CONFIG_CMD_JFFS2
CONFIG_CMD_IOTRACE
CONFIG_CMD_IO
CONFIG_CMD_IMMAP
Also move this command out of the cmd/ directory since it is
PowerPC-specific.
At present IDE support is controlled by CONFIG_CMD_IDE. Add a separate
CONFIG_IDE option so that IDE support can be enabled without requiring
the 'ide' command.
Update existing users and move the ide driver into drivers/block since
it should not be in common/.
CONFIG_CMD_IDE
At present CONFIG_CMD_HASH enables the 'hash' command which also brings
in the hashing API. Some boards may wish to enable the API without the
command. Add a separate CONFIG to permit this.
CONFIG_CMD_HASH
[trini: Rework slightly, enable on some boards again]
CONFIG_CMD_GETTIME
CONFIG_CMD_FUSE
CONFIG_CMD_FPGA_LOADBP
CONFIG_CMD_FPGA_LOADFS
CONFIG_CMD_FPGA_LOADMK
CONFIG_CMD_FPGA_LOADP
CONFIG_CMD_FPGAD
This option is not used by any board. Drop it.
CONFIG_CMD_FDC
CONFIG_CMD_ETHSW
Also enable it for sandbox to increase build coverage.
CONFIG_CMD_ENV_FLAGS
CONFIG_CMD_ENV_CALLBACK
CONFIG_CMD_EEPROM
CONFIG_CMD_EEPROM_LAYOUT
CONFIG_EEPROM_LAYOUT_HELP_STRING
[trini: Rework Kconfig logic slightly, define EEPROM location on TI eval
platforms]
This subsystem is quite old. It has been replaced with a driver-model
version (UCLASS_THERMAL). Boards are free to convert to that if required,
but here is a removal patch that could be applied in the meantime.
Drop use of this long-deprecated option.
We first check that if argc is less than 2 we return CMD_RET_USAGE. We
then see if argc is greater than 2 and if so call get_led_cmd() to set
'cmd' and otherwise set it to LEDST_COUNT (which will always be positive
as it's an enum with 0 already assigned). Therefore the test on if cmd
is less than 0 will always be false and simply be omitted. Reported by
clang-3.8.
The function cmd_get_data_size() returns an int and not unsigned. So we
should assign it to an int rather than unsigned so that we can later
compare the return value. Reported by clang-3.8.
On most architectures we do not call print_std_bdinfo() so mark it with
__maybe_unused. Reported by clang-3.8.
The value assigned to variable 'value' is never used.
The problem was indicated by clang scan-build.
Use uclass_first_device and uclass_next_device in order to avoid exceptions
for drivers that aren't probed when cpu ops are requested.
Improve code style and fix indentations.
Fix incorrect line break when cpu info is not available.
Remove unneeded brackets.
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
Commit 740d5d3 added two new features but only one feature name,
which results in NULL prints when device_id feature is selected.
Before:
HG556a # cpu detail
-1: cpu@0 BCM6358A1
ID = 0, freq = 300 MHz: L1 cache, MMU, NULL
Device ID 0x2a010
-1: cpu@1 BCM6358A1
ID = 1, freq = 300 MHz: L1 cache, MMU, NULL
Device ID 0x2a010
After:
HG556a # cpu detail
-1: cpu@0 BCM6358A1
ID = 0, freq = 300 MHz: L1 cache, MMU, Device ID
Device ID 0x2a010
-1: cpu@1 BCM6358A1
ID = 1, freq = 300 MHz: L1 cache, MMU, Device ID
Device ID 0x2a010
Fix the NAND structures in bubt command according to latest
changes in MTD API.
Signed-off-by: Konstantin Porotchkin <kostap@marvell.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Igal Liberman <igall@marvell.com>
Cc: Nadav Haklai <nadavh@marvell.com>
Signed-off-by: Chris Packham <judge.packham@gmail.com>
[trini: default y if DM_RTC, re-sync]
CONFIG_CMD_DISPLAY
CONFIG_CMD_DIAG
[trini: imply CMD_DIAG on some keymile configs]
Rather than using CMD_CRAMFS for both the filesystem and its command, we
should have a separate option for each. This allows us to enable CRAMFS
support without the command, if desired, which reduces U-Boot's size
slightly.
[trini: imply FS_CRAMFS for keymile]
CONFIG_CMD_CRAMFS
[trini: imply CMD_CRAMFS for keymile]
CONFIG_CMD_CLK
[trini: imply CMD_CLK on ARCH_ZYNQ]
Rather than using CMD_CBFS for both the filesystem and its command, we
should have a separate option for each. This allows us to enable CBFS
slightly.
[trini: imply FS_CBFS on SYS_COREBOOT]
CONFIG_CMD_CBFS
[trini: imply CMD_CBFS on SYS_COREBOOT]
CONFIG_CMD_BSP
CONFIG_CMD_BMP
[trini: Add depends on LCD || DM_VIDEO || VIDEO]
CONFIG_CMD_BLOB
[trini: Add imply CMD_BLOB under CHAIN_OF_TRUST]
CONFIG_CMD_BEDBUG
CONFIG_CMD_AES
CONFIG_AES
[trini: Add select AES to CMD_AES]
CONFIG_CMD_FS_UUID was neither whitelisted, nor was it declared in
Kconfig.
Now it can be enabled in .config and defconfig as expected.
Signed-off-by: Josua Mayer <josua.mayer97@gmail.com>
These commands have no user since commit ea3310e8aafa ("Blackfin:
Remove").
As with most other commands, this needs to factor in the sysmem offset
in the sandbox or it will try to dereference the simulated physical
address directly.
Signed-off-by: Tyler Hall <tylerwhall@gmail.com>
A size_t variable can never be negative.
The problem was indicated by cppcheck.
When driver model is used for LEDs, provide a command to allow LED access.
Reviewed-by: Ziping Chen <techping.chan@gmail.com>
The existing 'led' command does not support driver model. Rename it to
indicate that it is legacy code.
Add some LEDs to the standard sandbox device tree.
Drop CONFIG_STACKSIZE from include/configs/imx6_logic.h
Add 'pci regions' which lists the I/O and memory regions accessible from
the PCI controller.
