default n/no doesn't need to be specified. It is default option anyway.
[trini: Rework FSP_USE_UPD portion]
All platforms define CONFIG_SYS_LOAD_ADDR, but only some define
CONFIG_LOADADDR. Very very rarely are these not the same address, and
qemu-ppce500 is one such case. However, based on reading the history of
the code, this mismatched value was simply a copy-paste from other
PowerPC platforms where it is this unused currently. Switch the code to
use CONFIG_SYS_LOAD_ADDR and update the documentation.
Cc: Bin Meng <bmeng.cn@gmail.com>
CONFIG_SYS_I2C_SPEED
CONFIG_SYS_I2C_SLAVE
There are no longer any cases where we are neither SYS_I2C_LEGACY nor
DM_I2C. Remove these code paths.
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot
have SYS_I2C_LEGACY and DM_I2C at the same time, introduce
CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only
in SPL. Finally, for some PowerPC cases we also need
CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to
one or more symbols.
- Rename usages of CONFIG_SYS_DEF_EEPROM_ADDR to CONFIG_SYS_I2C_EEPROM_ADDR
based on current usage.
- Convert CONFIG_SYS_I2C_EEPROM_ADDR, CONFIG_SYS_I2C_EEPROM_ADDR_LEN,
CONFIG_SYS_I2C_EEPROM_BUS, CONFIG_CONFIG_SYS_EEPROM_SIZE
CONFIG_SYS_EEPROM_PAGE_WRITE_BITS and CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS
to Kconfig. We move these symbols around a bit and add appropriate
dependencies to them. In some cases, we now add a correct default value
as well.
At this point in time, there's no systems with "U-Boot environment
exists on an EEPROM which is accessed over the I2C bus" that sets this
option. Drop it.
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze
Xilinx changes for v2021.10-rc3
xilinx:
- Disable CONFIG_ARCH_FIXUP_FDT_MEMORY
- Print information about cpu via soc drivers and enable DISPLAY_CPUINFO
- Wire infrastructure for DTB_RESELECT and MULTI_DTB_FIT
zynq:
- Wire single QSPI
- Use power-source instead of io-standard properties
- Enable nor on zc770-xm012
zynqmp:
- Change handling around multi_boot()
- Setup offset for u-boot.itb in spi
- Generate run time dfu_alt_info for capsule update
- Use explicit values for enums (zynqmp_firmware.h)
- Enable RTC/SHA1/BUTTON/BUTTON_GPIO command
- Disable WDT driver by default
- Bind usb/scsi via preboot because of EFI
- DT updates/fixes
- Add soc driver
- Fix SPL SPI boot mode
versal:
- Add soc driver
sdhci:
- Update tap delay programming for zynq_sdhci driver
cmd:
- Fix RTC uclass handling in date command
- Update pwm help message
- Update reset help message
watchdog:
- Fix wwdt compilation
rtc:
- Deal with seq alias in rtc uclass
- Add zynqmp RTC driver
fdt:
- Add kernel-doc for fdt_fixup_memory_banks()
The commit 573a3811edc8 ("sysreset: psci: support system reset in a generic
way with PSCI") has added support for warm reset via PSCI but this hasn't
been reflected in usage message and user has to look at the code how to run
it. That's why update usage text to make this clear.
Here is full help with updated usage:
ZynqMP> help reset
reset - Perform RESET of the CPU
Usage:
reset - cold boot without level specifier
reset -w - warm reset if implemented
Reviewed-by: Igor Opaniuk <igor.opaniuk@foundries.io>
The first name is taken from command name that's why shouldn't be listed in
help. And commands shouldn't be listed with <> which means value but value
itself is command name.
Also add description for commands to make it clear what it does.
Before
pwm pwm <invert> <pwm_dev_num> <channel> <polarity>
pwm <config> <pwm_dev_num> <channel> <period_ns> <duty_ns>
After:
pwm invert <pwm_dev_num> <channel> <polarity> - invert polarity
pwm config <pwm_dev_num> <channel> <period_ns> <duty_ns> - config PWM
pwm enable <pwm_dev_num> <channel> - enable PWM output
pwm disable <pwm_dev_num> <channel> - disable PWM output
RTCs are using sequence number defined in aliases node. Date command with
DM_RTC enabled is looking for the first RTC with index 0. But when
RTC_EMULATION is enabled it gets likely most of the time index 0 even when
system has rtc0 device via aliases node and gets sequence number 0.
