Introduce a new version of the Keystone-II "ddr" command
for testing the inline ECC support in the DDRSS bridge
available on AM62 and AM64. The ECC hardware support in
K3's DDRSS and the test method differ substantially from
what we support in the K2 variant of the command. The
name of the new command is "ddrss".
The ECC test procedure follows these steps:
1) Flush and disable the data cache.
2) Shrink the protected ECC R0 range.
3) Flip a bit outside the shrunk range.
4) Restore the range to original.
5) Read the modified value (corrected).
6) Re-enable the data cache.
This which will cause the 1-bit ECC error count to increase
while the read will return the corrected value.
The K3 version of the command preserves the syntax for the
"ecc_err" argument.
The "ti,am64-ddrss" memory controller node is available only
in the R5 device tree. We don't have Linux kernel support
for DDRSS (e.g EDAC driver) yet, so the command uses a fixed
address as base. Once a Linux kernel consumer is available
we can fetch the DDRSS base from dts.
Signed-off-by: Georgi Vlaev <g-vlaev@ti.com>
Upstream commit 69076dff2284ed099cc0583e5e64bd8012d1ab5c
This adds support for specifying FDT overlays in an extlinux/pxelinux
configuration file.
Without this, there is no simple way to apply overlays when the kernel
and fdt is loaded by the pxe command.
This change adds the 'fdtoverlays' keyword for a label, supporting multiple
overlay files to be applied on top of the fdt specified in the 'fdt' or
'devicetree' keyword.
Example:
label linux
kernel /Image
fdt /soc-board.dtb
fdtoverlays /soc-board-function.dtbo
append console=ttyS0,115200 root=/dev/mmcblk0p2 rootwait
This code makes usage of a new variable called fdtoverlay_addr_r used to load
the overlay files without overwritting anything important.
Cc: Jernej Å krabec <jernej.skrabec@siol.net>
Cc: Jonas Karlman <jonas@kwiboo.se>
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Link: https://lists.denx.de/pipermail/u-boot/2019-May/368388.html
[robertcnelson@gmail.com: Backport to TI u-boot]
Signed-off-by: Robert Nelson <robertcnelson@gmail.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
The slot rollback system is intended for normal boot failures after an
OTA, and therefore, we should not attempt to change slots based on a
failure to boot to recovery (or any other non-normal boot sequence).
Signed-off-by: Ram Muthiah <rammuthiah@google.com>
Link: https://android-review.googlesource.com/c/platform/external/u-boot/+/1446441
Signed-off-by: Guillaume La Roque <glaroque@baylibre.com>
commit e7588d81cd84b8a43633850a13ba94ffc139044d upstream.
The arm64 version of the exception command was just defining the
undefined exception, but actually copied the AArch32 instruction.
Replace that with an encoding that is guaranteed to be and stay
undefined. Also add instructions to trigger unaligned access faults and
a breakpoint.
This brings ARM64 on par with ARM(32) for the exception command.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
[nm@ti.com: backport from upstream]
commit 19f7a34a4642e25aa8b80c6d75129fe7848a158d upstream.
Add support for enumerating MMC card in a given mode using mmc rescan and
mmc dev commands. The speed mode is provided as the last argument in these
commands and is indicated using the index from enum bus_mode in
include/mmc.h. A speed mode can be set only if it has already been enabled
in the device tree.
Signed-off-by: Aswath Govindraju <a-govindraju@ti.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Tested-by: Jaehoon Chung <jh80.chung@samsung.com>
Add support command for debugging K3 power domains. This is useful with
the HSM rearch setup, where power domains are directly controlled by SPL
instead of going through the TI SCI layer. The debugging support is only
available in the u-boot codebase though, so the raw register access
power domain layer must be enabled on u-boot side for this to work. By
default, u-boot side uses the TI SCI layer, and R5 SPL only uses the
direct access methods.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
Add new clk subcommand "clk setfreq", for setting up a clock rate
directly from u-boot cmdline. This is handy for any debugging purposes
towards clocks.
Acked-by: Lukasz Majewski <lukma@denx.de>
Some clocks are not associated to a DM node, so just parsing the DM is not
enough. This is especially true for root clocks, which typically don't have
any parents. Instead, fetch every registered UCLASS_CLK instance, and dump
these out.
This commits add a check on the command ubi rename. This check avoids
to rename a volume to with a name that is already used on another ubi
volume. If two volumes has the same name, then the ubi device can't be
mounted anymore.
Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
For implementing the EFI_TCG2_PROTOCOL we need the count field returned by
the TPM when reading capabilities via tpm2_get_capability().
Adjust the implementation of the 'tpm2 get_capability' command accordingly.
Suggested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Signed-off-by: Ilias Apalodimas <ilias.apalodimas@linaro.org>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
This command was missed when renaming getc() to getchar().
Fixes: c670aeee3df9 ("common: rename getc() to getchar()")
This adds several commands to add, list, and remove log filters. Due to the
complexity of adding a filter, `log filter-list` uses options instead of
positional arguments.
These commands have been added as subcommands to log by using a dash to
join the subcommand and subsubcommand. This is stylistic, and they could be
converted to proper subsubcommands if it is wished.
Signed-off-by: Sean Anderson <seanga2@gmail.com>
This makes the log level command print all valid log levels. The default
log level is annotated. This provides an easy way to see which log levels
are compiled-in.
This allows users to query which categories and drivers are available on
their system. This allows them to construct filter-add commands without
(e.g.) adjusting the log format to show categories and drivers.
Move parsing of log level into its own function so it can be re-used. This
also adds support for using log level names instead of just the integer
equivalent.
This reduces duplicate code, and makes adding new sub-commands easier.
When rebasing this series I had to renumber all my log tests because
someone made another log test in the meantime. This involved updaing a
number in several places (C and python), and it wasn't checked by the
compiler. So I though "how hard could it be to just rewrite in C?" And
though it wasn't hard, it *was* tedious. Tests are numbered the same as
before to allow for easier review.
A note that if a test fails, everything after it will probably also fail.
This is because that test won't clean up its filters. There's no easy way
to do the cleanup, except perhaps removing all filters in a wrapper
function.
Checkpatch complains about using #ifdef for CONFIG variables.
- Bug fixes and updates on vid, ls1088a lx2160a and other layerscape
platforms.
- Add optee_rpmb support for LX2 & Kontron sl28 support
This command lets the user list, select, and deselect mux controllers
introduced with the mux framework on the fly. It has 3 subcommands:
list, select, and deselect.
List: Lists all the mux present on the system. The muxes are listed for
each chip. The chip is identified by its device name. Each chip can have
a number of mux controllers. Each is listed in sequence and is assigned
a sequential ID based on its position in the mux chip. It lists details
like ID, whether the mux is currently selected or not, the current
state, the idle state, and the number of states.
A sample output would look something like:
=> mux list
a-mux-controller:
ID Selected Current State Idle State Num States
0 no unknown as-is 0x4
1 no 0x2 0x2 0x10
2 no 0x73 0x73 0x100
another-mux-controller:
0 no 0x1 0x1 0x4
1 no 0x2 0x2 0x4
Select: Selects a given mux and puts it in the specified state. This
subcommand takes 3 arguments: mux chip, mux ID, state to set
the mux in. The arguments mux chip and mux ID are used to identify which
mux needs to be selected, and then it is selected to the given state.
The mux needs to be deselected before it can be selected again in
another state. The state should be a hexadecimal number.
For example:
=> mux list
a-mux-controller:
0 no 0x1 0x1 0x4
1 no 0x1 0x1 0x4
=> mux select a-mux-controller 0 0x3
=> mux list
a-mux-controller:
0 yes 0x3 0x1 0x4
1 no 0x1 0x1 0x4
Deselect: Deselects a given mux and puts it in its idle state. This
subcommand takes 2 arguments: the mux chip and mux ID to identify which
mux needs to be deselected. So in the above example, we can deselect mux
0 using:
=> mux deselect a-mux-controller 0
=> mux list
a-mux-controller:
0 no 0x1 0x1 0x4
1 no 0x1 0x1 0x4
Signed-off-by: Pratyush Yadav <p.yadav@ti.com>
do_save() function defined in fs.c also supports FAT file system
re-use the same for fatwrite command.
Also fix the FAT test script to match the expected output.
Signed-off-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com>
Reviewed-by: Biju Das <biju.das.jz@bp.renesas.com>
Enable the command "misc" for accessing miscellaneous devices with
a MISC uclass driver. The command provides listing all MISC devices
as well as read and write functionalities via their drivers.
Signed-off-by: Bin Meng <bin.meng@windriver.com>
CONFIG_CMD_TIMER merits a single file instead of co-exist in the
sleep command file.
