path: root/cmd
2018-04-23cmd: clk: Check return value from soc_clk_dumpMichal Simek
In case of error in soc_clk_dump function are returned different values then CMD return values (-1, 0, 1). For example: ZynqMP> clk dump exit not allowed from main input shel The patch is checking all negative return values and return CMD_RET_FAILURE which is proper reaction for these cases. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-04-16bootvx: x86: Assign bootaddr based on kernel memory baseBin Meng
On VxWorks x86 its bootline address is at a pre-defined offset @ 0x1200. If 'bootaddr' is not passed via environment variable, we assign its value based on the kernel memory base address. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2018-04-16bootvx: Exit if bootline address is not specifiedBin Meng
Exit the 'bootvx' command if bootline address is not specified. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2018-04-16bootvx: Refactor the bootline copy codes a little bitBin Meng
There is a small duplication in do_bootvx() that does the bootline copy. Refactor this a little bit to make it simpler. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-16bootvx: x86: Make VxWorks EFI console driver happyBin Meng
When booting from EFI BIOS, VxWorks bootloader stores the EFI GOP framebuffer info at a pre-defined offset @ 0x6100. When VxWorks kernel boots up, its EFI console driver tries to find such a block and if the signature matches, the framebuffer information will be used to initialize the driver. However it is not necessary to prepare an EFI environment for VxWorks's EFI console driver to function (eg: EFI loader in U-Boot). If U-Boot has already initialized the graphics card and set it to a VESA mode that is compatible with EFI GOP, we can simply prepare such a block for VxWorks. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-16elf: Add a very simple ELF64 loaderBin Meng
This adds a very simple ELF64 loader via program headers, similar to load_elf_image_phdr() that we already have. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-16x86: Rename e820entry to e820_entryBin Meng
This changes 'struct e820entry' to 'struct e820_entry' to conform with the coding style. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2018-04-16vxworks: x86: Rename e820info to e820_infoBin Meng
This changes 'struct e820info' to 'struct e820_info' to conform with the coding style. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2018-04-16bootvx: x86: Explicitly clear the bootloader image sizeBin Meng
VxWorks bootloader stores its size at a pre-defined offset @ 0x5004. Later when VxWorks kernel boots up and system memory information is retrieved from the E820 table, the bootloader size will be subtracted from the total system memory size to calculate the size of available memory for the OS. Explicitly clear the bootloader image size otherwise if memory at this offset happens to contain some garbage data, the final available memory size for the kernel is insane. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-16bootvx: x86: Prepare e820 related stuff from the given kernel memory base ↵Bin Meng
address At present two environment variables 'e820data'/'e820info' are required to boot a VxWorks x86 kernel, but this is superfluous. The offset of these two tables are actually at a fixed offset from the kernel memory base address and we can provide the kernel memory base address to U-Boot via only one variable 'vx_phys_mem_base'. Note as it name indicates, the physical address should be provided. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2018-04-15Merge git://git.denx.de/u-boot-netTom Rini
2018-04-13vxworks: fixed cpu enable using PSCI on armv8Vasyl Vavrychuk
Without armv8_setup_psci register VBAR_EL3 is not set up property which makes SMC calls jump to invalid location. smp_kick_all_cpus is required to make slave cpus leave gic_wait_for_interrupt. Without this they will never pursue booting process. Fix was applied to the two ways of booting VxWorks: bootvx and bootm commands. This implementation is very similar to what is done in boot_jump_linux in arch/arm/lib/bootm.c file. Tested on VxWorks 7 release SR0520 2017-12-08 Intel Stratix 10 SX SoC Development Kit board. Signed-off-by: Vasyl Vavrychuk <vasyl.vavrychuk@globallogic.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-04-13Revert "Kconfig: cmd: Make networking command dependent on NET"Joe Hershberger
This reverts the parts of commit 3b3ea2c56ec4bc5588281fd103c744e608f8b25c where it changed the EFI dependency on NET. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Duncan Hare <dh@synoia.com>
2018-04-13net: Make the BOOTP options defaultJoe Hershberger
