CONFIG_CMD_LOG without CONFIG_LOG leads to a build error:
‘gd_t {aka volatile struct global_data}’ has no member named
‘default_log_level’
So CMD_LOG should select LOG.
We have a large number of places where while we historically referenced
gd in the code we no longer do, as well as cases where the code added
that line "just in case" during development and never dropped it.
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
In case of error in soc_clk_dump function are returned different values
then CMD return values (-1, 0, 1).
For example:
ZynqMP> clk dump
exit not allowed from main input shel
The patch is checking all negative return values and return
CMD_RET_FAILURE which is proper reaction for these cases.
On VxWorks x86 its bootline address is at a pre-defined offset @
0x1200. If 'bootaddr' is not passed via environment variable, we
assign its value based on the kernel memory base address.
Exit the 'bootvx' command if bootline address is not specified.
There is a small duplication in do_bootvx() that does the bootline
copy. Refactor this a little bit to make it simpler.
When booting from EFI BIOS, VxWorks bootloader stores the EFI GOP
framebuffer info at a pre-defined offset @ 0x6100. When VxWorks
kernel boots up, its EFI console driver tries to find such a block
and if the signature matches, the framebuffer information will be
used to initialize the driver.
However it is not necessary to prepare an EFI environment for
VxWorks's EFI console driver to function (eg: EFI loader in
U-Boot). If U-Boot has already initialized the graphics card and
set it to a VESA mode that is compatible with EFI GOP, we can
simply prepare such a block for VxWorks.
This adds a very simple ELF64 loader via program headers, similar
to load_elf_image_phdr() that we already have.
This changes 'struct e820entry' to 'struct e820_entry' to conform
with the coding style.
Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
This changes 'struct e820info' to 'struct e820_info' to conform
VxWorks bootloader stores its size at a pre-defined offset @ 0x5004.
Later when VxWorks kernel boots up and system memory information is
retrieved from the E820 table, the bootloader size will be subtracted
from the total system memory size to calculate the size of available
memory for the OS.
Explicitly clear the bootloader image size otherwise if memory
at this offset happens to contain some garbage data, the final
available memory size for the kernel is insane.
address
At present two environment variables 'e820data'/'e820info' are required
to boot a VxWorks x86 kernel, but this is superfluous. The offset of
these two tables are actually at a fixed offset from the kernel memory
base address and we can provide the kernel memory base address to U-Boot
via only one variable 'vx_phys_mem_base'.
Note as it name indicates, the physical address should be provided.
Without armv8_setup_psci register VBAR_EL3 is not set up property which
makes SMC calls jump to invalid location.
smp_kick_all_cpus is required to make slave cpus leave gic_wait_for_interrupt.
Without this they will never pursue booting process.
Fix was applied to the two ways of booting VxWorks: bootvx and bootm commands.
This implementation is very similar to what is done in boot_jump_linux
in arch/arm/lib/bootm.c file.
Tested on VxWorks 7 release SR0520 2017-12-08 Intel Stratix 10 SX SoC
Development Kit board.
Signed-off-by: Vasyl Vavrychuk <vasyl.vavrychuk@globallogic.com>
This reverts the parts of commit 3b3ea2c56ec4bc5588281fd103c744e608f8b25c
where it changed the EFI dependency on NET.
Reviewed-by: Duncan Hare <dh@synoia.com>
The BOOTP options used to be and should still be default for all boards
with CMD_NET enabled. One should not be forced to use DISTRO_DEFAULTS to
get them.
Improve the documentation and correct the listed dependencies.
Commit 3b3ea2c56ec4bc5 ("Kconfig: cmd: Make networking command dependent on NET")
removed the help documentation from the README but didn't add it back to Kconfig.
Reviewed-by: Chris Packham <judge.packham@gmail.com>
The options were pretty unhelpful, so improve them some.
Move DHCP to directly follow BOOTP so that Kconfig can show the
dependency as a hierarchy.
Options that controlled the tftp and bootp commands depended on their
commands, but lived in the net menu.
Move them so they are in a consistent location.
Previously, CMD_NET was an alias for 2 commands (bootp and tftpboot) and
they we not able to be disabled. Separate out those 2 commands and move
CMD_NET up to the menu level, which more accurately represents the code.
Patch queue for efi - 2018-04-09
Highlights this time around:
- Lots of minor spec compliance fixes
- Support full range of GOP BLT commands
- More fine grained error checking
- Network fixes (init, DP)
- Lots of other bug fixes...
In order that we can use eth_env_* even when CONFIG_NET isn't set, move
these functions to environment code from net code.