The "cmd/Kconfig" has a TODO description for CMD_MISC that it should
really be named as CMD_SLEEP. Change it in the whole source tree.
Enable "optee_rpmb" command to write/read named persistent values
created on RPMB by opening session with OPTEE AVB TA.
This provides easy test for establishing a session with OPTEE
TA and storage of persistent data in MMC RPMB.
It includes following subcommands:
optee_rpmb read_pvalue:read persistent values on rpmb via OPTEE AVB TA
optee_rpmb write_pvalue:write persistent values on rpmb via OPTEE AVB
TA
Signed-off-by: Ruchika Gupta <ruchika.gupta@nxp.com>
[Rebased]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
The sandbox is built with the SDL2 library with invokes the X11 library
which in turn calls getc(). But getc() in glibc is defined as
int getc(FILE *)
This does not match our definition.
int getc(void)
The sandbox crashes when called with parameter -l.
Rename our library symbol getc() to getchar().
To make the button command useful in a shell script it should return the
status of the button:
* 0 (true) - pressed, on
* 1 (false) - not pressed, off
The button command takes only one argument. Correct maxargs.
Adjust the Python unit test.
Reviewed-by: Philippe Reynes <philippe.reynes@softathome.com>
To simplify configuration and keep synchronized the PStore/Ramoops between
U-Boot and the Linux kernel, this commit dynamically adds the Ramoops
parameters defined in the U-Boot session to the Device Tree.
Signed-off-by: Frédéric Danis <frederic.danis@collabora.com>
Cc: Heinrich Schuchardt <xypron.glpk@gmx.de>
This patch adds a new pstore command allowing to display or save ramoops
logs (oops, panic, console, ftrace and user) generated by a previous
kernel crash.
PStore parameters can be set in U-Boot configuration file, or at run-time
using "pstore set" command. Records size should be the same as the ones
used by kernel, and should be a power of 2.
This command allows:
- to display uncompressed logs
- to save compressed or uncompressed logs, compressed logs are saved as a
compressed stream, it may need some work to be able to decompress it,
e.g. adding a fake header:
"printf "\x1f\x8b\x08\x00\x00\x00\x00\x00\x00\x00" |
cat - dmesg-ramoops-0.enc.z | gzip -dc"
- ECC part is not used to check memory corruption
- only 1st FTrace log is displayed or saved
[trini: Minor updates for current design, correct spacing in rST]
At present the autoboot options are in cmd/Kconfig but they don't really
relate to commands. They relate to booting, so move this menu under the
boot menu.
bloblist enhancement for alignment
Update ofnode/dev_read phandle function
sandbox keyboard enhancements and fixes
It is helpful to be able to see basic statistics about the bloblist and
also to list its contents. Add a 'bloblist' command to handle this.
Put the display functions in the bloblist modules rather than in the
command code itself. That allows showing a list from SPL, where commands
are not available.
Also make bloblist_first/next_blob() static as they are not used outside
this file.
The device tree may contain a /reserved-memory node. The no-map property
of the sub-nodes signals if the memory may be accessed by the UEFI payload
or not.
In the EBBR specification (https://github.com/arm-software/ebbr) the
modeling of the reserved memory has been clarified.
If a reserved memory node in the device tree has the no-map property map,
create a EfiReservedMemoryType memory map entry else use
EfiBootServicesData.
Bring in the assorted changes that have been staged in the 'next' branch
prior to release.
This commits update the support of sntp to use
the framework udp. This change allows to remove
all the reference to sntp in the main network
file net/net.c.
For RISC-V arch, no need for CMD_IRQ so disable the same.
Signed-off-by: Pragnesh Patel <pragnesh.patel@sifive.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Reviewed-by: Bin Meng <bin.meng@windriver.com>
Add the Random Number Generator (RNG) protocol to the GUIDs that the
'efidebug dh' protocol can replace by a text.
into next
- Enhance the 'zboot' command to be more like 'bootm' with sub-commands
- The last series of ACPI core changes for programmatic generation of
ACPI tables
- Add all required ACPI tables for ApolloLake and enable ACPIGEN on
Chromebook Coral
- A feature minor enhancements to the 'hob' command
- Intel edison: Support for writing an xFSTK image via binman
At present the 'bdinfo' command shows the framebuffer address, but not the
address of the copy framebuffer, if present. Add support for this.