The BOOTP options used to be and should still be default for all boards with CMD_NET enabled. One should not be forced to use DISTRO_DEFAULTS to get them. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Duncan Hare <dh@synoia.com>
2018-04-13net: Improve BOOTP PXE config optionJoe Hershberger
Improve the documentation and correct the listed dependencies. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Duncan Hare <dh@synoia.com>
2018-04-13net: Add the BOOTP_DNS2 option to KconfigJoe Hershberger
Commit 3b3ea2c56ec4bc5 ("Kconfig: cmd: Make networking command dependent on NET") removed the help documentation from the README but didn't add it back to Kconfig. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Duncan Hare <dh@synoia.com>
2018-04-13net: Improve menu options and help for BOOTP optionsJoe Hershberger
The options were pretty unhelpful, so improve them some. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Chris Packham <judge.packham@gmail.com>
2018-04-13net: Move the DHCP command below the BOOTP commandJoe Hershberger
Move DHCP to directly follow BOOTP so that Kconfig can show the dependency as a hierarchy. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Duncan Hare <dh@synoia.com>
2018-04-13net: Move net command options to the cmd menuJoe Hershberger
Options that controlled the tftp and bootp commands depended on their commands, but lived in the net menu. Move them so they are in a consistent location. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Chris Packham <judge.packham@gmail.com>
2018-04-13net: Make CMD_NET a menuconfigJoe Hershberger
Previously, CMD_NET was an alias for 2 commands (bootp and tftpboot) and they we not able to be disabled. Separate out those 2 commands and move CMD_NET up to the menu level, which more accurately represents the code. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Duncan Hare <dh@synoia.com>
2018-04-09Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2018-04-09 Highlights this time around: - Lots of minor spec compliance fixes - Support full range of GOP BLT commands - More fine grained error checking - Network fixes (init, DP) - Lots of other bug fixes...
2018-04-08net: Move enetaddr env access code to env config instead of net configAlex Kiernan
In order that we can use eth_env_* even when CONFIG_NET isn't set, move these functions to environment code from net code. This fixes failures such as: board/ti/am335x/built-in.o: In function `board_late_init': board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr' u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr' which caters for use cases such as: commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment variable") when Ethernet is required in Linux, but not U-Boot. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-04-08treewide: Migrate CONFIG_SYS_ALT_MEMTEST to KconfigMario Six
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration after also including CMD_MEMTEST] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-06cmd: Add command for calculating binary operationsMario Six
This patch adds a command that enables the calculation of bit operations (AND, OR, XOR) on binary data from the command line. Memory locations as well as the contents of environment variables are eligible as sources and destination of the binary data used in the operations. The possible applications are manifold: Setting specific bits in registers using the regular read-OR-write pattern, masking out bits in bit values, implementation of simple OTP encryption using the XOR operation, etc. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-04-06cmd: ximg: Respect cache line size for flushingMario Six
Make sure that the cache line size if respected when flushing the cache. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-04-06bootvx: use program header for loadingChristian Gmeiner
The section header address is a VMA whereas the address found in the program header is a physical one. With this change it is possible to load and start a vx7 intel generic based image. $ readelf -l /tmp/vx7 Elf file type is EXEC (Executable file) Entry point 0x408000 There are 2 program headers, starting at offset 52 Program Headers: Type Offset VirtAddr PhysAddr FileSiz MemSiz Flg Align LOAD 0x001000 0x00408000 0x00408000 0x04000 0x04000 RWE 0x1000 LOAD 0x005000 0xe040c000 0x0040c000 0x583a84 0x5ccc70 RWE 0x1000 Section to Segment mapping: Segment Sections... 