path: root/cmd
2017-04-05OpenRISC: RemoveTom Rini
The OpenRISC architecture is currently unmaintained, remove. Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-05SPARC: RemoveTom Rini
The SPARC architecture is currently unmaintained, remove. Cc: Francois Retief <fgretief@spaceteq.co.za> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05Blackfin: RemoveTom Rini
The architecture is currently unmaintained, remove. Cc: Benjamin Matthews <mben12@gmail.com> Cc: Chong Huang <chuang@ucrobotics.com> Cc: Dimitar Penev <dpn@switchfin.org> Cc: Haitao Zhang <hzhang@ucrobotics.com> Cc: I-SYST Micromodule <support@i-syst.com> Cc: M.Hasewinkel (MHA) <info@ssv-embedded.de> Cc: Marek Vasut <marex@denx.de> Cc: Martin Strubel <strubel@section5.ch> Cc: Peter Meerwald <devel@bct-electronic.com> Cc: Sonic Zhang <sonic.adi@gmail.com> Cc: Valentin Yakovenkov <yakovenkov@niistt.ru> Cc: Wojtek Skulski <info@skutek.com> Cc: Wojtek Skulski <skulski@pas.rochester.edu> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-04dm: core: Add flags parameter to device_remove()Stefan Roese
This patch adds the flags parameter to device_remove() and changes all calls to this function to provide the default value of DM_REMOVE_NORMAL for "normal" device removal. This is in preparation for the driver specific pre-OS (e.g. DMA cancelling) remove support. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2017-04-04Merge git://git.denx.de/u-boot-dmTom Rini
2017-03-28i2c: Set default I2C bus numberLukasz Majewski
This patch allows using i2c commands (e.g. "i2c probe", "i2c md", etc) without the need to first select the bus number with e.g. "i2c dev 0". This is the "i2c" command behavior similar to the one from pre DM, where by default bus 0 was immediately accessible. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2017-03-26lib: tpm: Add command to list resourcesmario.six@gdsys.cc
It is sometimes convenient to know how many and/or which resources are currently loaded into a TPG, e.g. to test is a flush operation succeeded. Hence, we add a command that lists the resources of a given type currently loaded into the TPM. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-26cmd: tpm: Fix flush commandmario.six@gdsys.cc
Commit 7690be35de ("lib: tpm: Add command to flush resources") added a command to flush resources from a TPM. However, a previous development version was accidentially used to generate the patch, resulting in a non-functional command. This patch fixes the flush command. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-26tpm: Add function to load keys via their parent's SHA1 hashmario.six@gdsys.cc
If we want to load a key into a TPM, we need to know the designated parent key's handle, so that the TPM is able to insert the key at the correct place in the key hierarchy. However, if we want to load a key whose designated parent key we also previously loaded ourselves, we first need to memorize this parent key's handle (since the handles for the key are chosen at random when they are inserted into the TPM). If we are, however, unable to do so, for example if the parent key is loaded into the TPM during production, and its child key during the actual boot, we must find a different mechanism to identify the parent key. To solve this problem, we add a function that allows U-Boot to load a key into the TPM using their designated parent key's SHA1 hash, and the corresponding auth data. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-17gpt: Fix uuid string formatVincent Tinelli
Change GPT UUID string format from UUID to GUID per specification. Signed-off-by: Vincent Tinelli <vincent.tinelli@intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-17cmd: itest: correct calculus for long formatSebastien Colleur
itest shell command doesn't work correctly in long format when doing comparaison due to wrong mask value calculus that overflow on 32 bits values. Signed-off-by: Sebastien Colleur <sebastienx.colleur@intel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-17Kconfig: introduce md5sum command selectionAndre Przywara
So far CONFIG_MD5SUM would need to be set by a board's include file. Since the command is really generic, move it over to Kconfig to allow it to be defined by either a board's defconfig, menuconfig or some config snippet merged via mergeconfig.sh. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-03-16Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-03-14arm64: booti: allow to place kernel image anywhere in physical memoryMasahiro Yamada