This fixes failures such as:
board/ti/am335x/built-in.o: In function `board_late_init':
board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr'
u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr'
which caters for use cases such as:
commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment
variable")
when Ethernet is required in Linux, but not U-Boot.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
[trini: Re-run migration after also including CMD_MEMTEST]
This patch adds a command that enables the calculation of bit operations
(AND, OR, XOR) on binary data from the command line. Memory locations as
well as the contents of environment variables are eligible as sources
and destination of the binary data used in the operations.
The possible applications are manifold: Setting specific bits in
registers using the regular read-OR-write pattern, masking out bits in
bit values, implementation of simple OTP encryption using the XOR
operation, etc.
Make sure that the cache line size if respected when flushing the cache.
The section header address is a VMA whereas the address found in
the program header is a physical one. With this change it is
possible to load and start a vx7 intel generic based image.
$ readelf -l /tmp/vx7
Elf file type is EXEC (Executable file)
Entry point 0x408000
There are 2 program headers, starting at offset 52
Program Headers:
Type Offset VirtAddr PhysAddr FileSiz MemSiz Flg Align
LOAD 0x001000 0x00408000 0x00408000 0x04000 0x04000 RWE 0x1000
LOAD 0x005000 0xe040c000 0x0040c000 0x583a84 0x5ccc70 RWE 0x1000
Section to Segment mapping:
Segment Sections...
00 .text.locore .data.locore
01 .text .eh_frame .wrs_build_vars .data .tls_data .tls_vars .bss
$ readelf -S /tmp/vx7
There are 13 section headers, starting at offset 0x588af8:
Section Headers:
[Nr] Name Type Addr Off Size ES Flg Lk Inf Al
[ 0] NULL 00000000 000000 000000 00 0 0 0
[ 1] .text.locore PROGBITS 00408000 001000 00011e 00 AX 0 0 16
[ 2] .data.locore PROGBITS 00409000 002000 003000 00 WA 0 0 4096
[ 3] .text PROGBITS e040c000 005000 4802a0 00 WAX 0 0 32
[ 4] .eh_frame PROGBITS e088c2a0 4852a0 0a1ed0 00 A 0 0 4
[ 5] .wrs_build_vars PROGBITS e092e170 527170 000190 00 Ax 0 0 1
[ 6] .data PROGBITS e092f000 528000 060a70 00 WA 0 0 4096
[ 7] .tls_data PROGBITS e098fa70 588a70 000004 00 A 0 0 4
[ 8] .tls_vars PROGBITS e098fa78 588a78 00000c 00 WA 0 0 4
[ 9] .bss NOBITS e098faa0 588a84 0491d0 00 WA 0 0 32
[10] .shstrtab STRTAB 00000000 588a84 000074 00 0 0 1
[11] .symtab SYMTAB 00000000 588d00 056ee0 10 12 9758 4
[12] .strtab STRTAB 00000000 5dfbe0 05f48a 00 0 0 1
Key to Flags:
W (write), A (alloc), X (execute), M (merge), S (strings)
I (info), L (link order), G (group), T (TLS), E (exclude), x (unknown)
O (extra OS processing required) o (OS specific), p (processor specific)
For completeness here are the same information for an old vx5 based image. After
this change it is possible to boot vx5 and vx7 (intel generic) images.
$ readelf -l /tmp/vx5
Entry point 0x308000
There are 1 program headers, starting at offset 52
Program Headers:
LOAD 0x000060 0x00308000 0x00308000 0x3513a0 0x757860 RWE 0x20
Segment Sections...
00 .text .data .bss
[christian@chgm-pc ~]$ readelf -S /tmp/vx5
There are 12 section headers, starting at offset 0x356580:
Section Headers:
[ 1] .text PROGBITS 00308000 000060 319b10 00 WAX 0 0 32
[ 2] .data PROGBITS 00621b20 319b80 037880 00 WA 0 0 32
[ 3] .bss NOBITS 006593a0 351400 4064c0 00 WA 0 0 16
[ 4] .debug_aranges PROGBITS 00000000 351400 000060 00 0 0 1
[ 5] .debug_pubnames PROGBITS 00000000 351460 00018b 00 0 0 1
[ 6] .debug_info PROGBITS 00000000 3515eb 003429 00 0 0 1
[ 7] .debug_abbrev PROGBITS 00000000 354a14 000454 00 0 0 1
[ 8] .debug_line PROGBITS 00000000 354e68 0016a4 00 0 0 1
[ 9] .shstrtab STRTAB 00000000 35650c 000071 00 0 0 1
[10] .symtab SYMTAB 00000000 356760 0440e0 10 11 8574 4
[11] .strtab STRTAB 00000000 39a840 03e66c 00 0 0 1
Key to Flags:
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Tested-by: Bin Meng <bmeng.cn@gmail.com>
CONFIG_8xx doesn't mean much outside of arch/powerpc/
This patch renames it CONFIG_MPC8xx just like CONFIG_MPC85xx etc ...