That's why extend the code to look for sequence 0 number first. If this
fails continue to use existing device with index 0.
Drop the pre-driver model code from this file.
Modified the help text of 'chpart' command ,mentioning that it is
for MTD devices.
Signed-off-by: Adarsh Babu Kalepalli <opensource.kab@gmail.com>
HELP description is provided for ‘configure’ sub-command
of ‘blkcache’.
- Fixed broken ICH SPI driver in software sequencer mode
- Added "m25p,fast-read" to SPI flash node for x86 boards
- Drop ROM_NEEDS_BLOBS and BUILD_ROM for x86 ROM builds
- Define a default TSC timer frequency for all x86 boards
- x86 MTRR MSR programming codes bug fixes
- x86 "hob" command bug fixes
- Don't program MTRR for DRAM for FSP1
- Move INIT_PHASE_END_FIRMWARE to FSP2
- Use external graphics card by default on Intel Crown Bay
- tangier: Fix DMA controller IRQ polarity in CSRT
It is a pain to have to specify the value 10 in each call. Add a new
dectoul() function and update the code to use it.
It is a pain to have to specify the value 16 in each call. Add a new
hextoul() function and update the code to use it.
Add a proper comment to simple_strtoul() while we are here.
The resource type for system memory is currently displayed as
"unknown", which is wrong.
Fixes: 51af144eb7a0 ("x86: Allow showing details about a HOB entry")
Tested on chromebook_coral, chromebook_samus, chromebook_link, minnowmax
At present the hob command usage and help messages are messed up
in a single line. They should be separated.
This was a regression introduced when [seq] and [-v] were added
to the command.
Fixes: d11544dfa9f4 ("x86: hob: Add way to show a single hob entry")
It seems useful to show whether the address of the Control or Working
devicetree is being shown. Add support for this. Drop the confusing 0x
prefix since the command itself only accepts hex.
Clean up the code a little before changing it.
It is quite confusing that CONFIG_SYS_I2C selects the legacy I2C and
CONFIG_DM_I2C selects the current I2C. The deadline to migrate I2C is less
than a year away.
Also we want to have a CONFIG_I2C for U-Boot proper just like we have
CONFIG_SPL_I2C for SPL, so we can simplify the Makefile rules.
Rename this symbol so it is clear it is going away.
Rename these options so that CONFIG_IS_ENABLED can be used with them.
Add format string handling operator to the setexpr command.
It allows to use C or Bash like format string expressions to be
evaluated with the result being stored inside the environment variable
name.
setexpr <name> fmt <format> [value]...
The following example
setexpr foo fmt "%d, 0x%x" 0x100 ff
will result in $foo being set to "256, 0xff".
Signed-off-by: Roland Gaudig <roland.gaudig@weidmueller.com>
Import the following helper functions from Busybox-1.33.1 which are
required by printf.c:
process_escape_sequence from libbb/process_escape_sequence.c,
skip_whitespace from libbb/skip_whitespace.c,
overlapping_strcpy from libbb/safe_strncpy.c
src-url: https://git.busybox.net/busybox/
commit bcc5b0e6caca6c7602a6a41f "Bump version to 1.33.1"
version: 1.33.1
Import printf.c from the Busybox project, which provides Bash like
format string handling.
version: 1.33.1
smc and hvc commands take upto 8 user input arguments, the maximum
number of arguments of the U_BOOT_CMD macro should set to 9.
Besides, fix the typo (arg7 -> arg6) in hvc command's help message.
Signed-off-by: Siew Chin Lim <elly.siew.chin.lim@intel.com>
As 'part_get_info_by_name' now returns more status codes than just
-1 to indicate failure, we need to update the return value check.
Signed-off-by: Anders Dellien <anders.dellien@arm.com>
Reviewed-by: Sean Anderson <sean.anderson@seco.com>
Allow pin name parameter for pimux staus command,
as gpio command to get status of one pin.
The possible usage of the command is:
> pinmux dev pinctrl
> pinmux status
> pinmux status -a
> pinmux status <pin-name>
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Update the result of do_status and always returns a CMD_RET_ value
(-ENOSYS was a possible result of show_pinmux).
This patch also adds pincontrol name in error messages (dev->name)
and treats correctly the status sub command when pin-controller device is
not selected.