At first, the ARM64 Linux booting requirement recommended that the kernel image be placed text_offset bytes from 2MB aligned base near the start of usable system RAM because memory below that base address was unusable at that time. This requirement was relaxed by Linux commit a7f8de168ace ("arm64: allow kernel Image to be loaded anywhere in physical memory"). Since then, the bit 3 of the flags field indicates the tolerance of the kernel physical placement. If this bit is set, the 2MB aligned base may be anywhere in physical memory. For details, see Documentation/arm64/booting.txt of Linux. The booti command should be also relaxed. If the bit 3 is set, images->ep is respected, and the image is placed at the nearest bootable location. Otherwise, it is relocated to the start of the system RAM to keep the original behavior. Another wrinkle we need to take care of is the unknown endianness of text_offset for a kernel older than commit a2c1d73b94ed (i.e. v3.16). We can detect this based on the image_size field. If the field is zero, just use a fixed offset 0x80000. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-03-14armv8: Add global variable resv_ramYork Sun
Use gd->arch.resv_ram to track reserved memory allocation. Signed-off-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-08cmd: move CONFIG_CMD_UNZIP and CONFIG_CMD_ZIP to KconfigMasahiro Yamada
CONFIG_CMD_ZIP is not defined by any board. I am moving CONFIG_CMD_UNZIP to defconfig files except UniPhier SoC family. I am the maintainer of UniPhier platform, so I know "select CMD_UNZIP" is better for this platform. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Ryan Harkin <ryan.harkin@linaro.org> Tested-by: Ryan Harkin <ryan.harkin@linaro.org>
2017-02-08cmd: bootm: fix build when CONFIG_CMD_IMLS_NANDGrygorii Strashko
Now when CONFIG_CMD_IMLS_NAND is enabled the u-boot build will fail, because nand_read_skip_bad() function has been changed to accept more parameters, hence fix it. CC cmd/bootm.o cmd/bootm.c: In function 'nand_imls_legacyimage': cmd/bootm.c:390:8: error: too few arguments to function 'nand_read_skip_bad' ret = nand_read_skip_bad(mtd, off, &len, imgdata); ^ In file included from cmd/bootm.c:18:0: include/nand.h:101:5: note: declared here int nand_read_skip_bad(struct mtd_info *mtd, loff_t offset, size_t *length, ^ LD drivers/block/built-in.o Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-08cmd: rework "license" commandMasahiro Yamada
The previous commit ("add a new command to show .config contents") improves the basic infrastructure of "embed a compressed file into the U-Boot image, and print it by a command". The same pattern for the "license" command. This commit reworks the command to improve the following: [1] Improve log style Kbuild style log GZIP cmd/license_data.gz CHK cmd/license_data_gz.h UPD cmd/license_data_gz.h CHK cmd/license_data_size.h UPD cmd/license_data_size.h instead of the bare Make log: cat ./Licenses/gpl-2.0.txt | gzip -9 -c | \ tools/bin2header license_gzip > ./include/license.h [2] Collect related code into the "cmd" directory Prior to this commit, the license.h was created by tools/Makefile, placed under the "include" directory, included from cmd/license.c, and deleted by the top-level Makefile. It is not a good idea to scatter related code. [3] Drop the fixed-malloc size LICENSE_MAX Just allocate the minimum required size of buffer because we know the size of the original gpl-2.0.txt. [4] Fix more issues Terminate the buffer with zero to prevent puts() from over-running. Add "static" to do_license. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-08cmd: add a new command "config" to show .config contentsMasahiro Yamada
This feature is inspired by /proc/config.gz of Linux. In Linux, if CONFIG_IKCONFIG is enabled, the ".config" file contents are embedded in the kernel image. If CONFIG_IKCONFIG_PROC is also enabled, the ".config" contents are exposed to /proc/config.gz. Users can do "zcat /proc/config.gz" to check which config options are enabled on the running kernel image. The idea is almost the same here; if CONFIG_CMD_CONFIG is enabled, the ".config" contents are compressed and saved in the U-Boot image, then printed by the new command "config". The usage is quite simple. Enable CONFIG_CMD_CONFIG, then run > config from the command line interface. The ".config" contents will be printed on the console. This feature increases the U-Boot image size by about 4KB (this is mostly due to the gzip-compressed .config file). By default, it is enabled only for Sandbox because we do not care about the memory footprint on it. Of course, this feature is architecture agnostic, so you can enable it on any board if the image size increase is acceptable for you. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-02-01lib: tpm: Add command to flush resourcesMario Six
This patch adds a function to the TPM library, which allows U-Boot to flush resources, e.g. keys, from the TPM. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Stefan Roese <sr@denx.de>
2017-01-28booti: Set images.os.archScott Wood
