Currenty any EFI status other than EFI_SUCCESS is reported as
Application terminated, r = -22
With the patch the status code returned by the EFI application
is printed.
The Unified Extensible Firmware Interface Specification, version 2.7,
defines in chapter 2.1.2 - UEFI Application that an EFI application may
either directly return or call EFI_BOOT_SERVICES.Exit().
Unfortunately U-Boot makes the incorrect assumption that
EFI_BOOT_SERVICES.Exit() is always called.
So the following application leads to a memory exception on the aarch64
architecture when returning:
EFI_STATUS efi_main(
EFI_HANDLE handle,
EFI_SYSTEM_TABlE systable) {
return EFI_SUCCESS;
With this patch the entry point is stored in the image handle.
The new wrapper function do_enter is used to call the EFI entry point.
ConvertPathToText is implemented for
* type 4 - media device path
* subtype 4 - file path
This is the kind of device path we hand out for block devices.
All other cases may be implemented later.
[agraf: fix whitespace]
The UEFI specification requires that LocateProtol finds the first
handle supporting the protocol and to return a pointer to its
interface.
So we have to assign the protocols to an efi_object and not use
any separate storage.
efi_open_protocol was implemented to call a protocol specific open
function to retrieve the protocol interface.
The UEFI specification does not know of such a function.
It is not possible to implement InstallProtocolInterface with the
current design.
With the patch the protocol interface itself is stored in the list
of installed protocols of an efi_object instead of an open function.
[agraf: fix efi gop support]
While the previous pass through fixed one place where we knew that
fdt_getprop would be given a positive len, in the case of 'fdt set' we
do not, so check that we did no get NULL from fdt_getprop().
Reported-by: Coverity (CID: 163249)
Fixes 72c98ed1ab48 ("fdt: Add a check to do_fdt() for coverity")
Move the display options code into a separate function so that the U-Boot
banner can be obtained from other code. Adjust the 'version' command to
use it.
Tested-by: Bin Meng <bmeng.cn@gmail.com>
The 'mode' parameter is actually a flag to determine whether to display
a list of devices found during the scan. Rename it to reflect this, add a
function comment and adjust callers to use a boolean.
With driver model these functions need a device pointer. Add one even
when CONFIG_DM_SCSI is not defined. This avoids having ugly conditional
function prototypes, When CONFIG_DM_SCSI is not defined we can just ignore
the pointer.
At present CONFIG_CMD_SATA enables the 'sata' command which also brings
in SATA support. Some boards may wish to enable SATA without the command.
Add a separate CONFIG to permit this.
CONFIG_CMD_SATA
If the value of either "nand options" or "bbt options" has a zero in
the most significant nibble, the '0x' prefix will be isolated from the
value like shown below:
|Device 0: nand0, sector size 128 KiB
| Page size 2048 b
| OOB size 64 b
| Erase size 131072 b
| subpagesize 2048 b
| options 0x40000200
| bbt options 0x 60000
Change the format string to produce leading zeroes filling the gap.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
CS Systemes d'Information (CSSI) manufactures 8xx boards for
critical communication systems. Those boards have been
running U-Boot since 2010 and will have to be maintained
until at least 2027.
commit 5b8e76c35ec312a3f73126bd1a2d2c0965b98a9f
("powerpc, 8xx: remove support for 8xx") orphaned those boards
by removing support for the mpc8xx CPU.
This commit partially restores support for the 8xx, with the
following limitations:
- Restores support for MPC866 and MPC885 only
- Does not restore IDE, PCMCIA, I2C, USB
- Does not restore examples
- Does not restore POST
- Does not restore Ethernet on SCC
- Does not restore console on SCC
- Does not restore bedbug and kgdb support
As the 866 and 885 do not support the following features,
they are not restored either:
- VIDEO / LCD
- RTC clock
The CPM uCODE patch is not restored either, because:
- 866 and 885 already have support for I2C and SPI relocation
without a uCODE patch
- relocation of SMC, I2C or SPI is only needed for using SCCs
for Ethernet or QMC
The dynamic setup/calculation of clocks is removed, we
expect the target being use with the clock and PLPRCR register
defined in the configuration.
All the clock settings for 8xx prior to 866 is removed as
well as we now only support 866 and 885.