At present the mtrr command only support 8 MTRRs. Some SoCs have more than
that. Update the implementation to support up to 10. Read the number of
MTRRs dynamically instead.
Some HOBs include information that can be decoded. Add a -v option to the
hob command, to allow this to be displayed. Add the ability to decode a
resource descriptor.
GUIDs are one of the seven evils of the computer world. They obfuscate the
meaning and require people to look up long hex strings to decode it.
Luckily only a miniscule fraction of the 10^38 possible GUIDs are in use.
Add a way to decode the GUIDs known to U-Boot. Add a few more to the list
for good measure.
The 'hob' command currently lists all HOB entries. Add way to list a
single entry, by index.
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze into next
Xilinx changes for v2021.01
arm64:
- Support for bigger U-Boot images compiled with PIE
microblaze:
- Extend support for LE/BE systems
zynqmp:
- Refactor silicon ID detection code with using firmware interface
- Add support for saving variables based on bootmode
zynqmp-r5:
- Fix MPU mapping and defconfig setting.
xilinx:
- Minor driver changes: names alignment
- Enable UBIFS
- Minor DT and macros fixes
- Fix boot with appended DT
- Fix distro boot
cmd:
- pxe: Add fixing for platforms with manual relocation support
clk:
- fixed_rate: Add DM flag to support early boot on r5
fpga:
- zynqmppl: Use only firmware interface and enable SPL build
serial:
- uartlite: Enable for ARM systems and support endians
mmc:
- zynq: Fix indentation
net:
- gem: Support for multiple phys
- emac: Fix 64bit support and enable it for arm64
kconfig:
- Setup default values for Xilinx platforms
- Fix dependecies for Xilinx drivers
- Source board Kconfig only when platform is enabled
- Fix FPGA Kconfig entry with SPL
- Change some defconfig values
bindings:
- Add binding doc for vsc8531
pxe sub commands need to be manually relocated for architectures which
enables MANUAL_RELOC as Microblaze.
Signed-off-by: T Karthik Reddy <t.karthik.reddy@xilinx.com>
Merge in v2020.10-rc5
The revisions are usually dates in hex-decimal format representing
YYYYmmdd. Print them in hex to see this clearly.
Before:
FACP 000e5420 0000f4 (v06 U-BOOT U-BOOTBL 538970376 INTL 0)
DSDT 000e4780 000ba0 (v02 U-BOOT U-BOOTBL 65536 INTL 538968870)
After:
FACP 000e5420 0000f4 (v06 U-BOOT U-BOOTBL 20200908 INTL 0)
DSDT 000e4780 000ba0 (v02 U-BOOT U-BOOTBL 10000 INTL 20200326)
Fixes: 0b885bcfd9b0 ("acpi: Add an acpi command")
Cc: Wolfgang Wallner <wolfgang.wallner@br-automation.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-efi
Pull request for UEFI sub-system for efi-2020-10-rc5 (2)
The following bugs are fixed:
* incorrect online help for setenv and env
* description of function efi_mem_carve_out()
* replace printf() by log_err() in stm32mp1_rng driver
A unit test is provided to check that the boot hart id is provided in the
RISC-V device-tree.
'env -e -i' syntax was changed from "," to ":". Account for this also
in the documentation.
Fixes: 2b3fbcb59f41 ("efi_loader: use ':' as separator for setenv -i")
Signed-off-by: Maxim Uvarov <maxim.uvarov@linaro.org>
Correct the usage description for setenv -e too.
The bitflip test uses two equal sized memory buffers. This is achieved
by splitting the range of memory into two pieces. The address of the
second buffer, as well as the length of each buffer, were not correctly
calculated. This caused bitflip test to access beyond the end of range.
This patch fixes the pointer arithmetic problem.
A second problem arises because u-boot "mtest" command expects the
ending address to be inclusive. When computing (end - start) this
results in missing 1 byte of the requested length. The bitflip test
expects a count rather than an "ending" address. Thus it fails to test
the last word of the requested range. Fixed by using (end - start + 1).
Added Kconfig option to optionally disable the bitflip test, since it
does add significantly to the time taken for "mtest".
Fixes: 8e434cb705d463bc8cff935160e4fb4c77cb99ab ("cmd: mem: Add bitflip
memory test to alternate mtest")
Signed-off-by: Ralph Siemsen <ralph.siemsen@linaro.org>