Commit ec6617c39741adc6c549 ("armv8: Support loading 32-bit OS in AArch32 execution state") broke SMP boot by assuming that an image is 32-bit if the arch field in the spin table != IH_ARCH_DEFAULT (i.e. IH_ARCH_ARM64), even if the arch field also does not match IH_ARCH_ARM, even though nothing actually set the arch field in the spin table. Commit e2c18e40b111470f ("armv8: fsl-layerscape: SMP support for loading 32-bit OS") fixed this for bootm by setting the arch field of the spin table based on images.os.arch, but booti remaineed broken because it did not set images.os.arch. Fixes: ec6617c39741adc6c549 ("armv8: Support loading 32-bit OS in AArch32 execution state") Fixes: e2c18e40b111 ("armv8: fsl-layerscape: SMP support for loading 32-bit OS") Cc: Alison Wang <alison.wang@nxp.com> Cc: Chenhui Zhao <chenhui.zhao@nxp.com> Cc: York Sun <york.sun@nxp.com> Cc: Stuart Yoder <stuart.yoder@nxp.com> Signed-off-by: Scott Wood <oss@buserror.net> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-26Merge git://www.denx.de/git/u-boot-marvellTom Rini
2017-01-26cmd: ubi: allow '-' to specify maximum volume sizeLadislav Michl
Currently maximum volume size can be specified only if no other arguments are used. Use '-' placeholder as volume size to allow maximum volume size to be specified together with volume id and type. Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2017-01-25arm64: mvebu: Update bubt command MMC block device accessKonstantin Porotchkin
Update the MMC block device access code in bubt command implementation according to the latest MMC driver changes. Change-Id: Ie852ceefa0b040ffe1362bdb7815fcea9b2d923b Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com>
2017-01-24bootz/booti: relocate ramdisk if CONFIG_SYS_BOOT_RAMDISK_HIGH setCédric Schieli
In commit c2e7e72, the ramdisk relocation code was moved from image_setup_linux to do_bootm, leaving the bootz and booti cases broken. This patch fixes both by adding the BOOTM_STATE_RAMDISK state in their call to do_bootm_states if CONFIG_SYS_BOOT_RAMDISK_HIGH is set. Signed-off-by: Cédric Schieli <cschieli@gmail.com> Reviewed-by: Rick Altherr <raltherr@google.com> Tested-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-21status_led: Kconfig migrationUri Mashiach
Move all of the status LED feature to drivers/led/Kconfig. The LED status definitions were moved from the board configuration files to the defconfig files. TBD: Move all of the definitions in the include/status_led.h to the relevant board's defconfig files. Tested boards: CL-SOM-AM57x, CM-T335 Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
2017-01-20bootm: qnx: Disable data cache before booting QNX imageEmmanuel Vadot
Instead of disabling the data cache in the bootelf command, disabling it in the do_bootm_qnxelf function. Some ELF binary might want the cache enabled. Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com>
2017-01-20cmd/host: add missing \n in help textSébastien Szymanski
Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2017-01-20bootm: relocate ramdisk if CONFIG_SYS_BOOT_RAMDISK_HIGH setRick Altherr
In 35fc84f, bootm was refactored so plain 'bootm' and 'bootm <subcommand>' shared a common implementation. The 'bootm ramdisk' command implementation is now part of the common implementation but not invoke by plain 'bootm' since the original implementation never did ramdisk relocation. Instead, ramdisk relocation happened in image_setup_linux() which is typically called during the OS portion of 'bootm'. On ARM, parameters to the Linux kernel can either be passed by FDT or ATAGS. When using FDT, image_setup_linux() is called which also triggers ramdisk relocation. When using ATAGS, image_setup_linux() is _not_ called because it mostly does FDT setup. Instead of calling image_setup_linux() in both FDT and ATAGS cases, include BOOTM_STATE_RAMDISK in the requested states during a plain 'bootm' if CONFIG_SYS_BOOT_RAMDISK_HIGH is set and remove the ramdisk relocation from image_setup_linux(). This causes ramdisk relocation to happen on any system where CONFIG_SYS_BOOT_RAMDISK_HIGH regardless of the OS being booted. Also remove IMAGE_ENABLE_RAMDISK_HIGH as it was only used by the now-removed code from image_setup_linux(). Signed-off-by: Rick Altherr <raltherr@google.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Joel Stanley <joel@jms.id.au>
2017-01-19Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-01-18armv8: aarch64: Fix the warning about x1-x3 nonzero issueAlison Wang
For 64-bit kernel, there is a warning about x1-x3 nonzero in violation of boot protocol. To fix this issue, input argument 4 is added for armv8_switch_to_el2 and armv8_switch_to_el1. The input argument 4 will be set to the right value, such as zero. Signed-off-by: Alison Wang <alison.wang@nxp.com> Reviewed-by: Alexander Graf <agraf@suse.de> Tested-by: Ryan Harkin <ryan.harkin@linaro.org> Tested-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-01-17usb: storage: Show number of storage devices detected for DM_USBMichal Simek
By enabling DM_USB information about number of storage devices was lost. Get this information back simply by printing number of devices detected via BLK uclass. For example: scanning bus 0 for devices... 7 USB Device(s) found scanning usb for storage devices... 3 Storage Device(s) found scanning usb for ethernet devices... 0 Ethernet Device(s) found Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-01-14cmd: sata: fix init command return valueGary Bisson