It also renames 8xx_immap.h to immap_8xx.h to be consistent with
other file names.
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
With legacy boot (booti, bootz), people can declare memory regions as
reserved using device tree memory reservations. This feature is some
times used to indicate memory regions that should not be touched.
Since in a UEFI world, the DT memory reservations do not get honored,
let's copy them into the UEFI memory map so everyone has a coherent
view of the world and we give people the chance to add reservations
on demand.
The device path of the loaded image should be set to the partition
from which the image was loaded. This requires using the same logic as
the load command.
Without the patch the device path pointed to the whole disk after executing
load mmc 0: 0x43000000 FILE
and not to the boot partition from which the file was actually loaded.
The second argument of the bootefi command should always be usable to
specify a device tree. This was missing for bootefi selftest and
bootefi hello.
Proper error handling is added.
Up to now errors in the initialization of the EFI subsystems was not
checked.
If any initialization fails, leave the bootefi command.
We do not retry initialization because this would require to undo all prior
initalization steps.
Suggested-by: Simon Glass <sjg@chromium.org>
The return type of do_bootefi_exec() is efi_status_t. So in case
of an error we should always return an EFI status code.
efi_init_obj_list() should be executed only once.
Rather than having the caller check this variable and the callee set it,
move all access to the variable inside the function. This reduces the
logic needed to call efi_init_obj_list().
In January some commits were introduced to mitigate the U-Boot image
size issues we encountered on sunxi builds.
Now with the MMC environment removed we can bring them back, as we
practically don't have a size limit anymore.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
The cast breaks the pointer on 64bit archs, so lets get rid of it.
Signed-off-by: Andre Heider <a.heider@gmail.com>
Reviewed-by: Alexander Graf <agraf@suse.de>
Make sure 0x00 is a valid address to read to. If `addr` is 0x00 then
map_physmem() will return 0 which should be a valid address.
Signed-off-by: Liam Beguin <liambeguin@gmail.com>
Refactor the code for "part start" and "part size" commands to avoid
code duplication.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Allow passing the partition name to "part start" and "part size"
commands, so we can avoid magic numbers in the environment.
Consider one real use-case: in include/environment/ti/boot.h we have
commands like these:
setenv boot_part 9
part start mmc ${mmcdev} ${boot_part} boot_start
part size mmc ${mmcdev} ${boot_part} boot_size
mmc read ${loadaddr} ${boot_start} ${boot_size}
Now suppose that we have changed the partition table and boot_part now
is 10. We will need to fix commands above. And anyone who relies on
these boot commands, will need to change them accordingly, too (this was
an actual case in our lab while testing Linux boot on Android
environment).
By providing the option to pass partition name instead, we fix mentioned
issue, by eliminating the necessity to use magic numbers.
Thomas reported U-Boot failed to build host tools if libfdt-devel
package is installed because tools include libfdt headers from
/usr/include/ instead of using internal ones.
This commit moves the header code:
include/libfdt.h -> include/linux/libfdt.h
include/libfdt_env.h -> include/linux/libfdt_env.h
and replaces include directives:
#include <libfdt.h> -> #include <linux/libfdt.h>
#include <libfdt_env.h> -> #include <linux/libfdt_env.h>
Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com>
Enable networking command only when NET is enabled.
And remove selecting NET for CMD_NET
Fix some style violations in the MDIO command.
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
When FASTBOOT is activated, only one the supported device is supported in
code at the same time
- CONFIG_FASTBOOT_FLASH_MMC_DEV
- CONFIG_FASTBOOT_FLASH_NAND_DEV
But Today the choice is not exclusive in Kconfig
and that cause Kconfig issue when :
- CONFIG_FASTBOOT, CONFIG_MMC, CONFIG_NAND are activated
- CONFIG_FASTBOOT_FLASH_MMC_DEV = 0
- CONFIG_FASTBOOT_FLASH_NAND_DEV is not activated
The patch add a choice in Kconfig to select the FLASH provider
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Do the following to make the symbol names less confusing.
sed -i "s/\([TU][^_]\+\)_FUNCTION_DFU/DFU_OVER_\1/g" \
`git grep _FUNCTION_DFU | cut -d ":" -f 1 | sort -u`
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Lukasz Majewski <lukma@denx.de>
Clean up the screaming mess of configuration options that DFU is.
It was impossible to configure DFU such that TFTP is enabled and
USB is not, this patch fixes that and assures that DFU TFTP and
DFU USB can be enabled separatelly and that the correct pieces
of code are compiled in.