This code is mature and addresses mature boards. Therefore
all code enclosed in '#if 0/#endif' and '#if XX_DEBUG/#endif'
is unneeded.
The following files are not restored by this patch:
- arch/powerpc/cpu/mpc8xx/bedbug_860.c
- arch/powerpc/cpu/mpc8xx/fec.h
- arch/powerpc/cpu/mpc8xx/kgdb.S
- arch/powerpc/cpu/mpc8xx/plprcr_write.S
- arch/powerpc/cpu/mpc8xx/scc.c
- arch/powerpc/cpu/mpc8xx/upatch.c
- arch/powerpc/cpu/mpc8xx/video.c
- arch/powerpc/include/asm/status_led.h
- arch/powerpc/lib/ide.c
- arch/powerpc/lib/ide.h
- doc/README.MPC866
- drivers/pcmcia/mpc8xx_pcmcia.c
- drivers/rtc/mpc8xx.c
- drivers/usb/gadget/mpc8xx_udc.c
- drivers/video/mpc8xx_lcd.c
- examples/standalone/test_burst.c
- examples/standalone/test_burst.h
- examples/standalone/test_burst_lib.S
- examples/standalone/timer.c
- include/mpc823_lcd.h
- include/usb/mpc8xx_udc.h
- post/cpu/mpc8xx/Makefile
- post/cpu/mpc8xx/cache.c
- post/cpu/mpc8xx/cache_8xx.S
- post/cpu/mpc8xx/ether.c
- post/cpu/mpc8xx/spr.c
- post/cpu/mpc8xx/uart.c
- post/cpu/mpc8xx/usb.c
- post/cpu/mpc8xx/watchdog.c
Some of the restored files are not located in a proper location.
In order to keep traceability of the changes, they will be
moved to their correct location and moved to Kconfig in a
followup patch.
This patch also declares CSSI as point of contact for the update
of the 8xx platform, as those boards are the only ones still
being maintained on the 8xx area. A later patch will add
those boards to the tree.
AVR32 is gone. It's already more than two years for no support in Buildroot,
even longer there is no support in GCC (last version is heavily patched 4.2.4).
Linux kernel v4.12 got rid of it (and v4.11 didn't build successfully).
There is no good point to keep this support in U-Boot either.
Patch queue for efi - 2017-07-04
Highlights this time: bugfixes. With these changes, OpenBSD should
be more happy.
There was for long time no activity in the 4xx area.
We need to go further and convert to Kconfig, but it
turned out, nobody is interested anymore in 4xx,
so remove it.
When running bootefi, we allocate new space but never check whether
the allocation succeeded. This patch adds a check so that in case
things go wrong, we at least know they did.
for debugging it is handy to know the fdt_blob
address. So print it in bdinfo.
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Make do_usb_mass_storage() static to fix the following sparse
warning:
cmd/usb_mass_storage.c:136:5: warning: symbol 'do_usb_mass_storage' was not declared. Should it be static?
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Use NULL for pointer to fix the following sparse warning:
cmd/usb_mass_storage.c:47:15: warning: Using plain integer as NULL pointer
There was for long time no activity in the mpx5xxx area.
turned out, nobody is interested anymore in mpc5xxx,
so remove it.
The for loop in cmd_keywords_opt_check() seems to use wrong array to
set boundary, reported by Coverity analysis.
Signed-off-by: York Sun <york.sun@nxp.com>
CC: Joe Hershberger <joe.hershberger@ni.com>
CC: Tom Rini <trini@konsulko.com>
CC: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Reported-by: Coverity (CID: 163251)
The list of symbols listed in the error message for missing Kconfig
symbols is out of sync with the symbols actually tested.
Add the missing symbols and reorder their appearance to be in sync
with the #if statement for easier checking.
commit 06a040a31bcf ("cmd: mtdparts: fix null pointer dereference in parse_mtdparts")
removed the initialization of a pointer variable, which is
subsequently used in a debug() call. This produces an uninitialized
variable warning, when compiling with DEBUG defined.
We know that fdt_getprop() does not return NULL when len is > 0 but
coverity does not. Add an extra check to keep it happy.
Reported-by: Coverity (CID: 163248)
Fixes: bc80295b (fdt: Add get commands to fdt)
There was for long time no activity in the 5xx area.
turned out, nobody is interested anymore in 5xx,
so remove it.