As the logic here is only used when we have a USB host controller, test
on CONFIG_USB_HOST rather than CONFIG_USB in general. This lets us move
towards using CONFIG_USB only as a menu symbol to say that we have some
form of USB, and then USB_HOST or USB_GADGET depending on the role that
USB plays within the build.
We cannot build this without USB_GADGET_DOWNLOAD support enabled, add
the appropriate depends line.
In a system with multiple network controllers it can be difficult
to know the names of the various devices available. This is especially
true for USB ether devices as they do not display device names upon
detection.
This is being added as a net sub-system in case other commands may
want to be added or moved here.
Note that this is only enabled for DM_ETH
Example:
U-Boot > net
net - NET sub-system
Usage:
net list - list available devices
U-Boot > net list
eth0 : ethernet@2188000 00:d0:12:98:f5:47 active
eth1 : e1000#0 00:d0:12:98:f5:48
eth2 : asix_eth 8c:ae:4c:f5:84:9d
eth3 : asix_eth 8c:ae:4c:f9:41:e3
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
Probably, a pointer to a variable in an inner block should not
be exposed to an outer block.
Fixes: c70f44817d46 ("efi_loader: simplify 'printenv -e'")
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
[trini: Don't make guid const now]
This reverts commit 4e1903a645453deab5ec5dd1cf4f0061469b99c3.
This local commit was not intended to be pushed out.
Prepare v2021.07-rc5
# gpg: Signature made Mon 28 Jun 2021 03:39:36 PM EDT
# gpg: using RSA key 1A3C7F70E08FAB1707809BBF147C39FF9634B72C
# gpg: Good signature from "Thomas Rini <trini@konsulko.com>" [ultimate]
# Conflicts:
# configs/am64x_evm_r5_defconfig
Display the number of the boot option and not its index.
Fixes: 2ecee31017bf ("efi_loader: use efi_create_indexed_name()")
The <name> argument can now also be MTD's DM device name or OF path.
Mention this is command help.
Signed-off-by: Marek Behún <marek.behun@nic.cz>
Reviewed-by: Miquel Raynal <miquel.raynal@bootlin.com>
Tested-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Cc: Priyanka Jain <priyanka.jain@nxp.com>
Print MTD's device OF path in the output of `mtd list` command.
This patch allows uboot scripts make choices about where to boot from based
on the active mmc boot partition. This allows having two copies of kernel,
filesystems etc, and choosing which to boot from based off of the active
bootloader partition.
Signed-off-by: Reuben Dowle <reuben.dowle@4rf.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
If the environment does not have "soc" or "board" set, and fdtdir
option is specified in extlinux.conf, the bootloader will crash whilst
dereferencing a null pointer. Add a guard against null soc or
board. Fixes a crash of qemu-riscv64_smode configuration, which does
not have CONFIG_SYS_SOC defined.
Signed-off-by: Dimitri John Ledkov <xnox@ubuntu.com>
Add support command for debugging K3 power domains. This is useful with
the HSM rearch setup, where power domains are directly controlled by SPL
instead of going through the TI SCI layer. The debugging support is only
available in the u-boot codebase though, so the raw register access
power domain layer must be enabled on u-boot side for this to work. By
default, u-boot side uses the TI SCI layer, and R5 SPL only uses the
direct access methods.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
Signed-off-by: Tero Kristo <kristo@kernel.org>
Add new clk subcommand "clk setfreq", for setting up a clock rate
directly from u-boot cmdline. This is handy for any debugging purposes
towards clocks.
Acked-by: Lukasz Majewski <lukma@denx.de>
Some clocks are not associated to a DM node, so just parsing the DM is not
enough. This is especially true for root clocks, which typically don't have
any parents. Instead, fetch every registered UCLASS_CLK instance, and dump
these out.
Add the missing dependency for the command ums:
- CONFIG_BLK: call of blk_* functions in usb_mass_storage.c
- CONFIG_USB_GADGET: required to select CONFIG_USB_FUNCTION_MASS_STORAGE
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Use efi_get_variable_int() instead of EFI_CALL(RT->get_variable()).
Use efi_set_variable_int() instead of EFI_CALL(efi_set_variable()).
Tested-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
Reviewed-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
Simplify the creation of indexed variable names like 'Boot0000' by using
function efi_create_indexed_name().
To print a UTF-16 string use %ls instead of converting string to UTF-8.
