fdt commands.
Move the check for a previously set FDT address to after we handle the
"move" command also, so we don't need a dummy call to "fdt addr" first,
before being able to move the devicetree.
This skips one pointless "fdt addr" call in scripts which aim to alter
the control DT, but need to copy it to a safe location first (for
instance to $fdt_addr_r).
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
The "fdt move" subcommand was using the provided DTB addresses directly,
without trying to "map" them into U-Boot's address space. This happened
to work since on the vast majority of "real" platforms there is a simple
1:1 mapping of VA to PAs, so either value works fine.
However this is not true on the sandbox, so the "fdt move" command fails
there miserably:
=> fdt addr $fdtcontroladdr
=> cp.l $fdtcontroladdr $fdt_addr_r 40 # simple memcpy works
=> fdt move $fdtcontroladdr $fdt_addr_r
Segmentation fault
Use the proper "map_sysmem" call to convert PAs to VAs, to make this
more robust in general and to enable operation in the sandbox.
The clock UCLASS need to be probed to allow availability of the
private data (struct clk *), get in show_clks() with dev_get_clk_ptr()
before use them.
Without this patch the clock dump can cause crash because all the
private data are not available before calling the API clk_get_rate().
It is the case for the SCMI clocks, priv->channel is needed for
scmi_clk_get_rate() and it is initialized only in scmi_clk_probe().
This issue causes a crash for "clk dump" command on STM32MP135F-DK board
for SCMI clock not yet probed.
Fixes: 1a725e229096 ("clk: fix clock tree dump to properly dump out every registered clock")
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Reviewed-by: Sean Anderson <seanga2@gmail.com>
Link: https://lore.kernel.org/r/20221213145708.v2.1.Ia0bc6b272f1e2e3f37873c61d79138c2663c4055@changeid
https://source.denx.de/u-boot/custodians/u-boot-efi
Pull request for efi-2023-04-rc2
Documentation:
* Provide page with links to talks on U-Boot
UEFI:
* Enable CTRL+S to save the boot order in eficonfig command
* Run attribute check for QueryVariableInfo() only for the file store
* Bug fixes
Others:
* Improve output formatting of the coninfo command
# -----END PGP SIGNATURE-----
# gpg: Signature made Fri 10 Feb 2023 12:15:45 PM EST
# gpg: using RSA key 6DC4F9C71F29A6FA06B76D33C481DBBC2C051AC4
# gpg: Good signature from "Heinrich Schuchardt <xypron.glpk@gmx.de>" [unknown]
# gpg: aka "[jpeg image of size 1389]" [unknown]
# gpg: WARNING: This key is not certified with a trusted signature!
# gpg: There is no indication that the signature belongs to the owner.
# Primary key fingerprint: 6DC4 F9C7 1F29 A6FA 06B7 6D33 C481 DBBC 2C05 1AC4
This converts 1 usage of this option to the non-SPL form, since there is
no SPL_EFI_SECURE_BOOT defined in Kconfig
no SPL_EFI_MM_COMM_TEE defined in Kconfig
no SPL_VIDEO_ANSI defined in Kconfig
This converts 2 usages of this option to the non-SPL form, since there is
no SPL_VIDEO defined in Kconfig
no SPL_USB_FUNCTION_FASTBOOT defined in Kconfig
no SPL_UDP_FUNCTION_FASTBOOT defined in Kconfig
This converts 5 usages of this option to the non-SPL form, since there is
no SPL_SYS_LONGHELP defined in Kconfig
The eficonfig command is required to set boot options.
The eficonfig command invokes functions implemented in common/menu.c like
* menu_default_set()
* menu_get_choice()
* menu_destroy()
* menu_item_add()
Fixes: 87d791423ac6 ("eficonfig: menu-driven addition of UEFI boot option")
The change boot order menu in eficonfig can have at most INT_MAX lines
and it is troublesome to scroll down to the "Save" entry.
This commit assigns CTRL+S to save the boot order.
Signed-off-by: Masahisa Kojima <masahisa.kojima@linaro.org>
Acked-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
On the sandbox called without "--terminal raw" CTRL+C leaves U-Boot,
"ESC/CTRL+C to quit" is misleading.
Let's remove CTRL+C to quit key handling from bootmenu and eficonfig menu.
Reviewed-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Device name are typically longer than 8 characters. This leads to ragged
output.
Only the I and O bit of the device flags are of interest for the user.
Writing a hexadecimal number is just confusing.
Before the patch the output looked like this:
=> coninfo
List of available devices:
pl011@9000000 00000007 IO stdin stdout stderr
serial 00000003 IO
usbkbd 00000001 I.
With the patch the output looks like this:
=> coninfo
|-- pl011@9000000 (IO)
| |-- stdin
| |-- stdout
| |-- stderr
|-- serial (IO)
|-- usbkbd (I)
This converts 3 usages of this option to the non-SPL form, since there is
no SPL_CMD_TFTPPUT defined in Kconfig
no SPL_CMD_NVEDIT_EFI defined in Kconfig
no SPL_CMD_EFICONFIG defined in Kconfig
This is not used anywhere, so drop it.
This is not used. Drop it.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
This is not used anywhere. Drop it.
This command has no Kconfig option at present, but seems useful enough to
keep around. Add one.
Add a command to load SEAMA (Seattle Image), a NAND flash
on-flash storage format.
This type of flash image is found in some D-Link routers such
as DIR-645, DIR-842, DIR-859, DIR-860L, DIR-885L, DIR890L and
DCH-M225, as well as in WD and NEC routers on the ath79
(MIPS), Broadcom BCM53xx, and RAMIPS platforms.
This U-Boot command will read and decode a SEAMA image from
raw NAND flash on any platform. As it is always using big endian
format for the data decoding is always necessary on platforms
such as ARM.
The command is needed to read a SEAMA-encoded boot image on the
D-Link DIR-890L router for boot from NAND flash in an upcoming
port of U-Boot to the Broadcom Northstar (BCM4709, BCM53xx)
architecture.
A basic test and documentation is added as well. The test must
be run on a target with NAND flash support and at least one
resident SEAMA image in flash.
Cc: Rafał Miłecki <rafal@milecki.pl>
This is currently in the cmd/ file but we want to call it from a driver.
Move it into a common place. Tidy up the header-file order while we are
here.
This uses casts all over the place. Use the correct type so that these
can be avoided, as is done with other commands. Also simplify a few
conditionals.
It is sometimes useful to have one without the other, e.g. on a device
without a display, since at present the expo feature requires CONFIG_VIDEO
to be enabled.
Update the Makefile and bootflow command to support this, as well as the
EXPO dependency.
https://source.denx.de/u-boot/custodians/u-boot-amlogic
- jethub j100: add rescue boot from microSD
- move meson sm command to cmd/meson and add efusedump sub-command
- switch dwc2 otg to DM for G12A, GXL & AXG
- Add new boards:
- Odroid Go Ultra
- Odroid-N2L