There was for long time no activity in the 8260 area.
turned out, nobody is interested anymore in 8260,
so remove it.
There was for long time no activity in the 8xx area.
turned out, nobody is interested anymore in 8xx,
so remove it (with a heavy heart, knowing that I remove
here the root of U-Boot).
Add poweroff description to Kconfig to make it selectable
via menuconfig.
With this commit we can modify single values within an array of a dts
property.
This is useful if we have for example a pwm-backlight where we want to
modifiy the pwm frequency per u-boot script.
The pwm is described in dts like this:
backlight {
pwms = <0x0000002b 0x00000000 0x004c4b40>;
For changing the frequency, here the 3rd parameter, we simply type:
fdt set /backlight pwms <? ? 0x1E8480>;
For doing all this we:
- backup the property content into our 'SCRATCHPAD'
- only modify the array-cell if the new content doesn't start with '?'
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Rename command ls to fsls as its conflicting with
generic file systesm command ls and this is causing
compilation failure as below, if both are enabled
and this patch fixes it.
cmd/jffs2.o:(.u_boot_list_2_cmd_2_ls+0x0):
multiple definition of `_u_boot_list_2_cmd_2_ls'
cmd/fs.o:(.u_boot_list_2_cmd_2_ls+0x0):first defined here
scripts/Makefile.build:359: recipe for target 'cmd/built-in.o'
failed
make[1]: *** [cmd/built-in.o] Error 1
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
With clang-3.8 we see warnings like:
cmd/ethsw.c:304:6: warning: implicit conversion from
enumeration type 'enum ethsw_keyword_opt_id' to different enumeration type
'enum ethsw_keyword_id' [-Wenum-conversion]
ethsw_id_pvid_no,
Because we have one enum for ethsw_keyword_id and a second enum for
ethsw_keyword_opt_id. This ends up being safe as ethsw_keyword_opt_id
explicitly starts after ethsw_keyword_id enum ends. Disable the
warning here rather than collapse these into one enum and rely on
comments to denote where optional keywords begin.
Cc: Codrin Ciubotariu <codrin.ciubotariu@freescale.com>
The bootelf command could, but does not, pass additional arguments along
on the command line. Make do_bootelf consume bootelf/flags/address as
needed and then pass along anything else to the ELF application we've
launched.
Reported-by: Thomas Doerfler <thomas.doerfler@embedded-brains.de>
Add Kconfig symbols for various configurations
supported by FAT filesystem support code.
CONFIG_SUPPORT_VFAT has been left out since its
force enabled in include/fat.h and probably
should get removed at some point.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
[trini: add select FS_FAT for CMD_FAT and SPL_FAT_SUPPORT]
This gives a warning with some native compilers:
cmd/pci.c:152:11: warning: format ‘%llx’ expects argument of type
‘long long unsigned int’, but argument 3 has type
‘u64 {aka long unsigned int}’ [-Wformat=]
Fix it with a cast.
This header includes things that are needed to make driver build. Adjust
existing users to include that always, even if other dm/ includes are
present
Currently these (board agnostic) commands cannot be selected using
menuconfig and friends. Fix this the obvious way. As part of this,
don't muddle the meaning of CONFIG_HASH_VERIFY to mean both 'hash -v'
and "we have a hashing command" as this makes the Kconfig logic odd.
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
[trini: Re-apply, add imply for a few cases, run moveconfig.py, also
migrate CRC32_VERIFY]
CONFIG_CMD_LZMADEC
CONFIG_CMD_KGDB
CONFIG_CMD_IRQ
Rather than using CMD_JFFS2 for both the filesystem and its command, we
should have a separate option for each. This allows us to enable JFFS2
support without the command, if desired, which reduces U-Boot's size
slightly.
CONFIG_CMD_JFFS2
CONFIG_CMD_IOTRACE
CONFIG_CMD_IO
CONFIG_CMD_IMMAP
Also move this command out of the cmd/ directory since it is
PowerPC-specific.
At present IDE support is controlled by CONFIG_CMD_IDE. Add a separate
CONFIG_IDE option so that IDE support can be enabled without requiring
the 'ide' command.
Update existing users and move the ide driver into drivers/block since
it should not be in common/.