00 .text.locore .data.locore 01 .text .eh_frame .wrs_build_vars .data .tls_data .tls_vars .bss $ readelf -S /tmp/vx7 There are 13 section headers, starting at offset 0x588af8: Section Headers: [Nr] Name Type Addr Off Size ES Flg Lk Inf Al [ 0] NULL 00000000 000000 000000 00 0 0 0 [ 1] .text.locore PROGBITS 00408000 001000 00011e 00 AX 0 0 16 [ 2] .data.locore PROGBITS 00409000 002000 003000 00 WA 0 0 4096 [ 3] .text PROGBITS e040c000 005000 4802a0 00 WAX 0 0 32 [ 4] .eh_frame PROGBITS e088c2a0 4852a0 0a1ed0 00 A 0 0 4 [ 5] .wrs_build_vars PROGBITS e092e170 527170 000190 00 Ax 0 0 1 [ 6] .data PROGBITS e092f000 528000 060a70 00 WA 0 0 4096 [ 7] .tls_data PROGBITS e098fa70 588a70 000004 00 A 0 0 4 [ 8] .tls_vars PROGBITS e098fa78 588a78 00000c 00 WA 0 0 4 [ 9] .bss NOBITS e098faa0 588a84 0491d0 00 WA 0 0 32 [10] .shstrtab STRTAB 00000000 588a84 000074 00 0 0 1 [11] .symtab SYMTAB 00000000 588d00 056ee0 10 12 9758 4 [12] .strtab STRTAB 00000000 5dfbe0 05f48a 00 0 0 1 Key to Flags: W (write), A (alloc), X (execute), M (merge), S (strings) I (info), L (link order), G (group), T (TLS), E (exclude), x (unknown) O (extra OS processing required) o (OS specific), p (processor specific) For completeness here are the same information for an old vx5 based image. After this change it is possible to boot vx5 and vx7 (intel generic) images. $ readelf -l /tmp/vx5 Elf file type is EXEC (Executable file) Entry point 0x308000 There are 1 program headers, starting at offset 52 Program Headers: Type Offset VirtAddr PhysAddr FileSiz MemSiz Flg Align LOAD 0x000060 0x00308000 0x00308000 0x3513a0 0x757860 RWE 0x20 Section to Segment mapping: Segment Sections... 00 .text .data .bss [christian@chgm-pc ~]$ readelf -S /tmp/vx5 There are 12 section headers, starting at offset 0x356580: Section Headers: [Nr] Name Type Addr Off Size ES Flg Lk Inf Al [ 0] NULL 00000000 000000 000000 00 0 0 0 [ 1] .text PROGBITS 00308000 000060 319b10 00 WAX 0 0 32 [ 2] .data PROGBITS 00621b20 319b80 037880 00 WA 0 0 32 [ 3] .bss NOBITS 006593a0 351400 4064c0 00 WA 0 0 16 [ 4] .debug_aranges PROGBITS 00000000 351400 000060 00 0 0 1 [ 5] .debug_pubnames PROGBITS 00000000 351460 00018b 00 0 0 1 [ 6] .debug_info PROGBITS 00000000 3515eb 003429 00 0 0 1 [ 7] .debug_abbrev PROGBITS 00000000 354a14 000454 00 0 0 1 [ 8] .debug_line PROGBITS 00000000 354e68 0016a4 00 0 0 1 [ 9] .shstrtab STRTAB 00000000 35650c 000071 00 0 0 1 [10] .symtab SYMTAB 00000000 356760 0440e0 10 11 8574 4 [11] .strtab STRTAB 00000000 39a840 03e66c 00 0 0 1 Key to Flags: W (write), A (alloc), X (execute), M (merge), S (strings) I (info), L (link order), G (group), T (TLS), E (exclude), x (unknown) O (extra OS processing required) o (OS specific), p (processor specific) Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2018-04-06powerpc: mpc8xx: Change CONFIG_8xx to CONFIG_MPC8xxChristophe Leroy
CONFIG_8xx doesn't mean much outside of arch/powerpc/ This patch renames it CONFIG_MPC8xx just like CONFIG_MPC85xx etc ... It also renames 8xx_immap.h to immap_8xx.h to be consistent with other file names. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2018-04-06efi_loader: Respect DT reserved regionsAlexander Graf
With legacy boot (booti, bootz), people can declare memory regions as reserved using device tree memory reservations. This feature is some times used to indicate memory regions that should not be touched. Since in a UEFI world, the DT memory reservations do not get honored, let's copy them into the UEFI memory map so everyone has a coherent view of the world and we give people the chance to add reservations on demand. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-04Merge git://git.denx.de/u-boot-sunxiTom Rini
2018-04-04efi_loader: correctly determine the boot partitionHeinrich Schuchardt
The device path of the loaded image should be set to the partition from which the image was loaded. This requires using the same logic as the load command. Without the patch the device path pointed to the whole disk after executing load mmc 0: 0x43000000 FILE and not to the boot partition from which the file was actually loaded. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-04efi_loader: support device tree for bootefi selftestHeinrich Schuchardt
The second argument of the bootefi command should always be usable to specify a device tree. This was missing for bootefi selftest and bootefi hello. Proper error handling is added. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-04efi_loader: check initialization of EFI subsystem is successfulHeinrich Schuchardt
Up to now errors in the initialization of the EFI subsystems was not checked. If any initialization fails, leave the bootefi command. We do not retry initialization because this would require to undo all prior initalization steps. Suggested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-04efi_loader: do_bootefi_exec should always return an EFI status codeHeinrich Schuchardt
The return type of do_bootefi_exec() is efi_status_t. So in case of an error we should always return an EFI status code. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-04efi_loader: simplify calling efi_init_obj_listHeinrich Schuchardt