Since commit aa6ab905b2, sata_initialize returns -1 if init_sata or scan_sata fails. But this return value becomes the do_sata return value which is equivalent to CMD_RET_USAGE. In case one issues 'sata init' and that the hardware fails to initialize, there's no need to display the command usage. Instead the command shoud just return the CMD_RET_FAILURE value. Fixes: aa6ab905b2 (sata: fix sata command can not being executed bug) Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com> Reviewed-by: Eric Nelson <eric@nelint.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-14cmd/fdt: Make fdt get value endian-safe for single-cell propertiesAndreas Färber
On a Raspberry Pi 2 disagreements on cell endianness can be observed: U-Boot> fdt print /soc/gpio@7e200000 phandle phandle = <0x0000000d> U-Boot> fdt get value myvar /soc/gpio@7e200000 phandle; printenv myvar myvar=0x0D000000 Fix this by always treating the pointer as BE and converting it in fdt_value_setenv(), like its counterpart fdt_parse_prop() already does. Consistently use fdt32_t, fdt32_to_cpu() and cpu_to_fdt32(). Fixes: bc80295 ("fdt: Add get commands to fdt") Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Gerald Van Baren <gvb@unssw.com> Signed-off-by: Andreas Färber <afaerber@suse.de> Acked-by: Simon Glass <sjg@chromium.org>
2017-01-13cmd: fdt: Print error message when fdt application failsStefan Agner
There are lots of reason why a FDT application might fail, the error code might give an indication. Let the error code translate in a error string so users can try to understand what went wrong. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-01-12cmd: mem: Use memcpy for 'cp' commandFabio Estevam
Simplify the 'cp' command implementation by using the memcpy() function, which brings the additional benefit of performance gain for those who have CONFIG_USE_ARCH_MEMCPY selected. Tested on a mx6qsabreauto board where a 5x gain in performance is seen when reading 10MB from the parallel NOR memory. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-01-10fpga: Use enum for bitstream command typesMichal Simek
Using enum simplify handling of different bitstream command types. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-12-27cmd: net: fix function name in commentBaruch Siach
In commit 7044c6bb6 (net: cosmetic: Clean up DHCP variables and functions) BootpCopyNetParams() was renamed to store_net_params(). Update the reference in comment. Cc: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il>
2016-12-27cmd/Kconfig: Fix typo in CMD_MEMORY help textFabio Estevam
Fix "Memory" and "initialize" typos in the CMD_MEMORY help text. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-12-12Merge git://www.denx.de/git/u-boot-marvellTom Rini
2016-12-12arm64: mvebu: Add bubt command for flash image burnKonstantin Porotchkin
Add support for mvebu bubt command for flash image load, check and burn on boot device. Signed-off-by: Konstantin Porotchkin <kostap@marvell.com> Reviewed-by: Stefan Roese <sr@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Nadav Haklai <nadavh@marvell.com> Cc: Neta Zur Hershkovits <neta@marvell.com> Cc: Omri Itach <omrii@marvell.com> Cc: Igal Liberman <igall@marvell.com> Cc: Haim Boot <hayim@marvell.com> Cc: Hanna Hawa <hannah@marvell.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-12-09cmd: pci: add option to parse and display BAR informationYehuda Yitschak
Currently the PCI command only allows to see the BAR register values but not the size and actual base address. This little extension parses the BAR registers and displays the base, size and type of each BAR. Signed-off-by: Yehuda Yitschak <yehuday@marvell.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-03Merge branch 'master' of git://www.denx.de/git/u-boot-dmTom Rini
2016-12-03cmd: move CMD_PXE to KconfigYann E. MORIN
Currently, CMD_PXE is forcibly enabled in config_distro_defaults.h, so that general purpose distributions can rely on it being defined. This header is included, under conditions or not, by various archs or famillies of archs / SoCs. However, it is very possible that boards based on those SoCs will not have a physical ethernet connector at all, even if the have a MAC; for example, the Nanopi Neo AIR (sunxi H3) does not. It is also possible that network booting is absolutely not necessary for a device. However, it is not possible to disable the PXE command, as it is forcibly enabled and is non-configurable. But it turns out we already have a config option to build a distro-ready image, in the name of DISTRO_DEFAULTS. Move CMD_PXE out of the hard-coded config_distro_defaults.h into a Kconfig option, that gets selected by DISTRO_DEFAULTS when it is set. Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Cc: Joe Hershberger <joe.hershberger@ni.com> [trini: Make it select MENU, run moveconfig.py] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-03cmd: Convert CMD_BOOTMENUTom Rini
Also convert MENU while we're in here. Signed-off-by: Tom Rini <trini@konsulko.com>