efi_init_obj_list() should be executed only once. Rather than having the caller check this variable and the callee set it, move all access to the variable inside the function. This reduces the logic needed to call efi_init_obj_list(). Suggested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-04-04sunxi: revert disabling of featuresAndre Przywara
In January some commits were introduced to mitigate the U-Boot image size issues we encountered on sunxi builds. Now with the MMC environment removed we can bring them back, as we practically don't have a size limit anymore. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-03-31cmd: cbfs: fix reading the end_of_rom pointer for 64bit archsAndre Heider
The cast breaks the pointer on 64bit archs, so lets get rid of it. Signed-off-by: Andre Heider <a.heider@gmail.com> Reviewed-by: Alexander Graf <agraf@suse.de>
2018-03-22cmd: sf: fix map_physmem checkLiam Beguin
Make sure 0x00 is a valid address to read to. If `addr` is 0x00 then map_physmem() will return 0 which should be a valid address. Signed-off-by: Liam Beguin <liambeguin@gmail.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2018-03-13cmd: part: Extract common code to separate functionSam Protsenko
Refactor the code for "part start" and "part size" commands to avoid code duplication. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-03-13cmd: part: Allow passing partition name to start and sizeSam Protsenko
Allow passing the partition name to "part start" and "part size" commands, so we can avoid magic numbers in the environment. Consider one real use-case: in include/environment/ti/boot.h we have commands like these: setenv boot_part 9 part start mmc ${mmcdev} ${boot_part} boot_start part size mmc ${mmcdev} ${boot_part} boot_size mmc read ${loadaddr} ${boot_start} ${boot_size} Now suppose that we have changed the partition table and boot_part now is 10. We will need to fix commands above. And anyone who relies on these boot commands, will need to change them accordingly, too (this was an actual case in our lab while testing Linux boot on Android environment). By providing the option to pass partition name instead, we fix mentioned issue, by eliminating the necessity to use magic numbers. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-02-27Merge git://git.denx.de/u-boot-netTom Rini
2018-02-27Kconfig: cmd: Make networking command dependent on NETMichal Simek
Enable networking command only when NET is enabled. And remove selecting NET for CMD_NET Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-26cmd: mdio: Fix style violationsMario Six
Fix some style violations in the MDIO command. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-02-21cmd: fastboot: Kconfig: solve config issuePatrick Delaunay
When FASTBOOT is activated, only one the supported device is supported in code at the same time - CONFIG_FASTBOOT_FLASH_MMC_DEV - CONFIG_FASTBOOT_FLASH_NAND_DEV But Today the choice is not exclusive in Kconfig and that cause Kconfig issue when : - CONFIG_FASTBOOT, CONFIG_MMC, CONFIG_NAND are activated - CONFIG_FASTBOOT_FLASH_MMC_DEV = 0 - CONFIG_FASTBOOT_FLASH_NAND_DEV is not activated The patch add a choice in Kconfig to select the FLASH provider - CONFIG_FASTBOOT_FLASH_MMC - CONFIG_FASTBOOT_FLASH_NAND Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2018-02-21dfu: Rename _FUNCTION_DFU to DFU_OVER_Marek Vasut
Do the following to make the symbol names less confusing. sed -i "s/\([TU][^_]\+\)_FUNCTION_DFU/DFU_OVER_\1/g" \ `git grep _FUNCTION_DFU | cut -d ":" -f 1 | sort -u` Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Lukasz Majewski <lukma@denx.de>
2018-02-21dfu: Fix up the Kconfig messMarek Vasut
Clean up the screaming mess of configuration options that DFU is. It was impossible to configure DFU such that TFTP is enabled and USB is not, this patch fixes that and assures that DFU TFTP and DFU USB can be enabled separatelly and that the correct pieces of code are compiled in. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Lukasz Majewski <lukma@denx.de>
2018-02-21usb: gadget: sdp: add missing line breaksAndre Heider
Cosmetic change. Signed-off-by: Andre Heider <a.heider@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2018-02-18sandbox: Add 64-bit sandboxMario Six
To debug device tree issues involving 32- and 64-bit platforms, it is useful to have a generic 64-bit platform available. Add a version of the sandbox that uses 64-bit integers for its physical addresses as well as a modified device tree. Signed-off-by: Mario Six <mario.six@gdsys.cc> Added CONFIG_SYS_TEXT_BASE to configs/sandbox64_defconfig Signed-off-by: Simon Glass <sjg@chromium.org>
2018-02-14cmd: scsi: move CMD_SCSI to device access commandsHeinrich Schuchardt
Configuration option CMD_SCSI should be placed in the same submenu as CMD_SATA and CMD_MMC. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
